مشاعره با واژه های انگلیسی معماری
metal
فلز
A solid material that is typically hard
  • پاسخ 497
Light weight concrete : بتن سبک
Autoclaved Aerated concrete (AAC), or otherwise known as Autoclave Cellular Concrete (ACC) was invented in the mid-1920s by Max Ginsberg. It is a lightweight, precast building material and provides structure, insulation, fire and mold resistance in a single material
exhibition
نمایشگاه
a public display of art, products, skills, activities, etc
Niche:تو رفتگی در دیوار، طاقچه
Niche: Recess in a wall or in a rock face
Suitable place or position
escalator:پله برقی
A escalator is a moving staircase – a
device for carrying people between floors of a building
railing:نرده ،ریل
railing:
Open fence or guard for safety, made of rails and posts
Groin vault : غرفه ، دهلیز
A groin vault or groined vault (also sometimes known as a double barrel vault or cross vault) is produced by the intersection at right angles of two barrel vaults
technical
فنی
having special and usually practical knowledge especially of a mechanical or scientific subject a technical consultant
eccentric:خارج از مرکز
Physics A disk or wheel having its axis of revolution displaced from its center so that it is capable of imparting
ceiling
سقف
The upper interior surface of a room or other similar compartment
griD
شبکه
A pattern of regularly spaced horizontal and vertical lines forming squares on a map, a chart, an aerial photograph, or an optical device, used as a reference for locating points.
dado
پایین ترین بخش دیوار ( قرنیز)
The lower part of the wall of a room, below about waist height, if it is a different color or has a different covering than the upper part.
objecT
شی،چیز،ماده
anything that is visible or tangible and is relatively stable in form.
Tower
برج
A building or part of a building that is exceptionally high in proportion to its width and length
rationalisM
خردگرایی
Reliance on reason as the best guide for belief and action
manufacture : ساختن
To make or process (a product), especially with the use of industrial machines
element : عنصر
1. A part or aspect of something, esp. one that is essential or characteristic.
2. A small but significant presence of a feeling or abstract quality: "it was the elementof danger he loved in flying"
theateR
تئاتر،اتاق نمایش
A building, room, or outdoor structure for the presentation of plays, films, or other dramatic performances
Riser : پیشانی پله
. The vertical part of a stair step.
