panisa 12132 اشتراک گذاری ارسال شده در 8 فروردین، ۱۳۹۱ Ease of Access keyboard shortcuts [TABLE] [TR] [TD]Right Shift for eight seconds[/TD] [TD]Turn Filter Keys on and off[/TD] [/TR] [TR] [TD]Left Alt+Left Shift+PrtScn (or PrtScn)[/TD] [TD]Turn High Contrast on or off[/TD] [/TR] [TR] [TD]Left Alt+Left Shift+Num Lock[/TD] [TD]Turn Mouse Keys on or off[/TD] [/TR] [TR] [TD]Shift five times[/TD] [TD]Turn Sticky Keys on or off[/TD] [/TR] [TR] [TD]Num Lock for five seconds[/TD] [TD]Turn Toggle Keys on or off[/TD] [/TR] [TR] [TD]Windows logo key +U[/TD] [TD]Open the Ease of Access Center[/TD] [/TR] [/TABLE] 10 لینک به دیدگاه
panisa 12132 مالک اشتراک گذاری ارسال شده در 8 فروردین، ۱۳۹۱ General keyboard shortcuts [TABLE] [TR] [TD]F1[/TD] [TD]Display Help[/TD] [/TR] [TR] [TD]Ctrl+C (or Ctrl+Insert)[/TD] [TD]Copy the selected item[/TD] [/TR] [TR] [TD]Ctrl+X[/TD] [TD]Cut the selected item[/TD] [/TR] [TR] [TD]Ctrl+V (or Shift+Insert)[/TD] [TD]Paste the selected item[/TD] [/TR] [TR] [TD]Ctrl+Z[/TD] [TD]Undo an action[/TD] [/TR] [TR] [TD]Ctrl+Y[/TD] [TD]Redo an action[/TD] [/TR] [TR] [TD]Delete (or Ctrl+D)[/TD] [TD]Delete the selected item and move it to the Recycle Bin[/TD] [/TR] [TR] [TD]Shift+Delete[/TD] [TD]Delete the selected item without moving it to the Recycle Bin first[/TD] [/TR] [TR] [TD]F2[/TD] [TD]Rename the selected item[/TD] [/TR] [TR] [TD]Ctrl+Right Arrow[/TD] [TD]Move the cursor to the beginning of the next word[/TD] [/TR] [TR] [TD]Ctrl+Left Arrow[/TD] [TD]Move the cursor to the beginning of the previous word[/TD] [/TR] [TR] [TD]Ctrl+Down Arrow[/TD] [TD]Move the cursor to the beginning of the next paragraph[/TD] [/TR] [TR] [TD]Ctrl+Up Arrow[/TD] [TD]Move the cursor to the beginning of the previous paragraph[/TD] [/TR] [TR] [TD]Ctrl+Shift with an arrow key[/TD] [TD]Select a block of text[/TD] [/TR] [TR] [TD]Shift with any arrow key[/TD] [TD]Select more than one item in a window or on the desktop, or select text within a document[/TD] [/TR] [TR] [TD]Ctrl with any arrow key+Spacebar[/TD] [TD]Select multiple individual items in a window or on the desktop[/TD] [/TR] [TR] [TD]Ctrl+A[/TD] [TD]Select all items in a document or window[/TD] [/TR] [TR] [TD]F3[/TD] [TD]Search for a file or folder[/TD] [/TR] [TR] [TD]Alt+Enter[/TD] [TD]Display properties for the selected item[/TD] [/TR] [TR] [TD]Alt+F4[/TD] [TD]Close the active item, or exit the active program[/TD] [/TR] [TR] [TD]Alt+Spacebar[/TD] [TD]Open the shortcut menu for the active window[/TD] [/TR] [TR] [TD]Ctrl+F4[/TD] [TD]Close the active document (in programs that allow you to have multiple documents open simultaneously)[/TD] [/TR] [TR] [TD]Alt+Tab[/TD] [TD]Switch between open items[/TD] [/TR] [TR] [TD]Ctrl+Alt+Tab[/TD] [TD]Use the arrow keys to switch between open items[/TD] [/TR] [TR] [TD]Ctrl+Mouse scroll wheel[/TD] [TD]Change the size of icons on the desktop[/TD] [/TR] [TR] [TD]Windows logo key Win +Tab[/TD] [TD]Cycle through programs on the taskbar by using Aero Flip 3-D[/TD] [/TR] [TR] [TD]Ctrl+Windows logo key Win +Tab[/TD] [TD]Use the arrow keys to cycle through programs on the taskbar by using Aero Flip 3-D[/TD] [/TR] [TR] [TD]Alt+Esc[/TD] [TD]Cycle through items in the order in which they were opened[/TD] [/TR] [TR] [TD]F6[/TD] [TD]Cycle through screen elements in a window or on the