spow 44203 ارسال شده در 15 تیر، 2012 جدول هفتگی لیگ های معتبر اروپایی دراین تاپیک سعی میشود جدول رده بندی لیگ های اروپایی به صورت هفتگی قرار داده شود 1
spow 44203 سازنده ارسال شده در 15 تیر، 2012 جدول لالیگا [TABLE] [TR] [TH] [En] [/TH] [TH=class: team]تيم[/TH] [TH=class: matches-played]بازی[/TH] [TH=class: wins]برد[/TH] [TH=class: draws]مساوي[/TH] [TH=class: losses]باخت[/TH] [TH=class: goals_for]زده[/TH] [TH=class: goals_against]خورده[/TH] [TH=class: goal_difference]تفاضل گل [/TH] [TH=class: points last]امتیاز[/TH] [/TR] [TR=class: first] [TD=class: rank]۱[/TD] [TD=class: team, align: right]رئال مادريد[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۲۷[/TD] [TD=class: draws]۴[/TD] [TD=class: losses]۲[/TD] [TD=class: goals_for]۱۰۷[/TD] [TD=class: goals_against]۲۹[/TD] [TD=class: goal_difference positive]+۷۸[/TD] [TD=class: points last]۸۵[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۲[/TD] [TD=class: team, align: right]بارسلونا[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۲۵[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۲[/TD] [TD=class: goals_for]۹۶[/TD] [TD=class: goals_against]۲۴[/TD] [TD=class: goal_difference positive]+۷۲[/TD] [TD=class: points last]۸۱[/TD] [/TR] [TR] [TD=class: rank first]۳[/TD] [TD=class: team, align: right]والنسيا[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۴[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۹[/TD] [TD=class: goals_for]۵۰[/TD] [TD=class: goals_against]۴۲[/TD] [TD=class: goal_difference positive]+۸[/TD] [TD=class: points last]۵۲[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۴[/TD] [TD=class: team, align: right]مالاگا[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۵[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۹[/TD] [TD=class: goals_against]۴۶[/TD] [TD=class: goal_difference positive]+۳[/TD] [TD=class: points last]۵۱[/TD] [/TR] [TR] [TD=class: rank first]۵[/TD] [TD=class: team, align: right]لوانته[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۴[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۴۷[/TD] [TD=class: goals_against]۴۶[/TD] [TD=class: goal_difference positive]+۱[/TD] [TD=class: points last]۴۸[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۶[/TD] [TD=class: team, align: right]اوساسونا[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۳[/TD] [TD=class: losses]۹[/TD] [TD=class: goals_for]۳۷[/TD] [TD=class: goals_against]۵۳[/TD] [TD=class: goal_difference negative]-۱۶[/TD] [TD=class: points last]۴۶[/TD] [/TR] [TR] [TD=class: rank first]۷[/TD] [TD=class: team, align: right]سويا[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۱[/TD] [TD=class: goals_for]۳۹[/TD] [TD=class: goals_against]۳۳[/TD] [TD=class: goal_difference positive]+۶[/TD] [TD=class: points last]۴۵[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۸[/TD] [TD=class: team, align: right]اتلتيک بيلبائو[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۲[/TD] [TD=class: losses]۱۰[/TD] [TD=class: goals_for]۴۸[/TD] [TD=class: goals_against]۴۴[/TD] [TD=class: goal_difference positive]+۴[/TD] [TD=class: points last]۴۵[/TD] [/TR] [TR] [TD=class: rank first]۹[/TD] [TD=class: team, align: right]اسپانيول[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۳[/TD] [TD=class: goals_against]۴۳[/TD] [TD=class: goal_difference positive]+۰[/TD] [TD=class: points last]۴۵[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۰[/TD] [TD=class: team, align: right]اتلتيكو مادريد[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۳[/TD] [TD=class: goals_against]۴۱[/TD] [TD=class: goal_difference positive]+۲[/TD] [TD=class: points last]۴۲[/TD] [/TR] [TR] [TD=class: rank first]۱۱[/TD] [TD=class: team, align: right]رئال بتيس[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۱۵[/TD] [TD=class: goals_for]۴۰[/TD] [TD=class: goals_against]۴۵[/TD] [TD=class: goal_difference negative]-۵[/TD] [TD=class: points last]۴۲[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۲[/TD] [TD=class: team, align: right]ختافه[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۳۳[/TD] [TD=class: goals_against]۴۳[/TD] [TD=class: goal_difference negative]-۱۰[/TD] [TD=class: points last]۴۲[/TD] [/TR] [TR] [TD=class: rank first]۱۳[/TD] [TD=class: team, align: right]مايورکا[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۰[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۳۵[/TD] [TD=class: goals_against]۴۱[/TD] [TD=class: goal_difference negative]-۶[/TD] [TD=class: points last]۴۰[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۴[/TD] [TD=class: team, align: right]والکانو[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۴[/TD] [TD=class: losses]۱۶[/TD] [TD=class: goals_for]۴۹[/TD] [TD=class: goals_against]۵۷[/TD] [TD=class: goal_difference negative]-۸[/TD] [TD=class: points last]۴۰[/TD] [/TR] [TR] [TD=class: rank first]۱۵[/TD] [TD=class: team, align: right]رئال سوسيداد[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۰[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۴[/TD] [TD=class: goals_for]۴۰[/TD] [TD=class: goals_against]۴۹[/TD] [TD=class: goal_difference negative]-۹[/TD] [TD=class: points last]۳۹[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۶[/TD] [TD=class: team, align: right]ويارئال[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۸[/TD] [TD=class: draws]۱۲[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۳۴[/TD] [TD=class: goals_against]۴۷[/TD] [TD=class: goal_difference negative]-۱۳[/TD] [TD=class: points last]۳۶[/TD] [/TR] [TR] [TD=class: rank first]۱۷[/TD] [TD=class: team, align: right]گرانادا[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۰[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۱۷[/TD] [TD=class: goals_for]۳۰[/TD] [TD=class: goals_against]۴۹[/TD] [TD=class: goal_difference negative]-۱۹[/TD] [TD=class: points last]۳۶[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۸[/TD] [TD=class: team, align: right]زاراگوزا[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۸[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۱۸[/TD] [TD=class: goals_for]۲۹[/TD] [TD=class: goals_against]۵۹[/TD] [TD=class: goal_difference negative]-۳۰[/TD] [TD=class: points last]۳۱[/TD] [/TR] [TR] [TD=class: rank first]۱۹[/TD] [TD=class: team, align: right]اسپورتينگ گيخون [/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۷[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۱۹[/TD] [TD=class: goals_for]۳۳[/TD] [TD=class: goals_against]۶۳[/TD] [TD=class: goal_difference negative]-۳۰[/TD] [TD=class: points last]۲۸[/TD] [/TR] [TR=class: last odd] [TD=class: rank first]۲۰[/TD] [TD=class: team, align: right]ريسينگ سانتاندر[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۴[/TD] [TD=class: draws]۱۴[/TD] [TD=class: losses]۱۵[/TD] [TD=class: goals_for]۲۴[/TD] [TD=class: goals_against]۵۲[/TD] [TD=class: goal_difference negative]-۲۸[/TD] [TD=class: points]۲۶[/TD] [/TR] [/TABLE] 1
spow 44203 سازنده ارسال شده در 15 تیر، 2012 جدول سری آ ایتالیا [TABLE] [TR] [TH] [En] [/TH] [TH=class: team]تيم[/TH] [TH=class: matches-played]بازی[/TH] [TH=class: wins]برد[/TH] [TH=class: draws]مساوي[/TH] [TH=class: losses]باخت[/TH] [TH=class: goals_for]زده[/TH] [TH=class: goals_against]خورده[/TH] [TH=class: goal_difference]تفاضل گل[/TH] [TH=class: points last]امتیاز[/TH] [/TR] [TR=class: first] [TD=class: rank]۱[/TD] [TD=class: team, align: right]يوونتوس[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۸[/TD] [TD=class: draws]۱۴[/TD] [TD=class: losses]۰[/TD] [TD=class: goals_for]۵۳[/TD] [TD=class: goals_against]۱۸[/TD] [TD=class: goal_difference positive]+۳۵[/TD] [TD=class: points last]۶۸[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۲[/TD] [TD=class: team, align: right]آ ث ميلان[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۲۰[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۵[/TD] [TD=class: goals_for]۶۲[/TD] [TD=class: goals_against]۲۶[/TD] [TD=class: goal_difference positive]+۳۶[/TD] [TD=class: points last]۶۷[/TD] [/TR] [TR] [TD=class: rank first]۳[/TD] [TD=class: team, align: right]لاتزيو[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۶[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۱۰[/TD] [TD=class: goals_for]۴۸[/TD] [TD=class: goals_against]۴۰[/TD] [TD=class: goal_difference positive]+۸[/TD] [TD=class: points last]۵۴[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۴[/TD] [TD=class: team, align: right]اودينزه[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۴[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۹[/TD] [TD=class: goals_for]۴۴[/TD] [TD=class: goals_against]۳۲[/TD] [TD=class: goal_difference positive]+۱۲[/TD] [TD=class: points last]۵۱[/TD] [/TR] [TR] [TD=class: rank first]۵[/TD] [TD=class: team, align: right]رم[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۵[/TD] [TD=class: draws]۵[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۵۲[/TD] [TD=class: goals_against]۴۲[/TD] [TD=class: goal_difference positive]+۱۰[/TD] [TD=class: points last]۵۰[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۶[/TD] [TD=class: team, align: right]ناپولي[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۱۲[/TD] [TD=class: losses]۸[/TD] [TD=class: goals_for]۵۶[/TD] [TD=class: goals_against]۴۱[/TD] [TD=class: goal_difference positive]+۱۵[/TD] [TD=class: points last]۴۸[/TD] [/TR] [TR] [TD=class: rank first]۷[/TD] [TD=class: team, align: right]اينتر[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۴[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۷[/TD] [TD=class: goals_against]۴۵[/TD] [TD=class: goal_difference positive]+۲[/TD] [TD=class: points last]۴۸[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۸[/TD] [TD=class: team, align: right]كاتانيا[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۰[/TD] [TD=class: draws]۱۳[/TD] [TD=class: losses]۹[/TD] [TD=class: goals_for]۴۲[/TD] [TD=class: goals_against]۴۳[/TD] [TD=class: goal_difference negative]-۱[/TD] [TD=class: points last]۴۳[/TD] [/TR] [TR] [TD=class: rank first]۹[/TD] [TD=class: team, align: right]كيه وو[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۳۰[/TD] [TD=class: goals_against]۴۰[/TD] [TD=class: goal_difference negative]-۱۰[/TD] [TD=class: points last]۴۲[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۰[/TD] [TD=class: team, align: right]آتالانتا[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۳[/TD] [TD=class: losses]۸[/TD] [TD=class: goals_for]۳۷[/TD] [TD=class: goals_against]۳۴[/TD] [TD=class: goal_difference positive]+۳[/TD] [TD=class: points last]۴۰[/TD] [/TR] [TR] [TD=class: rank first]۱۱[/TD] [TD=class: team, align: right]پالرمو[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۱۴[/TD] [TD=class: goals_for]۴۴[/TD] [TD=class: goals_against]۴۹[/TD] [TD=class: goal_difference negative]-۵[/TD] [TD=class: points last]۴۰[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۲[/TD] [TD=class: team, align: right]بلونيا[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۰[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۳۳[/TD] [TD=class: goals_against]۳۸[/TD] [TD=class: goal_difference negative]-۵[/TD] [TD=class: points last]۴۰[/TD] [/TR] [TR] [TD=class: rank first]۱۳[/TD] [TD=class: team, align: right]سينا[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۰[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۳۷[/TD] [TD=class: goals_against]۳۴[/TD] [TD=class: goal_difference positive]+۳[/TD] [TD=class: points last]۳۹[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۴[/TD] [TD=class: team, align: right]كالياري[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۹[/TD] [TD=class: draws]۱۱[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۳۳[/TD] [TD=class: goals_against]۳۹[/TD] [TD=class: goal_difference negative]-۶[/TD] [TD=class: points last]۳۸[/TD] [/TR] [TR] [TD=class: rank first]۱۵[/TD] [TD=class: team, align: right]پارما[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۹[/TD] [TD=class: draws]۱۱[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۱[/TD] [TD=class: goals_against]۵۰[/TD] [TD=class: goal_difference negative]-۹[/TD] [TD=class: points last]۳۸[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۶[/TD] [TD=class: team, align: right]فيورنتينا[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۹[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۳۲[/TD] [TD=class: goals_against]۳۸[/TD] [TD=class: goal_difference negative]-۶[/TD] [TD=class: points last]۳۷[/TD] [/TR] [TR] [TD=class: rank first]۱۷[/TD] [TD=class: team, align: right]جنوا[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۹[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۴[/TD] [TD=class: goals_for]۴۳[/TD] [TD=class: goals_against]۵۸[/TD] [TD=class: goal_difference negative]-۱۵[/TD] [TD=class: points last]۳۶[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۸[/TD] [TD=class: team, align: right]لچه[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۸[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۴[/TD] [TD=class: goals_for]۳۷[/TD] [TD=class: goals_against]۴۸[/TD] [TD=class: goal_difference negative]-۱۱[/TD] [TD=class: points last]۳۴[/TD] [/TR] [TR] [TD=class: rank first]۱۹[/TD] [TD=class: team, align: right]نووارا[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۵[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۷[/TD] [TD=class: goals_for]۲۷[/TD] [TD=class: goals_against]۵۴[/TD] [TD=class: goal_difference negative]-۲۷[/TD] [TD=class: points last]۲۵[/TD] [/TR] [TR=class: last odd] [TD=class: rank first]۲۰[/TD] [TD=class: team, align: right]چيزينا[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۴[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۹[/TD] [TD=class: goals_for]۱۹[/TD] [TD=class: goals_against]۴۸[/TD] [TD=class: goal_difference negative]-۲۹[/TD] [TD=class: points]۲۱[/TD] [/TR] [/TABLE] 1
spow 44203 سازنده ارسال شده در 15 تیر، 2012 جدول بوندس لیگای المان [TABLE] [TR] [TH] [En] [/TH] [TH=class: team]تيم[/TH] [TH=class: matches-played]بازی[/TH] [TH=class: wins]برد[/TH] [TH=class: draws]مساوي[/TH] [TH=class: losses]باخت[/TH] [TH=class: goals_for]زده[/TH] [TH=class: goals_against]خورده[/TH] [TH=class: goal_difference]تفاضل گل[/TH] [TH=class: points last]امتیاز[/TH] [/TR] [TR=class: first] [TD=class: rank]۱[/TD] [TD=class: team, align: right]بورسيا دورتموند[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۲۲[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۳[/TD] [TD=class: goals_for]۶۹[/TD] [TD=class: goals_against]۲۳[/TD] [TD=class: goal_difference positive]+۴۶[/TD] [TD=class: points last]۷۲[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۲[/TD] [TD=class: team, align: right]بايرن مونيخ[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۲۰[/TD] [TD=class: draws]۴[/TD] [TD=class: losses]۷[/TD] [TD=class: goals_for]۶۹[/TD] [TD=class: goals_against]۲۰[/TD] [TD=class: goal_difference positive]+۴۹[/TD] [TD=class: points last]۶۴[/TD] [/TR] [TR] [TD=class: rank first]۳[/TD] [TD=class: team, align: right]شالكه ۰۴[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۱۸[/TD] [TD=class: draws]۳[/TD] [TD=class: losses]۱۰[/TD] [TD=class: goals_for]۶۶[/TD] [TD=class: goals_against]۴۱[/TD] [TD=class: goal_difference positive]+۲۵[/TD] [TD=class: points last]۵۷[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۴[/TD] [TD=class: team, align: right]مونشن گلادباخ[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۱۶[/TD] [TD=class: draws]۸[/TD] [TD=class: losses]۷[/TD] [TD=class: goals_for]۴۶[/TD] [TD=class: goals_against]۲۲[/TD] [TD=class: goal_difference positive]+۲۴[/TD] [TD=class: points last]۵۶[/TD] [/TR] [TR] [TD=class: rank first]۵[/TD] [TD=class: team, align: right]اشتوتگارد[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۱۴[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۱۰[/TD] [TD=class: goals_for]۵۹[/TD] [TD=class: goals_against]۴۱[/TD] [TD=class: goal_difference positive]+۱۸[/TD] [TD=class: points last]۴۹[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۶[/TD] [TD=class: team, align: right]بايرلوركوزن[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۰[/TD] [TD=class: goals_for]۴۶[/TD] [TD=class: goals_against]۴۳[/TD] [TD=class: goal_difference positive]+۳[/TD] [TD=class: points last]۴۵[/TD] [/TR] [TR] [TD=class: rank first]۷[/TD] [TD=class: team, align: right]هانوفر[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۱[/TD] [TD=class: losses]۹[/TD] [TD=class: goals_for]۳۹[/TD] [TD=class: goals_against]۴۳[/TD] [TD=class: goal_difference negative]-۴[/TD] [TD=class: points last]۴۴[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۸[/TD] [TD=class: team, align: right]وردربرمن[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۱[/TD] [TD=class: goals_for]۴۵[/TD] [TD=class: goals_against]۵۰[/TD] [TD=class: goal_difference negative]-۵[/TD] [TD=class: points last]۴۲[/TD] [/TR] [TR] [TD=class: rank first]۹[/TD] [TD=class: team, align: right]هوفنهايم[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۱۰[/TD] [TD=class: draws]۱۱[/TD] [TD=class: losses]۱۰[/TD] [TD=class: goals_for]۳۸[/TD] [TD=class: goals_against]۴۰[/TD] [TD=class: goal_difference negative]-۲[/TD] [TD=class: points last]۴۱[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۰[/TD] [TD=class: team, align: right]ولفزبورگ[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۴[/TD] [TD=class: losses]۱۵[/TD] [TD=class: goals_for]۴۲[/TD] [TD=class: goals_against]۵۶[/TD] [TD=class: goal_difference negative]-۱۴[/TD] [TD=class: points last]۴۰[/TD] [/TR] [TR] [TD=class: rank first]۱۱[/TD] [TD=class: team, align: right]نورنبرگ[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۵[/TD] [TD=class: losses]۱۵[/TD] [TD=class: goals_for]۳۳[/TD] [TD=class: goals_against]۴۲[/TD] [TD=class: goal_difference negative]-۹[/TD] [TD=class: points last]۳۸[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۲[/TD] [TD=class: team, align: right]ماينتس[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۹[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۷[/TD] [TD=class: goals_against]۴۸[/TD] [TD=class: goal_difference negative]-۱[/TD] [TD=class: points last]۳۷[/TD] [/TR] [TR] [TD=class: rank first]۱۳[/TD] [TD=class: team, align: right]فرايبورگ[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۹[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۴۱[/TD] [TD=class: goals_against]۵۶[/TD] [TD=class: goal_difference negative]-۱۵[/TD] [TD=class: points last]۳۶[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۴[/TD] [TD=class: team, align: right]هامبورگ[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۸[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۳۴[/TD] [TD=class: goals_against]۵۵[/TD] [TD=class: goal_difference negative]-۲۱[/TD] [TD=class: points last]۳۴[/TD] [/TR] [TR] [TD=class: rank first]۱۵[/TD] [TD=class: team, align: right]آگسبورگ[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۷[/TD] [TD=class: draws]۱۲[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۳۴[/TD] [TD=class: goals_against]۴۸[/TD] [TD=class: goal_difference negative]-۱۴[/TD] [TD=class: points last]۳۳[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۶[/TD] [TD=class: team, align: right]کلن[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۸[/TD] [TD=class: draws]۵[/TD] [TD=class: losses]۱۸[/TD] [TD=class: goals_for]۳۶[/TD] [TD=class: goals_against]۶۶[/TD] [TD=class: goal_difference negative]-۳۰[/TD] [TD=class: points last]۲۹[/TD] [/TR] [TR] [TD=class: rank first]۱۷[/TD] [TD=class: team, align: right]هرتابرلين[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۶[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۵[/TD] [TD=class: goals_for]۳۴[/TD] [TD=class: goals_against]۵۷[/TD] [TD=class: goal_difference negative]-۲۳[/TD] [TD=class: points last]۲۸[/TD] [/TR] [TR=class: last odd] [TD=class: rank first]۱۸[/TD] [TD=class: team, align: right]کايزرسلاترن[/TD] [TD=class: matches-played]۳۱[/TD] [TD=class: wins]۳[/TD] [TD=class: draws]۱۱[/TD] [TD=class: losses]۱۷[/TD] [TD=class: goals_for]۱۹[/TD] [TD=class: goals_against]۴۶[/TD] [TD=class: goal_difference negative]-۲۷[/TD] [TD=class: points]۲۰[/TD] [/TR] [/TABLE] 1
spow 44203 سازنده ارسال شده در 15 تیر، 2012 جدول لیگ دسته اول انگلستان [TABLE] [TR] [TH] [En] [/TH] [TH=class: team]تيم[/TH] [TH=class: matches-played]بازی[/TH] [TH=class: wins]برد[/TH] [TH=class: draws]مساوي[/TH] [TH=class: losses]باخت[/TH] [TH=class: goals_for]زده[/TH] [TH=class: goals_against]خورده[/TH] [TH=class: goal_difference]تفاضل گل[/TH] [TH=class: points last]امتیاز[/TH] [/TR] [TR=class: first] [TD=class: rank]۱[/TD] [TD=class: team, align: right]منچستر يونايتد[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۲۶[/TD] [TD=class: draws]۴[/TD] [TD=class: losses]۴[/TD] [TD=class: goals_for]۸۲[/TD] [TD=class: goals_against]۲۸[/TD] [TD=class: goal_difference positive]+۵۴[/TD] [TD=class: points last]۸۲[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۲[/TD] [TD=class: team, align: right]منچستر سيتي[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۲۴[/TD] [TD=class: draws]۵[/TD] [TD=class: losses]۵[/TD] [TD=class: goals_for]۸۵[/TD] [TD=class: goals_against]۲۷[/TD] [TD=class: goal_difference positive]+۵۸[/TD] [TD=class: points last]۷۷[/TD] [/TR] [TR] [TD=class: rank first]۳[/TD] [TD=class: team, align: right]آرسنال[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۲۰[/TD] [TD=class: draws]۴[/TD] [TD=class: losses]۹[/TD] [TD=class: goals_for]۶۶[/TD] [TD=class: goals_against]۴۱[/TD] [TD=class: goal_difference positive]+۲۵[/TD] [TD=class: points last]۶۴[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۴[/TD] [TD=class: team, align: right]تاتنهام[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۷[/TD] [TD=class: draws]۸[/TD] [TD=class: losses]۸[/TD] [TD=class: goals_for]۵۷[/TD] [TD=class: goals_against]۳۸[/TD] [TD=class: goal_difference positive]+۱۹[/TD] [TD=class: points last]۵۹[/TD] [/TR] [TR] [TD=class: rank first]۵[/TD] [TD=class: team, align: right]نيوکاسل[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۷[/TD] [TD=class: draws]۸[/TD] [TD=class: losses]۸[/TD] [TD=class: goals_for]۵۰[/TD] [TD=class: goals_against]۴۲[/TD] [TD=class: goal_difference positive]+۸[/TD] [TD=class: points last]۵۹[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۶[/TD] [TD=class: team, align: right]چلسي[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۶[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۸[/TD] [TD=class: goals_for]۵۶[/TD] [TD=class: goals_against]۳۸[/TD] [TD=class: goal_difference positive]+۱۸[/TD] [TD=class: points last]۵۷[/TD] [/TR] [TR] [TD=class: rank first]۷[/TD] [TD=class: team, align: right]اورتون[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۳[/TD] [TD=class: draws]۸[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۳۸[/TD] [TD=class: goals_against]۳۴[/TD] [TD=class: goal_difference positive]+۴[/TD] [TD=class: points last]۴۷[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۸[/TD] [TD=class: team, align: right]ليورپول[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۱[/TD] [TD=class: goals_for]۴۰[/TD] [TD=class: goals_against]۳۶[/TD] [TD=class: goal_difference positive]+۴[/TD] [TD=class: points last]۴۶[/TD] [/TR] [TR] [TD=class: rank first]۹[/TD] [TD=class: team, align: right]ساندرلند[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۴۲[/TD] [TD=class: goals_against]۴۱[/TD] [TD=class: goal_difference positive]+۱[/TD] [TD=class: points last]۴۳[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۰[/TD] [TD=class: team, align: right]فولام[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۳[/TD] [TD=class: goals_against]۴۳[/TD] [TD=class: goal_difference positive]+۰[/TD] [TD=class: points last]۴۳[/TD] [/TR] [TR] [TD=class: rank first]۱۱[/TD] [TD=class: team, align: right]نورويج سيتي[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۴۷[/TD] [TD=class: goals_against]۵۸[/TD] [TD=class: goal_difference negative]-۱۱[/TD] [TD=class: points last]۴۳[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۲[/TD] [TD=class: team, align: right]سوانسي سيتي[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۴[/TD] [TD=class: goals_for]۳۸[/TD] [TD=class: goals_against]۴۴[/TD] [TD=class: goal_difference negative]-۶[/TD] [TD=class: points last]۴۲[/TD] [/TR] [TR] [TD=class: rank first]۱۳[/TD] [TD=class: team, align: right]وست برومويچ[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۱۶[/TD] [TD=class: goals_for]۴۰[/TD] [TD=class: goals_against]۴۷[/TD] [TD=class: goal_difference negative]-۷[/TD] [TD=class: points last]۴۲[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۴[/TD] [TD=class: team, align: right]استوک[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۳۲[/TD] [TD=class: goals_against]۴۵[/TD] [TD=class: goal_difference negative]-۱۳[/TD] [TD=class: points last]۴۲[/TD] [/TR] [TR] [TD=class: rank first]۱۵[/TD] [TD=class: team, align: right]استون ويلا[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۷[/TD] [TD=class: draws]۱۴[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۳۵[/TD] [TD=class: goals_against]۴۸[/TD] [TD=class: goal_difference negative]-۱۳[/TD] [TD=class: points last]۳۵[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۶[/TD] [TD=class: team, align: right]كوئينز پارك[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۸[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۱۹[/TD] [TD=class: goals_for]۳۸[/TD] [TD=class: goals_against]۵۷[/TD] [TD=class: goal_difference negative]-۱۹[/TD] [TD=class: points last]۳۱[/TD] [/TR] [TR] [TD=class: rank first]۱۷[/TD] [TD=class: team, align: right]ويگان[/TD] [TD=class: matches-played]۳۳[/TD] [TD=class: wins]۷[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۶[/TD] [TD=class: goals_for]۳۱[/TD] [TD=class: goals_against]۵۷[/TD] [TD=class: goal_difference negative]-۲۶[/TD] [TD=class: points last]۳۱[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۸[/TD] [TD=class: team, align: right]بولتون[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۹[/TD] [TD=class: draws]۲[/TD] [TD=class: losses]۲۱[/TD] [TD=class: goals_for]۳۶[/TD] [TD=class: goals_against]۶۵[/TD] [TD=class: goal_difference negative]-۲۹[/TD] [TD=class: points last]۲۹[/TD] [/TR] [TR] [TD=class: rank first]۱۹[/TD] [TD=class: team, align: right]بلکبرن[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۷[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۲۰[/TD] [TD=class: goals_for]۴۵[/TD] [TD=class: goals_against]۷۳[/TD] [TD=class: goal_difference negative]-۲۸[/TD] [TD=class: points last]۲۸[/TD] [/TR] [TR=class: last odd] [TD=class: rank first]۲۰[/TD] [TD=class: team, align: right]ولورهمپتون[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۵[/TD] [TD=class: draws]۸[/TD] [TD=class: losses]۲۱[/TD] [TD=class: goals_for]۳۴[/TD] [TD=class: goals_against]۷۳[/TD] [TD=class: goal_difference negative]-۳۹[/TD] [TD=class: points]۲۳[/TD] [/TR] [/TABLE] 1
spow 44203 سازنده ارسال شده در 27 تیر، 2012 جدول لالیگا [TABLE] [TR] [TH] [En] [/TH] [TH=class: team]تيم[/TH] [TH=class: matches-played]بازی[/TH] [TH=class: wins]برد[/TH] [TH=class: draws]مساوي[/TH] [TH=class: losses]باخت[/TH] [TH=class: goals_for]زده[/TH] [TH=class: goals_against]خورده[/TH] [TH=class: goal_difference]تفاضل گل[/TH] [TH=class: points last]امتیاز[/TH] [/TR] [TR=class: first] [TD=class: rank]۱[/TD] [TD=class: team, align: right]رئال مادريد[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۲۸[/TD] [TD=class: draws]۴[/TD] [TD=class: losses]۲[/TD] [TD=class: goals_for]۱۰۹[/TD] [TD=class: goals_against]۳۰[/TD] [TD=class: goal_difference positive]+۷۹[/TD] [TD=class: points last]۸۸[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۲[/TD] [TD=class: team, align: right]بارسلونا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۲۵[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۳[/TD] [TD=class: goals_for]۹۷[/TD] [TD=class: goals_against]۲۶[/TD] [TD=class: goal_difference positive]+۷۱[/TD] [TD=class: points last]۸۱[/TD] [/TR] [TR] [TD=class: rank first]۳[/TD] [TD=class: team, align: right]والنسيا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۵[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۹[/TD] [TD=class: goals_for]۵۴[/TD] [TD=class: goals_against]۴۲[/TD] [TD=class: goal_difference positive]+۱۲[/TD] [TD=class: points last]۵۵[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۴[/TD] [TD=class: team, align: right]مالاگا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۵[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۵۰[/TD] [TD=class: goals_against]۴۷[/TD] [TD=class: goal_difference positive]+۳[/TD] [TD=class: points last]۵۲[/TD] [/TR] [TR] [TD=class: rank first]۵[/TD] [TD=class: team, align: right]لوانته[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۴[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۴۸[/TD] [TD=class: goals_against]۴۷[/TD] [TD=class: goal_difference positive]+۱[/TD] [TD=class: points last]۴۹[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۶[/TD] [TD=class: team, align: right]اتلتيک بيلبائو[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۱۲[/TD] [TD=class: losses]۱۰[/TD] [TD=class: goals_for]۴۹[/TD] [TD=class: goals_against]۴۴[/TD] [TD=class: goal_difference positive]+۵[/TD] [TD=class: points last]۴۸[/TD] [/TR] [TR] [TD=class: rank first]۷[/TD] [TD=class: team, align: right]اتلتيكو مادريد[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۳[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۷[/TD] [TD=class: goals_against]۴۲[/TD] [TD=class: goal_difference positive]+۵[/TD] [TD=class: points last]۴۸[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۸[/TD] [TD=class: team, align: right]اوساسونا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۴[/TD] [TD=class: losses]۹[/TD] [TD=class: goals_for]۳۸[/TD] [TD=class: goals_against]۵۴[/TD] [TD=class: goal_difference negative]-۱۶[/TD] [TD=class: points last]۴۷[/TD] [/TR] [TR] [TD=class: rank first]۹[/TD] [TD=class: team, align: right]سويا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۱[/TD] [TD=class: goals_against]۳۹[/TD] [TD=class: goal_difference positive]+۲[/TD] [TD=class: points last]۴۶[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۰[/TD] [TD=class: team, align: right]اسپانيول[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۴۴[/TD] [TD=class: goals_against]۴۶[/TD] [TD=class: goal_difference negative]-۲[/TD] [TD=class: points last]۴۵[/TD] [/TR] [TR] [TD=class: rank first]۱۱[/TD] [TD=class: team, align: right]ختافه[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۳۸[/TD] [TD=class: goals_against]۴۵[/TD] [TD=class: goal_difference negative]-۷[/TD] [TD=class: points last]۴۵[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۲[/TD] [TD=class: team, align: right]مايورکا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۳۶[/TD] [TD=class: goals_against]۴۱[/TD] [TD=class: goal_difference negative]-۵[/TD] [TD=class: points last]۴۳[/TD] [/TR] [TR] [TD=class: rank first]۱۳[/TD] [TD=class: team, align: right]رئال بتيس[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۱۶[/TD] [TD=class: goals_for]۴۰[/TD] [TD=class: goals_against]۴۹[/TD] [TD=class: goal_difference negative]-۹[/TD] [TD=class: points last]۴۲[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۴[/TD] [TD=class: team, align: right]رئال سوسيداد[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۰[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۴[/TD] [TD=class: goals_for]۴۱[/TD] [TD=class: goals_against]۵۰[/TD] [TD=class: goal_difference negative]-۹[/TD] [TD=class: points last]۴۰[/TD] [/TR] [TR] [TD=class: rank first]۱۵[/TD] [TD=class: team, align: right]والکانو[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۴[/TD] [TD=class: losses]۱۸[/TD] [TD=class: goals_for]۵۰[/TD] [TD=class: goals_against]۶۰[/TD] [TD=class: goal_difference negative]-۱۰[/TD] [TD=class: points last]۴۰[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۶[/TD] [TD=class: team, align: right]گرانادا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۱۷[/TD] [TD=class: goals_for]۳۱[/TD] [TD=class: goals_against]۴۹[/TD] [TD=class: goal_difference negative]-۱۸[/TD] [TD=class: points last]۳۹[/TD] [/TR] [TR] [TD=class: rank first]۱۷[/TD] [TD=class: team, align: right]ويارئال[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۸[/TD] [TD=class: draws]۱۳[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۳۵[/TD] [TD=class: goals_against]۴۸[/TD] [TD=class: goal_difference negative]-۱۳[/TD] [TD=class: points last]۳۷[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۸[/TD] [TD=class: team, align: right]اسپورتينگ گيخون[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۸[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۱۹[/TD] [TD=class: goals_for]۳۵[/TD] [TD=class: goals_against]۶۴[/TD] [TD=class: goal_difference negative]-۲۹[/TD] [TD=class: points last]۳۱[/TD] [/TR] [TR] [TD=class: rank first]۱۹[/TD] [TD=class: team, align: right]زاراگوزا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۸[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۱۹[/TD] [TD=class: goals_for]۲۹[/TD] [TD=class: goals_against]۶۰[/TD] [TD=class: goal_difference negative]-۳۱[/TD] [TD=class: points last]۳۱[/TD] [/TR] [TR=class: last odd] [TD=class: rank first]۲۰[/TD] [TD=class: team, align: right]ريسينگ سانتاندر[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۴[/TD] [TD=class: draws]۱۴[/TD] [TD=class: losses]۱۶[/TD] [TD=class: goals_for]۲۴[/TD] [TD=class: goals_against]۵۳[/TD] [TD=class: goal_difference negative]-۲۹[/TD] [TD=class: points]۲۶[/TD] [/TR] [/TABLE] [TABLE] [TR=class: first] [TD=class: weekday]دوشنبه[/TD] [TD=class: date]۲۳/۰۴/۱۲[/TD] [TD=class: team-a]اوساسونا[/TD] [TD=class: result]۱ - ۱[/TD] [TD=class: team-b last]مالاگا[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]والنسيا[/TD] [TD=class: result]۴ - ۰[/TD] [TD=class: team-b last]رئال بتيس[/TD] [/TR] [TR] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]اتلتيكو مادريد[/TD] [TD=class: result]۳ - ۱[/TD] [TD=class: team-b last]اسپانيول[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]ريسينگ سانتاندر[/TD] [TD=class: result]۰ - ۱[/TD] [TD=class: team-b last]اتلتيک بيلبائو[/TD] [/TR] [TR] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]گرانادا[/TD] [TD=class: result]۱ - ۰[/TD] [TD=class: team-b last]ختافه[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]رئال سوسيداد[/TD] [TD=class: result]۱ - ۱[/TD] [TD=class: team-b last]ويارئال[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]سويا[/TD] [TD=class: result]۱ - ۱[/TD] [TD=class: team-b last]لوانته[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]بارسلونا[/TD] [TD=class: result]۱ - ۲[/TD] [TD=class: team-b last]رئال مادريد[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]مايورکا[/TD] [TD=class: result]۱ - ۰[/TD] [TD=class: team-b last]زاراگوزا[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]اسپورتينگ گيخون[/TD] [TD=class: result]۲ - ۱[/TD] [TD=class: team-b last]والکانو[/TD] [/TR] [TR] [TD=class: weekday first]دوشنبه[/TD] [TD=class: date]۱۶/۰۴/۱۲[/TD] [TD=class: team-a]ختافه[/TD] [TD=class: result]۵ - ۱[/TD] [TD=class: team-b last]سويا[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۱۵/۰۴/۱۲[/TD] [TD=class: team-a]والکانو[/TD] [TD=class: result]۰ - ۱[/TD] [TD=class: team-b last]اتلتيكو مادريد[/TD] [/TR] [TR] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۱۵/۰۴/۱۲[/TD] [TD=class: team-a]اتلتيک بيلبائو[/TD] [TD=class: result]۱ - ۰[/TD] [TD=class: team-b last]مايورکا[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۱۵/۰۴/۱۲[/TD] [TD=class: team-a]زاراگوزا[/TD] [TD=class: result]۱ - ۰[/TD] [TD=class: team-b last]گرانادا[/TD] [/TR] [TR] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۱۵/۰۴/۱۲[/TD] [TD=class: team-a]رئال بتيس[/TD] [TD=class: result]۱ - ۰[/TD] [TD=class: team-b last]اوساسونا[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۱۵/۰۴/۱۲[/TD] [TD=class: team-a]ويارئال[/TD] [TD=class: result]۱ - ۱[/TD] [TD=class: team-b last]ريسينگ سانتاندر[/TD] [/TR] [TR] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۱۵/۰۴/۱۲[/TD] [TD=class: team-a]مالاگا[/TD] [TD=class: result]۱ - ۱[/TD] [TD=class: team-b last]رئال سوسيداد[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۱۵/۰۴/۱۲[/TD] [TD=class: team-a]اسپانيول[/TD] [TD=class: result]۴ - ۰[/TD] [TD=class: team-b last]والنسيا[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۱۴/۰۴/۱۲[/TD] [TD=class: team-a]لوانته[/TD] [TD=class: result]۱ - ۲[/TD] [TD=class: team-b last]بارسلونا[/TD] [/TR] [TR=class: last odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۱۴/۰۴/۱۲[/TD] [TD=class: team-a]رئال مادريد[/TD] [TD=class: result]۳ - ۱[/TD] [TD=class: team-b]اسپورتينگ گيخون[/TD] [/TR] [/TABLE]
spow 44203 سازنده ارسال شده در 27 تیر، 2012 جدول سری آ ایتالیا [TABLE] [TR] [TH] [En] [/TH] [TH=class: team]تيم[/TH] [TH=class: matches-played]بازی[/TH] [TH=class: wins]برد[/TH] [TH=class: draws]مساوي[/TH] [TH=class: losses]باخت[/TH] [TH=class: goals_for]زده[/TH] [TH=class: goals_against]خورده[/TH] [TH=class: goal_difference]تفاضل گل[/TH] [TH=class: points last]امتیاز[/TH] [/TR] [TR=class: first] [TD=class: rank]۱[/TD] [TD=class: team, align: right]يوونتوس[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۲۰[/TD] [TD=class: draws]۱۴[/TD] [TD=class: losses]۰[/TD] [TD=class: goals_for]۵۸[/TD] [TD=class: goals_against]۱۸[/TD] [TD=class: goal_difference positive]+۴۰[/TD] [TD=class: points last]۷۴[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۲[/TD] [TD=class: team, align: right]آ ث ميلان[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۲۱[/TD] [TD=class: draws]۸[/TD] [TD=class: losses]۵[/TD] [TD=class: goals_for]۶۴[/TD] [TD=class: goals_against]۲۷[/TD] [TD=class: goal_difference positive]+۳۷[/TD] [TD=class: points last]۷۱[/TD] [/TR] [TR] [TD=class: rank first]۳[/TD] [TD=class: team, align: right]لاتزيو[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۶[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۱۱[/TD] [TD=class: goals_for]۵۰[/TD] [TD=class: goals_against]۴۳[/TD] [TD=class: goal_difference positive]+۷[/TD] [TD=class: points last]۵۵[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۴[/TD] [TD=class: team, align: right]ناپولي[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۴[/TD] [TD=class: draws]۱۲[/TD] [TD=class: losses]۸[/TD] [TD=class: goals_for]۶۰[/TD] [TD=class: goals_against]۴۱[/TD] [TD=class: goal_difference positive]+۱۹[/TD] [TD=class: points last]۵۴[/TD] [/TR] [TR] [TD=class: rank first]۵[/TD] [TD=class: team, align: right]اودينزه[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۴[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۰[/TD] [TD=class: goals_for]۴۵[/TD] [TD=class: goals_against]۳۵[/TD] [TD=class: goal_difference positive]+۱۰[/TD] [TD=class: points last]۵۲[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۶[/TD] [TD=class: team, align: right]اينتر[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۵[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۵۰[/TD] [TD=class: goals_against]۴۶[/TD] [TD=class: goal_difference positive]+۴[/TD] [TD=class: points last]۵۲[/TD] [/TR] [TR] [TD=class: rank first]۷[/TD] [TD=class: team, align: right]رم[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۵[/TD] [TD=class: draws]۵[/TD] [TD=class: losses]۱۴[/TD] [TD=class: goals_for]۵۳[/TD] [TD=class: goals_against]۴۸[/TD] [TD=class: goal_difference positive]+۵[/TD] [TD=class: points last]۵۰[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۸[/TD] [TD=class: team, align: right]كاتانيا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۳[/TD] [TD=class: losses]۱۰[/TD] [TD=class: goals_for]۴۴[/TD] [TD=class: goals_against]۴۶[/TD] [TD=class: goal_difference negative]-۲[/TD] [TD=class: points last]۴۶[/TD] [/TR] [TR] [TD=class: rank first]۹[/TD] [TD=class: team, align: right]پارما[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۱[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۶[/TD] [TD=class: goals_against]۵۱[/TD] [TD=class: goal_difference negative]-۵[/TD] [TD=class: points last]۴۴[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۰[/TD] [TD=class: team, align: right]سينا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۴۲[/TD] [TD=class: goals_against]۳۶[/TD] [TD=class: goal_difference positive]+۶[/TD] [TD=class: points last]۴۳[/TD] [/TR] [TR] [TD=class: rank first]۱۱[/TD] [TD=class: team, align: right]آتالانتا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۱۳[/TD] [TD=class: losses]۹[/TD] [TD=class: goals_for]۳۸[/TD] [TD=class: goals_against]۳۶[/TD] [TD=class: goal_difference positive]+۲[/TD] [TD=class: points last]۴۳[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۲[/TD] [TD=class: team, align: right]كيه وو[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۳۰[/TD] [TD=class: goals_against]۴۱[/TD] [TD=class: goal_difference negative]-۱۱[/TD] [TD=class: points last]۴۳[/TD] [/TR] [TR] [TD=class: rank first]۱۳[/TD] [TD=class: team, align: right]بلونيا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۰[/TD] [TD=class: draws]۱۲[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۳۵[/TD] [TD=class: goals_against]۴۰[/TD] [TD=class: goal_difference negative]-۵[/TD] [TD=class: points last]۴۲[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۴[/TD] [TD=class: team, align: right]فيورنتينا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۰[/TD] [TD=class: draws]۱۱[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۳۴[/TD] [TD=class: goals_against]۳۹[/TD] [TD=class: goal_difference negative]-۵[/TD] [TD=class: points last]۴۱[/TD] [/TR] [TR] [TD=class: rank first]۱۵[/TD] [TD=class: team, align: right]پالرمو[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۸[/TD] [TD=class: losses]۱۵[/TD] [TD=class: goals_for]۴۷[/TD] [TD=class: goals_against]۵۳[/TD] [TD=class: goal_difference negative]-۶[/TD] [TD=class: points last]۴۱[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۶[/TD] [TD=class: team, align: right]كالياري[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۰[/TD] [TD=class: draws]۱۱[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۳۶[/TD] [TD=class: goals_against]۴۲[/TD] [TD=class: goal_difference negative]-۶[/TD] [TD=class: points last]۴۱[/TD] [/TR] [TR] [TD=class: rank first]۱۷[/TD] [TD=class: team, align: right]جنوا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۹[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۶[/TD] [TD=class: goals_for]۴۴[/TD] [TD=class: goals_against]۶۳[/TD] [TD=class: goal_difference negative]-۱۹[/TD] [TD=class: points last]۳۶[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۸[/TD] [TD=class: team, align: right]لچه[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۸[/TD] [TD=class: draws]۱۱[/TD] [TD=class: losses]۱۵[/TD] [TD=class: goals_for]۳۸[/TD] [TD=class: goals_against]۵۱[/TD] [TD=class: goal_difference negative]-۱۳[/TD] [TD=class: points last]۳۵[/TD] [/TR] [TR] [TD=class: rank first]۱۹[/TD] [TD=class: team, align: right]نووارا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۶[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۸[/TD] [TD=class: goals_for]۲۹[/TD] [TD=class: goals_against]۵۷[/TD] [TD=class: goal_difference negative]-۲۸[/TD] [TD=class: points last]۲۸[/TD] [/TR] [TR=class: last odd] [TD=class: rank first]۲۰[/TD] [TD=class: team, align: right]چيزينا[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۴[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۲۰[/TD] [TD=class: goals_for]۲۱[/TD] [TD=class: goals_against]۵۱[/TD] [TD=class: goal_difference negative]-۳۰[/TD] [TD=class: points]۲۲[/TD] [/TR] [/TABLE] [TABLE] [TR=class: first] [TD=class: weekday]چهارشنبه[/TD] [TD=class: date]۲۵/۰۴/۱۲[/TD] [TD=class: team-a]چيزينا[/TD] [TD=class: result]۰ - ۱[/TD] [TD=class: team-b last]يوونتوس[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]چهارشنبه[/TD] [TD=class: date]۲۵/۰۴/۱۲[/TD] [TD=class: team-a]آ ث ميلان[/TD] [TD=class: result]۱ - ۰[/TD] [TD=class: team-b last]جنوا[/TD] [/TR] [TR] [TD=class: weekday first]چهارشنبه[/TD] [TD=class: date]۲۵/۰۴/۱۲[/TD] [TD=class: team-a]رم[/TD] [TD=class: result]۱ - ۲[/TD] [TD=class: team-b last]فيورنتينا[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]چهارشنبه[/TD] [TD=class: date]۲۵/۰۴/۱۲[/TD] [TD=class: team-a]سينا[/TD] [TD=class: result]۱ - ۱[/TD] [TD=class: team-b last]بلونيا[/TD] [/TR] [TR] [TD=class: weekday first]چهارشنبه[/TD] [TD=class: date]۲۵/۰۴/۱۲[/TD] [TD=class: team-a]اودينزه[/TD] [TD=class: result]۱ - ۳[/TD] [TD=class: team-b last]اينتر[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]چهارشنبه[/TD] [TD=class: date]۲۵/۰۴/۱۲[/TD] [TD=class: team-a]لچه[/TD] [TD=class: result]۰ - ۲[/TD] [TD=class: team-b last]ناپولي[/TD] [/TR] [TR] [TD=class: weekday first]چهارشنبه[/TD] [TD=class: date]۲۵/۰۴/۱۲[/TD] [TD=class: team-a]پالرمو[/TD] [TD=class: result]۱ - ۲[/TD] [TD=class: team-b last]پارما[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]چهارشنبه[/TD] [TD=class: date]۲۵/۰۴/۱۲[/TD] [TD=class: team-a]نووارا[/TD] [TD=class: result]۲ - ۱[/TD] [TD=class: team-b last]لاتزيو[/TD] [/TR] [TR=class: hover] [TD=class: weekday first]سه شنبه[/TD] [TD=class: date]۲۴/۰۴/۱۲[/TD] [TD=class: team-a]كالياري[/TD] [TD=class: result]۳ - ۰[/TD] [TD=class: team-b last]كاتانيا[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]سه شنبه[/TD] [TD=class: date]۲۴/۰۴/۱۲[/TD] [TD=class: team-a]آتالانتا[/TD] [TD=class: result]۱ - ۰[/TD] [TD=class: team-b last]كيه وو[/TD] [/TR] [TR] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]يوونتوس[/TD] [TD=class: result]۴ - ۰[/TD] [TD=class: team-b last]رم[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]آ ث ميلان[/TD] [TD=class: result]۱ - ۱[/TD] [TD=class: team-b last]بلونيا[/TD] [/TR] [TR] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]چيزينا[/TD] [TD=class: result]۲ - ۲[/TD] [TD=class: team-b last]پالرمو[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]لاتزيو[/TD] [TD=class: result]۱ - ۱[/TD] [TD=class: team-b last]لچه[/TD] [/TR] [TR] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]جنوا[/TD] [TD=class: result]۱ - ۴[/TD] [TD=class: team-b last]سينا[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]فيورنتينا[/TD] [TD=class: result]۰ - ۰[/TD] [TD=class: team-b last]اينتر[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]كاتانيا[/TD] [TD=class: result]۲ - ۰[/TD] [TD=class: team-b last]آتالانتا[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]ناپولي[/TD] [TD=class: result]۲ - ۰[/TD] [TD=class: team-b last]نووارا[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]پارما[/TD] [TD=class: result]۳ - ۰[/TD] [TD=class: team-b last]كالياري[/TD] [/TR] [TR=class: last odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]كيه وو[/TD] [TD=class: result]۰ - ۰[/TD] [TD=class: team-b]اودينزه[/TD] [/TR] [/TABLE]
spow 44203 سازنده ارسال شده در 27 تیر، 2012 جدول بوندس لیگای المان [TABLE] [TR] [TH] [En] [/TH] [TH=class: team]تيم[/TH] [TH=class: matches-played]بازی[/TH] [TH=class: wins]برد[/TH] [TH=class: draws]مساوي[/TH] [TH=class: losses]باخت[/TH] [TH=class: goals_for]زده[/TH] [TH=class: goals_against]خورده[/TH] [TH=class: goal_difference]تفاضل گل[/TH] [TH=class: points last]امتیاز[/TH] [/TR] [TR=class: first] [TD=class: rank]۱[/TD] [TD=class: team, align: right]بورسيا دورتموند[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۲۳[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۳[/TD] [TD=class: goals_for]۷۱[/TD] [TD=class: goals_against]۲۳[/TD] [TD=class: goal_difference positive]+۴۸[/TD] [TD=class: points last]۷۵[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۲[/TD] [TD=class: team, align: right]بايرن مونيخ[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۲۱[/TD] [TD=class: draws]۴[/TD] [TD=class: losses]۷[/TD] [TD=class: goals_for]۷۱[/TD] [TD=class: goals_against]۲۱[/TD] [TD=class: goal_difference positive]+۵۰[/TD] [TD=class: points last]۶۷[/TD] [/TR] [TR] [TD=class: rank first]۳[/TD] [TD=class: team, align: right]شالكه ۰۴[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۸[/TD] [TD=class: draws]۴[/TD] [TD=class: losses]۱۰[/TD] [TD=class: goals_for]۶۷[/TD] [TD=class: goals_against]۴۲[/TD] [TD=class: goal_difference positive]+۲۵[/TD] [TD=class: points last]۵۸[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۴[/TD] [TD=class: team, align: right]مونشن گلادباخ[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۶[/TD] [TD=class: draws]۸[/TD] [TD=class: losses]۸[/TD] [TD=class: goals_for]۴۶[/TD] [TD=class: goals_against]۲۴[/TD] [TD=class: goal_difference positive]+۲۲[/TD] [TD=class: points last]۵۶[/TD] [/TR] [TR] [TD=class: rank first]۵[/TD] [TD=class: team, align: right]اشتوتگارد[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۴[/TD] [TD=class: draws]۸[/TD] [TD=class: losses]۱۰[/TD] [TD=class: goals_for]۶۰[/TD] [TD=class: goals_against]۴۲[/TD] [TD=class: goal_difference positive]+۱۸[/TD] [TD=class: points last]۵۰[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۶[/TD] [TD=class: team, align: right]بايرلوركوزن[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۳[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۰[/TD] [TD=class: goals_for]۴۷[/TD] [TD=class: goals_against]۴۳[/TD] [TD=class: goal_difference positive]+۴[/TD] [TD=class: points last]۴۸[/TD] [/TR] [TR] [TD=class: rank first]۷[/TD] [TD=class: team, align: right]هانوفر[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۲[/TD] [TD=class: