آرشیو(قبل از مرتب سازی در تیر 91)
محمد جان زحمت کشیدند و لینک را درست کردند.
*http://www.noandishaan.com**
  • 4 هفته بعد...
  • پاسخ 760
Scott russell linkage
The Inventor
John Scott Russell was born in Glasgow in 1808. He was a Scottish naval engineer who built the Great Eastern (the largest ship built at that time) in collaboration with Isambard Kingdom Brunel, and made the discovery that gave birth to the modern study of solitons. He was made a Fellow of the Royal Society of Edinburgh (FRSE) and a Fellow of the Royal Society (FRS) of London. John Scott Russell is also remembered for a very useful linkage which carries his name, even though, by one of those quirks of historical misnaming, it is thought to have been invented by a certain William Fremantle in 1803.
The Scott Russell linkage is also called a half beam mechanism.
The Linkage
A Scott Russell linkage converts linear motion, to linear motion in a line roughly perpendicular to the input.
The half-beam mechanism is shown in the figure at left. A and D are fixed pivot points. The link CD is taken to be as long as is conveniently possible, as we want C to traverse a short horizontal path. In order that P be guided on a straight line, the length of link AB should be the mean proportional between the lengths CB and BP: that is, AB2 = CB x BP. Now as C moves backwards and forwards along a short straight horizontal path, the linkage makes point P move backwards and forwards along a short straight near-vertical path.
This mechanism was used on the locomotives of Wylam Colliery built by William Hedley, notably the Puffing Billy of 1813, which had vertical cylinders and drove the wheels through cranks. The engines on each side of the locomotive were 90° out of phase, to avoid dead spots, and the large half-beams above the engines had a shape and syncopated motion that was likened to that of a grasshopper’s legs, and so the engines were called ‘grasshoppers’. This name spread to the mechanism itself in later years.
The engineering design of locomotives improved over theyears and by the year 1830, the linkage straight-line motion finally disappeared. It lingered on for many years with stationary engines, especially those with vertical cylinders. It was thought for many years that horizontal cylinders would wear unevenly, a fear that turned out to be unwarranted. The main defect of the straight-line motions was their ungainly size and weight, especially for fast engines, compared to a compact slider mechanism.
Scott Rusell linkages are still used today in front wheel drive motor vehicles with solid rear axles to control lateral movement.
The Mathematics
There are several approaches to the mathematics of this problem. One is called ‘the sliding ladder problem’. A ladder leaning against a wall starts to slide, with the top of the ladder sliding down the wall, and the foot sliding out along the floor. The usual question is to find the locus of the centre of the ladder. As we shall see, this is precisely our problem here.
If the positions of the ladder are all drawn in, we obtain the first quadrant of the envelope of a curve called the astroid (pictured right). The quadrant of this interesting curve has equation
x2/3 + y2/3 = c2/3
Now, suppose the ladder (sliding segment) has length 1, and meets the x-axis in point (x, 0), and the y-axis in (0, y).
Clearly by the theorem of Pythagoras, x2 + y2 = 1.
The midpoint of the segment has coordinates (x', y') = (x/2, y/2), so the locus of the midpoint is the circle
x'2 + y'2 = 1/4.
In terms of our linkage mechanism, we see that this is precisely the situation we have: one end of the main link moving vertically, one end moving horizontally, and the centre mocing in an arc of a circle.
The Java Applet
The diagram at right shows the Scott Russell linkage constructed using JSP. I have chosen to use a 250 x 300 window, and segment lengths 80 (160 for PC).
You will notice that small horizontal movements of C give rise to linear movements of P – to a very good approximation. C and P are not programmed to lie on the given lines.
Try constructing your own program – you should be finding it easy by now! If you want to check my code, click here.
Bibliography
HOEKENS LINKAGE
The Inventor(s)
I have been unable to discover any detail of the so-called inventor of this linkage. The linkage belongs to a class of linkages known as Grashof crank-rockers. It may be that Hoekens’ (Hoeken’s?) linkage was discovered first and then generalized by Grashof, or perhaps Hoekens found that this example of the Grashof crank-rockers was particularly useful.
We do have some information about Franz Grashof. He was a German engineer who lived from 1826 to 1893. He was a professor of Applied Mechanics at the Technischen Hochschule Karlsruhe, and was one of the founding directors of Verein Deutscher Ingenieure (VDI) in 1855. He developed some early steam-flow formulas, and is remembered for the Grashof Number and the Grashof Condition. After his death, the Association of German Engineers (VDI) honored Grashof’s memory by instituting the Grashof Commemorative Medal as the highest distinction that the society could bestow for merit in the engineering skills.
We observe that Grashof lived in the time when linkages were being actively developed.
