کتاب Teach Yourself Google SketchUp 8 in 10 Minutes
کتاب Teach Yourself Google SketchUp 8 in 10 Minutes یا همون آموزش اسکتچاپ 8 در 10 دقیقه کتاب خوب و جالبیه که با شکل و تصویر این نرم افزار رو آموزش داده و شامل فهرست زیر میشه:
Getting Started with SketchUp ..................................................5
Drawing Lines. ........................................................................7
Drawing Simple Figures . ..........................................................7
Pushing (or Pulling) for 3D. ......................................................9
Panning and Orbiting . ............................................................10
Rotating and Moving . ............................................................15
Painting . ..............................................................................17
Using the Component Libraries ..............................................18
Zooming. ..............................................................................19
Creating Guides and Dimension Indicators ..............................22
Lots of Cool Stuff Coming Up ................................................23
What SketchUp Is All About ....................................................29
Getting and Installing SketchUp ..............................................30
Starting SketchUp. ................................................................33
Understanding the Parts of SketchUp......................................36
Using the Orbit Tool . ............................................................37
Using the Pan Tool . ..............................................................39
Using the Zoom Tool . ............................................................40
Selecting a Work Template ....................................................42
Understanding SketchUp Axes ................................................44
Understanding Edges and Surfaces ........................................45
Drawing Edges . ....................................................................48
Inferring Edges . ....................................................................50
Getting Started......................................................................55
Drawing Lines........................................................................56
Drawing Multiline Shapes ......................................................57
Drawing Measured Lines ........................................................59
Drawing Rectangles. ..............................................................60
Drawing Circles. ....................................................................62
Drawing Polygons . ................................................................65
Setting the Number of Sides of Circles or Polygons..................67
Orienting Shapes . ................................................................69
Getting Information About Shapes ..........................................70
Saving Your Work . ................................................................72
Arcs, Freehand, and Text ........................................................73
Drawing Arcs . ......................................................................73
Drawing Measured Arcs..........................................................75
Drawing Arcs Tangent to Corners ............................................76
Drawing Multiple Tangent Arcs ................................................79
Setting the Number of Arc Segments ......................................80
Drawing Freehand . ................................................................82
Drawing Surfaces Freehand ....................................................83
Drawing Text . ........................................................................84
Annotating Objects with Text ..................................................86
Setting Text Properties ..........................................................88
Drawing 3D Text . ..................................................................91
Getting Started ......................................................................95
Pulling Objects into 3D ..........................................................96
Pushing Objects into 3D ........................................................98
Using Measured Push/Pull ..................................................100
Inferring Push/Pull ..............................................................101
Cutting Openings ................................................................103
Erasing Edges with the Eraser Tool........................................106
Selecting Edges and Surfaces with the Select Tool ................109
Copying Objects ..................................................................110
Moving Edges and Surfaces with the Move Tool ....................112
Drawing 3D by Subtracting Elements ....................................115
Getting Started....................................................................119
Using Sticky Geometry ........................................................120
Creating a Group ................................................................121
Creating Components ..........................................................125
Editing Components ............................................................127
Understanding the Difference Between Groups and Components......................................................129
Exploding a Component........................................................132
Managing Components ........................................................133
Using the Component Sampler ............................................135
Using the 3D Warehouse......................................................136
Painting ..............................................................................141
Using the Paint Tool ............................................................143
Selecting Materials ..............................................................145
Eliminating Automatic Shading..............................................146
Drawing in Solid Color ..........................................................148
Painting Multiple Surfaces at Once........................................149
Examining All Materials in Your Model ..................................151
Creating Materials ..............................................................152
Editing Materials..................................................................154
Replacing All of a Material in a Drawing ................................156
Sampling Existing Materials..................................................157
Undoing Changes and Canceling Operations ..........................160
Using Some New Tools ........................................................161
Rotating Objects . ................................................................161
Rotating Parts of Objects. ....................................................164
Locking the Rotate Tool’s Orientation ....................................168
Scaling 2D Objects . ............................................................171
Scaling 3D Objects . ............................................................172
Tapering Objects in 3D ........................................................175
Scaling from the Center of Objects........................................177
Setting Exact Scale. ............................................................178
Using the Follow-Me Tool ......................................................179
Getting Started....................................................................183
X-Raying Objects ..................................................................184
Offsetting Edges with the Offset Tool ....................................186
Selecting Edges to Offset ....................................................189
Creating Exact Offsets..........................................................192
Repeating Offsets on Other Surfaces ....................................194
Measuring Distances with the Tape Measure ........................195
Creating Guides with the Tape Measure Tool..........................198
Drawing Guides at Specific Offsets ......................................200
Deleting Guides ..................................................................204
Dimensioning Distances ......................................................206
Dimensioning Arcs . ............................................................208
Freezing Dimensions . ..........................................................209
Configuring Dimensioning Labels ..........................................211
Measuring Angles . ..............................................................214
Creating Guides at Specific Angles........................................217
Creating Cutaway Views of Your Model ..................................220
Reversing the Direction of a Section Cut ..............................222
این کتاب رو به صورت PDF از لینک زیر می تونید دانلود کنید:
