.Yaprak 15748 ارسال شده در 23 آذر، 2012 The A to Z of Correct English .Common errors in English- Quick solutions to everyday spelling, punctuation and grammar problems -able/-ible Adjectives ending in -able or -ible can be difficult to spell because both endings sound identical. You’ll always need to be on guard with these words and check each word individually when you are in doubt, but here are some useful : guidelines i) Generally use -able when the : companion word ends in -ation abominable, abomination irritable, irritation ii) Generally use -ible when the : companion word ends in -ion comprehensible, comprehension digestible, digestion iii) Use -able after hard c and hard g: (practicable (c sounds like k (navigable (hard g iv) Use -ible after soft c and soft g: (forcible (c sounds like s (legible (g sounds like j See also ADDING ENDINGS (ii); SOFT C AND .SOFT G 6
.Yaprak 15748 مالک ارسال شده در 23 آذر، 2012 ?accept or except .We ACCEPT your apology Everybody was there EXCEPT Stephen 5
.Yaprak 15748 مالک ارسال شده در 23 آذر، 2012 ?Accessory or accessary If you want to preserve the traditional distinction in meaning between these two words, use ACCESSARY to refer to someone associated with a crime and ACCESSORY to refer to something that is added (a fashion accessory or car accessories). However, the distinction has now become blurred and it is perfectly acceptable to use one spelling to cover both meanings. Of the two, accessory is the more widely used, but both are .correct 5
.Yaprak 15748 مالک ارسال شده در 23 آذر، 2012 accidentally The adverb is formed by adding -ly to .accidental (not accidently) 5
.Yaprak 15748 مالک ارسال شده در 23 آذر، 2012 accommodation This is a favourite word in spelling quizzes and is frequently seen misspelt on painted .signs (not accomodation or accommadation) 5
.Yaprak 15748 مالک ارسال شده در 25 آذر، 2012 adapter or adaptor Traditional usage would distinguish between these two words and reserve -er for the person (an adapter of novels, for instance) and -or for the piece of electrical equipment. However, the distinction has become very blurred and the two spellings are considered by many authorities to be interchangeable. Use either for both meanings but be consistent .within a single piece of writing 4
.Yaprak 15748 مالک ارسال شده در 25 آذر، 2012 adding endings Usually endings (suffixes) can be added to base words without any complications. You just add them and that is that! e.g. iron + ing = ironing steam + er = steamer list + less = listless However, there are four groups of words which need especial care. Fortunately, there are some straightforward rules which save your learning thousands of .words individually (i) The 1-1-1 rule :This rule applies to words of ONE syllable ending with ONE consonant preceded by ONE vowel .e.g. drop, flat, sun, win When you add an ending beginning with a consonant to a l-l-l word, there :is no change to the base word drop + let = droplet flat + ly = flatly win + some = winsome When you add an ending beginning with a vowel to a l-l-l word, you double the final letter of the base :word drop + ed = dropped flat + est = flattest win + ing = winning sun + *y = sunny y counts as a vowel when it* .sounds like i or e .See VOWELS :Treat qu as one letter quit + ing = quitting quip + ed = quipped Don’t double final w and x. They would look very odd and so we have :correctly tax + ing = taxing paw + ed = pawed ii) The magic -e rule This rule applies to all words ending .with a silent -e e.g. hope, care, achieve, sincere, .separate When you add an ending beginning :with a consonant, keep the -e hope + ful = hopeful care + less = careless sincere + ly = sincerely separate + ly = separately achieve + ment = achievement When you add an ending beginning :with a vowel, drop the -e hope + ing = hoping care + er = carer sincere + ity = sincerity separate + ion = separation achieve + ed = achieved Do, however, keep the -e in words like singeing (different from singing) and dyeing (different from dying) and whenever you need to keep the identity of the base word clear (e.g. .(shoeing, canoeing Do remember to keep the -e with soft c and soft g words. It’s the e that keeps them soft (courageous, (traceable). (See SOFT C AND SOFT G Don’t keep the -e with these eight exceptions to the rule: truly, duly, ninth, argument, wholly, awful, .whilst, wisdom (iii) -y rule This rule applies to all words ending in -y. Look at the letter before the -y .in the base word It doesn’t matter at all what kind of ending you are adding. When you add an ending to a word ending in a :vowel + y, keep the y portray + ed = portrayed employ + ment = employment When you add an ending to a word ending in a consonant + y, change :the y to i try +al = trial empty + er = emptier pity + less = pitiless lazy + ness = laziness Do keep the y when adding -ing. Two i’s together would look very odd, despite our two