Iman-Emperatour 4937 ارسال شده در 27 مرداد، 2010 Zabrus tenebrioides Goeze - Corn Ground Beetle. Systematic position. Class Insecta, order Coleoptera, family Carabidae, subfamily Carabinae, tribe Amarini, genus Zabrus. Synonyms. Zabrus gibbus Fabr. Biological group. Cereal pests. Morphology and biology. Imago 14-16 mm in length, black with weak metallic sheen. Elytra convex, with nine strips. Pronotum with rough punctation in posterior quarter. Antennae, tibiae, and tarsi brown-red; fore tibiae dilated, with strong spine. Egg 2 mm in size, oval, white, brilliant. Larva off-white; head and three thoracic segments dark-brown; abdominal segments with light-brown dorsal spots. Pupa yellowish, with visible legs and wings, located in ground cocoon. Female fertility, 120-270 eggs. Eggs develop in 9 to 25 days depending on average daily temperature. Duration of larval damage to plants in autumn and spring depends on precipitation, reaching 15 to 105 days in autumn; harm in ring due to larval age and temperature conditions. Larvae live in the upper layer of soil, within burrows adjacent to fodder plants. At night, they leave burrows and eat wheat leaves. For diurnal feeding larvae take leaves inside their burrows. They stop feeding in November when temperatures drop to 0 - -5°C. The larvae (mainly 2nd and 3rd instars) over winter in soil on winter crops. Pupation occurs in soil at a depth of 10-20 cm at the end of April to second half of May. The pupal phase lasts 15-20 days. Beetles damage ears from the beginning of flowering to almost maturity. Distribution. Occurs from England and Southern Sweden to Northern Africa and Minor Asia, on Cyprus; in the Ukraine, Moldova, and Transcaucasia. In Russia it is widely distributed in steppe and forest-steppe zones, northward to the Orel Region, and eastward to the Astrakhan Region bordering Kazakhstan. Ecology. Monovoltine species. Beetles usually fly in May - June. Beetles are most active at temperatures between 20-26°C. Above 36°C, beetles perish. During summer heat and drought, beetles bury themselves into the ground to a depth of 40 cm. Dormant beetles renew activity after rains and when temperatures drop, usually in the second half of August or in the beginning of September. Factors that limit reproduction are low ground temperatures in late spring and in winter, and drought during egg hatching. Eggs do not develop at low humidity. Factors that limit distribution of the Corn Ground Beetle in areas of industrial winter wheat cultivation are climatic conditions, mainly lowering of average ground temperature to -3°C and lower, to a depth of 20 cm during the coldest month , and annual precipitation less than 400 mm. Economic significance. The greatest damage occurs to winter wheat. Damage also occurs with other cereals: rye, barley, and less often with oat. Sometimes maize is damaged. Among the wild cereals, beetles prefer Poa sp., Eremopyrum sp., Phleum pratense, Alopecurus pratensis, and Elytrigia