ELASTO-PLASTIC SOLUTION OF TUNNEL PROBLEMS USING
THE GENERALIZED FORM OF THE HOEK-BROWN FAILURE CRITERION
Abstract: The Hoek-Brown failure criterion is a semi-empirical method widely used in the estimation of shear
strength of rock. Among other parameters involved in this criterion, the coefficient a dictates whether the criterion
applies to intact rock or rock masses (a = 0.5 for intact rock anda > 0.5 for rock masses). Most of the existing
elasto-plastic solutions for tunnel problems in Hoek-Brown media consider an intact rock (i.e., a = 0.5). This
is not only due to historical reasons (the failure criterion was originally developed for intact rock), but also due
to the mathematical difficulties of deriving neat, closed-form expressions for the general case in which a ≥ 0.5.
This paper presents a rigorous, elasto-plastic solution for the axi-symmetrical problem of excavating a circular
tunnel in generalized Hoek-Brown material (a ≥ 0.5). The solution is obtained by re-writing the generalized
Hoek-Brown failure criterion in terms of transformed stress quantities. Application of the transformation rule
described in this paper to elasto-plastic problems of excavations in generalized Hoek-Brown materials is shown
to bring significant advantages in the interpretation and extrapolation of results obtained with analytical and
numerical methods. C. Carranza-Torres1
Penetration rate of TBMs
SYNOPSIS: A number of empirical relationships have been in vogue to predict the penetration rate of
TBMs. These relations consider compressive strength, tensile strength, hardness test data, RQD, RSR, RMR,
Q-values etc., either independently or in combination with some of these parameters. Barton proposed an
elaborate expression consisting of 21 parameters. Experimental studies in Italian Alps on the performance of
TBM in medium to hard metamorphic rocks revealed considerable deviation from Barton-approach.
A simple expression dimensionally correct to predict penetration rate is presented considering the basic TBM
data, properties of rock mass and also intact rock, in situ stress and drilling rate index of rock. It has been
verified with the data from 16 rock types of Maen and Pieve tunnels in Italian Alps giving very encouraging
results. A brief mention is also made how to predict advance rate of TBMs.
A MAMDANI FUZZY INFERENCE SYSTEM FOR THE GEOLOGICAL STRENGTH
INDEX (GSI) AND ITS USE IN SLOPE STABILITY ASSESSMENTS
Abstract: The strength and deformation modulus of closely jointed rock masses can be estimated by using
the Hoek and Brown empirical criterion in conjunction with the Geological Strength Index (GSI)
classification system. To minimize the uncertainties of the rock masses, experienced engineers commonly
use the engineering judgment. Intervals of the GSI, rather than point-valued observations, are also likely to
be obtained when using the original GSI chart. This study is an attempt to provide an approach on the fuzzy
set theory for determining GSI ratings to be used by the empirical failure criterion. For the purpose, the
original GSI system and its quantitative modified form were defined by fuzzy sets, and Mamdani fuzzy
algorithm was constructed employing 23 “if-then” rules. In addition, the validity of the approach and
methodology of parameter estimation were checked by back analysis of the well-documented slope
instabilities occurred in the heavily jointed rock masses
Shallow Cover Tunnel Under Heritage Listed Brick Buildings:
Brisbane Boggo Road Busway Tunnel
Introduction
The use of underground space for new transport infrastructure in urban environments has become very common due to space constraints. In built-up areas these tunnels will often pass under sensitive buildings. This article presents a case study on a shallow cover driven busway tunnel under heritage-listed buildings on shallow footings. Phase2 (in design), Unwedge and Dips computer software packages were used extensively. The latter two packages were used extensively during tunnel excavation.
Influence of rock mass properties on TBM penetration
rate in Karaj-Tehran water conveyance tunnel
Predicting penetration rate (PR) of tunnel boring machine (TBM) due to the properties of rock mass
surrounding tunnel has been an important subject in the mechanized method of excavating tunnel.
Influence of uniaxial compressive strength (UCS), Brazilian tensile strength (BTS), peak slope index
(punch penetration), spacing of discontinuities (of weakness planes), orientation of discontinuities with
respect to the tunnel axis (Beta angle) on penetration rate of TBM was investigated while excavating Karaj-
Tehran water conveyance tunnel by a double shield Herencnesht TBM. Statistic analysis was carried
out on the relationship between measured test results of the five different parameters of rock mass
properties and the penetration rate of TBM. The results showed that each of the five different
parameters of rock mass properties individually has affected the penetration rate of TBM. The
relationship between peak slope index (PSI) and penetration rate of TBM has the best correlation
coefficient ® of 0.57 in comparison with the four others relationship between rock mass properties and
the penetration rate of TBM. The relationship between BTS of rock and PR of TBM has a very poor
correlation coefficient ® of 0.11. Multilinear regression analysis was applied to indicate the combined
influence of the five different rock mass properties on the penetration rate of TBM using a database of
measured test results. A new empirical formula was achieved to predict PR of TBM as a function of
different rock mass properties (r = 0.75).
  • 5 ماه بعد...
  • 6 ماه بعد...
نام لاتین کتاب : Introduction to Tunnel Constraction
نام فارسی کتاب : مقدمه ای بر ساخت تونل
ناشر :Alfred Stärk , David Chapman, Nicole Metje
سال انتشار : ۲۰۱۰
لینک دانلود :
  • 4 ماه بعد...
