درخواست نرم افزار مهندسی مکانیک
  • پاسخ 72
سلام مجدد .
لینک دانلود نرم افزار AdvantEdge FEM رو کسی داره ؟
در مورد المان محدود و آنالیز پروسه ماشینکاری هست .
اینم لینکی که در مورد نرم افزار توضیحاتی داده :
:icon_gol:
با سلام
به نرم افزار copra بطور فوری نیاز دارم
اینهم لینک شرکت
مهندس ببین همینه ؟
Datam Copra RF v.2005 SR1
BIN | 380.4 mb | 5% recovery
data M software company set up in 1987, is headquartered in Munich, Germany. data M software companies are focused on sheet metal forming technology developed by independent software private companies. Has been committed to developing and marketing leading solution roller Cold forming software COPRA RF (
). Provide roll contour detection system (COPRA Roll Scanner contour). data M Software Corporation is a mechanical engineer to create and operate software companies. data M not only able to provide sheet metal bending and bending roller innovative products, can also provide design services roll, roll Detect authentication, as well as the only leader in technology research and development who can provide technical know-how includes services.
data M COPRA RF 2005 SR1 latest version (issued by the end of 2007) Product Name: COPRA Cold Roll Forming Design Software
Product introduction:
COPRA RF tests are designed virtual reality roller integrated software. It supports open, closed all types of profiles from the cross-section design to the various steps in the whole process of forming the technical documentation generation (product graphics, parts lists, CNC programming, etc.) as well as the follow-up product cut-off type, the quality control of roll.
COPRA roll contour detector - gratitude are in accordance with the new design with high-precision roller contour scanning equipment. Can scan the existing roller geometric contour and the respective data control, continuous quality control and has been give the outline of the repair roller data.
COPRA cable molding - is through interactive model provides solutions shaped wire rod rolling problem forming software solutions.
COPRA ® is a roller for each cold-formed shape of the package developed by the designer. COPRA allows designers to use a professional way to design simple or very complex opening or closed profiles. It can save you plan, design and engineering costs, and lead designers from roller flower design (bending steps), roller design and technical computing to the forming process simulation, roll materials management, CNC manufacturing and quality control. By analyzing the process of molding strip of the stress and strain of the situation, COPRA allows designers to roll in before the decision to create a suitable forming process.
And data M's, like all other procedures, COPRA ® for users is very kind, easy to learn and to guide the operator to complete the entire process of design. Where necessary, provide an explanation dialog. COPRA running on the AutoCAD environment, can also be obtained as the OEM version. Use this version of AutoCAD are because the whole package as part of the learning process to minimize, and. COPRA reflects Cold Roll Forming the latest technology. It is a world-wide in more than 50 countries used by the designers of standard tools.
کدوم یکی از اینهاست .
Tecplot 360 2009 12.0.0.3116 x64 | 104 MB
Tecplot 360 is a Numerical Simulation & CFD Visualization Software that combines vital engineering plotting with advanced data visualization into one tool. It allows you to quickly plot and animate all your data exactly the way you want, as well as analyze complex data, arrange multiple layouts, and communicate your results with professional images and animations. Tecplot 360 also helps save time and effort by automating routine tasks. Tecplot 360 loads unsteady data and displays only the first time step. Style changes applied to a given time step are propagated to the entire solution. Coupled with load on demand, time to first image is much faster. Tecplot 360 2008 includes several advanced transient analysis options. A user can now synchronize transient animations among multiple frames – effectively showing multiple views of your data through time.
Smarter loading of data results in faster time to first image. Load on demand loads just the data you are actively using. For example, a Temperature contour plot only loads X, Y, Z and Temperature. When you switch to a new variable to contour (i.e., Pressure), Tecplot 360 loads Pressure and unloads Temperature (assuming it is not being used for anything else). Dual processor Linux and Windows boxes are becoming a standard for desktop engineering workstations. With Tecplot 360, intensive computing operations are spread across up to 64 CPUs or Cores, leading to faster streamtraces, slices, and iso-surfaces.
Python is a powerful open-source, object-oriented extensible programming language. Python scripting was added to Tecplot 360 specifically for engineers who require additional analysis (FFTs, splines, statistical functions, etc.) or more scripting flexibility than macro writing/recording. Additionally, you can run your Python scripts on Windows, Linux, and Mac OS X. Python offers strong support for integration with other languages and tools and comes with extensive standard libraries. The SciPy and NumPy scientific computing libraries are included with Tecplot 360, along with the Tk library for simple GUI development.