repens. Control measures include appropriate crop rotation (no more than two years of consecutive grain crops.); early harvest of grain crops, exclusion of grain losses, immediate and careful removal of straw from fields, stubble shelling with subsequent plowing to a depth of 20-22 cm; chemically dressing seeds, dusting and spraying crops using insecticides to control young-instar larvae. سوسك سياه گندم Zabrus tenebrioides اين آفت علاوه بر گندم روي جو و چاودار نيز خسارت زا است و خسارت اصلي مربوط به لارو آن مي باشد كه در پائيز و زمستان به بوته هاي گندم حمله كرده و با جويدن برگ ها و باقي گذاشتن رگبرگ هاي اصلي خسارت مي زند. لاروها به هنگام فعاليت سوراخ هايي در خاك ايجاد مي كنند و برگ ها را به داخل اين سوراخ ها برده و مورد تغذيه قرار مي دهند. از کجا جوابشو پیدا کردی فرناز!!!!!!!!!!!!!!!!!!!!!! :jawdrop: :jawdrop: فکم پله شد دیدم انقد خوب توضیح نوشتی!!:jawdrop::jawdrop::smiley (18): (ادمینی بیا ما رو بذار یه گروه دیگه اینا شوخی ندارن!:45645::45645::jawdrop:) 3
mamooshak 8194 ارسال شده در 27 مرداد، 2010 ادميني من به دليل دپسردگي نبودم مدتي، اينجا هم نيومدم، الان ما بايد جواب بديم؟ ميشه لينك بدي؟؟؟:shad::shad: 1
Mohammad Aref 120459 مالک ارسال شده در 28 مرداد، 2010 ادميني من به دليل دپسردگي نبودم مدتي، اينجا هم نيومدم، الان ما بايد جواب بديم؟ ميشه لينك بدي؟؟؟:shad::shad: سوال شما تو پست زیر پرسیده شده: http://www.noandishaan.com/forums/showpost.php?p=84871&postcount=64 1
mamooshak 8194 ارسال شده در 28 مرداد، 2010 سوال شما تو پست زیر پرسیده شده:http://www.noandishaan.com/forums/showpost.php?p=84871&postcount=64 ميسي ادميني ديدم، باشه جواب ميديم ايشالا :shad:
Mohammad Aref 120459 مالک ارسال شده در 28 مرداد، 2010 دوست عزیز. این دور اول که به صورت آزمایشی بوده شروع شده. ایشالا تو دور بعدی که دور اصلیه مسابقات هست با یه هم تیمی شرکت میکنی 3
Peyman 16150 ارسال شده در 28 مرداد، 2010 سوال دوم تیم امپراطور چهار کتیبه معروف دوران ساسانیان را نام ببرید. (ذکر نام محل آنها الزامی است) - حداقل در دو مورد اشاره کنید که محتوای کتیبه به کدامیک از پادشاهان ساسانی اشاره دارد ؟ پ. ن. 1 . یه تشکر از فرناز خانوم من به دلیل گرفتاری شخصی ممکنه نتونم اینجا حاضر باشم، پرسش و پاسخ ها رو فرناز خانوم محبت می کنن و ادامه میدن، به مانند پرسش و پاسخ قبلی. پ.ن. 2 . سوال اول مطرح شده برای شما سخت بود، اینو براتون ساده گرفتیم، برید حال کنید مهلت پاسخگویی به سوال شماره 2 : روز شنبه مورخ 8 خرداد، ساعت 16:45 4
رهگذر 521 ارسال شده در 28 مرداد، 2010 دوست عزیز. این دور اول که به صورت آزمایشی بوده شروع شده. ایشالا تو دور بعدی که دور اصلیه مسابقات هست با یه هم تیمی شرکت میکنی مرسی ادمین جون. خب دور جدید از کی شروع میشه اونوقت؟ 1
Mohammad Aref 120459 مالک ارسال شده در 28 مرداد، 2010 ایشالا بعد از تموم شدن این دوره آزمایشی و احتمال زیاد از اواسط تیر
