اینم می خواستم بی زحمت
A new time domain voltage source model for an arc furnace using EMTP
  • پاسخ 1.7k
با سلام این مقاله رو می خواستم با تشکر:
Voltage flicker mitigation by DSTATCOM for voltage source Arc furnace model
اگه امکانش هست این مقالات رو برای پایان نامم می خواستم خیلی خیلی ممنون از لطفتون
STATCOM control research and analysis
Electric arc furnace power modeling for STATCOM Controller Application
STATCOM for flicker suppression from a steel plant connected to a weak 66 kV grid
STATCOM for compensation of large electric arc furnace installations
Analysis of flicker mitigation in a utility distribution network
Voltage flicker mitigation using PWM-based distribution STATCOM
A Novel Linear Feedback Control Strategy for Compensation of Voltage Flicker using Statcom
An Improved Nonlinear STATCOM Control for Electric Arc Furnace Voltage Flicker Mitigation
Modelling and control of a cascade-multilevel converter-based STATCOM for electric arc furnace flicker mitigation
Simulated electric arc furnace voltage flicker mitigation with 3-level current-controlled STATCOM
Voltage flicker compensation using STATCOM
STATCOM, an efficient means for flicker mitigation
Evaluation of cascade-multilevel converter based STATCOM for arc fumace flicker mitigation
دستتون درد نکنه ببخشید که همشو یجا درخواست کردم بازم ممنون
با سلام
اين چند تا مقاله
1-
2-
3-http://ieeexplore.ieee.org/xpl/articleDetails.jsp?tp=&arnumber=4632094&contentType=Conference+Publications&queryText%3Dsoftware+risk+management+model
4-http://ieeexplore.ieee.org/xpl/articleDetails.jsp?tp=&arnumber=4625010&contentType=Conference+Publications&queryText%3Dsoftware+risk+management+model
با تشكر
با سلام
اين چند تا مقاله
1-
2-
با تشكر
:icon_gol:
:icon_gol:
با سلام و خسته نباشید خدمت شما . خواهش برای دریافت مقالات زیر را دارم:
1-[h=1]Using a surge tester to detect rotor eccentricity faults in induction motors [/h]
Author(s): Xianghui Huang
2-[h=1]The effect of induction motor rotor eccentricity on surge test data [/h]
3-[h=1]Modelling, Simulation and Experimental Analysis of Transient Terminal Overvoltage in PWM-Inverter fed Induction Motors [/h]
Author(s): Basavaja, B.
4-[h=1]A New Concept for Online Surge Testing for the Detection of Winding Insulation Deterioration in Low-Voltage Induction Machines [/h]
Author(s): Grubic, S.
متشکر و ممنون
1-Using a surge tester to detect rotor eccentricity faults in induction motors
2-The effect of induction motor rotor eccentricity on surge test data
3-Modelling, Simulation and Experimental Analysis of Transient Terminal Overvoltage in PWM-Inverter fed Induction Motors
4-A New Concept for Online Surge Testing for the Detection of Winding Insulation Deterioration in Low-Voltage Induction Machines
متشکر و ممنون
داداشم اگر ایناروهم بدی یک دنیا ممنونتم:
1-[h=1]Effects of deterioration equipment reliability in a gas turbine cogeneration power plant [/h]
Author(s): Hazi, A.
2-[h=1]Effect of combined transmission line (overhead line/cable) on power system reliability indices [/h]
Author(s): Damchi, Y
3-[h=1]Reliability improvement of composite electric power system using Unified Power Flow Controller [/h]
Author(s): Kumar, T.S.
4-[h=1]Impacts of Fault Diagnosis Schemes on Distribution System Reliability [/h]
Author(s): Kazemi, S.
بازهم تشکر از لطفتون
1-Effects of deterioration equipment reliability in a gas turbine cogeneration power plant
Author(s): Hazi, A.
2-Effect of combined transmission line (overhead line/cable) on power system reliability indices
3-Reliability improvement of composite electric power system using Unified Power Flow Controller
4-Impacts of Fault Diagnosis Schemes on Distribution System Reliability
با سلام لطفا سه مقاله زیر را ارسال کنید با تشکر از زحمات شما
Model and Dynamic Simulation of Belt Conveyor
Dynamic simulation of belt conveyor based on virtual prototyping
Dynamic Simulation on the Belt Conveyor on Emergency Braking
در ضمن در سایت زیر اپلود نکنید باز هم ممنونم چون پسورد می خواد
:ws3: آقا خيلي ممنون ، من اينا رو مي خوام لطفا
[h=1]
[/h]و
و
و
و
و همينا :icon_gol:
و
و
و
و
و همينا :icon_gol:
داداشم میشه مقالات زیر رو زاسم بذاری!!!!!
1-[h=1]Optimized Sectionalizing Switch Placement Strategy in Distribution Systems [/h]
2-[h=1]Decentralized topology inference of electrical distribution networks [/h]
3-[h=1]Applications of smart grid technologies on power distribution systems [/h]
4-[h=1]Secure wireless data communications for distribution automation in the Smart Grid [/h]
5-[h=1]Requirements on distribution management for service-oriented automation systems [/h]
[h=1]Optimal coordination of overcurrent relay using an enhanced discrete differential evolution algorithm in a distribution system with DG [/h]
1-Optimized Sectionalizing Switch Placement Strategy in Distribution Systems
2-Decentralized topology inference of electrical distribution networks
3-Applications of smart grid technologies on power distribution systems
4-Secure wireless data communications for distribution automation in the Smart Grid
5-Requirements on distribution management for service-oriented automation systems
سلام.
خسته نباشید.
