WHEN A LIZARD CAN, WHY CAN’T WE
TRUE INSPIRING STORY.. WHEN A LIZARD CAN, WHY CAN’T WE?
This is a true story that happened in Japan (I am not sure about the authentcity about its truth.).
In order to renovate the house, someone in Japan breaks open the wall. Japanese houses normally have a hollow space between the wooden walls. When tearing down the walls, he found that there was a lizard stuck there because a nail from outside hammered into one of its feet. He sees this, feels pity, and at the same time curious, as when he checked the nail, it was nailed 5 years ago when the house was first built!!!
What happened? The lizard has survived in such position for 5 years! In a dark wall partition for 5 years without moving, it is impossible and mind-boggling. Then he wondered how this lizard survived for 5 years! without moving a single step–since its foot was nailed! So he stopped his work and observed the lizard, what it has been doing, and what and how it has been eating. Later, not knowing from where it came, appears another lizard, with food in its mouth. Ah! He was stunned and touched deeply. For the lizard that was stuck by nail, another lizard has been feeding it for the past 5 years… Imagine? it has been doing that untiringly for 5 long years, without giving up hope on its partner.
Imagine what a small creature can do that a creature blessed with a brilliant mind can’t. Please never abandon your loved ones
Lesson from the Story:
Never Say you are Busy When They Really Need You …
You May Have The Entire World At Your Feet.
But You Might Be The Only World To Them..
A Moment of negligence might break the very heart which loves you thru all odds.. Before you say something just remember.. it takes a moment to Break but an entire lifetime to make
  • پاسخ 42
راز اعداد در زبان انگلیسی چیست؟
آیا تا به حال به این فکر کرده‌اید که چرا در زبان انگلیسی اعداد به صورت ۱، ۲، ۳‌ و… نوشته می‌شوند؟ آیا می‌دانید که نوشتن هر یک از این اعداد یک دلیل دارد و آن تعداد زاویه‌های موجود در اعداد است.
ماجرا از این قرار است که به ازای هر عدد زاویه، آن عدد خوانده می‌شود؛ مثلا عدد ۱ چون تنها یک زاویه دارد، یک خوانده می‌شود. برای عدد ۲ چون دو زاویه دارد، دو خوانده می‌شود و…
برای درک بهتر به عکس زیر نگاه کنید:
جالب بود ولی دروغ بود و هرکسی اینا رو ساخته فقط تخیلات قوی داشته و از اعداد انگلیسی چیزی نمی دونسته!
اون 7 که نوشته شده، اصلا 7 انگلیسی نیست و 7 روسی هست! 7 انگلیسی او دو تا خط رو نداره!!
اون زایده ی کوچیکی که آخر عدد 9 هست هم اضافیه و برای اینکه حرفش رو به زور اثبات کنه اون زایده رو گذاشته! اگه 9 اون خط رو داشته باشه، 6 هم باید اون زایده رو داشته باشه!!!!!!
تازه عدد 1 هم یه خط داره 2 و 3 و 4هم ایراد دارن:ws3:
هم تاپیک باحال بود هم نظراتتون....:ws47:
It was awsome dear marjan
:ws44:
Roman numerals are written as combinations of the seven letters in the table below. The letters can be written as capital (XVI) or lower-case letters (xvi).
Roman Numerals
I = 1
C = 100
V = 5
D = 500
X = 10
M = 1000
L = 50
You can use a roman numerals chart or conversion table to lookup roman numerals or you can easily learn how to calculate them yourself with a few simple rules.
How to Translate Roman Numerals
If smaller numbers follow larger numbers, the numbers are added. If a smaller number precedes a larger number, the smaller number is subtracted from the larger. For example, if you want to say 1,100 in Roman Numerals, you would say M for 1000 and then put a C after it for 100; in other words 1,100=MC in Roman Numerals.