یا
Tecplot Focus 2009 R1 12.0.0.4818 | 83.04 Mb
Tecplot Focus is an engineering plotting software with extensive XY, 2D and 3D capabilities. It is designed for measured field data, performance plotting of test data, mathematical analysis, and engineering plotting in general. Unlike our Windows-only competitors, Tecplot Focus is a multi-platform engineering tool that gives you total control to get all the types of plots you want for effective analysis, presentation, and publication. One of the key differentiators between Tecplot Focus and Tecplot 360 is that Tecplot Focus does not support CFD data formats, CFD analysis, and polyhedral grids.
Expanded Analysis with the Power of Python
Python is a powerful open-source, object-oriented extensible programming language. Python scripting was added to Tecplot Focus specifically for engineers who require additional analysis (FFTs, splines, statistical functions, etc.) or more scripting flexibility than macro writing/recording. Additionally, you can run your scripts on Windows, Linux, and Macintosh platforms. Python offers strong support for integration with other languages and tools and comes with extensive standard libraries. Tecplot Focus 2008 users can now leverage the extensive set of open-source libraries that are now available. The SciPy and NumPy scientific computing libraries are included, along with the Tk library for simple GUI development.
Some key features are:
» Unique, multi-frame layout
» Macros and automation
» XY, 2D, and 3D plotting (vector, scatter, contour, polar)
» High quality vector and raster output
New User Interface
» Streamlined layout with improved access to important features.
» Double-clicking buttons acts as a shortcut to the function’s details menu.
» Bounce and loop features were added to the animation options.
» Improved animation options for slices and iso-surfaces.
Easily Understand Complex Engineering Systems
» Gain full understanding with multi-dimensional parametric plots
» XY, Polar, 2D and 3D plotting in one unified environment
» Control over 2,500 attributes of your plot
» Work with a unique multi-frame workspace allowing up to 2048 drawing windows
» Assign arbitrary independent axes for specialty plots
» Apply multiple constraints to define and create performance envelopes
» Create complex performance plots
» Plot irregularly spaced data
Communicate Clearly and Effectively
» Copy and paste your images/animations directly into PowerPoint, Word and other Microsoft Office applications
» Publish and share results directly to the web
» Export presentation-quality vector and raster formats (JPEG, PNG, TIFF, BMP, WMF, PostScript, EPS)
» Share your 3D results in the X3D open source standard
Home Page -
  • 1 سال بعد...
با سلام
از دوستان عزیز، کسی میتونه کمک کنه چطور میتونم فایل با پسوند chm رو باز کنم
chm reader برای نصب پیدا نکردم
و chm reader هم که روی فایرفاکس هست جواب نداد
با تشکر
بانو
  Eng HVAC گفته است:
با سلام
با تشکر
بانو
ویندوزتون چیه؟
این افزونه رو برای فایرفاکس داری؟
قبلی رو پاک کنید و این رو مجدد بریزید
یک فایل ریجستری براتون ساختم،اجرا کنید ببینید کار میکنه یا نه؟
  Eng HVAC گفته است:
ممنون از لطف شما
ولی این chm reader که لینکش رو گذاشتید رو فایرفاکس 11 جواب نمیده
و اینکه ویندوزم 7 هست
چه اروری میده؟
مثل شکل زیر میشه؟
اگر مثل شکل بالا میشه،روی فایلتون رایت کلیک کنید و وارد Properties بشید،پایین سمت راست دکمه Unblock رو کلیک کنید
یه تصویر از ارور بگذارید تا بهتر بتونم کمک کنم
اگر دیگه هیچ راهی نموند،فایلتون رو به HTMLتبدیل کنید و اون موقع باز کنید(توسط نرم افزار زیر)
  • 5 هفته بعد...
  ma-ali گفته است:
سلام من نرم افزاره "thermoflow" در زمینه طراحی سیستم های chp و نیروگاهی رو می خوام . کسی میتونه کمک کنه ؟ هر جا گشتم پیدا نکردم :ws52:
این لینک رو چک کنید .
  S.F گفته است:
سلام این لینک خود شرکت سازندس و نرم افزارو بصورت دمو قابل دانلود گذاشته
یه لینک دیگه تو hotfile پیدا کردم که کرکش ناقص و نا کارامد بود
کسی کرک کاملشو داره یا لینکی برا دانلود میشناسه ؟
  • 2 ماه بعد...
سلام دوستان .
آخرین نسخه نرم افزار Autodesk Mechanical Desktop چیه ؟
این درسته که از سال 2009 دیگه مکانیکال نسخه جدیدی بیرون نداده ؟
  mohammad.ef گفته است:
سلام دوستان .
دوستان اطلاعی ندارن ظاهرا
