Peyman 16150 ارسال شده در 25 تیر، 2010 Electron Beam WeldingElectron beam welding (EBW) is a welding process which produces coalescence of metals with the heat obtained from a concentrated beam composed primarily of high-velocity electrons impinging upon the surfaces to be joined. Heat is generated in the workpiece as it is bombarded by a dense stream of high-velocity electrons. Virtually all of the kinetic energy-the energy of motion-of the electrons is transformed into heat upon impact.The electron beam welding process had its inception in the 1950s in the nuclear field. There were many requirements to weld refractory and reactive metals. These metals, because of their affinity for oxygen and nitrogen of the air, are very difficult to weld.The original work was done in a high vacuum. The process utilized an electron gun similar to that used in an X-ray tube. In an X-ray tube the beam of electrons is focused on a target of either tungsten or molybdenum which gives off X-rays. The target becomes extremely hot and must be water-cooled. In welding, the target is the base metal which absorbs the heat to bring it to the molten stage. In electron beam welding, X-rays may be produced if the electrical potential is sufficiently high.As developments continued, two basic designs evolved: (1) the low-voltage electron beam system, which uses accelerating voltages in 30,000 volts or (30 kV) to 60,000-volt (60 kV) range and (2) the high-voltage system with accelerating voltages in the 100,000- volt (100 kV) range. The higher voltage system emits more X-rays than the lower voltage system.In both systems, the electron gun and the work piece are housed in a vacuum chamber. There are three basic components in an electron beam-welding machine. These are (1) the electron beam gun, (2) the power supply with controls, and (3) a vacuum work chamber with work-handling equipment. The electron beam gun emits electrons, accelerates the beam of electrons, and focuses it on the work piece.Recent advances in equipment allow the work chamber to operate at a medium vacuum or pressure. In this system, the vacuum in the work chamber is not as high. It is sometimes called a "soft" vacuum. This vacuum range allowed the same contamination that would be obtained in atmosphere of 99.995% argon. Mechanical pumps can produce vacuums to the medium pressure level.One of the major advantages of electron beam welding is its tremendous penetration. This occurs when the highly accelerated electron hits the base metal. It will penetrate slightly below the surface and at that point release the bulk of its kinetic energy which turns to heat energy. The addition of the heat brings about a substantial temperature increase at the point of impact. The succession of electrons striking the same place causes melting and then evaporation of the base metal. This creates metal vapors but the electron beam travels through the vapor much easier than solid metal. This causes the beam to penetrate deeper into the base metal. The width of the penetration pattern is extremely narrow. The depth-to-width can exceed a ratio of 20 to 1. As the power density is increased penetration is increased. 2
Peyman 16150 مالک ارسال شده در 25 تیر، 2010 The heat input of electron beam welding is controlled by four variables:(1) the number of electrons per second hitting the work piece or beam current,(2) the electron speed at the moment of impact, the accelerating potential,(3) the diameter of the beam at or within the work-piece, the beam spot size, and(4) the speed of travel or the welding speed.The first two variables, beam current and accelerating potential, are used in establishing welding parameters. The third factor, the beam spot size, is related to the focus of the beam, and the fourth factor is also part of the procedure.Since the electron beam has tremendous penetrating characteristics, with the lower heat input, the heat-affected zone is much smaller than that of any arc welding process. In addition, because of the almost parallel sides of the weld nugget, distortion is greatly minimized. The cooling rate is much higher and for many metals this is advantageous; however, for high-carbon steel this is a disadvantage and cracking may occur.The weld joint details for electron beam welding must be selected with care. In high vacuum chamber welding special techniques must be used to properly align the electron beam with the joint. Welds are extremely narrow and therefore preparation for welding must be extremely accurate.Filler metal is not used in electron beam welding; however, when welding mild steel highly deoxidized filler metal is sometimes used. This helps deoxidize the molten metal and produce dense welds.Almost all metals can be welded with the electron beam welding process. The metals that are most often welded are the super alloys, the refractory metals, the reactive metals, and the stainless steels. Many combinations of dissimilar metals can also be welded.One of the disadvantages of the electron beam process is its high capital cost. The price of the equipment is very high and it is expensive to operate due to the need for vacuum pumps. In addition, fit up must be precise and locating the parts with respect to the beam must be perfect برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام 2
rahele_s 6472 ارسال شده در 9 مرداد، 2010 اصول فرآيند جوشكاري با پرتو الكتروني فرآيند جوشكاري با پرتو الكتروني يك فرآيند اتصال ذوبي است كه در طي آن قطعه كار توسط جرياني متراكم از الكترون هاي داراي سرعت بالا بمباران شده و كل انرژي جنبشي الكترون ها،در اثر برخورد با قطعه كار به حرارت تبديل ميشود. اين حرارت موجب ذوب لبه هاي قطعات واتصال دو قطعه پس از انجماد مي شود. اين جوشكاري معمولا در يك محفظه خلا با استفاده از يك سيستم توليد و تمركز پرتو الكتروني انجام ميشود. متغيرهاي فرآيند انرژي ورودي به قطعه كار ولتاژ شتاب دهنده چگالي توان جريان پرتو فاصله بين كاتد و آند سرعت جوشكاري فلز پر كننده انرژي ورودي به قطعه كار Energy input(H.I.P)[j/in] E.I/s P/s ولتاژ شتاب دادن پرتو جريان پرتو قدرت پرتو سرعت جوشكاري ولتاژ شتاب دهنده با افزايش ولتاژ شتاب دهنده نفوذ جوش افزايش مي يابد. چگالی توان با افزايش ولتاژ وكاهش قطر پرتو ،چگالي توان افزايش مي يابد. مقدار حرارت توليد شده در نقطه جوشكاري تابع چگالي توان است. افزايش بيش از حد چگالي توان سبب بخار شدن فلزات مي شود. جريان پرتو با افزايش جريان پرتو نفوذ جوش افزايش مي يابد. شدت جريان با توجه به ولتاژ ورودي كه با شدت پرتو ارتباط دارد تغيير مي كند. فاصله بين آند وكاتد توان وشدت جريان پرتو در سطح قطعه كار مي تواند با تغيير فاصله كاتد وآند تغيير يابد سرعت جوشكاري چنانچه سرعت جوشكاري افزايش يابد،پهناي گرده و همچنين نفوذ جوش كاهش مي يابد. فلز پر كننده محيط جوشكاري جوشكاري در خلا بالا جوشكاري در خلا متوسط جوشكاري بدون استفاده از خلا تجهيزات فرآيند ولتاژ بالا ولتاژ پايين تجهيزات افزودن سيم جوش. :flowerysmile: 3
rahele_s 6472 ارسال شده در 13 مرداد، 2010 اجزا ماشين جوشكاري پرتو الكتروني يك تفنگ الكتروني كه پرتو كنترل شده الكتروني توليد ميكند يك محفظه خلا با تجهيزات و پمپ هاي مربوطه يك دستگاه كه پرتو را در امتداد خط اتصالحركت مي دهد يا قطعه كار رازير تفنگ الكتروني جابه جا مينمايد تجهيزات ولتاژ بالا ستون ديد الكترون ستون ديد الكترون شامل تفنگ الكتروني ،چشمي الكترون و سيستم ديد ميباشد. تفنگ الكتروني خود شتاب دهنده است. الكترونها از فيلمان تنگستن حرارتي يا كاتد تابش مي يابند وبه صورت الكتروستاتيك توسط يك شبكه انحراف دهنده،به پرتو تبديل ميشود و توسط آند شتاب مي يابند. آند و ديگر اجزاي زير آن شامل قطعه كاردر پتانسيل زمين هستند.ولتاژ كاتد تا 150000ولت قابل تغيير است.بنابراين يك ولتاژ شتاب دهنده مثبت براي الكترون ها توليد مي كند.جريان پرتو وابسته به ولتاژشتاب دهنده با كنترل خروجي ولتاژمورد نياز براي شبكه شتاب دهنده كنترل مي شود. منبع قدرت منبع قدرت با ولتاژ بالا در يك كابين جدا قرار دارد،اما كنترل ها در ايستگاه اپراتور قرار دارند. ولتاژ خطي در حالت عادي 440 ولت،سه فاز و 60 سيكل است،اما ولتاژ متناوب 220 ولت نيز مي تواند استفاده گردد. محفظه كار جداره محفظه كار معمولا به منظور تميز بودن و حداقل بودن عبور گاز از جداره آن از فولادهاي زنگ نزن ساخته مي شود ودر قسمت هاي از آن از سرب استفاده مي شود تا از عبور پرتو ايكس جلوگيري شود. يك پنجره با شيشه سربي در جلوي محفظه در منطقه ديد اپراتورويك لامپ فلورسنت دروني براي روشن كردن قرار داده ميشود. ستون تفنگ الكتروني معمولا در مركز محفظه قرار مي گيرد ولي مي تواند در يك انتها قرار گيرد.در ماشين مي توان يك ميز كار قرار داد كه به صورت دستي يا اتوماتيك در جهت هاي x&y حركت نمايد. تجهيزات ولتاژ پايين واژه ولتاژ پايين يك واژه نسبي است و معمولا براي تجهيزاتي كه در ولتاژ كمتر از60000ولت كار مي كنند،به كار ميرود. تفنگ الكتروني در داخل محفظه قرار داده ميشود و مي تواند در طول محورها حركت كند وديواره فولادي محفظه براي ممانعت از تابش پرتوكافي است. تجهيزات افزودن سيم جوش تجهيزات اضافه كردن سيم جوش يا شبيه فرايند سيستم تغذيه سيم جوش در فرايند جوشكاري قوس تنگستن ساخته ميشود يا اينكه به طور خاص جهت محفظه خلا طراحي ميگردد. قطر سيم جوش عموما كوچك و 0.02 اينچ يا كمتر است. سيستم تغذيه سيم بايد قابليت تغذيه يكنواخت سيمهاي با قطر كوچك را داشته باشد تا سيم را به طرف لبهها وحوضچه مذاب كوچك هدايت نمايد. نكات تكنيكي فرآيند جوشكاري با پرتو الكتروني الكترون داراي بار منفي است و بر اثر برخورد به قطعه ، بار منفي به نمونه انتقال مييابد. اين بار منفي در قسمتهاي مختلف دستگاه و نمونه ميتواند باعث اثر دافعه بر پرتو شود.براي جلوگيري از اين مشكل، نمونه و دستگاهها به اتصال زمين وصل ميشوند.مسئله ديگر اثرات مغناطيسي است كه بايد كنترل شوند و قطعه از مغناطيس خالي شود تا موجب انحراف پرتو نگردد. :flowerysmile: 3
pesare shad 1097 ارسال شده در 4 شهریور، 2010 راحله عزیز سلام گلم، جوشکاری بیش از 120 متد و روش مختلف داره که بیان اونها همه در یک تاپیک امکان داره ولی دیگه قابل استفاده برای علاقه مندان نیست ویا سخت میشه و خارج از حوصله. پس با اجازتون من تاپیکهای روشهای جوشکاری های مختلف رو ایجاد کردم. شاد باشی و موفق:ws2: 3
pesare shad 1097 ارسال شده در 4 شهریور، 2010 پیمان جان سلام داداش مطلب شما با مطلب تاپیک زیر به یک چیز اشاره داره،بهتر نیست ادغام بشه؟ ببخشید ها:w410: انواع جوشکاری 2