desktop[/TD] [/TR] [TR] [TD]F4[/TD] [TD]Display the address bar list in Windows Explorer[/TD] [/TR] [TR] [TD]Shift+F10[/TD] [TD]Display the shortcut menu for the selected item[/TD] [/TR] [TR] [TD]Ctrl+Esc[/TD] [TD]Open the Start menu[/TD] [/TR] [TR] [TD]Alt+underlined letter[/TD] [TD]Display the corresponding menu[/TD] [/TR] [TR] [TD]Alt+underlined letter[/TD] [TD]Perform the menu command (or other underlined command)[/TD] [/TR] [TR] [TD]F10[/TD] [TD]Activate the menu bar in the active program[/TD] [/TR] [TR] [TD]Right Arrow[/TD] [TD]Open the next menu to the right, or open a submenu[/TD] [/TR] [TR] [TD]Left Arrow[/TD] [TD]Open the next menu to the left, or close a submenu[/TD] [/TR] [TR] [TD]F5 (or Ctrl+R)[/TD] [TD]Refresh the active window[/TD] [/TR] [TR] [TD]Alt+Up Arrow[/TD] [TD]View the folder one level up in Windows Explorer[/TD] [/TR] [TR] [TD]Esc[/TD] [TD]Cancel the current task[/TD] [/TR] [TR] [TD]Ctrl+Shift+Esc[/TD] [TD]Open Task Manager[/TD] [/TR] [TR] [TD]Shift when you insert a CD[/TD] [TD]Prevent the CD from automatically playing[/TD] [/TR] [TR] [TD]Left Alt+Shift[/TD] [TD]Switch the input language when multiple input languages are enabled[/TD] [/TR] [TR] [TD]Ctrl+Shift[/TD] [TD]Switch the keyboard layout when multiple keyboard layouts are enabled[/TD] [/TR] [TR] [TD]Right or Left Ctrl+Shift[/TD] [TD]Change the reading direction of text in right-to-left reading languages[/TD] [/TR] [/TABLE] 5 لینک به دیدگاه
panisa 12132 مالک اشتراک گذاری ارسال شده در 8 فروردین، ۱۳۹۱ Dialog box keyboard shortcuts [TABLE] [TR] [TD]Ctrl+Tab[/TD] [TD]Move forward through tabs[/TD] [/TR] [TR] [TD]Ctrl+Shift+Tab[/TD] [TD]Move back through tabs[/TD] [/TR] [TR] [TD]Tab[/TD] [TD]Move forward through options[/TD] [/TR] [TR] [TD]Shift+Tab[/TD] [TD]Move back through options[/TD] [/TR] [TR] [TD]Alt+underlined letter[/TD] [TD]Perform the command (or select the option) that goes with that letter[/TD] [/TR] [TR] [TD]Enter[/TD] [TD]Replaces clicking the mouse for many selected commands[/TD] [/TR] [TR] [TD]Spacebar[/TD] [TD]Select or clear the check box if the active option is a check box[/TD] [/TR] [TR] [TD]Arrow keys[/TD] [TD]Select a button if the active option is a group of option buttons[/TD] [/TR] [TR] [TD]F1[/TD] [TD]Display Help[/TD] [/TR] [TR] [TD]F4[/TD] [TD]Display the items in the active list[/TD] [/TR] [TR] [TD]Backspace[/TD] [TD]Open a folder one level up if a folder is selected in the Save As or Open dialog box[/TD] [/TR] [/TABLE] 7 لینک به دیدگاه
panisa 12132 مالک اشتراک گذاری ارسال شده در 8 فروردین، ۱۳۹۱ Windows logo key keyboard shortcuts [TABLE] [TR] [TD]Windows logo key [/TD] [TD]Open or close the Start menu.[/TD] [/TR] [TR] [TD]Windows logo key +Pause[/TD] [TD]Display the System Properties dialog box.[/TD] [/TR] [TR] [TD]Windows logo key +D[/TD] [TD]Display the desktop.[/TD] [/TR] [TR] [TD]Windows logo key +M[/TD] [TD]Minimize all windows.[/TD] [/TR] [TR] [TD]Windows logo key +Shift+M[/TD] [TD]Restore minimized windows to the desktop.[/TD] [/TR] [TR] [TD]Windows logo key +E[/TD] [TD]Open Computer.[/TD] [/TR] [TR] [TD]Windows logo key +F[/TD] [TD]Search for a file or folder.[/TD] [/TR] [TR] [TD]Ctrl+Windows logo key +F[/TD] [TD]Search for computers (if you're on a network).[/TD] [/TR] [TR] [TD]Windows logo key +L[/TD] [TD]Lock your computer or switch users.