Some more examples:
  • VIII = 5+3 = 8
  • IX = 10-1 = 9
  • XL = 50-10 = 40
  • XC = 100-10 = 90
  • MCMLXXXIV = 1000+(1000-100)+50+30+(5-1) = 1984
Roman Numeral Table
1 I
14 XIV
27 XXVII
150 CL
2 II 15 XV
28 XXVIII
200 CC
3 III
16 XVI
29 XXIX
300 CCC
4 IV
17 XVII
30 XXX
400 CD
5 V
18 XVIII
31 XXXI
500 D
6 VI
19 XIX
40 XL
600 DC
7 VII
20 XX
50 L
700 DCC
8 VIII
21 XXI
60 LX
800 DCCC
9 IX
22 XXII
70 LXX
900 CM
10 X
23 XXIII
80 LXXX
1000 M
11 XI
24 XXIV
90 XC
1600 MDC
12 XII
25 XXV
100 C
1700 MDCC
13 XIII
26 XXVI
101 CI
1900 MCM
A Brief History of Roman Numerals
What is the history of Roman Numerals? Roman numerals, as the name suggests, originated in ancient Rome. No one is sure when roman numerals were first used, but they far predate the middle ages. Theories abound as to the origins of this counting system, but it is commonly believed to have started with the ancient Etruscans. The symbol for one in the roman numeral system probably represented a single tally mark of the kind people would notch into wood or dirt to keep track of items or events they were counting.
Where are Roman Numerals Used in Modern Times?
Roman Numbers are still used today in a variety of applications. If you are creating an outline for a story or report, you will be expected to use Roman Numerals. They are also commonly used on clocks and watches to number book chapters, films and big events. Monarchs and Popes are usually numbered with this system as are guitar chords and the cranial nerves
Roman Numerals in Crosswords
Crossword puzzle creators are fond of using Roman Numerals in their puzzles, ranging from requiring translation of complex numbers to expecting puzzlers to know that a Roman Numeral M stands for one thousand. If you want to be an expert crossword puzzler, you probably need to get familiar with the roman numeral conversion process or keep a conversion chart handy. A typical crossword clue is "Half of MCIV" which should be answered "DLII".
Moments In Life
There are moments in life when you miss someone
so much that you just want to pick them from
your dreams and hug them for real!
گاهي در زندگي دلتان به قدري براي كسي تنگ مي شود
كه مي خواهيد او را از روياهايتان بيرون بياوريد و در آغوش بگيريد.
When the door of happiness closes, another opens;
But often times we look so long at the
Closed door that we don't see the one,
Which has been opened for us.
وقتي در شادي بسته مي شود، در ديگري باز مي شود.
ولي معمولاً آنقدر به در بسته شده خيره مي مانيم كه دري كه برايمان باز شده را نمي بينيم.
Don't go for looks; they can deceive.
Don't go for wealth; even that fades away.
Go for someone who makes you smile,
Because it takes only a smile to
Make a dark day seem bright.
Find the one that makes your heart smile.
به دنبال ظواهر نرو؛ شايد فريب بخوري.
به دنبال ثروت نرو؛ اين هم ماندني نيست.
به دنبال كسي باش كه به لبانت لبخند بنشاند.
چون فقط يك لبخند مي تواند شب سياه را نوراني كند.
كسي را پيدا كن كه دلت را بخنداند.
Dream what you want to dream;
Go where you want to go;
Be what you want to be,
Because you have only one life
And one chance to do all the things
You want to do.
هرچه مي خواهي آرزو كن؛
هرجايي كه مي خواهي برو؛
هر چه كه مي خواهي باش؛
چون فقط يك بار زندگي مي كني و براي انجام آنچه مي خواهي فقط يك شانس داري.
May you have enough happiness to make you sweet
Enough trials to make you strong,
Enough sorrow to keep you human and
Enough hope to make you happy.
خوب است كه آنقدر شادي داشته باشي كه دوست داشتني باشي
آنقدر ورزش كني كه نيرومند باشي
آنقدر غم داشته باشي كه انسان باقي بماني
و آنقدر اميد داشته باشي كه شادمان باشي.
The happiest of people don't necessarily
Have the best of everything;
They just make the most of
Everything that comes along their way.
شاد ترين مردم لزوماً بهترين چيزها را ندارند؛
بلكه از هر چه سر راهشان قرار مي گيرد بهترين استفاده را مي كنند.
The brightest future will always
Be based on a forgotten past;
You can't go forward in life until
You let go of your past failures and heartaches.
هميشه بهترين آينده بر پايه گذشته اي فراموش شده بنا مي شود؛
تا غمها و اشتباهات گذشته را رها نكني نميتواني در زندگي پيشرفت كني.
When you were born, you were crying
And everyone around you was smiling.
Live your life so at the end,
You’re the one who is smiling and everyone
Around you is crying.
وقتي كه به دنيا آمدي تو گريه مي كردي و اطرافيانت لبخند به لب داشتند.
آن گونه باش كه در پايان زندگي تو لبخند بزني و اطرافيانت گريه كنند.
