درخواست و دانلود مقالات علمی رایگان از سایر پایگاه ها ( ISI ، Wiley و . . .)
Monte Carlo-aided dosimetry of a new high dose-rate brachytherapy source
با سلام
Functional fitting of interstitial brachytherapy dosimetry data recommended by the AAPM Radiation Therapy Committee Task Group 43
خیلی خیلی ممنون
با سلام فراوان
1- Dose rate constant and energy spectrum of interstitial brachytherapy sources.
2- Radial dose functions for 103Pd,125 I, 169Yb, and 192 Ir brachytherapy sources: an EGS4 Monte Carlo study
3- Anisotropy functions for low energy interstitial brachytherapy sources: an EGS4 Monte Carlo study
بسیار بسیار ببخشید .
این مقالات را هم اگر می شود برایم بگیرید.
1- The radial dose function of low-energy brachytherapy seeds in different solid phantoms: comparison between calculations with the EGSnrc and MCNP4C Monte Carlo codes and measurements
1- Characteristics of miniature electronic brachytherapy x-ray sources based on TG-43U1 formalism using Monte Carlo simulation techniques
2- SU‐E‐T‐527: A Fast Novel Analytical Model Accounting for Interseed Attenuation Effect in Low Energy Brachytherapy Sources
3- SU‐E‐T‐551: A Novel Analytical Model to Determine Inhomogeneity Correction Factor in TG‐43U1 Low Dose Rate Brachytherapy
4- SU‐E‐T‐525: Developing a GYN Cs‐Selectron Brachytherapy Treatment Planning Software Accounting for Inter‐Source, Applicator and Heterogeneity Effects
5- SU‐E‐T‐539: Developing a Method for Dose Heterogeneity Corrections for Cs‐137 Brachytherapy Sources
6- SU-C-16A-06: Optimum Radiation Source for Radiation Therapy of Skin Cancer
سلام.این مقاله رو می خواستم.واقعا ممنون می شم اگه لینک دانلودش رو بذارید:icon_redface::icon_gol::icon_gol:
Creativity in design: analyzing and modeling the creative leap
با سلام
B Reniers1, F Verhaegen2 and S Vynckier1
با سلام
Experimental determination of dosimetric characteristics of Best 125I brachytherapy source.
خدمت شما:
طبق قوانین سایت، بیش از دو تا مقاله نمیشه در روز درخواست داد.:a030:
با سلام؛
High coercivity, isotropic plasma sprayed samarium‐cobalt magnets
سپاسگزارم :)
[quote name='A.m.i.r']با سلام؛
[URL]http://scitation.aip.org/content/aip/journal/jap/49/3/10.1063/1.324790[/URL]
سپاسگزارم :)[/QUOTE]
خدمت شما:
[URL="http://sci-hub.org/downloads/bb9b/10.0000@scitation.aip.org@generic-41247963F135.pdf"][COLOR=#0000ff][B][RIGHT]High coercivity, isotropic plasma sprayed samarium‐cobalt magnets[/RIGHT][/B][/COLOR][/URL]
دوتا قبلی دسترسی نداشتم
با سلام فراوان
قبلیایی که نگرفتم هیچ کدوم دسترسی نداشتم :w16:.
خدمت شما:
2.
با سلام
Inverse planning anatomy-based dose optimization for HDR-brachytherapy of the prostate using fast simulated annealing algorithm and dedicated objective function
A comparison of radial dose functions for 103Pd, 125I, 145Sm, 241Am, 169Yb, 192Ir, and 137Cs brachytherapy sources.
[h=1]The development and validation of the organisational innovativeness construct using confirmatory factor analysis[/h]
ببخشید اگه لینک دانلود این مقاله رو واسم بذارین سپاسگزارم
خدمت شما:
سلام. لطفا این مقاله رو واسم بذارید:
In vivo threedimensional patellar tracking on the femur.
Difference between the epicondylar and cylindrical axis of the knee.
با سلام
1-
ایا امکانی هست که پایان نامه های سایت
را دانلود کرد ؟ کسی راهی داره ! ایا برای دانشگاه های بزرگ ایران باز هستن؟
لطفا راهنمایی کنید
تشکر فراوان
ممنون میشم این مقاله رو برام دان کنید
[h=1]Fault-tolerant scheduling in homogeneous real-time systems[/h]
سلام به دوستان عزیز
این پست رو در دو تالار گذاشتم تا دوستان بدونن از هر پایگاهی مقاله بخواهند براشون میتونم پیدا کنم
اگر کسی به مقاله نیاز داشت از سایت های خارجی به من هم میتونه بگه تا براش پیدا کنم.سقف درخواست حدودا 10 تا در روز هست.
یا میتونید به صورت خصوصی بهم بگید یا همینجا بهم بگید تا براتون بذارم.لطفا از من نخواهید براتون دنبال مقاله باشم.فقط خودتون پیداش کنید. دانلود و ارسالش با من.با تشکر