[/TD] [/TR] [TR] [TD]Windows logo key +R[/TD] [TD]Open the Run dialog box.[/TD] [/TR] [TR] [TD]Windows logo key +T[/TD] [TD]Cycle through programs on the taskbar.[/TD] [/TR] [TR] [TD]Windows logo key +number[/TD] [TD]Start the program pinned to the taskbar in the position indicated by the number. If the program is already running, switch to that program.[/TD] [/TR] [TR] [TD]Shift+Windows logo key number[/TD] [TD]Start a new instance of the program pinned to the taskbar in the position indicated by the number.[/TD] [/TR] [TR] [TD]Ctrl+Windows logo key +number[/TD] [TD]Switch to the last active window of the program pinned to the taskbar in the position indicated by the number.[/TD] [/TR] [TR] [TD]Alt+Windows logo key +number[/TD] [TD]Open the Jump List for the program pinned to the taskbar in the position indicated by the number.[/TD] [/TR] [TR] [TD]Windows logo key +Tab[/TD] [TD]Cycle through programs on the taskbar by using Aero Flip 3-D.[/TD] [/TR] [TR] [TD]Ctrl+Windows logo key +Tab[/TD] [TD]Use the arrow keys to cycle through programs on the taskbar by using Aero Flip 3-D.[/TD] [/TR] [TR] [TD]Ctrl+Windows logo key +B[/TD] [TD]Switch to the program that displayed a message in the notification area.[/TD] [/TR] [TR] [TD]Windows logo key +Spacebar[/TD] [TD]Preview the desktop.[/TD] [/TR] [TR] [TD]Windows logo key +Up Arrow[/TD] [TD]Maximize the window.[/TD] [/TR] [TR] [TD]Windows logo key +Left Arrow[/TD] [TD]Maximize the window to the left side of the screen.[/TD] [/TR] [TR] [TD]Windows logo key +Right Arrow[/TD] [TD]Maximize the window to the right side of the screen.[/TD] [/TR] [TR] [TD]Windows logo key +Down Arrow[/TD] [TD]Minimize the window.[/TD] [/TR] [TR] [TD]Windows logo key +Home[/TD] [TD]Minimize all but the active window.[/TD] [/TR] [TR] [TD]Windows logo key +Shift+Up Arrow[/TD] [TD]Stretch the window to the top and bottom of the screen.[/TD] [/TR] [TR] [TD]Windows logo key +Shift+Left Arrow or Right Arrow[/TD] [TD]Move a window from one monitor to another.[/TD] [/TR] [TR] [TD]Windows logo key +P[/TD] [TD]Choose a presentation display mode.[/TD] [/TR] [TR] [TD]Windows logo key +G[/TD] [TD]Cycle through gadgets.[/TD] [/TR] [TR] [TD]Windows logo key +U[/TD] [TD]Open Ease of Access Center.[/TD] [/TR] [TR] [TD]Windows logo key +X[/TD] [TD]Open Windows Mobility Center.[/TD] [/TR] [/TABLE] 7 لینک به دیدگاه
panisa 12132 مالک اشتراک گذاری ارسال شده در 8 فروردین، ۱۳۹۱ Windows Explorer keyboard shortcuts [TABLE] [TR] [TD]Ctrl+N[/TD] [TD]Open a new window[/TD] [/TR] [TR] [TD]Ctrl+W[/TD] [TD]Close the current window[/TD] [/TR] [TR] [TD]Ctrl+Shift+N[/TD] [TD]Create a new folder[/TD] [/TR] [TR] [TD]End[/TD] [TD]Display the bottom of the active window[/TD] [/TR] [TR] [TD]Home[/TD] [TD]Display the top of the active window[/TD] [/TR] [TR] [TD]F11[/TD] [TD]Maximize or minimize the active window[/TD] [/TR] [TR] [TD]Ctrl+Period (.)