The Linkage
The Hoekens linkage is a four bar mechanism that converts rotational motion to approximate straight-line motion. The figure at right is an animated gif file which appears in Wikipedia (see reference below). As shown in the animation, good values for the lengths of the linkage segments are 1, 2 (blue), 2.5 and 2.5 (red). Hoekens_linkage_animated.gif
The Mathematics
Mathematical analysis of this linkage appears to be difficult. Numerical methods can be used to choose linkage lengths to optimize the straightness of the horizontal segment, or to optimize the constancy of the velocity along this segment. These do not occur for the same linkage lengths.
The Java Applet
The applet at right is easy to construct.
I chose the red segment to have length 50 pixels, the green segment 125 pixels, and the blue segment 2 x 125 = 250 pixels. The window is 330 x 370, but these measurements were chosen during the construction to fit the linkage.
My program required 20 lines. There is a sort of challenge here, to obtain the required result using a minimal number of commands!
Bibliography
سلام منم کتاب موتورهای دیزلی نوشته اد می رو می خونم واقعا کتاب خوبیه مخصوصا برای اونایی که می خوان در مورد موتور های دیزلی از پایه مطالعه کنند!
The Motor Car_ How it Works
David Carey, "The Motor Car (How it Works)"
Ladybird Books Ltd | 1965 | 52 pages | PDF | 13,1 MB
How it works informs and shows all the components of the working automobile. The line drawings are detailed and simple to understand
the motor car_ how it works
david carey, "the motor car (how it works)"
ladybird books ltd | 1965 | 52 pages | pdf | 13,1 mb
how it works informs and shows all the components of the working automobile. The line drawings are detailed and simple to understand
or
اگر ممکن فایل را جایی دیگه آپلود کن
فایل برداشته شده
ممنون
:ws49:
:ws49:
:ws49:
The CRC handbook of mechanical engineering / edited by Frank Kreith, Yogi Goswami. –
2nd ed.
p. cm. — (Mechanical engineering handbook series
Includes bibliographical references and index.
ISBN 0-8493-0866-6 )alk. paper)
1. Mechanical engineering—Handbooks, manuals, etc. I. Kreith, Frank. II. Goswami, D.
Yogi. III. Series.
:ws49:
دانلود مجله ماشین های بروز بهترینهای دنیا > سبک , سنگین , سرعتی , قدرتی و ...
دانلود مجله ماشین گلچین 21 مجله
/ French | 124 pages | PDF | 24.49 MB
/ French | PDF | 84 Pages | 15.48 Mb
nglish | PDF | 68 Pages | 21.6 Mb
English | PDF | 134 Pages | 34.4 Mb
English | 100 pages | True PDF | 14.30 Mb
Hot Rod - March 2010 * | 17.04MB
English | PDF | 132 Pages | 41.5 Mb دانلود ۲ مجله
84 Pages | 43.8 Mb
English | PDF | 116 Pages | 41.2 Mb
English | PDF | 132 Pages | 22.5 Mb
French | PDF | 188 Pages | 60.1 Mb
English | True PDF | 116 Pages | 18.44 Mb
French | PDF | 188 Pages | 51.6 Mb
English | True PDF | 108 Pages | RS & HF | 15.3 Mb
French | PDF | 148 Pages | 116.3 Mb
French | PDF | 132 Pages | 108.5 Mbگ
English | True PDF | 100 Pages | RS & HF | 19.4 Mb
English | True PDF | 100 Pages | RS & HF | 18.3 Mb
sh | True PDF | 100 Pages | RS & HF | 16.2 Mb
با عرض سلام به شما دوستان ارجمند .
طی ترم گذشته تحصیلی از سوی استاد درس سمینار و مدیریت محترم مدیرگروه کارشناسی ارشد ساخت و تولید موضوعی جهت تحقیق ارائه شد که به نظر با مهندسی مکانیک سنخیتی ندارد .
اما دوستانی که در واحد های صنعتی مشغول بکار میباشند با مطالعه ی این مقاله به نکات ظریفی که هدف ان بوده است پی خواهند برد :
مهندسی ارزش
مهندسی ارزش یک روش منسجم برای رسیدن به بالاترین ارزش به ازای هر واحد پولی که هزینه شده است می باشد ، در حالی که کیفیت ، ایمنی ، قابلیت اطمینان ، قابلیت نگهداری حفظ و یا ارتقاء یابد .
هدف این مقاله معرفی مفهوم مهندسی ارزش و روشهای توسعه داده شده در این زمینه است.
مهندسی ارزش فرآیندی است که به یک تیم پروژه کمک می کند تا در یک زمان کوتاه به بررسی و ارزیابی اهداف و عملکردهای پروژه و راه حل های گوناگونی در یک زمان محدود بپردازد.
