*Cloudy sky* 22513 ارسال شده در 29 خرداد، 2013 Mutule :عنصر بیرون نشسته Rectangular block under the soffit of the cornice of the Greek Doric temple, which is studded with guttae. It is supposed to represent the piece of timber through which the wooden pegs were driven in order to hold the rafter in position, and it follows the sloping rake of the roof. In the Roman Doric order the mutule was horizontal, with sometimes a crowning fillet, so that it virtually fulfilled the purpose of the modillion in the Corinthian cornice 3
*Reyhaneh* 3812 ارسال شده در 4 تیر، 2013 entablature: پیشانی، بخشی افقی در شیوه ی ستون سازی کلاسیک که بر روی شتون ها قرار می گیرد و معمولا شامل قرنیز، افریز و فرسب است. 3
*Cloudy sky* 22513 ارسال شده در 28 شهریور، 2013 exterior wall : ديوار خارجي Framing exterior walls is a pretty straightforward process. Assembling walls on a level surface - probably the subfloor or slab - and raising them into place will help you frame faster. However, raising walls usually requires some extra help. 3
sam arch 55879 ارسال شده در 30 شهریور، 2013 lean-to چهار طاقی - ساباط A structure with a single-pitch roof that is attached to the side of a building as a wing or an extension. 3
سـارا 20071 ارسال شده در 23 خرداد، 2014 Non bearing wall :دیوار غیر باربر Non-bearing walls are walls that do not support any other load other than their own weight. Generally, non-bearing walls are found in the interior of the structure. 2
sam arch 55879 ارسال شده در 31 خرداد، 2014 lounge ...سالن و محل استراحت A public room in a hotel, theatre, or club in which to sit and relax:the hotel has a pleasant lounge and bara TV lounge
سـارا 20071 ارسال شده در 4 تیر، 2014 Elevator : آسانسور a platform or compartment housed in a shaft for raising and lowering people or things to different floors or levels. 3
سـارا 20071 ارسال شده در 4 تیر، 2014 Ramp : رمپ a slope or inclined plane for joining two different levels, as at the entrance or between floors of a building. (بچه ها یه توضیح کوچیک هم بدین به انگلیسی.مرسی ) 1
ENG.SAHAND 31645 ارسال شده در 13 آبان، 2014 packaged concrete بتن کیسه ایی [TABLE] [TR] [TD] شمع اتکائی[/TD] [TD]end bearing pile[/TD] [/TR] [/TABLE] 2
سامیار220 10919 ارسال شده در 8 اردیبهشت، 2015 edifice :ساختمان بزرگ Exposed aggregate finish: نمای بتن اکسپوز زبر 1
