اکیپ مقاله خوانی مهندسین شیمی نواندیشان
alimec
منم هستم!:w16: فقط تا کی باید تحویل بدیم؟
مرسی عزیزم:ws37:
صفحه دوم مقاله مال تو که میشه صفحه سوم فایل بالا(صفحه ای که عدد 2 بالاش نوشته شده رو ترجمه کن):icon_gol:
والا نمیدونم
هرچی زودتر، بهتر
باید از فائزه سوال کنم:w16:
  • پاسخ 297
فرنوش جون چه خبر از ترجمه؟
اگه کسی فرصتشو داره، بقیه ترجمه رو همکاری کنه و به تیم بپیونده که زودتر تحویل بدیم:a030:
درسا شرو شده.
حتما همینطور بهتون مشق شب گفتن که سرتون شلوغه:ws3:
یک پیشنهاد غیر لازم الاجرا..!:ws3:
Non-Adiabatic Multitubular Fixed-Bed Catalytic Reactor Model Coupled with Shell-Side Coolant CFD Model
ABSTRACT: An overall fixed-bed reactor model that combines a one-dimensional plug flow reactor model with a
computational fluid dynamics (CFD) model of the shell-side coolant fluid over a series of individual reactor tubes is presented.
The model chemistry is the partial oxidation of o-xylene to phthalic anhydride, a well-studied system for reactor performance.
The model is used to investigate the effect of variation in cooling temperature on overall reactor performance: temperature
profiles at the wall and centerline and o-xylene conversion. Non-isothermal shell-side cooling temperature profiles are calculated
using computational fluid dynamics and heat flux profiles along the reactor tube length. This analysis demonstrates that, with
faster coolant flow rates, the coupled fixed-bed reactor and CFD model process outputs approach the nominal case. Alternative
shell-side baffle configurations are examined. The calculated coolant velocity profiles, though different between evaluated
configurations, result in similar overall reactor performance. However, it should be noted that none of the simulations observe
isothermal shell-side coolant temperatures, as is commonly assumed in fixed-bed and plug flow reactor models. This coupled
model enables opportunity for further reactor optimization on both the shell-side CFD model and the fixed-bed reactor model, as
it can be applied to pilot- and commercial-scale reactors for existing or new chemistries. This model provides a more realistic
estimation of the reactor performance, when considering isothermal coolant profiles. Specifically, for the fixed-bed reactor model,
alternative catalyst packing schedules (i.e., activity profiles) or feed rates can be considered. Additionally, conditions or individual
reactor tubes can be identified that are more prone to runaway
پیشنهاد زینب رو که کسی تحویل نگرفت:banel_smiley_4:
یه مقاله مدیریتی هست که سپرده شده برای ترجمه به مسئول بخش ترجمه(هزینش پرداخت میشه:a030:)
دوستانی که مایل به همکاری هستن، به من سریعتر اطلاع بدین که تقسیم کار انجام بشه
http://www.noandishaan.com/form/down...gwZGZkZGMwYg==
  • 4 ماه بعد...
دوستان محترم ترجمه کننده مهندسی شیمی نواندیشان، هرچند میدونم واستون دیگه فرقی نمی‌کرد اما فایل ترجمه Basics of Electrochemical Impedance Spectroscopy که جاوید پیشنهاد داده بود رو تو بخش ترجمه قرار دادم.
توضيح: ويرايش مقاله رو همون موقع انجام دادم، فائزه خانم هم بعد از چندوقت زحمت كشيدن و به فرمت اينجا درآوردن، فقط فايل متن ترجمه شده قرار داده نشده بود.
بازم برای تاخیر طولانی مدت عذر می‌خواهم:icon_gol:
:banel_smiley_4:
  • 1 سال بعد...
سلام.من مقاله ای میخونم درباره جداسازی با غربال زیولیت میخواستم ببینم کسی درباره این عکس ها اطلاعاتی داره تا بهتر بفهمم و تحلیل کنم
http://www.noandishaan.com/upload/images/wbp4uhlhjgvw0uviny0.png
