نرزایی در ماهی کپور (انگلیسی به فارسی)
[h=2][/h]
Interspecific androgenesis in Cyprinids
B. Urbanyi’*, I. Magyary’, M. BercsCnyi2, L. Orb&r3 and L. Horvath’
’ University
of
Agricultural Sciences, Institute
of
Animal Husbandry, Biotechnological
Laboratory, Pa’ter K.St. l., H-21 03 Giidiill8, Hungary
2 Warm Water Fish Hatchery Ltd., Szdzhalombatta P$28., H-2441 Hungary
3Agricultural Biotechnology Center, Institute
for
Molecular Genetics, H-21 01 Giidiill6,
Hungary
*Corresponding author
SUMMARY
Due to increasing demand for preservation of fish genotypes methods suitable for
conservation and restoration of precious, rare or endangered fish species, landraces and
stocks should be developed. Since the long-term preservation of fish ova is not yet possible
(unlike the cryopreservation of fish sperm) the only way to conserve and restore a given
genotype is the combination of sperm cryopreservation and androgenesis. If the ova of a rare
genotype are not available interspecific androgenesis could be applied in order to increase the
efficiency of this combined method.
Viable diploid goldfish
(Carassius auratus)
progenies were produced through interspecific
androgenesis using common
carp (Cyprinus carpio)
eggs. Irradiated ova of common carp
(gamma-rays, 25 kR) were fertilized with fresh or cryopreserved goldfish sperm. Diploidy
was restored by application of heat shock (4O”C, 2 min). Colour and morphological markers
were used to prove the male origin of androgenetic progenies. The analyse of genome in the
progeny was carried out with RAPD (Random Amplified Polymorphic DNA) method. Of
twenty-two examined RAPD primary secvences we managed to choose 14, which showed
different pattern of the DNA from the two parents. These experiments proved that the
genome of the progeny was indeed from the goldfish male, but maternal stripes were detected
as well, which were probably of mitochondrial origin.
High fertilization rates and hatching rates were achieved using fresh or frozen goldfish sperm.
Manifestation of phenotypic markers characteristic to common carp was not found among
androgenetic goldfish progenies during half year of development.
Keywords: carp, goldfish, interspecific androgenesis, sperm cryopreservation, genotype
restoration
INTRODUCTION
Fish are ideal objects for genome manipulation: various forms of these techniques are applied
routinely in the daily practice of aquaculture. Androgenesis is a single-parent type of
inheritance where by definition the genetic material of the progeny originates exclusively
from the male gametes (Purdom, 1995), while the maternal chromosomes are presumed to be
totally excluded from the process. In this publication we demonstrate and verify by DNA
analysis, that it is possible to perform interspecific androgenesis between two Cyprinid
species.
MATERIALS AND METHODS
Eggs obtained from a common carp were irradiated by gamma-ray (Purdom, 1995) for the
inactivation of maternal chromosomes and they were then fertilized using cryopreserved
(Magyary et al. 1996a,b) (l-3 weeks prior to propagation) and fresh sperm of goldfish. The
dosage of irradiation was 300 Gray. In controls eggs were not irradiated. Since haploid
embryos are not viable genome of the male pronucleus was duplicated applying heat-shock
on the eggs prior to the first mitotic cleavage. Heat shock parameters (Sheerer et al., 1991)
applied: 2 minutes duration, 40 OC shock temperature starting the shock 37 minutes
postfertilization at 22 OC ambient temperature. Fertilized and shocked eggs were incubated in
Zug jars. Ten to fifteen thousand eggs were used per treatment what made a pilot plant size.
Following a heat shock performed for duplication of the haploid paternal chromosome set,
androgenic goldfish embryos, possessing all three phenotypic recessive markers (triangle tail,
bubble eye, coloration) from their father, but none of the dominant alleles of these genes from
carp, have hatched out (Table 1.).
RED CAP BUBBLE EYE BLACK TELESCOPE
red spot on head bubble eyes telescope eyes
triangle tail triangle tail triangle tail
no barbels no barbels no barbels
I white body red colour black colour
Table 1. Recessive phenotypic markers of the three varieties of goldfish males used for
Concerning these markers no maternal characters of the carp were detected in androgenetic
groups while the hybrids showed full maternal dominance having single tail, simple eyes and
gray color.
Though the morphological markers gave excellent evidence of the lack of female-derived
intact genes, we have also decided to study the genetic material of the androgenetic
individuals by DNA analysis. Since despite of ongoing research on the isolation of
microsatellite markers from common carp no microsatellites applicable to the investigation of
farmed cyprinids are published or available commercially to date, random amplified
polymorphism of DNA (RAPD) appeared to be the most efficient means of studying the
genetic composition of the androgenetic fry. The oligonucleotide primers were selected on
the basis of the pattern produced with zebrafish DNA, the closest relative of carp and
goldfish thoroughly studied with RAPD analysis.
RESULTS AND DISCUSSION
Out of the twenty two RAPD markers tested eight produced a band pattern different in the
two parents. By testing fourteen androgenic individuals belonging to six families, complete
transmission of all paternal bands could be observed, as demonstrated on one family with two
androgenic individuals tested. DNA analysis allows for studying the fine details of genome
manipulations, which could not be revealed by using traditional techniques. RAPD analysis
appears to be superior to fingerprinting for this purpose, due to its lower template and time
requirement and to its better reproducibility.
