partow 25305 ارسال شده در 11 تیر، 2012 مراحل تبدیل RGB به CMYK در برنامه های گرافیکی [TABLE=class: promos3 text2, width: 740, align: center] [TR] [TH=class: text1, bgcolor: #FFFFE1, colspan: 3, align: left]How to Convert from RGB to CMYK in Many Common Programs[/TH] [/TR] [TR] [TH=width: 155, bgcolor: #FFFFE1, align: left]Adobe Illustrator 10, CS-CS5[/TH] [TD=bgcolor: white] [*=left]Select File/Document color mode/CMYK color [/TD] [/TR] [TR] [TH=bgcolor: #FFFFE1, align: left]Adobe InDesign CS-CS5[/TH] [TD=bgcolor: white] [*=left]Select Window/Swatches & Window/Color[*=left]Double-click Color in Swatches[*=left]Change color mode to CMYK & color type to Process[*=left]Any colors created in the document that are not in the Swatches palette need to be changed to the CMYK color space[*=left]Select each object you want to convert and make sure the Color palette reflects the CMYK percentages[*=left]Click top right arrow in the palette to change to CMYK if necessary[*=left]Send us your layout and linked images [/TD] [/TR] [TR] [TH=bgcolor: #FFFFE1, align: left]Adobe Pagemaker 6.5[/TH] [TD=bgcolor: white] [*=left]Select Window/Show Colors[*=left]Double-click Colors in palette[*=left]Select Model to be CMYK & Type to be Process [/TD] [/TR] [TR] [TH=bgcolor: #FFFFE1, align: left]Adobe Photoshop[/TH] [TD=bgcolor: white] Existing file: [*=left]Select Image/Mode/CMYK New file: [*=left]Select CMYK for the mode before clicking OK [/TD] [/TR] [TR] [TH=bgcolor: #FFFFE1, align: left]CorelDraw 9[/TH] [TD=bgcolor: white] [*=left]Select each object you want to convert[*=left]Select the Fill tool and click Fill Color Dialog[*=left]Make sure the color model is CMYK[*=left]For each object with an outline:[*=left]Select the Outline tool and click the Outline Color Dialog[*=left]Make sure the color model is CMYK. [/TD] [/TR] [TR] [TH=bgcolor: #FFFFE1, align: left]Microsoft Publisher 2003 and later[/TH] [TD=bgcolor: white] [*=left]Select File Tab, then select Info. Select Commercial Print Settings[*=left]Select Choose Color Model, then Select Process Colors (CMYK) [/TD] [/TR] [TR] [TH=bgcolor: #FFFFE1, align: left]QuarkXpress 4.1[/TH] [TD=bgcolor: white] [*=left]Select Edit/Edit Colors/Show Colors in Use/Highlight Color; click Edit[*=left]Change model to CMYK; deselect Spot color[*=left]Send us your layout and linked images [/TD] [/TR] [TR] [TH=bgcolor: #FFFFE1, align: left]Adobe PhotoDeluxe Adobe Photoshop LE Microsoft Excel Microsoft PhotoDraw Microsoft PowerPoint Microsoft Word Microsoft Works Picture It Publishing[/TH] [TD=bgcolor: white, align: left]These programs do not have the capability to convert to CMYK. We are happy to do the conversion for you free of charge![/TD] [/TR] [/TABLE] فقط خط آخری رو نخونید ! برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام 2
