M!Zare 48040 ارسال شده در 26 تیر، 2013 درود...باز هم تالار مکانیک و یک مسابقه جدید... بدین صورت که یک تصویری قرار داده میشه و دوستان در مورد علت آن توضیح میدهند....حتی میشه نظر بقیه رو هم به چالش کشید و از میان آنها جامع ترین پاسخ به عنوان برگزیده انتخاب میشه... نظرتون در مورد تصویر زیر و علت وقوع آن چیست؟ 7
GBG10 2039 ارسال شده در 26 تیر، 2013 شاید احتمالا چون هوای اطراف کوه بخاطر مجاورت با برف و یخ کوه سرد هست، کاهش دما و تراکم بخار هوا رخ داده در اون ناحیه، 4
alimec 23102 ارسال شده در 26 تیر، 2013 درود و لذت بردم امتیاز نه مدال میخوام: Photo taken by Mark J. Madigan - Walsenburg, Colorado - May 20, 2003 Lenticular clouds, technically known as altocumulus standing lenticularis, are stationary lens-shaped clouds that form at high altitudes, normally aligned at right-angles to the wind direction. Where stable moist air flows over a mountain or a range of mountains, a series of large-scale standing waves may form on the downwind side. Lenticular clouds sometimes form at the crests of these waves. Under certain conditions, long strings of lenticular clouds can form, creating a formation known as a wave cloud. Power pilots tend to avoid flying near lenticular clouds because of the turbulence of the rotor systems that accompany them, but sailplane pilots actively seek them out. This is because the systems of atmospheric standing waves that cause "lennies" (as they are sometimes familiarly called) also involve large vertical air movements, and the precise location of the rising air mass is fairly easy to predict from the orientation of the clouds. "Wave lift" of this kind is often very smooth and strong, and enables gliders to soar to remarkable altitudes and great distances. The current gliding world records for both distance (over 3,000km) and altitude (14,938m) were set using such lift. Lenticular clouds have been mistaken for UFOs(or "visual cover" for UFOs) because these clouds have a characteristic lens appearance and smooth saucer-like shape. برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام 4
M!Zare 48040 مالک ارسال شده در 26 تیر، 2013 درود...امتیاز منفی بهتون بدم؟ میخوام قدرت تحلیل خودتون رو نشون بدید....و اینکه برداشت خودتون رو به زبان فارسی سلیس بفرمایید درود و لذت بردم امتیاز نه مدال میخوام: Photo taken by Mark J. Madigan - Walsenburg, Colorado - May 20, 2003 Lenticular clouds, technically known as altocumulus standing lenticularis, are stationary lens-shaped clouds that form at high altitudes, normally aligned at right-angles to the wind direction. Where stable moist air flows over a mountain or a range of mountains, a series of large-scale standing waves may form on the downwind side. Lenticular clouds sometimes form at the crests of these waves. Under certain conditions, long strings of lenticular clouds can form, creating a formation known as a wave cloud. Power pilots tend to avoid flying near lenticular clouds because of the turbulence of the rotor systems that accompany them, but sailplane pilots actively seek them out. This is because the systems of atmospheric standing waves that cause "lennies" (as they are sometimes familiarly called) also involve large vertical air movements, and the precise location of the rising air mass is fairly easy to predict from the orientation of the clouds. "Wave lift" of this kind is often very smooth and strong, and enables gliders to soar to remarkable altitudes and great distances. The current gliding world records for both distance (over 3,000km) and altitude (14,938m) were set using such lift. Lenticular clouds have been mistaken for UFOs(or "visual cover" for UFOs) because these clouds have a characteristic lens appearance and smooth saucer-like shape. برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام 3
alimec 23102 ارسال شده در 26 تیر، 2013 درود...امتیاز منفی بهتون بدم؟ میخوام قدرت تحلیل خودتون رو نشون بدید....و اینکه برداشت خودتون رو به زبان فارسی سلیس بفرمایید همون امتیاز + هم خوبه حالا:5c6ipag2mnshmsf5ju3 برداشت من سفینه ی فضایی هست 3
M!Zare 48040 مالک ارسال شده در 26 تیر، 2013 همون امتیاز + هم خوبه حالا:5c6ipag2mnshmsf5ju3برداشت من سفینه ی فضایی هست کامل نیست...نظر بعدی 1