با سلام به شما دوستان ارجمند
مقاله ی زیر گریزیست اجمالی به مبحث ( تبدیل موجک ) .
این مقاله طی ترم گذشته ی بعنوان تحقیقی مفصل مربوط به درس انالیز عددی پیشرفته ارائه گردید .
برای کسب اطلاعات بیشتر در این رابطه میتوانید به هلپ نرم افزار متلب مراجعه نمایید :
تبدیل فوریه ی یک سیگنال پایا با مولفه های بسامدی f1 تا fn با تبدیل فوریه سیگنال ناپایا که مولفه های بسامدی آنهم از f1 تا fn است ٬ یکی است .
تبدیل فوریه در تفکیک تریس لرزه ای به امواج سینوسی یا کسینوسی تشکیل دهنده ی آن بسیار موثر عمل میکند ٬ ولی متاسفانه پس از این تفکیک اطلاعات زمانی از بین میرود .
بدین معنی که وقتی به تبدیل فوریه ی یک سیگنال نگاه شود غیر ممکن است که بتوان گفت این مولفه ها در چه زمانی روی سیگنال مورد نظر قرار دارند . چون تریسهای لرزه ای ناپایا هستند ٬ به عبارت دیگر خواص بسامدی و فازی آنها متغیر با زمان است ٬ بنابراین نمیتوان از تبدیل فوریه برای تشخیص این خواص استفاده کرد ( پاپولیس ٬ 1962 و بریگام ٬ 1999 ) .
حال این سوال مطرح میشود که آیا میتوان برای رفع این مشکل سیگنال ناپایا را در بخش های کوچکتری به عنوان سیگنالهای پایا فرض کرد ؟
به عبارت دیگر آیا میتوان یک سیگنال ناپایا را به چند سیگنال پایا تقسیم نمود ؟
دانلود كتاب شيمي عمومي
نوشته : دكتر علي افضل صمدي
انتشارات : ني
قالب : PDF
حجم كتاب : 20MB
تعداد صفحات : 830
وب سايت نگارنده :
پست الكترونيك :
با سپاس فراوان از جناب آقاي دكتر صمدي كه متن كامل كتاب را در اختيار شبكه فيزيك هوپا قرار دادند.
دانلود نسخه كامل كتاب ( كليه فصول ) :
جهت دانلود روي دكمه مقابل كليك راست كرده و گزينه Save target as را انتخاب كنيد.
جهت سهولت دريافت فايل در ايران با سرعت پايين اينترنت ميتوانيد فصول كتاب را به شكل مجزا دانلود نماييد:
دانلود بخش يك و دو :
دانلود بخش سه و چهار :
دانلود بخش پنج ، شش و هفت :
دانلود بخش هشت و نه :
دانلود بخش ده و يازده :
دانلود بخش دوازده :
دانلود بخش سيزده و چهارده :
دوستان گرامی
کتاب فوق نوشته Joseph Riskin را میتوانید بصورت رایگان از وبسایت زیر دریافت نمایید.
و لینک مستقیم
دانلود کتابهای مکانیک ، طراحی و موضوعات مرتبط
ebook_-_pdf_-_software_engineering)_mit_press_-_how_to_design
-۱
-۲
-۳
Simple Guide to Understanding User Interface Design Rules
Designing with the Mind in Mind: Simple Guide to Understanding User Interface Design Rules
Morgan | 2010 | ISBN: 012375030X | 200 pages | PDF | 11 MB
دانلود
Designing Embedded Systems with PIC Microcontrollers, Second Edition: Principles and Applications
Newnes | 2009 | ISBN: 1856177505 | 750 pages | PDF | 42 MB
PIC microcontrollers are used worldwide in commercial and industrial devices. The 8-bit PIC which this book focuses on is a versatile work horse that completes many designs. An engineer working with applications that include a microcontroller will no doubt come across the PIC sooner rather than later. It is a must to have a working knowledge of this 8-bit technology.
This book takes the novice from introduction of embedded systems through to advanced development techniques for utilizing and optimizing the PIC family of microcontrollers in your device. To truly understand the PIC, assembly and C programming language must be understood. The author explains both with sample code and examples, and makes the transition from the former to the latter an easy one. This is a solid building block for future PIC endeavors.
New to the 2nd Edition:
*Include end of chapter questions/activities moving from introductory to advanced
*More worked examples
*Includes PowerPoint slides for instructors
*Includes all code snips on a companion web site for ease of use
*A survey of 16/32-bit PICs
*A project using ZigBee
*Covers both assembly and C programming languages, essential for optimizing the PIC
*Amazing breadth of coverage moving from introductory to advanced topics covering more and more complex microcontroller families
*Details MPLAB and other Microchip design tools
Download Links:
مهمان
