مقالات کنفرانس بین‌المللی خوردگی nace . 2009
a.namdar
در این تایپیک یکسری از مقالات منتشر شده در کنگره خوردگی NACE در سال 2009 قرار میدم.
Title: SINGLE PACK, HIGH PERFORMANCE, LOW VOC, FINISH
Author:Emmanuelle Schwob
Key Words: Single Pack, Finish, Durability, Welds, Polysiloxane, Maintenance
Title: BRISTLE BLASTING SURFACE PREPARATION METHOD FOR MAINTENANCE
Author:Neil Wilds
Key Words: Maintenance, surface preparation, power tool, bristle blast
Title: EVALUATION & PERFORMANCE OF CHEMICAL SURFACE TREATMENTS FOR MAINTENANCE
Author: Stuart Sharman
Key Words: Rust remover, surface preparation, maintenance, biodegradable
Title:Reliability on Coating Pull-Off Adhesion Strength Test
Author:Yun Ho Baek, Mong Kyu Chung, Seong Mo Son, Eun Ha Song, Chil Seok Shin and Kwang Ki Baek
Keywords : pull-off strength, curing time, thickness of the panel, adhesion test
Title: CONTROLLING THE COMPONENTS OF CALCAREOUS DEPOSIT TO PROTECT STEEL STRUCTURES FROM ALWC WITH DC AND PULSE CURRENT
Author: Khoi Tu and R.A. Cottis
Key words: ALWC, low water corrosion, calcareous deposit, endurance, cost effectiveness, environmentally-friendly, quality, DC, pulse current
Title: Heavy Duty Glass Flake Coatings for Arduous Anti-Corrosion SeNice
Author: Charles J Watkinson MICorr. MSOE. MIMI. MIRTE. MIPel
Keywords: Coatings. Fire Retardancy. Filler. glass flake. Heat Distortion Temperature.Moisture Vapour Transmission. MVT. Reinforcement. Epoxy. Vinyl Ester. Gas Diffusion Barrier. Barrier Pigment. Corrosion Protection. Anti-Corrosion. Ultra Violet Light Resistance. High Temperature Coating. Cathodic Disbondment. Atlas Test Cell. Cold Wall. Undercutting. Aspect Ratio. Silane. Pipe. Flow Lines. Chemical Resistance
Title:A BALLAST TANK COATING INSPECTION DATA MANAGEMENT SYSTEM
Author:JF Fletcher
Keywords: coating inspection, software, coating technical file, data logging, ballast tanks, paperless QA, PSPC, CTF, IMO
Title:Premature Coating Disbonding on Ships and Offshore Structures
Author:Chung-Seo Park, H.I. Lee, S.M. Son, M.K. Chung, K.K. Baek, E.S. Chung
Keywords: Intercoat adhesion failure, amine blush, FT-IR, epoxy/urethane coating system
Title:PROTECTIVE COATINGS OFFSHORE: INTRODUCING A RISK BASED MAINTENANCE MANAGEMENT SYSTEM
Author:Sten B. Axelsen ,Ole Øystein Knudsen ,Roy Johnsen
Keywords: Protective coatings, maintenance, corrosion control, risk
Title:PERFORMANCE OF MAINTENANCE COATINGS APPLIED ON RUSTY STEEL SURFACES
Author:Ole Øystein Knudsen, Ann Karin Kvernbråten, Astrid Bjørgum
Keywords: Organic coatings, maintenance, surface cleaning
Title:HOW NOT TO PERFORM A FAILURE ANALYSIS
Author:Randy Nixon, Mark Schilling
Keywords: isocyanate, polyol, polyurethane, carbon dioxide, hydrolysis
Title:OSMOTIC BLISTERING – COATINGS UNDER PRESSURE
Author:Mark S. Schilling
Keywords: osmotic blistering, osmotic pressure, water soluble salts, vapor pressure
Title: COATINGS FAILURES IN PLANTS AND INDUSTRIAL ENVIRONMENTS
Author:Oluwatoyin Ashiru and Mohammed Al-Sonidah
Keywords: Protective paintwork, coating selection, corrosion under insulation, coating failures, coating
Title: THE CUSTOMER MAY NOT ALWAYS BE RIGHT, HOWEVER, THEY ARE ALWAYS THE CUSTOMER
Author:Russell Spotten
Keywords: Epoxy, Novolac, Stochiometry
Title:Recoating Case History for a 32" Products Pipeline
Author:Jeffrey L. Didas
Keywords : recoating, pipeline
Title:ADVANCEMENTS IN HIGH PERFORMANCE ZINC EPOXY COATINGS
Author:Lars Thorslund Pedersen, Claus Weinell ,Pascal Verbiest, Jeroen Van Den Bosch
Key word:Zinc pigment, Zinc-alloy, Bismuth, Corrosion Protection, Rust Creep, Zinc Silicate
Title:Dueling Technical Experts
Author:Mark B. Dromgool
Key word:expert witness, litigation, advocacy, expert reports, evidence, cross-examination
Title:Strange but True Occurrences in Refineries
Author:Monica M. Chauviere,Mark S. Schilling
Key word:not available
Title:INFRARED SPECTROSCOPY AS A FAILURE ANALYSIS TOOL FOR COATINGS
Author:Dwight G. Weldon
Keyword:not available
ABSTRACT
Infrared spectroscopy is a very versatile tool for the investigation of coating failures. This paper will present a brief introduction to the theory of the infrared spectroscopy, followed by examples which will point out both strengths and weaknesses of the technique.
