بهترین مبدا برای آغاز تاریخ ایران چیست؟
48 کاربر تاکنون رای داده است
  1. 1. بهترین مبدا برای آغاز تاریخ ایران چیست؟
amin 202 مهمان
خوب اینکه استقلال طلبیه :ws38:
نه کاملاً!
http://fa.wikipedia.org/wiki/%D9%BE%D8%A7%D9%86%D8%AA%D8%B1%DA%A9%DB%8C%D8%B3%D9%85
ولی تو همین شرایط کنونی هرگونه استقلال طلبی هم به ضرر ماست و هم کل ایران!
تو فرض کن خوزستان بخواد از ایران جدا شه....باور کن که خیلی بیشتر از ماها به اونا کم توجهی میشه....ولی قضیه ی جنوب سودان اونجا حاکمه....همه چی دارن(نفت)...ولی انگار هیچی ندارن!:icon_pf (34):
  • پاسخ 166
در مورد چنین مسائل قومیتی لینک دادن از ویکیپدیای انگلیسی منطقی تره
In the research literature, the term "Pan-Turkism" is used to describe the idea of political, cultural and ethnic unity of all
people.
is a closely related movement but a more general term than Turkism, since Turkism applies only to the Turkic peoples. However, researchers and politicians engaged in the field of Turkic ideology have used these terms interchangeably in a multitude of sources and literature.
The term "Turkism" started to be used with a prefix "Pan" (from Greek pan = all), for a "Panturkism".
While the various Turkic peoples often share historical, cultural and linguistic roots, the rising of a pan-Turkic political movement is a phenomenon only of the 19th and 20th century
and can be seen in parallel with European developments like
and
or with Middle-Eastern
. Proponents use the latter most often as a point of comparison as the concept of "Turkic" is not a true racial or ethnic description but more of a linguistic and cultural distinction. This is to differentiate it from the term "Turkish" which is more of an ethnic/racial term for the citizens and denizens primarily residing in Turkey. Pan-Turkic ideas and "re-unification" movements have been popular since the collapse of the
in Central Asian and other
countries.
چیزی که از اینجا میشه نتیجه گرفت اینه که پان ترکیسم هرچی هست هم خانوادی چیزی به اسم پان ایرانیسم هست :icon_gol:
چه جوری این مشکلات را جستجو کنین !!!!
مگه کار راحتیه؟
خودتون دارین میگین بخشی عظیمی از مردم جامعه عوام هستند،خیلی از عوام هم باید براشون الگو تعریف کنین تا آدم خوبی بشن.
اگر کسانی الگو شوند که خودشان کارنامه درخشانی ندارند،چیز جالبی به دست نمیاد.
تاکید من بیشتر روی قشر عوامه برای رهایی از بدبختی،اما تاکید 90 درصد دوستان تو این انجمن روی خواص است.
اکثر کتابهای جامعه شناسی معاصر ایران، ریشه های خیلی از مشکلات مارو توی تاریخ و آداب و رسوم و عادات اشتباه ما بررسی کردند.
کاملا مشخص هستش. به خصوص این کتابها:
ما چگونه ما شدیم - صادق زیباکلام،
چرا ایران عقب ماند و غرب پیش رفت-کاظم علمداری،
تاملی بر استبداد زدگی ما-حسن نراقی،
جامعه شناسی خودمانی-حسن نراقی،
استبداد در ایران- حسن قاضی مرادی،
در پیرامون خودمداری ایرانیان-حسن قاضی مرادی،
تاملی بر عقب ماندگی ما: نگاهی به کتاب "دیباچه ای بر نظریه انحطاط ایران"نوشته ی دکتر جواد طباطبایی
در پیرامون خودمداری ایرانیان: رساله ای در روانشناسی اجتماعی مردم ایران - حسن قاضی مرادی
اول اینکه من خودم رو خاص نمیدونم اون مورینیوه! دی:
دوما اینکه اتفاقا سعی ما باید بر این باشد که مردم ما از الگوپرستی بیرون بیان که تمام بدبختی ما همین است.
از نظر من کسی که کبیر کبیر میگوید فرقی با کسی که آقا آقا میکند ندارد...
اون تو یه فاز دیگری توی یه فاز دیگه.