Please send this message to those people
Who mean something to you (I JUST DID);
To those who have touched your life in one way or another;
To those who make you smile when you really need it;
To those who make you see the
Brighter side of things when you are really down;
To those whose friendship you appreciate;
To those who are so meaningful in your life.
لطفاً اين پيام را به كساني بفرست كه برايت ارزشي دارند (همان طور كه من اين كار را كردم) ؛
به كساني كه به طرق مختلف در زندگيت تأثير داشته اند؛
به كساني كه وقتي نياز داشتي لبخند به لبانت نشاندند؛
به آنهايي كه وقتي واقعاً نااميد بودي دريچه هاي نور را نشانت دادند؛
به كساني كه به دوستي با آنها ارج مي گذاري؛
و به آنهايي كه در زندگيت بسيار پرمعنا هستند.
Don't count the years - count the memories!
سالها را نشمار ،خاطرات را بشمار!
به شدت قبول دارم
نه اینایی که تو گفت اصلا هیچ ایرادی ندارن ... اصلا با تو مخالفم به کل ... کی به تو میگه حرف بزنی اصلا؟
این جمله با کلمه ای یک حرفی آغاز می شود٬ کلمه دوم دو حرفیست٬‌ چهارم
چهار حرفی... تا بیستمین کلمه بیست حرفی
نویسنده این جمله یا مغز دستور زبان بوده یا بی کار:
I do not know where family doctors acquired illegibly perplexing
handwriting nevertheless, extraordinary pharmaceutical intellectuality
counterbalancing indecipherability, transcendentalizes
intercommunications incomprehensibleness
ترجمه جمله :
نمیدانم این دكترهای خانواده گی این دست خطهای گیج کننده را از کجا کسب
میکنند.با این حال سواد پزشکی انها غیر قابل کشف بودن این دست خط ها را
جبران کرده و بر غیر قابل کشف بودن انها ( دست خط ) برتری میجوید
:ws28:
Accept - پذیرا باشید
دیگران را همانگونه که هستند بپذیرید، حتی اگر برایتان مشکل باشد
که عقاید، رفتارها و نظرات آنها را درک کنید.
Break away - خودتان را جدا سازید
خود را از تمام چیزهایی که مانع رسیدن شما به اهدافتان می شود جدا سازید.
Create - خلق کنید
خانواده ای از دوستان و آشنایانتان تشکیل دهید
و با آنها امیدها، آرزوها، ناراحتی ها و شادی هایتان را شریک شوید.
Decide - تصمیم بگیرید
تصمیم بگیرید که در زندگی موفق باشید. در آن صورت شادی راهش را
به طرف شما پیدا می کند و اتفاقا
شایند و دلپذیری برای شما رخ خواهد داد.
Explore - کاوشگر باشید
جستجو و آزمایش کنید. دنیا چیزهای زیادی برای ارائه کردن دارد و شما هم قادرید چیزهای زیادی را ارائه دهید. هر زمان که کار جدیدی را آزمایش می کنید خودتان را بیشتر می شناسید.
Forgive - ببخشید
ببخشید و فراموش کنید. کینه فقط بارتان را سنگین تر می کند و الهام بخش ناخوشایندی است. از بالا به موضوع نگاه کنید و به خاطر داشته باشید که هر کسی امکان دارد اشتباه کند.
Grow - رشد کنید
عادات و احساسات نادرست خود را ترک کنید
تا نتوانند مانع رشد و سد راه شما برای رسیدن به اهدافتان شوند.
Hope - امیدوار باشید
به بهترین چیزها امید داشته باشید و هرگز فراموش نکنید که هر چیزی امکان پذیر است،
البته اگر در کارهایتان پشتکار داشته باشید و از خدا کمک بخواهید.
Ignore - نادیده بگیرید
امواج منفی را نادیده بگیرید. روی اهدافتان تمرکز کنید و موفقیت
سپارید. پیروزی های گذشته نشانه و رابطی برای موفقیت های آینده هستند.
Journey سفر کنید
به جاهای جدید سر بزنید و با فکر روشن، امکانات جدید را آزمایش کنید. سعی کنید هر روز چیزهای جدیدی را بیاموزید، بدین صورت رشد خواهید کرد و احساس زنده بودن می کنید.
Know - آگاه باشید
آگاه باشید که هر مساله ای هر چقدر هم که سخت و دشوار باشد در نهایت حل خواهد شد. همانطور که گرمای مطبوع و دلپذیر بهار پس از سرمای طاقت فرسای زمستان می آید.