Title:DEVELOPMENT OF A LOW APPLICATION TEMPERATURE FBE COATING
Author:Dr. Jennifer K. Pratt ,Meghan L. Mallozzi
Keyword:fusion-bonded epoxy, FBE, pipecoating, low temperature application, low temperature cure, high strength steel, cathodic disbondment
Title:COATINGS USED IN CONJUCTION WITH CATHODIC PROTECTION – SHIELDING VS NON-SHIELDING PIPELINE COATINGS
Author:Richard Norsworthy
ABSTRACT
When using cathodic protection on coated pipelines, end users must consider the problems that exist if the coating disbonds (loses adhesion). Many in the pipeline industry assume cathodic protection will solve their external corrosion problems without truly understanding the relationship between the coating and cathodic protection. Cathodic protection (CP) current is very effective when it actually has a path to the pipe metal. Most external corrosion on pipelines is caused by disbonded coatings that shield CP, not lack of CP.
Title:PIPELINE INTEGRITY RESTORATION
Author:M. A. Saleem
Keyword:Non-Associated gas, Khuff gas, coatings, cathodic protection, integrity management, transition points, polymeric anode, and line travel application
Title:Performance of External Pipeline Coatings in Low Temperature Conditions
Author:Mark Yunovich ,Colin Scott, Robert Denzine
KeyWord: cathodic protection, overprotection, disbondment, arctic, low temperature, fusion bonded epoxy (FBE
Title: MECHANICAL AND ENVIRONMENTAL EVALUATION OF TWO COMMERCIAL INTERNAL COATINGS USED IN A 5-INCH DRILL PIPE
Author:Fengmei Song, Jim Feiger and Jim Lankford ,Junfeng Fang
Keyword: drill pipe, internal coating, corrosion, production, wear resistance
Title: DEVELOPMENT OF A NEW TWO-LAYER POLYETHYLENE COATING USING STATE OF THE ART ADHESIVE TECHNOLOGY
Author: Alfredo Andrenacci, Dennis Wong, Shiwei William Guan and Peter Mayes
Keywords: pipeline coating, adhesive, two-layer extruded polyethylene, three-layer extruded polyethylene
Title: Relevance of Cathodic Disbondment Test for Evaluating External Pipeline Coatings at Higher Temperatures
Author: Sankara Papavinasam and Alex Doiron
Keyword: not available
Abstract
This paper investigates the applicability of cathodic disbondment (CD) test at higher temperatures, i.e., up to 150C. This paper also presents different factors affecting applicability of the CD test at higher temperatures. It was found that CD Experiments are relevant for high-temperature coating evaluation up to 150C. Maintaining temperature of the experimental pipe section simulates conditions as those of hot pipes. Slow evaporation of water occurs. The rate of water evaporation decreases in the presence of soil – the extent of which depends on the type of soil. Conducting the experiments in an autoclave is not an adequate way to conduct high-temperature CD tests because it does not simulate the temperature differentials that occur under pipeline operating conditions. While conducting long-term experiments care should be exercised to avoid evaporation of electrolyte. Evaporation can be prevented or minimized by refluxing the electrolyte, replenishing the electrolyte, or by covering the experimental set up. The thickness and thermal conductivity of a pipeline coating affect how much heat is transmitted from a hot pipe section to the soil it is in contact with.