[/TD] [TD]Rotate a picture clockwise[/TD] [/TR] [TR] [TD]Ctrl+Comma (,)[/TD] [TD]Rotate a picture counter-clockwise[/TD] [/TR] [TR] [TD]Num Lock+Asterisk (*) on numeric keypad[/TD] [TD]Display all subfolders under the selected folder[/TD] [/TR] [TR] [TD]Num Lock+Plus Sign (+) on numeric keypad[/TD] [TD]Display the contents of the selected folder[/TD] [/TR] [TR] [TD]Num Lock+Minus Sign (-) on numeric keypad[/TD] [TD]Collapse the selected folder[/TD] [/TR] [TR] [TD]Left Arrow[/TD] [TD]Collapse the current selection (if it's expanded), or select the parent folder[/TD] [/TR] [TR] [TD]Alt+Enter[/TD] [TD]Open the Properties dialog box for the selected item[/TD] [/TR] [TR] [TD]Alt+P[/TD] [TD]Display the preview pane[/TD] [/TR] [TR] [TD]Alt+Left Arrow[/TD] [TD]View the previous folder[/TD] [/TR] [TR] [TD]Backspace[/TD] [TD]View the previous folder[/TD] [/TR] [TR] [TD]Right Arrow[/TD] [TD]Display the current selection (if it's collapsed), or select the first subfolder[/TD] [/TR] [TR] [TD]Alt+Right Arrow[/TD] [TD]View the next folder[/TD] [/TR] [TR] [TD]Alt+Up Arrow[/TD] [TD]View the parent folder[/TD] [/TR] [TR] [TD]Ctrl+Shift+E[/TD] [TD]Display all folders above the selected folder[/TD] [/TR] [TR] [TD]Ctrl+Mouse scroll wheel[/TD] [TD]Change the size and appearance of file and folder icons[/TD] [/TR] [TR] [TD]Alt+D[/TD] [TD]Select the address bar[/TD] [/TR] [TR] [TD]Ctrl+E[/TD] [TD]Select the search box[/TD] [/TR] [TR] [TD]Ctrl+F[/TD] [TD]Select the search box[/TD] [/TR] [/TABLE] 6 لینک به دیدگاه
panisa 12132 مالک اشتراک گذاری ارسال شده در 8 فروردین، ۱۳۹۱ Taskbar keyboard shortcuts [TABLE] [TR] [TD]Shift+Click on a taskbar button[/TD] [TD]Open a program or quickly open another instance of a program[/TD] [/TR] [TR] [TD]Ctrl+Shift+Click on a taskbar button[/TD] [TD]Open a program as an administrator[/TD] [/TR] [TR] [TD]Shift+Right-click on a taskbar button[/TD] [TD]Show the window menu for the program[/TD] [/TR] [TR] [TD]Shift+Right-click on a grouped taskbar button[/TD] [TD]Show the window menu for the group[/TD] [/TR] [TR] [TD]Ctrl+Click on a grouped taskbar button[/TD] [TD]Cycle through the windows of the group[/TD] [/TR] [/TABLE] 5 لینک به دیدگاه
panisa 12132 مالک اشتراک گذاری ارسال شده در 8 فروردین، ۱۳۹۱ Magnifier keyboard shortcuts [TABLE] [TR] [TD]Windows logo key + Plus Sign (+) or Minus Sign (-)[/TD] [TD]Zoom in or out[/TD] [/TR] [TR] [TD]Ctrl+Alt+Spacebar[/TD] [TD]Preview the desktop in full-screen mode[/TD] [/TR] [TR] [TD]Ctrl+Alt+F[/TD] [TD]Switch to full-screen mode[/TD] [/TR] [TR] [TD]Ctrl+Alt+L[/TD] [TD]Switch to lens mode[/TD] [/TR] [TR] [TD]Ctrl+Alt+D[/TD] [TD]Switch to docked mode[/TD] [/TR] [TR] [TD]Ctrl+Alt+I[/TD] [TD]Invert colors[/TD] [/TR] [TR] [TD]Ctrl+Alt+arrow keys[/TD] [TD]Pan in the direction of the arrow keys[/TD] [/TR] [TR] [TD]Ctrl+Alt+R[/TD] [TD]Resize the lens[/TD] [/TR] [TR] [TD]Windows logo key + Esc[/TD] [TD]Exit Magnifier[/TD] [/TR] [/TABLE] 6 لینک به دیدگاه
panisa 12132 مالک اشتراک گذاری ارسال شده در 8 فروردین، ۱۳۹۱ Remote Desktop Connection keyboard shortcuts [TABLE] [TR] [TD]Alt+Page Up[/TD] [TD]Move between programs from left to right.[/TD] [/TR] [TR] [TD]Alt+Page Down[/TD] [TD]Move between programs from right to left.[/TD] [/TR] [TR] [TD]Alt+Insert[/TD] [TD]Cycle through programs in the order that they were started in.[/TD] [/TR] [TR] [TD]Alt+Home[/TD] [TD]Display the Start menu.[/TD] [/TR] [TR] [TD]Ctrl+Alt+Break[/TD] [TD]Switch between a window and full screen.[/TD] [/TR] [TR] [TD]Ctrl+Alt+End[/TD] [TD]Display the Windows Security dialog box.[/TD] [/TR] [TR] [TD]Alt+Delete[/TD] [TD]Display the system menu.[/TD] [/TR] [TR] [TD]Ctrl+Alt+Minus Sign (-) on the numeric keypad[/TD] [TD]Place a copy of the active window, within the client, on the Terminal server clipboard (provides the same functionality as pressing Alt+PrtScn on a local computer).