آریوبرزن 13988 ارسال شده در 28 مرداد، 2010 جواب تیم لیان به سوال تیم سپیدار: (امیدوارم که درست باشه) ماده 28 قانون وکالت. مصوب 1315:در صورتی که وکیل در دو یا چند دادگاه اعم از جنایی و غیر آن دعوت شود و جمع بین اوقاتممکن نباشد باید حضور در دیوان جنایی و دیوان کیفر را مقدم بدارد و به دادگاه یا دادگاههای دیگر لایحه بفرستد یا در صورت داشتن حق توکیل وکیل دیگری را اعزام بدارد. در صورتی که وکیل در دو یا چند دادگاه غیر از دادگاه جنایی و دیوان کیفر دعوت شود و جمع بین اوقاتممکن نباشد در دادگاهی که حضور خود را لازم میداند حاضر میشود و به دادگاههای دیگر لایحه میفرستد یا در صورت داشتن حق توکیل وکیل دیگری را اعزام میدارد. جلسه رسیدگی در هر حال از این جهت تجدید نخواهد شد مگر آنکه حضور وکیل در دادگاه ضروریباشد که در اینصورت یا به دادگاه مذکور وکیل دیگری میفرستد و یا اگر حق توکیل نداشته باشد نسخهثانی اخطاریه دادگاه جنایی با دیوان کیفر را ضمن لایحهای برای اعتذار از حضور تقدیم دادگاه میکند و در صورت اخیر فقط برای یک نوبت تجدید خواهد شد. تبصره 1 ـ وکیل باید دادگاه جنایی را بر دیوان کیفر مقدم بدارد و در صورتی که در دو یا چند دادگاهجنایی یا دیوان کیفر دعوت شده باشد حضور وکیل در هریک از دادگاههای مذکور بر حسب تقدم تاریخابلاغ از طرف دادگاه خواهد بود. تبصره 2 ـ عزل یا استعفا یا تعیین وکیل جدید باید در موقعی به عمل آید که موجب تجدید جلسهنشود. در صورت عدم رعایت این ترتیب استعفا و عزل و تعیین وکیل جدید برای این جلسه پذیرفتهنمیشود و دادگاه به رسیدگی ادامه میدهد. تبصره 3 ـ هرگاه جلسه دادگاه جنایی یا هر دادگاه جزایی دیگر که حضور وکیل متهم در آن ضرورتدارد به معاذیر قانونی وکیل تجدید شود، رئیس دادگاه مکلف است بلافاصله وکیل انتخابی برای متهمتعیین کند و وقت دادرسی را به وکیل مذکور ابلاغ کند. -هرگاه در جلسه بعد وکیل قبلی یا وکیل دیگری که متهم انتخاب و معرفی کرده است در دادگاه حضور یابدو از متهم دفاع نماید دادرسی با حضور او ادامه خواهد یافت و الا وکیل انتخابی دادگاه از متهم دفاعمیکند و دادگاه حکم خواهد داد. 3
YAGHOT SEFID 29302 ارسال شده در 29 مرداد، 2010 با توجه به اینکه مهلت تیم امپراطور تمام شد، جواب درست اون سوال رو میذارم: The World of Rare Stones: Painite is the World's Rarest Gem The world's rarest gem is believed to be برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام , a gem that most have never even heard of. Rarity does not equate to beauty in gems, however. The painite is an orangish or reddish brown, with the brown tint coming from iron in the crystal. It was first discovered in Burma in the 1950s and was widely considered to be the rarest of all gems, with only two faceted crystals in existence. Within the last couple of years, however, برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام and now a few hundred faceted stones exist. ***** Painite was once considered the "Holy Grail" of rare gemstones and one of the rarest minerals on earth. The Guinness Book of World Records has described Painite as THE rarest gem mineral. Painite is deep red to brownish red in color, very strongly pleochroic (showing different hues from different angles) and it fluoresces a lovely green under short wave UV. Its chemical formula is ideally: CaZrBAl9O18. However, it also contains minor amounts of chromium and vanadium and traces of iron that contribute to the orange-red to brownish-red color of the mineral. It comes from Mogok and Kachin State in Myanmar and was named after its discoverer, British gemologist Arthur Charles Davy Pain. برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام ممنون فرناز عزیز ... :icon_gol: ولی محبت کنید ترجمه متن لاتین رو هم برای اطلاع بیشتر دوستان قرار بدین .. !! بدون ترجمه که جالب نیست ... !! :banel_smiley_4: 5