Title: External Corrosion Control of Northern Pipelines Influence of Construction Conditions on the Performance of Coatings
ABSTRACT
The design of coatings must be adequate to protect pipelines under long-term, severe environmental conditions, including the extreme climatic conditions that will apply in the North before the pipe is installed and operation begins. Practices and standardised methodologies for evaluating and qualifying pipeline coatings for application in northern pipelines are discussed. Results from laboratory and field experiments, carried out under the conditions to which coatings will be exposed during construction, are presented. Based on one-year laboratory experiments in which samples were exposed to temperatures as low as -45o C and three-year data from the field experiments, it is concluded that Canadian Standards Association (CSA) standards CSA Z662, CSA Z245.20 and CSA Z245.21 adequately cover evaluation of coatings for northern pipelines. However, in order to evaluate the effects of low temperatures, the specimens should be exposed for at least four months. Coatings qualified by CSA Z245.21 system B1 and B2 are less affected by exposure to low temperatures than those qualified by CSA Z245.21 system A1 and CSA Z245.20.
Title: EVALUATION OF A COAL TAR EPOXY COATING PERFORMANCE FOR PRESTRESSED CONCRETE CYLINDER PIPE OF THE GREAT MAN-MADE RIVER PROJECT (GMRP) PIPE LINES IN LIBYA
Author:Saad Arfan, Salah Elkoum
Keywords: coating systems, coal tar epoxy, coating qualification, coating service life, weathered and non-weathered samples.
Title:CORROSION OF 316 TI MOTOR-PUMP CASINGS IN DEEP WATER WELLS DUE TO WELDING DEFECTS
Author:Fawzi Al-Madani, Mohamed Azoumi, Ayad Omran, Salah Elkoum
Keywords: Stainless steels, Pitting corrosion, Welding, Heat affected zone, Sensitization.
Title:Alternative to the Use of Phosphonates in Cooling Water Systems
Author:Suresh Patel, Norman Hill,Jeffery Kramer
Key words: Phosphonates, Calcium Carbonate, Corrosion, Pilot Cooling Tower, Scale, Formulations and Cooling Water
Title:OPTIMIZATION OF COOLING SYSTEM PASSIVATION IN PETROCHEMICAL FACILITIES
Author:Fraser King ,Chris Friesen ,Bill Santos, Katherine Ikeda, Adam Smith, Bryan Stock and Alex Tomic
Keywords: cyclic voltammetry, EIS, carbon steel, cooling water, nitrite, phosphate, OCP
Title:EFFICACY OF ISOTHIAZOLONE BIOCIDE VERSUSSULFATE REDUCING BACTERIA
Author:Terry M. Williams
Keywords: isothiazolone, biocide, sulfate reducing bacteria, SRB, biofouling, sulfide
دانلود
Title: SUCCESSFUL CAUSTIC TREATMENT OF ELECTRIC UTILITY DRUM BOILERS
Author:K. Anthony Selby
Keywords: caustic treatment, electric utility boiler, cycle chemistry, phosphate chemistry, boiler,corrosion control
Title: Comparison Between Computer Model Predictions And Survey Data Of Interactions Between A FPSO And Subsea Cathodic Protection System
Author:R A Adey , J Baynham ,R Jacob
Keywords: Cathodic Protection, Boundary Element Modeling, Modeling, ICCP
Title:Failure Analysis on a Buried Flowline in Elevated Temperature and Acidic Soil
Author:Wei Chu , Muhdi Sujatmiko
Keywords: coal seam, soil acidification, elevated temperature, cathodic protection, liquid epoxy polymer coating
Title: Mooring chains - extent of drain from ICCP system and sacrificial CP system
Authors:Harald Osvoll, Svenn Magne Wigen, Lene Marita Green
Keywords; Current Drain, Mooring Chains, Impressed Current Cathodic Protection
Title:ISOLATION JOINT STRAY CURRENTS EXPERIMENTAL TESTING AND MODELLING
Author:S. M. Hesjevik وStatoilHydro
Keywords:Stray current corrosion, isolation joint, modeling, experimental testing
Title:ADVANCES IN CATHODIC PROTECTION MODELLING OF DEEP WELL CASINGS IN MULTI-LAYERED MEDIA Author:Andres B Peratta, John M W Baynham, and Robert A. Adey
Keywords:CP, Cathodic Protection, Modeling, Multi-Layer soil, Well Casing, Boundary Element Method
Title:CATHODIC PROTECTION POTENTIAL DISTRIBUTION SIMULATION FOR PIPELINE BURIED IN DISCONTINUOUS PERMAFROST
Author:Yanxia Du, Minxu Lu& Lei Zhang,Xueyuan Rd, Haidian District
Key words: discontinuous permafrost, cathodic protection, numerical simulation, potential, distribution, anode groundbed
Title:Harsh Environment – ICCP System for Large Marine Loading Facility
Authors:Richard E. Baxter , William E. Jamrok
keywords:not availbe
Abstract
An Impressed Current Cathodic Protection (ICCP) system utilizing local and remote anodes was installed for a
ship loading facility in Quebec, Canada, to protect the submerged H-piles, cylindrical piles and sheet piles
associated with the facility. This facility is subject to extreme ice loading conditions, tides, changing water
resistivity, ship traffic and dredging operations.
