warnings
amirinice
:ws21:کسی میدونه این خطاها مال چیه؟ جطور برطرفشون کنم؟
Path based tracking is defined in contact pair (assembly_s_surf-30,assembly_surface-1_m_surf-30). Path based tracking cannot be used with analytical rigid master surfaces, the state based tracking algorithm will be used instead.
For *tie pair (assembly_s_surf-32-assembly_m_surf-32), not all the nodes that have been adjusted were printed. Specify *preprint,model=yes for complete printout.
Solver problem. Zero pivot when processing D.O.F. 1 at one or more of the internal nodes of 3 elements. The elements have been identified in element set WarnElemSolvProbZeroPiv_1_1_1_1_1.
با تشکر
  • 4 ماه بعد...
با تشکر
نوع کاتکتی که تعریف کردید با مدل " انالیتیکال ریجید " همخوانی ندارد.
نوع مدل رو اصلاح کننید.