losses]۹[/TD] [TD=class: goals_for]۳۹[/TD] [TD=class: goals_against]۴۳[/TD] [TD=class: goal_difference negative]-۴[/TD] [TD=class: points last]۴۵[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۸[/TD] [TD=class: team, align: right]وردربرمن[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۶[/TD] [TD=class: goals_against]۵۲[/TD] [TD=class: goal_difference negative]-۶[/TD] [TD=class: points last]۴۲[/TD] [/TR] [TR] [TD=class: rank first]۹[/TD] [TD=class: team, align: right]هوفنهايم[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۰[/TD] [TD=class: draws]۱۱[/TD] [TD=class: losses]۱۱[/TD] [TD=class: goals_for]۳۸[/TD] [TD=class: goals_against]۴۱[/TD] [TD=class: goal_difference negative]-۳[/TD] [TD=class: points last]۴۱[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۰[/TD] [TD=class: team, align: right]ولفزبورگ[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۵[/TD] [TD=class: losses]۱۵[/TD] [TD=class: goals_for]۴۲[/TD] [TD=class: goals_against]۵۶[/TD] [TD=class: goal_difference negative]-۱۴[/TD] [TD=class: points last]۴۱[/TD] [/TR] [TR] [TD=class: rank first]۱۱[/TD] [TD=class: team, align: right]نورنبرگ[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۱۵[/TD] [TD=class: goals_for]۳۴[/TD] [TD=class: goals_against]۴۳[/TD] [TD=class: goal_difference negative]-۹[/TD] [TD=class: points last]۳۹[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۲[/TD] [TD=class: team, align: right]ماينتس[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۹[/TD] [TD=class: draws]۱۱[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۷[/TD] [TD=class: goals_against]۴۸[/TD] [TD=class: goal_difference negative]-۱[/TD] [TD=class: points last]۳۸[/TD] [/TR] [TR] [TD=class: rank first]۱۳[/TD] [TD=class: team, align: right]فرايبورگ[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۹[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۴۱[/TD] [TD=class: goals_against]۵۶[/TD] [TD=class: goal_difference negative]-۱۵[/TD] [TD=class: points last]۳۷[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۴[/TD] [TD=class: team, align: right]هامبورگ[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۸[/TD] [TD=class: draws]۱۱[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۳۵[/TD] [TD=class: goals_against]۵۶[/TD] [TD=class: goal_difference negative]-۲۱[/TD] [TD=class: points last]۳۵[/TD] [/TR] [TR] [TD=class: rank first]۱۵[/TD] [TD=class: team, align: right]آگسبورگ[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۷[/TD] [TD=class: draws]۱۳[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۳۵[/TD] [TD=class: goals_against]۴۹[/TD] [TD=class: goal_difference negative]-۱۴[/TD] [TD=class: points last]۳۴[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۶[/TD] [TD=class: team, align: right]کلن[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۸[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۱۸[/TD] [TD=class: goals_for]۳۷[/TD] [TD=class: goals_against]۶۷[/TD] [TD=class: goal_difference negative]-۳۰[/TD] [TD=class: points last]۳۰[/TD] [/TR] [TR] [TD=class: rank first]۱۷[/TD] [TD=class: team, align: right]هرتابرلين[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۶[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۶[/TD] [TD=class: goals_for]۳۵[/TD] [TD=class: goals_against]۵۹[/TD] [TD=class: goal_difference negative]-۲۴[/TD] [TD=class: points last]۲۸[/TD] [/TR] [TR=class: last odd] [TD=class: rank first]۱۸[/TD] [TD=class: team, align: right]کايزرسلاترن[/TD] [TD=class: matches-played]۳۲[/TD] [TD=class: wins]۴[/TD] [TD=class: draws]۱۱[/TD] [TD=class: losses]۱۷[/TD] [TD=class: goals_for]۲۱[/TD] [TD=class: goals_against]۴۷[/TD] [TD=class: goal_difference negative]-۲۶[/TD] [TD=class: points]۲۳[/TD] [/TR] [/TABLE] [TABLE] [TR=class: first] [TD=class: weekday]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]هانوفر[/TD] [TD=class: result]۰ - ۰[/TD] [TD=class: team-b last]فرايبورگ[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]آگسبورگ[/TD] [TD=class: result]۱ - ۱[/TD] [TD=class: team-b last]شالكه ۰۴[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]بورسيا دورتموند[/TD] [TD=class: result]۲ - ۰[/TD] [TD=class: team-b last]مونشن گلادباخ[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]وردربرمن[/TD] [TD=class: result]۱ - ۲[/TD] [TD=class: team-b last]بايرن مونيخ[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]نورنبرگ[/TD] [TD=class: result]۱ - ۱[/TD] [TD=class: team-b last]هامبورگ[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]هوفنهايم[/TD] [TD=class: result]۰ - ۱[/TD] [TD=class: team-b last]بايرلوركوزن[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]کلن[/TD] [TD=class: result]۱ - ۱[/TD] [TD=class: team-b last]اشتوتگارد[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]هرتابرلين[/TD] [TD=class: result]۱ - ۲[/TD] [TD=class: team-b last]کايزرسلاترن[/TD] [/TR] [TR] [TD=class: weekday first]جمعه[/TD] [TD=class: date]۲۰/۰۴/۱۲[/TD] [TD=class: team-a]ماينتس[/TD] [TD=class: result]۰ - ۰[/TD] [TD=class: team-b last]ولفزبورگ[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۱۵/۰۴/۱۲[/TD] [TD=class: team-a]فرايبورگ[/TD] [TD=class: result]۰ - ۰[/TD] [TD=class: team-b last]هوفنهايم[/TD] [/TR] [TR] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۱۵/۰۴/۱۲[/TD] [TD=class: team-a]مونشن گلادباخ[/TD] [TD=class: result]۳ - ۰[/TD] [TD=class: team-b last]کلن[/TD] [/TR] [TR=class: odd hover] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۱۴/۰۴/۱۲[/TD] [TD=class: team-a]بايرن مونيخ[/TD] [TD=class: result]۰ - ۰[/TD] [TD=class: team-b last]ماينتس[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۱۴/۰۴/۱۲[/TD] [TD=class: team-a]بايرلوركوزن[/TD] [TD=class: result]۳ - ۳[/TD] [TD=class: team-b last]هرتابرلين[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۱۴/۰۴/۱۲[/TD] [TD=class: team-a]هامبورگ[/TD] [TD=class: result]۱ - ۰[/TD] [TD=class: team-b last]هانوفر[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۱۴/۰۴/۱۲[/TD] [TD=class: team-a]شالكه ۰۴[/TD] [TD=class: result]۱ - ۲[/TD] [TD=class: team-b last]بورسيا دورتموند[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۱۴/۰۴/۱۲[/TD] [TD=class: team-a]کايزرسلاترن[/TD] [TD=class: result]۰ - ۲[/TD] [TD=class: team-b last]نورنبرگ[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۱۴/۰۴/۱۲[/TD] [TD=class: team-a]ولفزبورگ[/TD] [TD=class: result]۱ - ۲[/TD] [TD=class: team-b last]آگسبورگ[/TD] [/TR] [TR=class: last odd] [TD=class: weekday first]جمعه[/TD] [TD=class: date]۱۳/۰۴/۱۲[/TD] [TD=class: team-a]اشتوتگارد[/TD] [TD=class: result]۴ - ۱[/TD] [TD=class: team-b]وردربرمن[/TD] [/TR] [/TABLE]
spow 44203 سازنده ارسال شده در 27 تیر، 2012 جدول لیگ دسته اول انگلستان [TABLE] [TR] [TH] [En] [/TH] [TH=class: team]تيم[/TH] [TH=class: matches-played]بازی[/TH] [TH=class: wins]برد[/TH] [TH=class: draws]مساوي[/TH] [TH=class: losses]باخت[/TH] [TH=class: goals_for]زده[/TH] [TH=class: goals_against]خورده[/TH] [TH=class: goal_difference]تفاضل گل[/TH] [TH=class: points last]امتیاز[/TH] [/TR] [TR=class: first] [TD=class: rank]۱[/TD] [TD=class: team, align: right]منچستر يونايتد[/TD] [TD=class: matches-played]۳۵[/TD] [TD=class: wins]۲۶[/TD] [TD=class: draws]۵[/TD] [TD=class: losses]۴[/TD] [TD=class: goals_for]۸۶[/TD] [TD=class: goals_against]۳۲[/TD] [TD=class: goal_difference positive]+۵۴[/TD] [TD=class: points last]۸۳[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۲[/TD] [TD=class: team, align: right]منچستر سيتي[/TD] [TD=class: matches-played]۳۵[/TD] [TD=class: wins]۲۵[/TD] [TD=class: draws]۵[/TD] [TD=class: losses]۵[/TD] [TD=class: goals_for]۸۷[/TD] [TD=class: goals_against]۲۷[/TD] [TD=class: goal_difference positive]+۶۰[/TD] [TD=class: points last]۸۰[/TD] [/TR] [TR] [TD=class: rank first]۳[/TD] [TD=class: team, align: right]آرسنال[/TD] [TD=class: matches-played]۳۵[/TD] [TD=class: wins]۲۰[/TD] [TD=class: draws]۵[/TD] [TD=class: losses]۱۰[/TD] [TD=class: goals_for]۶۷[/TD] [TD=class: goals_against]۴۳[/TD] [TD=class: goal_difference positive]+۲۴[/TD] [TD=class: points last]۶۵[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۴[/TD] [TD=class: team, align: right]نيوکاسل[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۸[/TD] [TD=class: draws]۸[/TD] [TD=class: losses]۸[/TD] [TD=class: goals_for]۵۳[/TD] [TD=class: goals_against]۴۲[/TD] [TD=class: goal_difference positive]+۱۱[/TD] [TD=class: points last]۶۲[/TD] [/TR] [TR] [TD=class: rank first]۵[/TD] [TD=class: team, align: right]تاتنهام[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۷[/TD] [TD=class: draws]۸[/TD] [TD=class: losses]۹[/TD] [TD=class: goals_for]۵۷[/TD] [TD=class: goals_against]۳۹[/TD] [TD=class: goal_difference positive]+۱۸[/TD] [TD=class: points last]۵۹[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۶[/TD] [TD=class: team, align: right]چلسي[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۶[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۸[/TD] [TD=class: goals_for]۵۶[/TD] [TD=class: goals_against]۳۸[/TD] [TD=class: goal_difference positive]+۱۸[/TD] [TD=class: points last]۵۸[/TD] [/TR] [TR] [TD=class: rank first]۷[/TD] [TD=class: team, align: right]اورتون[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۳[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۲[/TD] [TD=class: goals_against]۳۸[/TD] [TD=class: goal_difference positive]+۴[/TD] [TD=class: points last]۴۸[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۸[/TD] [TD=class: team, align: right]ليورپول[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۰[/TD] [TD=class: goals_against]۳۷[/TD] [TD=class: goal_difference positive]+۳[/TD] [TD=class: points last]۴۶[/TD] [/TR] [TR] [TD=class: rank first]۹[/TD] [TD=class: team, align: right]فولام[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۲[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۲[/TD] [TD=class: goals_for]۴۵[/TD] [TD=class: goals_against]۴۴[/TD] [TD=class: goal_difference positive]+۱[/TD] [TD=class: points last]۴۶[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۰[/TD] [TD=class: team, align: right]وست برومويچ[/TD] [TD=class: matches-played]۳۵[/TD] [TD=class: wins]۱۳[/TD] [TD=class: draws]۶[/TD] [TD=class: losses]۱۶[/TD] [TD=class: goals_for]۴۱[/TD] [TD=class: goals_against]۴۷[/TD] [TD=class: goal_difference negative]-۶[/TD] [TD=class: points last]۴۵[/TD] [/TR] [TR] [TD=class: rank first]۱۱[/TD] [TD=class: team, align: right]ساندرلند[/TD] [TD=class: matches-played]۳۵[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۱[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۴۲[/TD] [TD=class: goals_against]۴۱[/TD] [TD=class: goal_difference positive]+۱[/TD] [TD=class: points last]۴۴[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۲[/TD] [TD=class: team, align: right]سوانسي سيتي[/TD] [TD=class: matches-played]۳۵[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۴[/TD] [TD=class: goals_for]۳۹[/TD] [TD=class: goals_against]۴۵[/TD] [TD=class: goal_difference negative]-۶[/TD] [TD=class: points last]۴۳[/TD] [/TR] [TR] [TD=class: rank first]۱۳[/TD] [TD=class: team, align: right]نورويج سيتي[/TD] [TD=class: matches-played]۳۵[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۴[/TD] [TD=class: goals_for]۴۷[/TD] [TD=class: goals_against]۶۰[/TD] [TD=class: goal_difference negative]-۱۳[/TD] [TD=class: points last]۴۳[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۴[/TD] [TD=class: team, align: right]استوک[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۱[/TD] [TD=class: draws]۹[/TD] [TD=class: losses]۱۴[/TD] [TD=class: goals_for]۳۲[/TD] [TD=class: goals_against]۴۸[/TD] [TD=class: goal_difference negative]-۱۶[/TD] [TD=class: points last]۴۲[/TD] [/TR] [TR] [TD=class: rank first]۱۵[/TD] [TD=class: team, align: right]استون ويلا[/TD] [TD=class: matches-played]۳۵[/TD] [TD=class: wins]۷[/TD] [TD=class: draws]۱۵[/TD] [TD=class: losses]۱۳[/TD] [TD=class: goals_for]۳۶[/TD] [TD=class: goals_against]۵۰[/TD] [TD=class: goal_difference negative]-۱۴[/TD] [TD=class: points last]۳۶[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۶[/TD] [TD=class: team, align: right]كوئينز پارك[/TD] [TD=class: matches-played]۳۵[/TD] [TD=class: wins]۹[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۱۹[/TD] [TD=class: goals_for]۳۹[/TD] [TD=class: goals_against]۵۷[/TD] [TD=class: goal_difference negative]-۱۸[/TD] [TD=class: points last]۳۴[/TD] [/TR] [TR] [TD=class: rank first]۱۷[/TD] [TD=class: team, align: right]ويگان[/TD] [TD=class: matches-played]۳۵[/TD] [TD=class: wins]۸[/TD] [TD=class: draws]۱۰[/TD] [TD=class: losses]۱۷[/TD] [TD=class: goals_for]۳۴[/TD] [TD=class: goals_against]۶۰[/TD] [TD=class: goal_difference negative]-۲۶[/TD] [TD=class: points last]۳۴[/TD] [/TR] [TR=class: odd] [TD=class: rank first]۱۸[/TD] [TD=class: team, align: right]بولتون[/TD] [TD=class: matches-played]۳۴[/TD] [TD=class: wins]۱۰[/TD] [TD=class: draws]۳[/TD] [TD=class: losses]۲۱[/TD] [TD=class: goals_for]۳۹[/TD] [TD=class: goals_against]۶۷[/TD] [TD=class: goal_difference negative]-۲۸[/TD] [TD=class: points last]۳۳[/TD] [/TR] [TR] [TD=class: rank first]۱۹[/TD] [TD=class: team, align: right]بلکبرن[/TD] [TD=class: matches-played]۳۵[/TD] [TD=class: wins]۸[/TD] [TD=class: draws]۷[/TD] [TD=class: losses]۲۰[/TD] [TD=class: goals_for]۴۷[/TD] [TD=class: goals_against]۷۳[/TD] [TD=class: goal_difference negative]-۲۶[/TD] [TD=class: points last]۳۱[/TD] [/TR] [TR=class: last odd] [TD=class: rank first]۲۰[/TD] [TD=class: team, align: right]ولورهمپتون[/TD] [TD=class: matches-played]۳۵[/TD] [TD=class: wins]۵[/TD] [TD=class: draws]۸[/TD] [TD=class: losses]۲۲[/TD] [TD=class: goals_for]۳۴[/TD] [TD=class: goals_against]۷۵[/TD] [TD=class: goal_difference negative]-۴۱[/TD] [TD=class: points]۲۳[/TD] [/TR] [/TABLE] [TABLE] [TR=class: first] [TD=class: weekday]سه شنبه[/TD] [TD=class: date]۲۴/۰۴/۱۲[/TD] [TD=class: team-a]استون ويلا[/TD] [TD=class: result]۱ - ۲[/TD] [TD=class: team-b last]بولتون[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]ولورهمپتون[/TD] [TD=class: result]۰ - ۲[/TD] [TD=class: team-b last]منچستر سيتي[/TD] [/TR] [TR] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]ليورپول[/TD] [TD=class: result]۰ - ۱[/TD] [TD=class: team-b last]وست برومويچ[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۲۲/۰۴/۱۲[/TD] [TD=class: team-a]منچستر يونايتد[/TD] [TD=class: result]۴ - ۴[/TD] [TD=class: team-b last]اورتون[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]كوئينز پارك[/TD] [TD=class: result]۱ - ۰[/TD] [TD=class: team-b last]تاتنهام[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]استون ويلا[/TD] [TD=class: result]۰ - ۰[/TD] [TD=class: team-b last]ساندرلند[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]بولتون[/TD] [TD=class: result]۱ - ۱[/TD] [TD=class: team-b last]سوانسي سيتي[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]بلکبرن[/TD] [TD=class: result]۲ - ۰[/TD] [TD=class: team-b last]نورويج سيتي[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]نيوکاسل[/TD] [TD=class: result]۳ - ۰[/TD] [TD=class: team-b last]استوک[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]فولام[/TD] [TD=class: result]۲ - ۱[/TD] [TD=class: team-b last]ويگان[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۲۱/۰۴/۱۲[/TD] [TD=class: team-a]آرسنال[/TD] [TD=class: result]۰ - ۰[/TD] [TD=class: team-b last]چلسي[/TD] [/TR] [TR=class: odd hover] [TD=class: weekday first]دوشنبه[/TD] [TD=class: date]۱۶/۰۴/۱۲[/TD] [TD=class: team-a]آرسنال[/TD] [TD=class: result]۱ - ۲[/TD] [TD=class: team-b last]ويگان[/TD] [/TR] [TR] [TD=class: weekday first]يكشنبه[/TD] [TD=class: date]۱۵/۰۴/۱۲[/TD] [TD=class: team-a]منچستر يونايتد[/TD] [TD=class: result]۴ - ۰[/TD] [TD=class: team-b last]استون ويلا[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۱۴/۰۴/۱۲[/TD] [TD=class: team-a]ساندرلند[/TD] [TD=class: result]۰ - ۰[/TD] [TD=class: team-b last]ولورهمپتون[/TD] [/TR] [TR] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۱۴/۰۴/۱۲[/TD] [TD=class: team-a]سوانسي سيتي[/TD] [TD=class: result]۳ - ۰[/TD] [TD=class: team-b last]بلکبرن[/TD] [/TR] [TR=class: odd] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۱۴/۰۴/۱۲[/TD] [TD=class: team-a]وست برومويچ[/TD] [TD=class: result]۱ - ۰[/TD] [TD=class: team-b last]كوئينز پارك[/TD] [/TR] [TR=class: last] [TD=class: weekday first]شنبه[/TD] [TD=class: date]۱۴/۰۴/۱۲[/TD] [TD=class: team-a]نورويج سيتي[/TD] [TD=class: result]۱ - ۶[/TD] [TD=class: team-b]منچستر سيتي[/TD] [/TR] [/TABLE]
ارسالهای توصیه شده