Title:INSTALLATION OF ROV-FRIENDLY CATHODIC PROTECTION SYSTEMS ON TWO DEEPWATER SUBSEA DEVELOPMENTS
Authors:D.K. Flanery and J.N. Britton ,K. Thompson ,P. Sandy
Keywords: cathodic protection life extension, deepwater, subsea production system, ROV, wet tree,jumper, manifold, flowline, anode pod, anode sled, aluminum anode
Title: CORROSION CONTROL OF ABOVE GROUND STORAGE TANK BOTTOM STEEL PLATES USING ALUMINUM MESH ANODE WITH NEWLY DEVELOPED BACKFILL
Author: Miki Funahashi, PE
Key words: above-ground storage tank, sacrificial anode, cathodic protection, aluminum mesh anode, passive film, backfill material, high pH
دانلود
Title: QUALIFICATION OF LEAN DUPLEX GRADE LDX 2101 (UNS32101) FOR CARCASS MATERIALIN FLEXIBLE PIPES
Authors:Jonas Gudme ,Torben Steen Nielsen
Key Words: flexible pipe, carcass, lean duplex stainless steel, autoclave testing, acceptance criteria
Title:UNS S33207 – A NEW HYPER DUPLEX STAINLESS STEEL FOR UMBILICALS
Authors:U.H. Kivisäkk, J. Eidhagen and A. Juhlin
Keywords: UNS S33207, duplex stainless steels, umbilical, crevice corrosion, pitting
Title: DEVELOPMENT OF SPRING AND FASTENER CHARACTERISTICS FOR ALLOY 725 FOR OIL AND GAS APPLICATIONS
Authors:Rashmi B. Bhavsar, P.E. Seth Silverman ,Jan Edwards
Keywords: 725, nickel-based, springs, completion equipment, pump shafts, fasteners, and service tools
Title:TITANIUM ALLOYS FOR OIL AND GAS SERVICE: A REVIEW
Author:R.D. Kane , B. Craig A. Venkatesh
Keywords: Titanium, HPHT, deep wells, metallurgy, corrosion, stress corrosion cracking, hydrogen sulfide, acid, completion fluids
Title:LIMITS OF USE OF LOW ALLOY AND STAINLESS STEELS IN UPSTREAM SOUR ENVIRONMENTS
Author:Thierry Cassagne, Gregory Moulié ,Claude Duret
Keywords: Low alloy steels, stainless steels, H2S, sulphide stress cracking, stress corrosion cracking, ISO 15156
Title:HIGH STRENGTH MODIFIED MARTENSITIC STAINLESS STEEL PRODUCTION TUBING FOR SOUR WELLS
Author:Ardjan Kopliku and Matthew Tabinor ,Jeremy Ryder and Phil Dent
Keywords: sulfide stress cracking, pitting, crevice corrosion, specified minimum yield strength, modified martensitic stainless steels
Title: Application Limits for 110ksi Strength Grade Super 13Cr steel in CO2 Environments Containing Small Amounts of H2S
Authors:Hideki Takabe , Masakatsu Ueda ,John William Martin
Key words: super 13Cr steel, super martensitic stainless steel, SSC, SCC, H2S
Title:SOUR SERVICE LIMITS OF 13% Cr AND SUPER 13% Cr STAINLESS STEELS FOR OCTG: EFFECT OF ENVIRONMENTAL FACTORS
Author:Hervé MARCHEBOIS, Hafida EL ALAMI , Jean LEYER, Arnaud GATEAUD
Keywords: Martensitic stainless steel, 13% Cr, Super martensitic stainless steel, Super 13% Cr, Sulfide Stress Cracking (SSC), Stress Corrosion Cracking (SCC), electrochemistry, fitness-for-purpose (FFP), pH, hydrogen sulfide (H2S); chloride, passivity