In the best batch 28 % of the interspecific androgenetic progenies reached hatching stage
(Figure 1.) and 15 % survived until 2 weeks. No significant differences (~~0.01) were found
between the hatching rates of androgenetic goldfish derived from fresh or frozen sperm. Ten
to thirty androgenetic goldfish individuals per male are being grown up to ***ual maturity for
future experiments.
etlilization rate
Figure 1.: Comparison of fertilization and hatching rates of three varieties of androgenic
goldfish derived from irradiated carp eggs using cryopreserved spem. Columns in the first
line indicate hatching rates, while those in the second line the fertilization rates (in percentage
of the total number of eggs fertilized per group for both). The columns mark the average
values of three experiments, the value of which is also shown in numerical form at their top.
It remains a very interesting question to be solved, how could a goldfish embryo with a rather
strict genetic programming grow around a yolk sac considerably larger, than its own.
Parallel application of interspecific androgenesis together with cryopreservation of fish sperm
could be used for restoring species in danger of extinction in the future.
REFERENCES
Purdom, C.E. Genetics anQX+z breeding. 206-207 (Chapman & Hall, London, UK, 1995)
Sheerer, P.D., Thorgard, G.H. & Allendorf, F.W. 1991.
J.Exp. Zd. 260,382-390
(1991)
Magyary, I., Urbanyi, B. & Horvath, L. Cryopreservation of common carp (Cyprinus carpio
L.) sperm I. The importance of oxygen supply. Journal of Applied Ichthyology, 12 , 113-l 15,
1996a.
L.) sperm II. Optimal conditions for fertilization. Journal of Applied Ichthyology, 12, 117-
119,1996b.
نر زایی در ماهی کپور
بر قرار کردن فن شناسایی عملیات در کشت
خلاصه:
نرزایی را برای افزایش تقاضا ؛حفاظت از ماهی گرانبها،گونه های ماهی کم ودر معرض خطرونژاد های بومی توسعه دادند.اگر تخم های نادر نمونه جنسی خاص در دسترس نباشد،نرزایی خاص می تواندبه افزایش کیفیت این روش ترکیبی به کار رود .ماهی قرمز دیپلوییدی زیست پذیر ودر گذشته با نرزایی هی ویژبا استفاده از تخم های ماهی کپور رایج تولید می شدند.تخم های تحت تاثیر گامای کپور معمولی بارور می شدند وبا نطفه های ماهیان قرمز سرمازی وتازه.ماهیان دیپلوییدی بااستفاده ازشوک دمایی ترمیم می شدند(40درجه درطول دو دقیقه) .مارک های رنگی ومورفولوژیکال برای ثابت کردن منشا نری در نمونه های نرزایی استفاده می شد.آنالیز ژنوم در این نسل با روش RAPD (DANی چند دگردیسی تصادفی تقویت یافته) انجام می شد.از 22 آزمایش RAPDاولیه که باعث شد14نمونه را انتخاب کنیم ،نمونه های مختفی از DNAاز دو والد مختلف نشان داده شد.این آزمایش ها ثابت کردکه ژنوم نسل هاازنر های ماهیان قرمز ایجاد شد.اما مارک های مادری به همان خوبی احتمالات اصل وتقسیم سلولی نشان داده شده بود.سرعت های لقاح وهچ کردن بااستفاده از نطفه های ماهیان قرمز وتازه ومنجمد انجام شدوآشکارسازی مارک های زیستی با مشخصه های ماهیان کپوری رایج در طول نسل های ماهیان قرمزنرزایی شده درطول نیمسال گسترش یافته نشد.معرفی:هدف هایی دلخواه برای دستکاری ژنوم ماهی ها:شکل های گوناگون ازاین تکنیک ها درگزارش شده است .به طور معمول درتمرین روزانه کشت آبی،بایک تک والد ،نوع وراثت بنابرتعریف بنابر تعریف مواد وراثتی اولاد منحصرا آغاز می شود.ازگامت های جنسی نرزمانی که کروموزوم ها مادری هستند فرض کردندکه کاملا ازفرایندمنع شده اند.در این انتشارهابوسیله واکاوی ماده وراثتی یاخته هاراتایید می کنند که ممکن است نرزایی بین دو گونه خاص کپور انجام شود.مواد وروش ها:تخم های بدست آمده از یک کپور معمولی بوسیله ی اشعه ی گاما برای غیرفعال نمودن کروموزوم های مادری بود،غلظت تابش دهی300GRAY بودودر تخم هاواز پرتو ها جلوگیری نشد.زمانی که رویان ها هاپلوییدی نیستند ژنوم زنده از هسته جنس نربا استفاده از شوک گرمایی ترک میتوتیک خورد.در مورد این علایم هیچ مشخصه ی مادری ماهی کپور در گروه های نرزایی دیده نشد. چراکه هیبرید ها نشان دادندتسلط کامل مشخصه های مادری شامل تک دم،چشم های ساده ورنگ خاکستری می شود.با این وجود علایم مورفلوژیکال یک نتیجه بسیار می دهدازنقص در ژن های سالم مشتق شده از جنس ماده،همچنین تصمیم گرفتند تا مواد ژنتیکی منحصر به فرد نرزایی را با آنالیز DNAمطالعه کنیم.با توجه به تحقیقات مداوم بر روی جدایی علایم انگل های ریز بر روی ماهیان کپوری رایج ،هیچ میکروانگلی منتشر نشده ویا اینکه بطورتجاری ثبت شده در دسترس نمی باشد،چند ریختی (چند حالتی)تصادفی پیشرفت یافته DNA (RADP)نشان می دهد که مهمترین وسیله موثر برای مطالعه ترکیب ژنتیکی تخم نرزایی می باشد.
منبع : شیلات ماهیان جنوب