YAGHOT SEFID 29302 ارسال شده در 29 مرداد، 2010 سوال دوم تیم امپراطور چهار کتیبه معروف دوران ساسانیان را نام ببرید. (ذکر نام محل آنها الزامی است) - حداقل در دو مورد اشاره کنید که محتوای کتیبه به کدامیک از پادشاهان ساسانی اشاره دارد ؟ پ. ن. 1 . یه تشکر از فرناز خانوم من به دلیل گرفتاری شخصی ممکنه نتونم اینجا حاضر باشم، پرسش و پاسخ ها رو فرناز خانوم محبت می کنن و ادامه میدن، به مانند پرسش و پاسخ قبلی. پ.ن. 2 . سوال اول مطرح شده برای شما سخت بود، اینو براتون ساده گرفتیم، برید حال کنید مهلت پاسخگویی به سوال شماره 2 : روز شنبه مورخ 8 خرداد، ساعت 16:45 کتیبه های دوران ساسانی ... :icon_gol: 1 - کتیبه اردشیر اول در نقش رستم ... 2 - کتیبه شاپور اول در نقش رجب ... 3 - کتیبه پهلوی ساسانی در زرتشت نقش رستم ... 4 - کتیبه پهلوی ساسانی در شاپور فارس ... 5
FrnzT 18194 ارسال شده در 29 مرداد، 2010 کتیبه های دوران ساسانی ... :icon_gol: 1 - کتیبه اردشیر اول در نقش رستم ... 2 - کتیبه شاپور اول در نقش رجب ... 3 - کتیبه پهلوی ساسانی در زرتشت نقش رستم ... 4 - کتیبه پهلوی ساسانی در شاپور فارس ... درود سید مهدی جان جواب سوال کامل نیست. ذکر محل اونها و حداقل دو موردش رو بگید که در چه مورد نوشته شده. 4
FrnzT 18194 ارسال شده در 29 مرداد، 2010 ممنون فرناز عزیز ... :icon_gol: ولی محبت کنید ترجمه متن لاتین رو هم برای اطلاع بیشتر دوستان قرار بدین .. !! بدون ترجمه که جالب نیست ... !! :banel_smiley_4: با اینکه متن انگلیسی آن به زبان بسیار ساده هست. با این حال به درخواست شما ترجمه میکنم. اعتقاد بر این است که painite کمیاب ترین جواهر دنیاست ، که حتی زیاد به گوش نخورده است. در جواهرات کمیابی به معنای زیبایی نیست. painite نارنجی یا قرمز مایل به قهوه ای است که بخاطر وجود آهن در کریستال است. برای اولین بار در 1950 در برمه کشف شد. تا قبل از دو سال پیش فقط دو عدد سنگ تراشیده وجود داشت.با این حال از دوسال پیش تا بحال منبع اصلی painite کریستال کشف شده ، و در حال حاضر چند صد سنگ تراشیده شده وجود دارد. Painite به عنوان"جام مقدس" از سنگ های قیمتی نادر و یکی از کمیاب ترین مواد معدنی روی زمین است. کتاب گینس رکوردهای جهانی است Painite را به عنوان ماده معدنی، کمیاب ترین جواهر توصیف کرد. Painite قرمز تیره تا قرمز مایل به قهوه ای است ، بیشتر به صورت pleochroic (به معنای دیدن طیف رنگهای مختلف از زوایای مختلف) و فلورسانس سبز دوست داشتنی در زیر نور ماورای بنفش موج کوتاه دیده میشود. فرمول ایده آل شیمیایی آن : CaZrBAl9O18 است، با این حال نیز حاوی مقادیر جزئی کروم و وانادیم و رگه هایی از آهن که منجر به نارنجی-قرمز تا قهوه ای-قرمز میشود. این سنگ از Mogok و Kachin در میانمار بدست می آید و نام آن به نام کاشف آن ،آرتور چارلز دیوی پین( Arthur Charles Davy Pain )نامیده شد. 5
آریوبرزن 13988 ارسال شده در 30 مرداد، 2010 سوال دوم تیم لیان از تیم سپیدار: نام فارسی و نام علمی این گیاه چیست؟ 4