Tiltle: INTERPRETATION OF THE BEHAVIOR OF CARBIDE PRCIPITATION IN HEAT AFFECTED ZONE OF SUPERMARTENSITIC STAINLESS STEEL USING STRAIN AGING PHENOMENA
Author:Yukio Miyata and Mitsuo Kimura,Haruo Nakamichi
Keywords: supermartensitic stainless steel (SMSS), intergranular stress corrosion cracking (IGSCC), sensitization, stress corrosion cracking (SCC), linepipe, girth welding, heat affected zone (HAZ), carbide, chromium depletion, strain aging, aging index
دانلود
Title: LOCAL ELECTROCHEMISTRY AND SCANNING PROBE MICROSCOPY TECHNIQUES TO CLARIFY INTERGRANULAR CRACKING PHENOMENA IN WELDABLE MARTENSITIC STAINLESS STEELS
Author:Jens Maier, Brian Kinsella, Stuart Bailey, Thomas Becker,Thomas L. Ladwein
Keyword:WMSS, IGSCC, EPR, Micro-electrochemistry, AFM
ٰTitle:EFFECT OF PWHT ON ELECTROCHEMICAL BEHAVIOR OF LOW C – 13%Cr WELDED JOINTS WITH THE USE OF A SOLUTION FLOW TYPE MICRO-DROPLET CELL
Author:Shuji HASHIZUME,T. Nakayama, M. Sakairi and K. Fushimi
keyword:Martensitic stainless steel, Weld joints, PWHT, SCC, Electrochemical behavior, Micro-drop cell
Title:DESIGN OF PIPELINES SUBJECT TO LATERAL BUCKLING TO RESIST CORROSION FATIGUE
Author:R.J. Pargeter and D.P. Baxter
Keywords: Fatigue, Corrosion, Lateral buckling, Pipeline, Girth weld, Sour, Seawater, Inhibitor, Fracture toughness
Title:Limits of Use for Coiled Tubing in Sour Service
Author:K. E. Szklarz ,Bernie Luft and Tomas Padron
key words:sulfide stress cracking, SSC, hydrogen-induced cracking, HIC, coiled tubing, fatigue, bending, testing, specifications
Title:NEAR NEUTRAL SCC PROPERTIES OF GRADE X80 LINEPIPE
Author:Tomohiko Omura ,Hisashi Amaya ,Hitoshi Asahi and Mitsuru Sawamura ,Mitsuo Kimura,Nobuyuki Ishikawa
Keyword:stress corrosion cracking, SCC, linepipe, hydrogen
Title:CORROSION ASSESSMENT OF HIGH STRENGTH CARBON STEEL GRADES P-110, Q-125, 140 AND 150 FOR H2S CONTAINING PRODUCING WELL ENVIRONMENTS
Author:Roberto Morana ,Perry Ian Nice
Key words: high strength steels, OCTG, production casing, corrosion, H2S, sulfide stress cracking, environmental cracking
Title:NACE TM0177 METHOD A UNIAXIAL TENSILE TESTING: LEARNINGS FROM INVESTIGATIONS ON TEST PROCEDURE
Authors:Hervé MARCHEBOIS, Nicolas DULCY, E. Paul CERNOCKY ,Chris DESADIER, Bruce URBAND,Frédéric LEGAY
Keywords: NACE TM0177 Method A, Uniaxial Tensile test, applied stress, bending, machining, polishing, storage, test procedure
Title:IMPROVED UNDERSTANDING OF TEST VARIABLES IN THE NACE TENSILE TEST
Authors:C. Bosch, E. Wanzenberg and A. Kulgemeyer ,J. Leyer and B. Orlans-Joliet ,C. Linne
Keywords: NACE TM0177 Method A, constant load, proof-ring, stress, stress release, specimen bending
Title:The Introduction of KIAPPLIED to TM0177 Method D (DCB) and Use of “Offspec” Results
Authors:K. E. Szklarz
Keywords: sulfide stress cracking, DCB, SSC, TM0177, testing, methodology, KIAPPLIED