[/TD] [/TR] [TR] [TD]Ctrl+Alt+Plus Sign (+) on the numeric keypad[/TD] [TD]Place a copy of the entire client window area on the Terminal server clipboard (provides the same functionality as pressing PrtScn on a local computer).[/TD] [/TR] [TR] [TD]Ctrl+Alt+Right Arrow[/TD] [TD]“Tab” out of the Remote Desktop controls to a control in the host program (for example, a button or a text box). Useful when the Remote Desktop controls are embedded in another (host) program.[/TD] [/TR] [TR] [TD]Ctrl+Alt+Left Arrow[/TD] [TD]“Tab” out of the Remote Desktop controls to a control in the host program (for example, a button or a text box). Useful when the Remote Desktop controls are embedded in another (host) program.[/TD] [/TR] [/TABLE] 7 لینک به دیدگاه
panisa 12132 مالک اشتراک گذاری ارسال شده در 8 فروردین، ۱۳۹۱ Note Ctrl+Alt+Break and Ctrl+Alt+End are available in all Remote Desktop sessions, even when you've set up the remote computer to recognize Windows keyboard shortcuts 6 لینک به دیدگاه
panisa 12132 مالک اشتراک گذاری ارسال شده در 8 فروردین، ۱۳۹۱ Paint keyboard shortcuts [TABLE] [TR] [TD]Ctrl+N [/TD] [TD]Create a new picture[/TD] [/TR] [TR] [TD]Ctrl+O[/TD] [TD]Open an existing picture[/TD] [/TR] [TR] [TD]Ctrl+S[/TD] [TD]Save changes to a picture[/TD] [/TR] [TR] [TD]F12[/TD] [TD]Save the picture as a new file[/TD] [/TR] [TR] [TD]Ctrl+P[/TD] [TD]Print a picture[/TD] [/TR] [TR] [TD]Alt+F4[/TD] [TD]Close a picture and its Paint window[/TD] [/TR] [TR] [TD]Ctrl+Z[/TD] [TD]Undo a change[/TD] [/TR] [TR] [TD]Ctrl+Y[/TD] [TD]Redo a change[/TD] [/TR] [TR] [TD]Ctrl+A[/TD] [TD]Select the entire picture[/TD] [/TR] [TR] [TD]Ctrl+X[/TD] [TD]Cut a selection[/TD] [/TR] [TR] [TD]Ctrl+C[/TD] [TD]Copy a selection to the Clipboard[/TD] [/TR] [TR] [TD]Ctrl+V[/TD] [TD]Paste a selection from the Clipboard[/TD] [/TR] [TR] [TD]Right Arrow[/TD] [TD]Move the selection or active shape right by one pixel[/TD] [/TR] [TR] [TD]Left Arrow[/TD] [TD]Move the selection or active shape left by one pixel[/TD] [/TR] [TR] [TD]Down Arrow[/TD] [TD]Move the selection or active shape down by one pixel[/TD] [/TR] [TR] [TD]Up Arrow[/TD] [TD]Move the selection or active shape up by one pixel[/TD] [/TR] [TR] [TD]Esc[/TD] [TD]Cancel a selection[/TD] [/TR] [TR] [TD]Delete[/TD] [TD]Delete a selection[/TD] [/TR] [TR] [TD]Ctrl+B[/TD] [TD]Bold selected text[/TD] [/TR] [TR] [TD]Ctrl++[/TD] [TD]Increase the width of a brush, line, or shape outline by one pixel[/TD] [/TR] [TR] [TD]Ctrl+-[/TD] [TD]Decrease the width of a brush, line, or shape outline by one pixel[/TD] [/TR] [TR] [TD]Ctrl+I[/TD] [TD]Italicize selected text[/TD] [/TR] [TR] [TD]Ctrl+U[/TD] [TD]Underline selected text[/TD] [/TR] [TR] [TD]Ctrl+E[/TD] [TD]Open the Properties dialog box[/TD] [/TR] [TR] [TD]Ctrl+W[/TD] [TD]Open the Resize and Skew dialog box[/TD] [/TR] [TR] [TD]Ctrl+Page Up[/TD] [TD]Zoom in[/TD] [/TR] [TR] [TD]Ctrl+Page Down[/TD] [TD]Zoom out[/TD] [/TR] [TR] [TD]F11[/TD] [TD]View a picture in full-screen mode[/TD] [/TR] [TR] [TD]Ctrl+R[/TD] [TD]Show or hide the ruler[/TD] [/TR] [TR] [TD]Ctrl+G[/TD] [TD]Show or hide gridlines[/TD] [/TR] [TR] [TD]F10 or Alt[/TD] [TD]Display keytips[/TD] [/TR] [TR] [TD]Shift+F10[/TD] [TD]Show the current shortcut menu[/TD] [/TR] [TR] [TD]F1[/TD] [TD]Open Paint Help [/TD] [/TR] [/TABLE] 7 لینک به دیدگاه
