سلام .دست همتون درد نکنه .اشاالله هرچی از خدا بخوای رو بهتون بده . این 3 مقاله به هم ربط داره . خیلی برام مهم هست . ممنون از لطفتون
مقاله :
Mutation based test case generation via a path selection strategy
نویسنده : mike papadakis, nicos malevrisلینک :
نام مقاله : Improving test efficiency through system test prioritizationنویسنده :hema srikanth , sean banerjeeلینک :
0164121212000027
  • پاسخ 1.9k
مقاله :
لینک :
لینک :
0164121212000027
Test coverage optimization for large code problems
نویسنده : tse yau huang
لینک :
سلام یه عالم براتون زحمت دارم
[h=1]Effects of an electric field on the confined hydrogen impurity states in a spherical parabolic quantum dot[/h] [h=1]
[/h]
  • برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید.
[h=1]Intersubband optical absorption coefficient changes and refractive index changes in a two-dimensional quantum pseudodot system[/h] [h=1]
[/h]
[h=1]Effect of magnetic fields on the linear and nonlinear intersubband optical absorption coefficients and refractive index changes in square and graded quantum wells[/h] [h=1]
[/h]
[h=1]Bound states and third-harmonic generation in a semi-parabolic quantum well with an applied electric field[/h] [h=2]
[/h]
[h=1]Exciton effects on the optical absorptions in one-dimensional quantum dots[/h]
[h=1]Exciton effects on nonlinear electro-optic effects in semi-parabolic quantum wires[/h]
[h=1][/h] [h=1]
[/h]
[h=1]Effects of position-dependent effective mass and dielectric function of a hydrogenic donor in a quantum dot[/h] [h=1]
[/h]
[h=1]Nonlinear optical rectification in parabolic quantum dots in the presence of electric and magnetic fields[/h]
[h=1]External electric field and hydrostatic pressure effects on the binding energy and self-polarization of an off-center hydrogenic impurity confined in a GaAs/AlGaAs square quantum well wire[/h] [h=1]
[/h]
[h=1]Linear and nonlinear intersubband optical absorption in symmetric double semi-parabolic quantum wells[/h]
با تشکر خیلییییییییییییییییییییییییییییی زیاد:w16:
با سلام و تشکر از زحمات شما دوستان گرامی این چندمین بار هست که این لینک ها رو قرار می دم لطفا اگر امکانش هست این مقالات رو برام دانلود کنید ظاهرا فراموش میشه باتشکر
به نظزم لینک هات ایراد داره. یه بار خودت هم چک کن
لینک :
مقاله :
Mutation based test case generation via a path selectionstrategy
لینک :
لینک :
0164121212000027
مقاله :
0164121212000027
فکر کنم در سه تا بود:w16: بفرماااا:
خسته نباشید.
لطفا این مقالاتو برام بزارید. ممنون
بفرمایید:
Talanta, Volume 67, Issue 1, 15 July 2005, Pages 245-251
Uğur Tamer, Nusret Ertaş, Yasemin A. Udum, Yücel Şahin, Kadir Pekmez, Attila Yıldız
Original Research Article
Analytica Chimica Acta, Volume 707, Issues 1–2, 30 November 2011, Pages 62-68
Akram Ameli, Naader Alizadeh
Analytica Chimica Acta, Volume 701, Issue 1, 2 September 2011, Pages 1-5
Mohammad Bagher Gholivand, Marzieh Piryaei, Mir Mahdi Abolghasemi
Talanta, Volume 58, Issue 4, 16 October 2002, Pages 739-745
Brian J Yates, Khalid R Temsamani, Özcan Ceylan, Serhan Öztemiz, Thompson P Gbatu, Rebecca A LaRue, Ugur Tamer, Harry B Mark Jr
ممنون میشم اینارو برام بفرستید
بفرمایید لینک دانلود:
    [*=right]
    [*=right]
    [*=right]
    [*=right]
    [*=right]
    [*=right]
Electric field effect on the second-order nonlinear optical properties of parabolic and semiparabolic quantum wells
    [*=right]
    [*=right]
    [*=right]
