  • پاسخ 125
بذار عزیزم:icon_gol::icon_gol:
اینم متن بعدییییییییییییییییییییییییییی:gnugghender::gnugghender:
ببینم کی ترجمش میکنه هااااا
Bridgestone Pavilion / Architectkidd
Courtesy of
Architect:
, Thailand
Design Team: Luke Yeung, PailinPaijitsattaya, PhuttipanAswakool
Exhibition Design: DesignLAB
Client Representative: Dentsu Thailand
Structural Design: MontreeSayabovorn
Contractor: Pico Thailand
Project Area: 500 sqm
Project Year: 2012
Photographs: PhuttipanAswakool, Luke Yeung
Courtesy of Architectkidd
The BOI (Board of Investment) Fair is a major event that aims to demonstrate Thailand’s rebuilding efforts among public and private sectors after last year’s floods. The objective of the Bridgestone Pavilion is to communicate the company’s commitment to the country in manufacturing, research and investment. With an emphasis on showcasing emerging technologies, Architectkidd had the opportunity to implement design approaches and features that are relatively unique among current standard construction practices in Thailand.
The building design was generated based on 3-dimensional spatial requirements. The starting points were the interior functions, building heights and site boundaries, as well as the continuous flow of visitors from entrance, exhibitions, to exit. The requirements were digitized volumetrically and merged to form the overall building, with the exterior a result of optimizing the interior spaces while minimizing extraneous elements such as additional edges, corners, and leftover spaces.
During construction, the structural design and steel fabrication team engineered 66 steel profiles – each with a distinct shape and curvature. All steel elements were hand-made and prefabricated before installing on the site.
For the finishes, the collaboration with Bridgestone allowed access to its extensive polymers expertise. One example is the use of EVA heat-reflecting film laminated on the glass windows and doors of the pavilion. Bridgestone also supplied materials for light-transmitting solar panels (installed as a roof skylight) as well as flexible roofing membranes. The entrance of the pavilion is made from elastic PVC fitted across pre-formed steel profiles.
خوب.........کی ترجمش میکنه؟:ws37:
who will translate this article?
common guys...the all aim is how to translate...it,s ok if you don't know how or you can't translate
even me....
hapydancsmil.gifhapydancsmil.gifso let's moveeeeeeeeeee
  • 4 ماه بعد...
مینا جونم من زبانم خوب نیست :girl_blush2:
ولی اگر بتونم کمک میکنم :icon_redface:
گلم همونطور که اول تاپیک هم گفتم ما اینجا متن میزاریم که هم ترجممون قوی بشه و هم اشکالاتمون برطرف شه
ترجمه رو میزاریم اینجا....خیلیا روش نطر میدن...و در نهایت متن اصلی و اصلاح شده با ترجمه شیوا و رسایی رو میبریم توو تاپیک اصلیشhapydancsmil.gif
منم زبانم خوب نیست ، ولی همکاری میکنم :hapydancsmil:
اینم از ترجمه:hapydancsmil.gif
غرفه بریجستون
معماری کید
معمار:معماری کید
موقعیت: بانکوک، تایلند
تیم طراحی:لوک یانگ ، پیلینگ پاجیتساتایا، فوتیپان آسواکول
طراحی نمایشگاه: گروه طراحی LAB
نماینده کارفرما: دنتسو تایلند
طراحی سازه: مانتری سایابوورن
مقاطع کار: Pico Thiland
مساحت پروژه: 500 متر مربع
سال اجرای پروژه: 2012
عکاس: فوتیپان اسواکول، لوک یانگ
هیئت سرمایه گذاری منصفانه یک واقعه عمده هست که هدفش تلاش دوباره سازی تایلند در میان عموم مردم و بخش های خصوصی بعد از سیل سال گذشته است.هدف غرفه بریجستون بر قراری ارتباط تعهدات شرکت در کشور؛ در تولید، تحقیق و سرمایه گذاری است.با تاکید بر نمایش تکنولوژی های در حال ظهور ، معماریِ کید فرصت لازم برای انجام روش طراحی و ویژگی هایی که نسبتا منحصر به فرد هستند، در میان شیوه های ساختار استاندارد جاری در تایلند را دارد.
طراحی ساختمان تولید شده بر پایه نیازهای 3 بعدی فضایی بوده است. نقطه آغاز توابع داخلی ،ارتفاع ساختمان و مرزهای سایت است،که به خوبی جریان پیوسته مراجعه کنندگان ، از ورود ، نمایشگاها(تماشا کردن) ، به خروج است.موارد مورد نیازی که به صورت حجمی دیجیتالی بوده اند و به فرم کلی ساختمان ادغام شده اند، با یک نتیجهگیری خارجیِ بهینه سازی فضاهای داخلی ، هنگامی که عناصر خروجی مانند لبه های اضافی، گوشه ها و فضاهای پس مانده هستند، به حداقل میرسند.
در طول ساخت، طراحی سازه ای و تیم ساخت فولاد ، 66 پروفیل فولاد را مهندسی کردند. – هر کدام با شکل و انحنای مجزا .تمامی عناصر فولادی دست ساز هستند و قبل از نصب در محوطه به صورت پیش ساخته قرار گرفته اند.
برای اتمام، همکاری با بریجستون اجازه دسترسی به تخصص پلیمرهای وسیعش را داده است. یک مثال این است که ، استفاده از فیلم های انعکاس حرارت ایی وی اِی طبقه بندی شده است که در شیشه پنجره ها و درهای غرفه مورد استفاده قرار گرفته است. بریجستون همچنین مصالحی برای انتقال نور پنل های خورشیدی (به عنوان نور آسمان سقف نصب میشود) که به خوبی غشاهای سقفی قابل انعطاف هستند را عرضه کرده است.
ورودی غرفه از پی وی سی نصب شده در جلوی پروفیلهای فولادی از پیش شکل داده، ساخته شده است.
سلااااااااااام و درود به دوستان همیشه در تالار حاضره معمار:a030:
دوستان...همونجور که در اطلاعیه هم گفتم گروه مترجمان معمار قرار بود به صورت گروه مجزا برای ترجمه کردن اصطلاحات انگلیسی معماری را بیفته..که متاسفانه به دلیل یک سری مشکلات منحل شد......
بعد از مشورتهای صورت گرفته با آدمین عزیز و مدیرای عزیز معماری،بر آن شدیم که دوباره این گروه رو در غالب ترجمه مقالات و اخبار معماری روز(در سال جاری) در اینجاا قرار بدیم.:ws37:..
مقالات به زبان انگلیسی هستند و توسط کسانی که در همینجا اعلام آمادگی خواهند کرد ترجمه میشن و بعد ترجمه نهایی و کلیدی در تاپیکی جداگانه گذاشته میشه.
حالا هر کس که مایل به همکاری با ما هست اینجا اعلام آمادگی کنه تا ما از تعداد شرکت کننده ها یک لیست تهیه کنیم
امیدوارم تالار معماری هر روز پیشرفت بهتری داشته باشه
ممنونم از همکاریتون
موفق باشیییییییییییییم:icon_pf (44):
منم هستم
منم هستم
Bellarine Peninsula House / Inarc Architects
Architects:
Project Architect: Cathie Wheelahan
Project Year: 2010
Photographs:
Project Area: sqm
Contributors: Jimmy Kiu
Structural Engineer: Mordue Engineering
The site for this new building is within a residential grid in the coastal Victorian (Australia) town of Barwon Heads. Due to the flat residential site the house was formed by a number of guiding factors. The clients required a house that would cater for both large groups whilst having zones that could be sectioned off when their needs changed. Further to this, we wanted the beach house environment reflects both the notion of coming together, and being linked to the external environment. By dividing the planning of the property into separate zones linked by one large main central hub, where people can come together to relax, socialize and prepare food, a direct link is created to this ideal. By extending large entertaining areas out from this main hub into the adjacent environment, a sense of space and flexibility is further added. Natural light, natural materials and a sense of transparency further promote a relaxed beachside environment. Large and open outdoor areas that are linked back to the interiors of the house were also required to emphasize the relaxed seaside environment.
© Peter Clarke
The clients wanted to maximize the connection with the external spaces created around the house whilst maintaining a certain amount of privacy from the adjacent neighboring properties. These principles acted in directly guiding the form of the building. A large central hub was created as the heart of the home. This central zone acts to anchor the two wings of the house and also works to divide up the square shaped block to create individual external environments. To the front of the property a smaller more intimate and private space has been created, whilst on the other side of the central hub a large more open area is created, and flanked by the two wings of the house. As the site is nestled within a coastal environment, but does not benefit from water views, water has been introduced as part of the external environments. Vistas are created through the house looking out into these external environments over reflection ponds or a larger landscaped pool.
Plan
To reduce the visual bulk of the building form, it has been designed to sit low within its environment. A system of layers on both the horizontal and vertical surfaces has been employed to create impressive internal areas without resulting in a harsh external block form. Walls and spaces are set in at different depths to further recess the skin of the building. Deep terraces act to not only provide weather protection, but also act to create a level of privacy to the internal areas without having physical barriers or screens.
© Peter Clarke
By zoning the house and landscape the functional aspects of the client’s requirements for the house are well met. However alternative complications arise by creating large open communal spaces, as they often tend to be quite barn like in appearance. In and attempt to mitigate this we have used an offset full height element within the space, which incorporates an open fireplace on one side and the kitchen bench on the other. This assists in delineating and defining the activity areas in what is essentially still an open, communal environment.
© Peter Clarke
این دفه رو مثه سری های پیش داوطلبانه میزارم:w02:
  • 3 هفته بعد...
hanghead.gifhanghead.gifداوطلب نیست؟
  • 4 هفته بعد...
~M~O~J~ مهمان
Architects: Inarc Architects
Project Year: 2010
Photographs: Peter Clarke
Project Area: sqm
5008692328ba0d33d4000091_bellarine-peninsula-house-inarc-architects_image_13-374x500.jpg
© Peter Clarke
Plan
5008690928ba0d33d400008b_bellarine-peninsula-house-inarc-architects_image_7-528x296.jpg
© Peter Clarke
5008691228ba0d33d400008d_bellarine-peninsula-house-inarc-architects_image_9-401x500.jpg
© Peter Clarke
همش رو باید ترجمه کنم؟:ws52:
بله :ws37:
بلییییییییییییییییییی:w16:
مصطفییییییییییییییییی
(ستاد استرس دهی به کاربران:ws3:)