panisa 12132 مالک اشتراک گذاری ارسال شده در 8 فروردین، ۱۳۹۱ WordPad keyboard shortcuts [TABLE] [TR] [TD]Ctrl+N[/TD] [TD]Create a new document[/TD] [/TR] [TR] [TD]Ctrl+O[/TD] [TD]Open an existing document[/TD] [/TR] [TR] [TD]Ctrl+S[/TD] [TD]Save changes to a document[/TD] [/TR] [TR] [TD]F12[/TD] [TD]Save the document as a new file[/TD] [/TR] [TR] [TD]Ctrl+P[/TD] [TD]Print a document[/TD] [/TR] [TR] [TD]Alt+F4[/TD] [TD]Close WordPad[/TD] [/TR] [TR] [TD]Ctrl+Z[/TD] [TD]Undo a change[/TD] [/TR] [TR] [TD]Ctrl+Y[/TD] [TD]Redo a change[/TD] [/TR] [TR] [TD]Ctrl+A[/TD] [TD]Select the entire document[/TD] [/TR] [TR] [TD]Ctrl+X[/TD] [TD]Cut a selection[/TD] [/TR] [TR] [TD]Ctrl+C[/TD] [TD]Copy a selection to the Clipboard[/TD] [/TR] [TR] [TD]Ctrl+V[/TD] [TD]Paste a selection from the Clipboard[/TD] [/TR] [TR] [TD]Ctrl+B[/TD] [TD]Make selected text bold[/TD] [/TR] [TR] [TD]Ctrl+I[/TD] [TD]Italicize selected text[/TD] [/TR] [TR] [TD]Ctrl+U[/TD] [TD]Underline selected text[/TD] [/TR] [TR] [TD]Ctrl+=[/TD] [TD]Make selected text subscript[/TD] [/TR] [TR] [TD]Ctrl+Shift+=[/TD] [TD]Make selected text superscript[/TD] [/TR] [TR] [TD]Ctrl+L[/TD] [TD]Align text left[/TD] [/TR] [TR] [TD]Ctrl+E[/TD] [TD]Align text center[/TD] [/TR] [TR] [TD]Ctrl+R[/TD] [TD]Align text right[/TD] [/TR] [TR] [TD]Ctrl+J[/TD] [TD]Justify text[/TD] [/TR] [TR] [TD]Ctrl+1[/TD] [TD]Set single line spacing[/TD] [/TR] [TR] [TD]Ctrl+2[/TD] [TD]Set double line spacing[/TD] [/TR] [TR] [TD]Ctrl+5[/TD] [TD]Set line spacing to 1.5[/TD] [/TR] [TR] [TD]Ctrl+Shift+>[/TD] [TD]Increase the font size[/TD] [/TR] [TR] [TD]Ctrl+Shift+ [TD]Decrease the font size[/TD] [/TR] [TR] [TD]Ctrl+Shift+A[/TD] [TD]Change characters to all capitals[/TD] [/TR] [TR] [TD]Ctrl+Shift+L[/TD] [TD]Change the bullet style[/TD] [/TR] [TR] [TD]Ctrl+D[/TD] [TD]Insert a Microsoft Paint drawing[/TD] [/TR] [TR] [TD]Ctrl+F[/TD] [TD]Find text in a document[/TD] [/TR] [TR] [TD]F3[/TD] [TD]Find the next instance of the text in the Find dialog box[/TD] [/TR] [TR] [TD]Ctrl+H[/TD] [TD]Replace text in a document[/TD] [/TR] [TR] [TD]Ctrl+Left Arrow[/TD] [TD]Move the cursor one word to the left[/TD] [/TR] [TR] [TD]Ctrl+Right Arrow[/TD] [TD]Move the cursor one word to the right[/TD] [/TR] [TR] [TD]Ctrl+Up Arrow[/TD] [TD]Move the cursor to the line above[/TD] [/TR] [TR] [TD]Ctrl+Down Arrow[/TD] [TD]Move the cursor to the line below[/TD] [/TR] [TR] [TD]Ctrl+Home[/TD] [TD]Move to the beginning of the document[/TD] [/TR] [TR] [TD]Ctrl+End[/TD] [TD]Move to the end of the document[/TD] [/TR] [TR] [TD]Ctrl+Page Up[/TD] [TD]Move up one page[/TD] [/TR] [TR] [TD]Ctrl+Page Down[/TD] [TD]Move down one page[/TD] [/TR] [TR] [TD]Ctrl+Delete[/TD] [TD]Delete the next word[/TD] [/TR] [TR] [TD]F10[/TD] [TD]Display keytips[/TD] [/TR] [TR] [TD]Shift+F10[/TD] [TD]Show the current shortcut menu[/TD] [/TR] [TR] [TD]F1[/TD] [TD]Open WordPad Help[/TD] [/TR] [/TABLE] 4 لینک به دیدگاه