    [*=right]
    [*=right]
    [*=right]
    [*=right]
      [*=right]
      [*=right]
    [*=right]
    [*=right] fields
      [*=right]
      [*=right]
      [*=right]
      [*=right]
      [*=right]
      [*=right]
    [*=right]
    [*=right]
    [*=right]
    [*=right]
    [*=right]
    [*=right]
با تشکر:whistle::whistle:
شما چرا مقاله تکراری درخواست میدی؟؟!!!!:ws38:
:vahidrk:
سلام مقاله ترویجی
درباره درامدهای پایدار شهرداریها میخواهم
شرمنده حواس پرتیه دیگه اقتضای سنه:icon_pf (34)::icon_pf (34)::icon_pf (34)::icon_pf (34)::icon_pf (34):
با سلام
مقاله زیر رو از sciencedirect نیاز دارم
Energy-aware resource allocation heuristics for efficient management of data centers for cloud computing
نویسندگان:
Beloglazov A, Abawajy J, Buyya R
لینک :
با تشکر فراوان
[h=2]Default.gif[/h]
سلام باز هم لینک ها رو گذاشتم اینها دیگه درسته لطفا هر چند زحمته ولی باز سعی کنید اردشیر جان با تشکر
Chapter 16 – Development of the Enteric Nervous System Pages 475–488
Chapter 17 – Cellular Physiology of Gastrointestinal Smooth Muscle
Chapter 18 – Organization and Electrophysiology of Interstitial Cells of Cajal and Smooth Muscle Cells in the Gastrointestinal Tract
Chapter 19 – Enteric Nervous System Structure and Neurochemistry Related to Function and Neuropathology Pages 557–581
Chapter 20 – Physiology of Prevertebral Sympathetic Ganglia Pages 583–627
Chapter 21 – Cellular Neurophysiology of Enteric Neurons
Chapter 22 - Integrative Functions of the Enteric Nervous System Pages 671–688
Chapter 23 – Processing of Gastrointestinal Sensory Signals in the Brain Pages 689–702
سلام، لینک دانلود مقالات :
Sensitivity analysis of dynamic lot-sizing heuristics
نام نویسنده :
http://www.sciencedirect.com/science/article/pii/S0925527303003141
[h=1]Warehouse space capacity and delivery time window considerations in dynamic lot-sizing for a simple supply chain[/h]نام نویسنده:
1. [h=1]Modeling, design and thermal performance of a BIPV/T system thermally coupled with a ventilated concrete slab in a low energy solar house: Part 2, ventilated concrete slab[/h]
2. [h=1]Influence of green-house cover on potential evapotranspiration and cucumber water requirements[/h]
با سلام ممنون میشم مقاله زیرو برام دانلود کنید.
International Journal of Hydrogen Energy
, July 1993, Pages 545–551
Parametric study for saline water electrolysis: Part II—Chlorine evolution, selectivity and determination
با سلام
نویسندگان:
لینک :
با تشکر فراوان
بفرمایید:
نام نویسنده :
نام نویسنده:
بفرمایید:
1. Modeling, design and thermal performance of a BIPV/T system thermally coupled with a ventilated concrete slab in a low energy solar house: Part 2, ventilated concrete slab
2. Influence of green-house cover on potential evapotranspiration and cucumber water requirements
بفرمایید:
متأسفانه دسترسی نبود
سلام لطف می کنید؟
Theoretical studies on the optical absorption coefficients and refractive index changes in parabolic quantum dots in the presence of electric and magnetic fields
    [*=left]
    [*=left]
    [*=left]
    [*=left]
    [*=left]
    [*=left]
Linear and nonlinear intersubband optical absorption coefficients and refractive index changes in a quantum box with finite confining potential
    [*=left]
    [*=left]
    [*=left]
تشکر:whistle:
با سلام لطفا برام دانلود کنید
design and simulation of a high power cmos driver for microactuators
khaied A Aggour
