Review of unit protection schemes for auto-transformers
Design of an electronic control system for overcurrent protection in a voltage regulator based on auto-transformer
A novel automatic voltage control architecture based on the infrastructures in the smart grid
Automatic Compensation Voltage Control strategy for on-load tap changer transformers with distributed generations
خدمت شما:
  • پاسخ 1.7k
salam
[h=1]Synchronous detection and digital control of Shunt Active Power Filter in power quality improvement[/h]
salam
خدمت شما:
[h=1]
High-Efficiency Voltage Regulator for Rural Networks [/h]
[h=1]Transformer Tap Changing Under Load [/h]
[h=1]Automatic-Ratio-Control Transformer and Regulator[/h]
با تشکر
Research on GIS Spatial Database Based on Grid Computing
لینک ها رو کوتاه کنید لطفا،
مثلا برای مقاله اول، فقط مین قسمت از لینک کافیه:
خدمت شما:
با تشکر
خدمت شما:
[h=1]Voltage regulation in distribution feeders with high DG penetration: From traditional to smart[/h]
لطفا مقالات زیر رو برام دانلود کنید
Algorithm for X-ray Scatter, Beam-Hardening, and Beam Profile Correction in Diagnostic (Kilovoltage) and Treatment (Megavoltage) Cone Beam CT
Scatter Correction Method for X-Ray CT Using Primary Modulation: Theory and Preliminary Results
Analysis model of X-ray coherent scatter images
Processing of X-ray images
ممنون
خدمت شما:
ممنون
خدمت شما:
اگه لطف کنید این مقاله رو برای من آپلود کنید ممنون می شم:icon_gol::icon_gol::icon_gol::icon_gol:
[h=1]An in-silico glial microdomain to invoke excitability in cortical neural networks[/h]
خدمت شما:
...Steady state exploration of 3-Φ SEIG using novel
A Discrete Matlab–Simulink Flickermeter Model for Power Quality Studies
Three single-phase voltage source converter based three-phase
Reduction in rating of voltage source converter of DSTATCOM using a zig-zag transformer
Implementation of Neural-Network-Controlled Three-Leg VSC and a Transformer as Three-Phase Four-Wire DSTATCOM
Neural network theory based voltage and frequency controller for standalone wind energy conversion system
Integrated solid state controller for small hydro generation using isolated asynchronous generator
Neural-Network-Based Integrated Electronic Load Controller for Isolated Asynchronous Generators in Small Hydro Generation
[h=1]A new modified PQ theory used for reactive power and current harmonic compensation[/h]
[h=1]A GUI based simulation of power electronic converters and reactive power compensators using MATLAB/SIMULINK[/h]
خدمت شما:
سلام.
من یکی دوبار سعی کردم لینک بزارم ولی وقتی دکمه ارسال رو میزنم لینکای اشتباهی ارسال می شوند.
برای همین لینکارو تو این فایل txt گذاشتم.
لطفا دوستان رسیدگی کنند.
با تشکر
امکان پذیر نیست، قوانین رو رعایت کنید
تا به حال کسی در گذاشتن لینک مشکلی نداشته
[h=1]Battery state-of-charge estimation[/h]
با تشکر
Comparative Performance Evaluation of Convolutionally Coded and LDPC Coded OFDM System over AWGN and SUI-5 Fading Channel
Goel, Ashish; Garg, Manoj Kumar
با تشکر
خدمت شما:
خدمت شما:
Generation and FEC-decoding of a 231.5-Gb/s PDM-OFDM signal with 256-iterative-polar-modulation achieving 11.15-b/s/Hz intrachannel spectral efficiency and 800-km reach
Image transmission over Gilbert-Elliot and ITU fading channels using DVB-T2 channel coding and QPSK-OFDM
Efficient implementation of channel coding and interleaver for Digital Video Broadcasting (DVB-T2) on FPGA
%3Ddesc_p_Publication_Year%26rowsPerPage%3D100%26queryText%3D
terative Channel Decoding of FEC-Based Multiple-Description Codes
PAPR reduction in OFDM with FEC (RS-CC and Turbo coding) using DHT preceding
Study on sub-block encoder of LDPC code with OFDM for image transmission
Are All Bits Equal?—Experimental Study of IEEE 802.11 Communication Bit Errors
Comparisons between gigabit NRZ, CAP and optical OFDM systems over FEC enhanced POF links using LEDs
Coded OFDM wireless systems with generalized prefix
Analysis of forward error correcting codes
Turbo decoding in ISI channels
خدمت شما:
سلام وقت بخیر
[h=1]Improved layed architecture for developing semantic web application[/h]Author(s):
[h=1]Design and Model Analysis of the E-Commerce Development Platform for 3-Tiered Web Applications[/h]Author(s):
با تشکر فراوان:icon_gol:
