Saye Noori 10314 ارسال شده در 5 مهر، 2013 ACTIVE CONTROL OF WIND-INDUCED BUILDING VIBRATION USING A LINEAR COUPLING STRATEGY HASHEMI S.M.GOLNARAGHI M.F Department of Aerospace Engineering, Ryerson University, Toronto (ON), Canada M5B 2K3 ABSTRACT The active control of building vibration is addressed. The aeroelastic lumped mass model of a building is designed to be used as the test bed for the active control system. The five stories lumped parameter model was modeled as a cantilever beam exhibiting planar vibration. A Linear Coupling Control (LCC) strategy was implemented to eliminate the vibrations. An active (moving) mass damper (AMD) was first designed and experimentally implemented to control the first mode vibration of the system. An alternative pendulum control system was then designed and implemented. The proposed pendulum, having three times smaller mass than the AMD, was found to be more effective in reducing the building vibrations Keywords: vibrations, active vibration control, aeroelastic model, linear compling ....... 3