Amir R. Haddadi 9164 ارسال شده در 30 مرداد، 2010 این هم سوال تیم سپیدار برای تیم لیان : حضور وکیل در دو دادگاه همزمان به چه صورت است : توضیح : برای مثال اگر یک وکیل در روز سه شنبه در ساعت 14:30 دو جلسه دادگاه داشته باشد . چگونه باید عمل کند . لطفا جواب همراه با ذکر ماده قانونی آن باشد . راهنمایی : چهار شرط برقرار است که باید به ترتیب ذکر شود . جواب تیم لیان به سوال تیم سپیدار:(امیدوارم که درست باشه) ماده 28 قانون وکالت. مصوب 1315:در صورتی که وکیل در دو یا چند دادگاه اعم از جنایی و غیر آن دعوت شود و جمع بین اوقاتممکن نباشد باید حضور در دیوان جنایی و دیوان کیفر را مقدم بدارد و به دادگاه یا دادگاههای دیگر لایحه بفرستد یا در صورت داشتن حق توکیل وکیل دیگری را اعزام بدارد. در صورتی که وکیل در دو یا چند دادگاه غیر از دادگاه جنایی و دیوان کیفر دعوت شود و جمع بین اوقاتممکن نباشد در دادگاهی که حضور خود را لازم میداند حاضر میشود و به دادگاههای دیگر لایحه میفرستد یا در صورت داشتن حق توکیل وکیل دیگری را اعزام میدارد. جلسه رسیدگی در هر حال از این جهت تجدید نخواهد شد مگر آنکه حضور وکیل در دادگاه ضروریباشد که در اینصورت یا به دادگاه مذکور وکیل دیگری میفرستد و یا اگر حق توکیل نداشته باشد نسخهثانی اخطاریه دادگاه جنایی با دیوان کیفر را ضمن لایحهای برای اعتذار از حضور تقدیم دادگاه میکند و در صورت اخیر فقط برای یک نوبت تجدید خواهد شد. تبصره 1 ـ وکیل باید دادگاه جنایی را بر دیوان کیفر مقدم بدارد و در صورتی که در دو یا چند دادگاهجنایی یا دیوان کیفر دعوت شده باشد حضور وکیل در هریک از دادگاههای مذکور بر حسب تقدم تاریخابلاغ از طرف دادگاه خواهد بود. تبصره 2 ـ عزل یا استعفا یا تعیین وکیل جدید باید در موقعی به عمل آید که موجب تجدید جلسهنشود. در صورت عدم رعایت این ترتیب استعفا و عزل و تعیین وکیل جدید برای این جلسه پذیرفتهنمیشود و دادگاه به رسیدگی ادامه میدهد. تبصره 3 ـ هرگاه جلسه دادگاه جنایی یا هر دادگاه جزایی دیگر که حضور وکیل متهم در آن ضرورتدارد به معاذیر قانونی وکیل تجدید شود، رئیس دادگاه مکلف است بلافاصله وکیل انتخابی برای متهمتعیین کند و وقت دادرسی را به وکیل مذکور ابلاغ کند. -هرگاه در جلسه بعد وکیل قبلی یا وکیل دیگری که متهم انتخاب و معرفی کرده است در دادگاه حضور یابدو از متهم دفاع نماید دادرسی با حضور او ادامه خواهد یافت و الا وکیل انتخابی دادگاه از متهم دفاعمیکند و دادگاه حکم خواهد داد. شرمنده از اینکه دیر جواب دادم" متعاسفانه باید بگوم که جواب شما جواب خواسته شده در سوال نمی باشد . شما تنها یک مورد رو اشاره کردید و بقیه موارد در مورد نحوه ادارا دادگاه در شرایط حضور یک وکیل در دو دادگاه بوده . در صورتی که ما فقط می خواستیم بدانیم که جضور یک وکیل در دو دادگاه همزمان چگونست یعنی چگونه می تواند یکی را انتخاب کنند که البته منهم در راهنماییم گفتم که چهار شرط برقرار است که باید به ترتیب ذکر شود . من جواب رو از نشریه دادگستر سال ششم - شماره 7و8 برای شما قرار میدم. 5
Artaria 13629 ارسال شده در 30 مرداد، 2010 حوصلم سر رفت، مرحله دوم کی شروع میشه؟ خواهشن اینبار یه حریف قوی بدین که سوکسش کنم ضعیف کشی دوس ندارم 1
FrnzT 18194 ارسال شده در 30 مرداد، 2010 حوصلم سر رفت، مرحله دوم کی شروع میشه؟ خواهشن اینبار یه حریف قوی بدین که سوکسش کنم ضعیف کشی دوس ندارم من قدرم :ws2: اگه خواستی میتونم یک تنه با تیمتون حریف بشم 1
Artaria 13629 ارسال شده در 30 مرداد، 2010 من قدرم :ws2: اگه خواستی میتونم یک تنه با تیمتون حریف بشم نه نمیخوام:ws46:، مرسی
Amir R. Haddadi 9164 ارسال شده در 31 مرداد، 2010 سوال دوم تیم لیان از تیم سپیدار: نام فارسی و نام علمی این گیاه چیست؟ اینم جواب دوم ما به سوال دوم شما : استبرق - خرگ امیدوارم ایندفه درست باشه 3