Love - دوست بدارید
اجازه دهید که عشق به جای نفرت، قلبتان را پر کند. زمانی که نفرت در قلب شما ساکن است هیچ فضای خالی برای عشق وجود ندارد، اما موقعی که عشق در قلبتان ساکن است،
تمام خوشبختی و شادی در وجودتان قرار دارد.
Manage - مدیر باشید
بر زمان مدیریت داشته باشید، تا استرس و نگرانی کمتری شما را رنج دهد.
استفاده درست از زمان باعث می شود که روی موضوعات مهم بهتر تمرکز کنید.
Notice - توجه کنید
هرگز افراد فقیر، ناامید، رنج کشیده و ضعیف را نادیده نگیرید
و هر نوع کمکی را که قادرید به
ارائه دهید از آنان دریغ نکنید.
Open - باز کنید
چشم هایتان را باز کنید و به تمام زیباییهایی که در اطرافتان وجود دارد نگاه کنید،
حتی در سخت ترین و بدترین شرایط، چیزهای زیادی برای سپاسگزاری وجود دارد.
Play - بازی و تفریح کنید
فراموش نکنید که در زندگیتان تفریح و سرگرمی داشته باشید.
بدانید که موفقیت بدون شادی و لذت های مشروع، مفهومی ندارد.
Question - سوال کنید
چیزهایی را که نمی دانید بپرسید، زیرا که شما برای یاد گرفتن به این کره خاکی آمده اید.
Relax آرامش داشته باشید
اجازه ندهید که نگرانی و استرس بر زندگی شما حاکم شود
و به یاد داشته باشید که همه چیز در نهایت درست خواهد شد.
Share - سهیم شوید
استعدادها، مهارته
ئیهایتان را با دیگران تقسیم کنید،
زیرا هزاران برابر آن به سمت خودتان برمی گردد.
Try - تلاش کنید
حتی زمانی که رویاهایتان غیر ممکن به نظر می رسند تلاشتان را بکنید.
با تلاش و مشارکت در انجام کارها ماهر و خبره می شوید.
Use - استفاده کنید
از استعدادها و توانایی هایتان به عنوان بهترین هدیه استفاده کنید.
هایی که تلف شوند ارزشی ندارند. استفاده صحیح از استعدادها و تواناییهایتان برای شما
پاداش های غیرمنتظره ای به دنبال دارد.
Value - احترام بگذارید
برای دوستان و اقوامی که شما را حمایت و تشویق کرده اند، ارزش قایل شوید
و هر کاری که از دستتان بر می آید برای آنها انجام دهید.
Warm - صمیمی باشید
با اطرافیانتان صمیمی باشید و نگذارید فضای اخلاقیتان
به سمت و سویی جز صمیمیت منتهی شود.
X-Ray - اشعه ایکس
با دقت و شبیه اشعه ایکس به قلب های انسانهای اطراف خود بنگرید،
در نتیجه شما زیبایی و خوبی را
ب آنها خواهید دید.
Yield - اجازه دهید
اجازه دهید که صداقت و درستکاری وارد زندگیتان شود.
اگر شما در راه درستی حرکت کنید در انتها سعادت واقعی را خواهید یافت .
Zoom - تمرکز کنید
زمانی که خاطرات تلخ، ذهنتان را پر کرده است سعی كنید با مثبت اندیشی به آینده فكر كنید.
و بر خوشبختی كه در ادامه ی عمر در انتظارتان است تمركز كنید.
Absolutely amazing
Beauty of Mathematics !!!!!!!
1 x 8 + 1 = 9
12 x 8 + 2 = 98
123 x 8 + 3 = 987
1234 x 8 + 4 = 9876
12345 x 8 + 5 = 98765
123456 x 8 + 6 = 987654
1234567 x 8 + 7 = 9876543
12345678 x 8 + 8 = 98765432
123456789 x 8 + 9 = 987654321
1 x 9 + 2 = 11
12 x 9 + 3 = 111
123 x 9 + 4 = 1111
1234 x 9 + 5 = 11111
12345 x 9 + 6 = 111111
123456 x 9 + 7 = 1111111
1234567 x 9 + 8 = 11111111
12345678 x 9 + 9 = 111111111
123456789 x 9 +10= 1111111111
9 x 9 + 7 = 88
98 x 9 + 6 = 888
987 x 9 + 5 = 8888
9876 x 9 + 4 = 88888
98765 x 9 + 3 = 888888
987654 x 9 + 2 = 8888888
9876543 x 9 + 1 = 88888888
98765432 x 9 + 0 = 888888888
Brilliant, isn't it?