panisa 12132 مالک اشتراک گذاری ارسال شده در 8 فروردین، ۱۳۹۱ Calculator keyboard shortcuts [TABLE] [TR] [TD]Alt+1[/TD] [TD]Switch to Standard mode[/TD] [/TR] [TR] [TD]Alt+2[/TD] [TD]Switch to Scientific mode[/TD] [/TR] [TR] [TD]Alt+3[/TD] [TD]Switch to Programmer mode[/TD] [/TR] [TR] [TD]Alt+4[/TD] [TD]Switch to Statistics mode[/TD] [/TR] [TR] [TD]Ctrl+E[/TD] [TD]Open date calculations[/TD] [/TR] [TR] [TD]Ctrl+H[/TD] [TD]Turn calculation history on or off[/TD] [/TR] [TR] [TD]Ctrl+U[/TD] [TD]Open unit conversion[/TD] [/TR] [TR] [TD]Alt+C[/TD] [TD]Calculate or solve date calculations and worksheets[/TD] [/TR] [TR] [TD]F1[/TD] [TD]Open Calculator Help[/TD] [/TR] [TR] [TD]Ctrl+Q[/TD] [TD]Press the M- button[/TD] [/TR] [TR] [TD]Ctrl+P[/TD] [TD]Press the M+ button[/TD] [/TR] [TR] [TD]Ctrl+M[/TD] [TD]Press the MS button[/TD] [/TR] [TR] [TD]Ctrl+R[/TD] [TD]Press the MR button[/TD] [/TR] [TR] [TD]Ctrl+L[/TD] [TD]Press the MC button[/TD] [/TR] [TR] [TD]%[/TD] [TD]Press the % button[/TD] [/TR] [TR] [TD]F9[/TD] [TD]Press the +/– button[/TD] [/TR] [TR] [TD]/[/TD] [TD]Press the / button[/TD] [/TR] [TR] [TD]*[/TD] [TD]Press the * button[/TD] [/TR] [TR] [TD]+[/TD] [TD]Press the + button[/TD] [/TR] [TR] [TD]-[/TD] [TD]Press the – button[/TD] [/TR] [TR] [TD]R[/TD] [TD]Press the 1/× button[/TD] [/TR] [TR] [TD]@[/TD] [TD]Press the square root button[/TD] [/TR] [TR] [TD]0-9[/TD] [TD]Press the number buttons (0-9)[/TD] [/TR] [TR] [TD]=[/TD] [TD]Press the = button [/TD] [/TR] [TR] [TD].[/TD] [TD]Press the . (decimal point) button[/TD] [/TR] [TR] [TD]Backspace[/TD] [TD]Press the backspace button[/TD] [/TR] [TR] [TD]Esc[/TD] [TD]Press the C button[/TD] [/TR] [TR] [TD]Del[/TD] [TD]Press the CE button[/TD] [/TR] [TR] [TD]Ctrl+Shift+D[/TD] [TD]Clear the calculation history[/TD] [/TR] [TR] [TD]F2[/TD] [TD]Edit the calculation history[/TD] [/TR] [TR] [TD]Up Arrow key[/TD] [TD]Navigate up in the calculation history[/TD] [/TR] [TR] [TD]Down Arrow key[/TD] [TD]Navigate down in the calculation history[/TD] [/TR] [TR] [TD]Esc[/TD] [TD]Cancel editing the calculation history[/TD] [/TR] [TR] [TD]Enter[/TD] [TD]Recalculate the calculation history after editing[/TD] [/TR] [TR] [TD]F3[/TD] [TD]Select Degrees in Scientific mode[/TD] [/TR] [TR] [TD]F4[/TD] [TD]Select Radians in Scientific mode[/TD] [/TR] [TR] [TD]F5[/TD] [TD]Select Grads in Scientific mode[/TD] [/TR] [TR] [TD]I[/TD] [TD]Press the Inv button in Scientific mode[/TD] [/TR] [TR] [TD]D[/TD] [TD]Press the Mod button in Scientific mode[/TD] [/TR] [TR] [TD]Ctrl+S[/TD] [TD]Press the sinh button in Scientific mode[/TD] [/TR] [TR] [TD]Ctrl+O[/TD] [TD]Press the cosh button in Scientific mode[/TD] [/TR] [TR] [TD]Ctrl+T[/TD] [TD]Press the tanh button in Scientific mode[/TD] [/TR] [TR] [TD]([/TD] [TD]Press the ( button in Scientific mode[/TD] [/TR] [TR] [TD])[/TD] [TD]Press the ) button in Scientific mode[/TD] [/TR] [TR] [TD]N[/TD] [TD]Press the ln button in Scientific mode[/TD] [/TR] [TR] [TD];[/TD] [TD]Press the Int button in Scientific mode[/TD] [/TR] [TR] [TD]S[/TD] [TD]Press the sin button in Scientific mode[/TD] [/TR] [TR] [TD]O[/TD] [TD]Press the cos button in Scientific mode[/TD] [/TR] [TR] [TD]T[/TD] [TD]Press the tan button in Scientific mode[/TD] [/TR] [TR] [TD]M[/TD] [TD]Press the dms button in Scientific mode[/TD] [/TR] [TR] [TD]P[/TD] [TD]Press the pi button in Scientific mode[/TD] [/TR] [TR] [TD]V[/TD] [TD]Press the F-E button in Scientific mode[/TD] [/TR] [TR] [TD]X[/TD] [TD]Press the Exp button in Scientific mode[/TD] [/TR] [TR] [TD]Q[/TD] [TD]Press the x^2 button in Scientific mode[/TD] [/TR] [TR] [TD]Y[/TD] [TD]Press the x^y button in Scientific mode[/TD] [/TR] [TR] [TD]#[/TD] [TD]Press the x^3 button