من نمیدونم چرا هر موقع این مسائل رو مطرح میکنم با برخورد تند دوستان روبرو میشوم.
در صورتیکه چیزهایی که گاها در مورد تاریخ توی اینجا مینویسم کاملا با دید ماتریالیستی است و به صورت خنثی است و غالبا مورد توافق محققان تاریخی دانشگاهی ماست.
من حتی برای گفته هایم منبع مینویسم ، اما دوستان بدون توجه به این منابع مرا به انواع و اقسام جرمهای ناسیونالیستی متهم میکنند.
متاسفانه هنوز عادت نکرده ایم به اینکه همه ی اقوال را بشنویم و بهترین را انتخاب کنیم. :icon_gol:
چند تا از بهترین اقوال معظـــم لـــه را میشه بگی...... :ws37:
بهترین اقوال معظم له توی سایتش نوشته شده. صداوسیما هم دم به دقیقه پخش میکنه.
مسلما مبدا تاریخی کشور ایران خیلی با ارزشه و جای افتخار داره که زمانی تاریخ ایران همچین شکوه و عظمتی داشته
اما مردم ایران بالاخره بیش از 90 درصد مسلمونن.. و اگر به گناه کار ترینشون که حتی یه دونه از آداب اسلامی رو هم رعایت نمیکنه بگی دینت چیه؟ ........ میگه من مسلمونم اونم شیعه
راستش من اصلا نمیخواستم برخورد دینی صورت بگیره.
اما چون دیدم فقط شما به گزینه اول رای دادین،ازتون میپرسم.
اگر به احترام پیامبر و با توافق با اعراب،اسم خلیج فارس بشه خلیج اسلامی،نظرتون چیه؟
نوستالژی خون میره بالا حس وطن پرستی بیداد میکند ناگاه یاد نیروی نظامی که زورش بر ملت خویش چربیده افتاده اعراب تن پرور را متصور میشویم که شکست خورده رودار جلوه میکند!(یک ایرانی!)
ما هر چی داریم از کورش داریم همون تاریخ شاهنشاهی از همه بهتره:ws37:
نمیدونم چرا نا خودآگاه یاد دوستان ارزشی ام افتادم!
دوستان ارزشی شما سایه ی کورش با تیر می زنن چه ربطی داشت:ws52:
اخه اونا هم هی میگن ما هرچی داریم از آقا داریم.:ws44:
خوب راست میگن ما هر بد بختی داریم از آقا داریم:icon_pf (34):
در فرهنگ شماها دروغ گفتن ماليات ندارد ......پس دروغ بگو .......:ws44:
شماها كه تاريخ هجرت پيامبر را قبول نداريد ........مشكل نيست
در عوض تاريخ شاهنشاهان را مي خواهيد ..............مشكل نيست
وما ميگويم خلايق هرچه لايق ..............
ما به پيامبر وتاريخش عشق مي ورزيم واز خداي متعال خواستاريم كه مارا با ايشان محشور كند وشماها با همان شاهتان محشور گرداند :ws21:
عزیز من اون آغا حتی 1 قدم به نفع بشریت برداشته؟
برنداشته دیگه....:banel_smiley_4: فکر نمیکنم هیچ آدم با انصافی بتونه بگه هرچی درباره کوروش میگن دروغ و بی پایه است. بالاخره 4 تا کار مفید در طول زندگیش کرده.
ای کاش هر آدمی تنها با خودش محشور شود......
و خودش یعنی همه چیز سوای نژادپرستی آن متعال.......
مشخصه مشکلی نداری!!!!!!!
آره تو فرهنگ من دروغ مالیات نداره!!!!!!!!
من امام زمانم
حالا بحث سر امپراطوری هخامنشی هست .
توصیه میکنم برنامه اغاز یک امپراطوری را امشب ساعت 10 که تکرارش هر 4 ساعت پخش میشه را ببینید.
این برنامه اختصاص داره به چگونگی بوجود امدن امپراطوری هخامنشی که با استفاده از دانشمندان و تاریخشناس های برجسته دنیا تولید شده.
اگر فرکانس این شبکه را ندارید پ خ بدید که بهتون بگم
صد تا از این فیلمها را هم ببینیم به درد نمیخوره:icon_pf (34):