words ski-ing and .taxi-ing try + ing = trying empty + ing = emptying Don’t apply the rule in these fourteen cases: daily, gaily, gaiety, laid, paid, said, slain, babyhood, shyly, shyness, .dryness, slyness, wryly, wryness (iv) The 2-1-1 rule :This rule applies to words of TWO syllables ending with ONE consonant preceded by ONE vowel. With this rule, it all depends on .which syllable of the word is stressed The 2-1-1 words below are stressed on the first syllable, and both vowel and consonant endings are added :without any complications gossip gossiping target targeted limit limitless eager eagerness ,But note that kidnap, outfit, worship :always double their final letter ADDING ENDINGS kidnapped, outfitter, worshipping Take care with 2-1-1 words which are stressed on the second syllable. There is no change when you add a :consonant ending forget + ful = forgetful equip + ment = equipment Double the final consonant of the base :word when you add a vowel ending forget + ing = forgetting equip + ed = equipped forbid + en = forbidden begin + er = beginner This rule is really valuable but you :must be aware of some exceptions " 2-1-1 words ending in -l seem to have a rule all of their own. Whether the stress is on the first or the second syllable, there is no change when a :consonant ending is added quarrel + some = quarrelsome instal + ment = instalment Double the -l when adding a vowel :ending quarrel + ing = quarrelling instal + ed = installed excel + ent = excellent " Notice how the change of stress in :these words affects the spelling confer conferred conferring conference defer deferred deferring deference infer inferred inferring inference prefer preferred preferring preference refer referred referring reference transfer transferred transferring transference See also -ABLE/-IBLE; -ANCE,-ANT/-ENCE,-ENT; -CAL/-CLE; -FUL;-LY. .ADDING ENDINGS 5
.Yaprak 15748 مالک ارسال شده در 30 آذر، 2012 ?advice or advise .My ADVICE is to forget all about it (noun = recommendation) ?What would you ADVISE me to do (verb = recommend) 2
.Yaprak 15748 مالک ارسال شده در 7 دی، 2012 affect or effect? Heavy drinking will AFFECT your liver.(verb)The EFFECT on her health wasimmediate. (noun)The new manager plans to EFFECTsweeping changes. (verb = to bring about) 2
.Yaprak 15748 مالک ارسال شده در 7 دی، 2012 agree to/agree with The choice of preposition alters themeaning of the verb:I AGREED TO do what he advised.I AGREED TO all the conditions.I AGREED WITH all they said.See PREPOSITIONS. 2
.Yaprak 15748 مالک ارسال شده در 7 دی، 2012 alley or ally? An ALLEY is a little lane.An ALLY is a friend.alley (singular), alleys (plural)ally (singular), allies (plural)See PLURALS (iii). 2
.Yaprak 15748 مالک ارسال شده در 7 دی، 2012 all most or almost? There is a difference in meaning. Usethese exemplar sentences as a guide:They were ALL (= everyone) MOST kind.The child was ALMOST (=nearly) asleep. 2
.Yaprak 15748 مالک ارسال شده در 7 دی، 2012 all ready or already? There is a difference in meaning. Usethese exemplar sentences as a guide:We are ALL (= everyone) READY.It is ALL (= everything) READY.She was ALREADY dead (= by then). 2
.Yaprak 15748 مالک ارسال شده در 7 دی، 2012 all right or alright? Traditional usage would consider ALLRIGHT to be correct and ALRIGHT to beincorrect. However, the use of ‘alright’ is sowidespread that some would see it asacceptable although the majority of educatedusers would take care to avoid it. 2
.Yaprak 15748 مالک ارسال شده در 7 دی، 2012 all so or also? There is a difference in meaning. Usethese exemplar sentences as a guide:You are ALL (= everyone) SO kind.You are ALSO (= in addition) generous. 2
.Yaprak 15748 مالک ارسال شده در 7 دی، 2012 allusion, delusion or illusion? There is a difference in meaning.or illusion? An ALLUSION is an indirect reference.A DELUSION is a false belief (oftenassociated with a mental disorder).An ILLUSION is a deceptive appearance. 2
.Yaprak 15748 مالک ارسال شده در 7 دی، 2012 alternate or alternative? We visit our grandparents onalternative? ALTERNATE Saturdays. (= every otherSaturday)I ALTERNATE between hope and despair.(= have each mood in turn)An ALTERNATIVE plan would be to goby boat. (= another possibility)The ALTERNATIVES are simple: work orgo hungry. (= two choices) 2
.Yaprak 15748 مالک ارسال شده در 7 دی، 2012 among or between? Use BETWEEN when something is sharedby two people. Use AMONG when it isshared by three or more.Share the sweets BETWEEN the two ofyou.Share the sweets AMONG yourselves.However, BETWEEN is used withnumbers larger than two when it meansan exact geographical location or when itrefers to relationships.Sardinia lies BETWEEN Spain, Algeria,Corsica and Italy.It will take a long time before the riftBETWEEN the five main parties heals. 2
.Yaprak 15748 مالک ارسال شده در 7 دی، 2012 ante-/anti- ANTE- means before.antenatal = before birthANTI- means against.antifreeze = against freezing 2
