دانلود مقالات isi در زمینه انرژی
Clarifying the Butler–Volmer equation and related approximations for
calculating activation losses in solid oxide fuel cell models
D.A. Noren , M.A. Hoffman
This paper shows the importance of including the activation losses in a model designed to accurately predict the voltage–current relationship
of a modern solid oxide fuel cell. The governing equation for voltage drop due to activation losses, the Butler–Volmer equation, is discussed
and the derivation and applicability of several approximations is investigated. Finally, the assumptions required to combine the separate anode
and cathode activation loss calculations into a single-term equation are clarified.
سلام ممنون از مریم خانوم واسه تاپیکشون و لینکهای که در اختیارم قرار دادن تا براتون تو این تاپیک قرار بدم
مقاله اول
Performance characteristics of a MW-class SOFC/GT hybrid system based on a commercially available gas turbine
  • برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید.
    , REemail.gif,
مقاله دوم
Solid oxide fuel cell/gas turbine trigeneration system for marine applications
مقاله سوم
Combined solid oxide fuel cell and gas turbine systems for efficient power and heat generation
مقاله ی چهارم
[h=1]A consortium approach to commercialized Westinghouse solid oxide fuel cell technology[/h]
مقاله پنجم
[h=1]Thermoeconomic modeling and parametric study of hybrid SOFC–gas turbine–steam turbine power plants ranging from 1.5 to 10 MWe[/h]
مقاله ی ششم
Reducing the manufacturing cost of tubular solid oxide fuel cell technology
مقاله هفتم
Exergy analysis of an integrated solid oxide fuel cell and organic Rankine cycle for cooling, heating and power production
  • Fahad A. Al-Sulaimana, REcor.gif, REemail.gif,
  • Ibrahim Dincerb, REemail.gif,
  • Feridun Hamdullahpurc,
روی دانلود کلیک کنید
مقاله هشتم
[h=1]On the intrinsic transient capability and limitations of solid oxide fuel cell systems[/h]
  • Fabian MuellerREcor.gif, REemail.gif,
  • Faryar Jabbari REemail.gif,
مقاله ی نهم
[h=1]A review of integration strategies for solid oxide fuel cells[/h]
    , REemail.gif,
    , REemail.gif,
    , REemail.gif,
مقاله دهم
[h=1]Thermo-economic modeling of an indirectly coupled solid oxide fuel cell/gas turbine hybrid power plant[/h]
    , REemail.gif, REemail.gif,
مقاله یازدهم
[h=1]Review of the micro-tubular solid oxide fuel cell: Part I. Stack design issues and research activities[/h]
  • V. Lawlora, b, REcor.gif, REemail.gif,
  • S. Griessera,
  • G. Buchingerd,
  • A.G. Olabib,
  • S. Cordinere,
  • D. Meissnera, c
مقاله دوازدهم
[h=1]Recent advances in fuel cell technology and its applications[/h]
این یه مقاله ی دیگه که واستون قرار میدم
Control strategies for single-phase grid integration of small-scale renewable energy sources: A review
نویسنده:
Mohammad Monfared; Saeed Golestan
مقاله ی
[h=1]Thermodynamic modeling of direct internal reforming solid oxide fuel cells operating with syngas[/h]C. Ozgur Colpana, REemail.gif,
Ibrahim Dincerb, REcor.gif, REemail.gif,
مقاله ی
سایت اصلی فعلا" مشکل داره و بعدا" باز میشه واسه همین خود مقاله رو واستون میذارم
موفق باشید:icon_gol:
Seawater desalination driven by renewable energies: a review
  • Departamento Física Fundamental y Experimental, Universidad de La Laguna, 38205 La Laguna (Tenerife), Canary Islands, Spain Tel. +34-922-318303. Fax: +34-922- 318228
Solar desalination with a humidification-dehumidification cycle: performance of the unit
    , REemail.gif,
Abstract
The closed air cycle humidification-dehumidification process was used for water desalination using solar energy. The circulated air by natural or forced convection was heated and humidified by the hot water obtained either from a flat plate solar collector or from an electrical heater. The latent heat of condensation was recovered in the condenser to preheat the saline feed water. Two units of different sizes were constructed from different materials. The productivity of these units was found to be much higher than those of the single-basin stills. Moreover, these units were capable of producing a large quantity of saline warm water for domestic uses other than drinking. No significant improvement in the performance of the desalination units was achieved using forced air circulation at high temperatures. While at lower temperatures, a larger effect was noticed. This can be related to the low heat and mass transfer coefficients at low temperatures and to the non-linear increase in the water vapor pressure with temperature.
Keywords
  • Solar desalination;
  • Humidification-dehumidification cycle
References
    • [1]
    • M.A. Malik, G.N. Tiwari, A. Kumar, M.S. Sohda
    • Solar Distillation (5th ed.)Pergamon Press, Oxford (1982)
    • [sD-008]
    • [2]
    • M.M. Farid, F. Hamad
    • Renewable Energ, 3 (1) (1993), p. 75
    • [sD-008]
    • [3]
    • R.A. Akhtamov, B.M. Achilov, O.S. Kamilov, S. Kakharov
    • Geliotekhnika, 14 (4) (1978), p. 51
    • [sD-008]
    • [4]
    • G.N. Tiwari, N. Madhuri, H.P. Garg
    • Energy Conver. Mgmt., 25 (3) (1985), p. 315
Development of intermediate-temperature solid oxide fuel cells for direct utilization of hydrocarbon fuels
C. Lu, S. An
Solid State Ionics 175 (2004) 47–50
Effects of thermal cycling and thermal aging on the hermeticity and strength of silver–copper oxide air-brazed seals
K. Scott Weil,Christopher A. Coyle
Journal of Power Sources 152 (2005) 97–104