And look at this symmetry:
1 x 1 = 1
11 x 11 = 121
111 x 111 = 12321
1111 x 1111 = 1234321
11111 x 11111 = 123454321
111111 x 111111 = 12345654321
1111111 x 1111111 = 1234567654321
11111111 x 11111111 = 123456787654321
111111111 x 111111111 = 12345678987654321
Amazing
Now, take a further look at this...
101%
From a strictly mathematical viewpoint:
What Equals 100%?
What does it mean to give MORE than 100%?
Ever wonder about those people who say they are giving more than 100%?
We have all been in situations where someone wants you to
GIVE OVER 100%.
How about ACHIEVING 101%?
What equals 100% in life?
Here's a little mathematical formula that might help
answer these questions:
If:
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
Is represented as:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26.
Then:
H-A-R-D-W-O- R- K
8+1+18+4+23+ 15+18+11 = 98%
And:
K-N-O-W-L-E- D-G-E
11+14+15+23+ 12+5+4+7+ 5 = 96%
But:
A-T-T-I-T-U- D-E
1+20+20+9+20+ 21+4+5 = 100%
THEN, look how far the Love of God will take you:
L-O-V-E-O-F- G-O-D
12+15+22+5+15+ 6+7+15+4 = 101% !!!
Therefore, one can conclude with mathematical certainty that:
While Hard Work and Knowledge will get you close, and Attitude will
get you there, It's the Love of God that will put you over the top!
We know that there are 7 special facts :
- 7 days in a week
- 7 colors in rainbow
- 7 layers of heavens
- 7 continents in the world
- 7 oceans in the world
- 7 orbits in an atom
- 7 layers of the earth
MATHEMATICS
1* 7 + 3 =10
14* 7 + 2 =100
142* 7 + 6 =1000
1428* 7 + 4 =10000
14285* 7 + 5 =100000
142857* 7 + 1 =1000000
1428571* 7 + 3 =10000000
14285714* 7 + 2 =100000000
142857142* 7 + 6 =1000000000
1428571428* 7 + 4 =10000000000
BIOLOGY
Most Mammals’ neck has 7 bones.
The no. of opening into the human’s head is :
mouth , 2 eyes , 2 ears , 2 nostrils .
CHEMISTRY
The most abundant gas on earth,
NITROGEN, has atomic No. 7
There are 7 Rows in the periodic table
The HALOGEN are found in group 7
The PH of pure water is 7
PHYSICS
There are 7st Base units:
Meter, Kilogram, Second, Kelvin, Mole and Candela
There are 7 colors in the visible light:
red, yellow, green, blue, indigo, violet
The atmosphere consists of 7layers:
Troposphere, Stratosphere, Ozonosphere, Mesosphere, Thermosphere, Ionosphere, Exosphere
ASTRONOMY
There are 7 visible ( to the naked eye ) STELLER OBJICTS:
Sun, Moon, Mercury, Mars, Jupitar, Venus, and Saturn
القدوس - The Holy
الملك - The Sovereign
Lord
الرحیم - The
Mercifull
الرحمن - The
Beneficent
الله - The Name Of
God
الجبار - The
Compeller
العزیز - The Mighty
المهیمن - The
Protector
الممن - The Guardian
Of Faith
السلام - The Source
Of Peace
الغفار - The Forgiver
- The Fashioner
- The Evolver
الخالق - The Creator
المتكبر - The
Majestic
العلیم - The All
Knowning
الفتاح - The Opner
  • 4 هفته بعد...
Did You Know,
Letters 'a', 'b', 'c' & 'd' do not appear anywhere in the spellings of 1 to 99
(Letter 'd' comes for the first time in Hundred)
Letters 'a', 'b' & 'c' do not appear anywhere in the spellings of 1 to 999
(Letter 'a' comes for the first time in Thousand)
Letters 'b' & 'c ' do not appear anywhere in the spellings of 1 to 999,999,999
(Letter 'b' comes for the first time in Billion)
And
Letter 'c' does not appear anywhere in the spellings of entire English Counting
ABCDEFG
A Boy Can DO Everythin For Girl
حالا بالعکس
GFEDCBA
Girl Forget Everything Done and Catch a Boy Again
:ws46:
