خواندن فایل
setarehbaran
سلام. من می خواستم یه سری فایل های stl رو وارد متلب کنم. کسی هست که بتونه کمکم کنه؟
اول یه نگاهی به این تاپیک بندازین، فکر کنم مرتبط باشه:
یه ویدئویی هم روی Youtube هست، از همین برنامه لینک استفاده می کنه:
این فایل ها رو از روی
برداشتم:
STLREAD imports geometry from a binary stereolithography (STL) file into MATLAB
:Description
In addition to the STLREAD import function, this submission also includes a small demo that loads an STL model of a human femur bone
FV = STLREAD(FILENAME) imports triangular faces from the binary STL file indicated by FILENAME, and returns the patch struct FV, with fields faces and vertices
F,V] = STLREAD(FILENAME) returns the faces F and vertices V separately]
F,V,N] = STLREAD(FILENAME) also returns the face normal vectors]
The faces and vertices are arranged in the format used by the PATCH plot object
:Description
CAD2MATDEMO is a demonstration of importing 3D CAD data into MATLAB
The demo includes: 1) the general program, 2) 4 CAD data file samples, and 3) a simple script that executes the program to show the 4 samples
To get CAD data into MATLAB, the process is: 1) Export the 3D CAD data as an ASCII STL (or Pro/E render SLP) file. 2) This MATLAB routine reads the CAD data, and 3) Once read, the CAD data is rotated around a bit for viewing
The program has been tested with: AutoCAD, Cadkey, and Pro/Engineer
It should work with most any CAD programs that can export STL files
Format Details: STL is supported, and the color version of STL that Pro/E exports, called 'render' is also supported. The render (SLP) is just like STL but includes color
Only that data associated with STL or SLP files are translated, e.g., geometry and the geometry color. No textures, transparencies, or other such things are exported with the STL (or SLP) file
Note: This routine has both the import function and some basic manipulation for testing. The actual reading mechanism is located at the end of the demo file
[h=1]
[/h]
سلام. من الان مختصات تک تک نقاط رو توی متلب پیدا کردم و شماره گوشه های مربوط به هر مثلث رو دارم. حالا میخوام یک سری نقاط از شکل stl رو پیدا کنم و مختصات y آنها رو تغییر بدم. کسی میدونه که چجوری شماره این نقاط رو روی شکل پیدا کنم و محتصات y آنها رو عوض کنم؟
سلام. من یه سری مختصات x,y,z نقاط روی یک سطح رو دارم و میخوام یه سطح کامل از اون نقاط رو هم ترسیم کنم و هم تمام مختصات نقاطش رو داشته باشم. کسی می دونه جحوری باید این کارو انجام بدم؟
