M!Zare 48037 مالک اشتراک گذاری ارسال شده در 10 شهریور، ۱۳۹۰ Sports balls Many games involve balls designed to use drag reduction brought about by surface roughness Many sports balls have some type of surface roughness, such as the seams on baseballs or cricket balls and the fuzz on tennis balls It is the Reynolds number (not the speed, per se) that determines whether the boundary layer is laminar or turbulent. Thus, the larger the ball, the lower the speed at which a rough surface can be of help in reducing the drag Typically sports ball games that use surface roughness to promote an early transition of the boundary layer from a laminar to a turbulent flow are played over a Reynolds number range that is near the “trough” of the Cd versus Re curve, where drag is lowest 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 10 شهریور، ۱۳۹۰ Flow in reference frame relative to the ball Note that we have been showing flow fields in the reference frame of the object, similar to the flow around the soccer ball shown here 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 10 شهریور، ۱۳۹۰ Flow in absolute reference frame However, one should keep in mind that the flow in the absolute reference frame may look quite different, as shown here 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 10 شهریور، ۱۳۹۰ Airfoil - effect of angle of attack The loss in pressure in the separated flow region behind solid bodies causes an imbalance between the upstream and downstream forces, contributing greatly to an increased net drag force In the case of streamlined airfoils at low angle of attack, separation occurs only at the tip, with minimal losses. As the angle of attack increases, the separation point moves upstream, leading to increased drag 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 10 شهریور، ۱۳۹۰ Airfoil - effect of shape The pressure field is changed by changing the thickness of a streamlined body placed in the flow. The acceleration and deceleration caused by a finite body width creates favorable and unfavorable pressure gradients When the body is thin, there are only weak pressure gradients and the flow remains attached. As the body is made thicker, the adverse pressure gradient resulting from the deceleration near the rear leads to flow separation, recirculation, and vortex shedding Focusing in on the rear region of the flow, it is seen that as the body is again reduced in thickness, the separated region disappears as the strengths of the adverse pressure gradient is diminished 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 10 شهریور، ۱۳۹۰ Suction Just as flow separation can be understood in terms of the combined effects of viscosity and adverse pressure gradients, separated flows can be reattached by the application of a suitable modification to the boundary conditions In this example, suction is applied to the leading edge of the airfoil at a sharp angle of attack, removing the early separation zone, and moving the separation point much farther downstream 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 10 شهریور، ۱۳۹۰ Blowing Separation in external flows, such as the flow past a sudden expansion can be controlled not only by suction but also by blowing In this video, the region of separated flow is eliminated by the introduction of high momentum fluid at a point near the separation point This acts to eliminate the adverse pressure gradient by accelerating the fluid close to the boundary, leading to re-attachment of the flow 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 10 شهریور، ۱۳۹۰ The turbulent boundary layer In turbulent flow, the boundary layer is defined as the thin region on the surface of a body in which viscous effects are important The boundary layer allows the fluid to transition from the free stream velocity Ut to a velocity of zero at the wall The velocity component normal to the surface is much smaller than the velocity parallel to the surface: v The gradients of the flow across the layer are much greater than the gradients in the flow direction The boundary layer thickness d is defined as the distance away from the surface where the velocity reaches 99% of the free-stream velocity 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 10 شهریور، ۱۳۹۰ The turbulent boundary layer 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 11 شهریور، ۱۳۹۰ Boundary layer structure 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 11 شهریور، ۱۳۹۰ Standard wall functions The experimental boundary layer profile can be used to calculate tw. However, this requires y+ for the cell adjacent to the wall to be calculated iteratively In order to save calculation time, the following explicit set of correlations is usually solved instead Here Up is the velocity in the center of the cell adjacent to the wall yp is the distance between the wall and the cell center kp is the turbulent kinetic energy in the cell center k is the von Karman constant (0.42 E is an empirical constant that depends on the roughness of the walls (9.8 for smooth surfaces 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 11 شهریور، ۱۳۹۰ Near-wall treatment - momentum equations The objective is to take the effects of the boundary layer correctly into account without having to use a mesh that is so fine that the flow pattern in the layer can be calculated explicitly Using the no-slip boundary condition at wall, velocities at the nodes at the wall equal those of the wall The shear stress in the cell adjacent to the wall is calculated using the correlations shown in the previous slide This allows the first grid point to be placed away from the wall, typically at 50 This approach is called the “standard wall function” approach The correlations shown in the previous slide are for steady state (“equilibrium”) flow conditions. Improvements, “non-equilibrium wall functions,” are available that can give improved predictions for flows with strong separation and large adverse pressure gradients لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 11 شهریور، ۱۳۹۰ Two-layer zonal model A disadvantage of the wall-function approach is that it relies on empirical correlations The two-layer zonal model does not. It is used for low-Re flows or flows with complex near-wall phenomena Zones distinguished by a wall-distance-based turbulent Reynolds number The flow pattern in the boundary layer is calculated explicitly Regular turbulence models are used in the turbulent core region Only k equation is solved in the viscosity-affected region e is computed using a correlation for the turbulent length scale Zoning is dynamic and solution adaptive 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 11 شهریور، ۱۳۹۰ Near-wall treatment - turbulence The turbulence structure in the boundary layer is highly anisotropic e and k require special treatment at the walls Furthermore, special turbulence models are available for the low Reynolds number region in the boundary layer These are aptly called “low Reynolds number” models This is still a very active area of research, and we will not discuss those here in detail لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 11 شهریور، ۱۳۹۰ Comparison of near-wall treatments 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 11 شهریور، ۱۳۹۰ Computational grid guidelines First grid point in log-law region Gradual expansion in cell size away from the wall Better to use stretched quad/hex cells for economy First grid point at y+ = 1 At least ten grid points within buffer and sublayers Better to use stretched quad/hex cells for economy 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 11 شهریور، ۱۳۹۰ Obtaining accurate solutions When very accurate (say 2%) drag, lift, or torque predictions are required, the boundary layer and flow separation require accurate modeling The following practices will improve prediction accuracy: Use boundary layer meshes consisting of quads, hexes, or prisms. Avoid using pyramid or tetrahedral cells immediately adjacent to the wall After converging the solution, use the surface integral reporting option to check if y+ is in the right range, and if not refine the grid using adaption. For best predictions use the two-layer zonal model and completely resolve the flow in the whole boundary layer 1 لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 11 شهریور، ۱۳۹۰ Summary The concept of the boundary layer was introduced Boundary layers require special treatment in the CFD model The influence of pressure gradient on boundary layer attachment showed that an adverse pressure gradient gives rise to flow separation For accurate drag, lift, and torque predictions, the boundary layer and flow separation need to be modeled accurately This requires the use of: A suitable grid. A suitable turbulence model. Higher order discretization. Deep convergence using the force to be predicted as a convergence monitor لینک به دیدگاه
M!Zare 48037 مالک اشتراک گذاری ارسال شده در 11 شهریور، ۱۳۹۰ Summary The concept of the boundary layer was introduced Boundary layers require special treatment in the CFD model The influence of pressure gradient on boundary layer attachment showed that an adverse pressure gradient gives rise to flow separation For accurate drag, lift, and torque predictions, the boundary layer and flow separation need to be modeled accurately This requires the use of A suitable grid A suitable turbulence model Higher order discretization Deep convergence using the force to be predicted as a convergence monitor لینک به دیدگاه
