توضیحاتی در مورد رابطه گشتاور در موتور هیسترزیس
Hysteresis Motor
Construction. The stator of hysteresis motors is produced in the same types
of construction as motors with magnet rotor, i. e. with slots, with claw poles
or with split poles. The rotor has a ring of hysteresis material. This is similar
to permanent-magnetic materials; the hysteresis loop, however, is less broad
and not prepolarized.
Mode of functioning. The ampere turns of the stator generate a field
rotating with synchronous speed (Eq. 2.99). They permanently reverse the
magnetization of the hysteresis rotor, so long as it stops or rotates slower
as the rotating field. The magnetic state of the rotor elements runs through
the whole hysteresis loop. The hysteresis losses PH generated by that are
proportional to the remagnetizing frequency
f2 = s · f1 (2.112)
with the slip s of the rotor with regard to the rotating field according to
Eq. (2.100). In the hysteresis material hysteresis losses arise analogously to
the rotor losses in asynchronous motors (Fig. 2.138, left):
PH = PV2 = s · Pδ (2.113)
and at the shaft, the output power is given by
P = (1 − s)Pδ . (2.114)
Neglecting first the eddy currents generated by the rotating field, no currents
flow in the rotor, which are reacting upon the air-gap field. The stator current
does not depend on the load, because there is no armature reaction. Therefore,
the power losses of the stator PV1 and the input power coming from the power
supply P1 are constant. As a result, the air-gap power is constant, too:
Pδ = P1 − PV1 . (2.115)
Therefore, the torque generated by the hysteresis is constant according to
Eq. (2.105):
T = P
2πn
= Pδ
2πns
. (2.116)
The above statements are valid for ideal motors. In reality, eddy-current
losses arise in every hysteresis rotor proportional to the square of the rotor
frequency sf1. The eddy-current torque TE is inversely proportional to the
slip. Therefore, it decreases linearly with the slip or with increasing speed
(Fig. 2.138, middle). The torque characteristic of real hysteresis motors is
2 Motors for Continuous Rotation 151
Fig. 2.138. Powers and torques of hysteresis motors. a, b Ideal motor. c Real motor
shown in Fig. 2.138 on the right side for three-phase or AC operation. Caused
by leakage fluxes and a generally high harmonic content of the air-gap field,
the real torque characteristic differs from that of an ideal motor. It is typical
for a hysteresis motor that it starts independently without swinging in and
pulls softly into synchronism. In the synchronism poles are formed. Now the
hysteresis motor acts like a magnet-rotor motor, but it creates a torque, which
is 20 to 30 times smaller. Therefore, gearings with a great reduction ratio are
used, in order to get sufficiently great torques for the respective application
case. Due to the low utilization hysteresis drives have considerably lost in
importance today.