in Scientific mode[/TD] [/TR] [TR] [TD]L[/TD] [TD]Press the log button in Scientific mode[/TD] [/TR] [TR] [TD]![/TD] [TD]Press the n! button in Scientific mode[/TD] [/TR] [TR] [TD]Ctrl+Y[/TD] [TD]Press the y√x button in Scientific mode[/TD] [/TR] [TR] [TD]Ctrl+B[/TD] [TD]Press the 3√x button in Scientific mode[/TD] [/TR] [TR] [TD]Ctrl+G[/TD] [TD]Press the 10x button in Scientific mode[/TD] [/TR] [TR] [TD]F5[/TD] [TD]Select Hex in Programmer mode[/TD] [/TR] [TR] [TD]F6[/TD] [TD]Select Dec in Programmer mode[/TD] [/TR] [TR] [TD]F7[/TD] [TD]Select Oct in Programmer mode[/TD] [/TR] [TR] [TD]F8[/TD] [TD]Select Bin in Programmer mode[/TD] [/TR] [TR] [TD]F12[/TD] [TD]Select Qword in Programmer mode[/TD] [/TR] [TR] [TD]F2[/TD] [TD]Select Dword in Programmer mode[/TD] [/TR] [TR] [TD]F3[/TD] [TD]Select Word in Programmer mode[/TD] [/TR] [TR] [TD]F4[/TD] [TD]Select Byte in Programmer mode[/TD] [/TR] [TR] [TD]K[/TD] [TD]Press the RoR button in Programmer mode[/TD] [/TR] [TR] [TD]J[/TD] [TD]Press the RoL button in Programmer mode[/TD] [/TR] [TR] [TD] [TD]Press the Lsh button in Programmer mode[/TD] [/TR] [TR] [TD]>[/TD] [TD]Press the Rsh button in Programmer mode[/TD] [/TR] [TR] [TD]%[/TD] [TD]Press the Mod button in Programmer mode[/TD] [/TR] [TR] [TD]([/TD] [TD]Press the ( button in Programmer mode[/TD] [/TR] [TR] [TD])[/TD] [TD]Press the ) button in Programmer mode[/TD] [/TR] [TR] [TD]|[/TD] [TD]Press the Or button in Programmer mode[/TD] [/TR] [TR] [TD]^[/TD] [TD]Press the Xor button in Programmer mode[/TD] [/TR] [TR] [TD]~[/TD] [TD]Press the Not button in Programmer mode[/TD] [/TR] [TR] [TD]&[/TD] [TD]Press the And button in Programmer mode[/TD] [/TR] [TR] [TD]A-F[/TD] [TD]Press the A-F buttons in Programmer mode[/TD] [/TR] [TR] [TD]Spacebar[/TD] [TD]Toggles the bit value in Programmer mode[/TD] [/TR] [TR] [TD]A[/TD] [TD]Press the Average button in Statistics mode[/TD] [/TR] [TR] [TD]Ctrl+A[/TD] [TD]Press the Average Sq button in Statistics mode[/TD] [/TR] [TR] [TD]S[/TD] [TD]Press the Sum button in Statistics mode[/TD] [/TR] [TR] [TD]Ctrl+S[/TD] [TD]Press the Sum Sq button in Statistics mode[/TD] [/TR] [TR] [TD]T[/TD] [TD]Press the S.D. button in Statistics mode[/TD] [/TR] [TR] [TD]Ctrl+T[/TD] [TD]Press the Inv S.D. button in Statistics mode[/TD] [/TR] [TR] [TD]D[/TD] [TD]Press the CAD button in Statistics mode[/TD] [/TR] [/TABLE] 4 لینک به دیدگاه
panisa 12132 مالک اشتراک گذاری ارسال شده در 8 فروردین، ۱۳۹۱ Windows Journal keyboard shortcuts [TABLE] [TR] [TD]Ctrl+N[/TD] [TD]Start a new note[/TD] [/TR] [TR] [TD]Ctrl+O[/TD] [TD]Open a recently used note[/TD] [/TR] [TR] [TD]Ctrl+S[/TD] [TD]Save changes to a note[/TD] [/TR] [TR] [TD]Ctrl+Shift+V[/TD] [TD]Move a note to a specific folder[/TD] [/TR] [TR] [TD]Ctrl+P[/TD] [TD]Print a note[/TD] [/TR] [TR] [TD]Alt+F4[/TD] [TD]Close a note and its Journal window[/TD] [/TR] [TR] [TD]Ctrl+Z[/TD] [TD]Undo a change[/TD] [/TR] [TR] [TD]Ctrl+Y[/TD] [TD]Redo a change[/TD] [/TR] [TR] [TD]Ctrl+A[/TD] [TD]Select all items on a page[/TD] [/TR] [TR] [TD]Ctrl+X[/TD] [TD]Cut a selection[/TD] [/TR] [TR] [TD]Ctrl+C[/TD] [TD]Copy a selection to the Clipboard[/TD] [/TR] [TR] [TD]Ctrl+V[/TD] [TD]Paste a selection from the Clipboard[/TD] [/TR] [TR] [TD]Esc[/TD] [TD]Cancel a selection[/TD] [/TR] [TR] [TD]Delete[/TD] [TD]Delete a selection[/TD] [/TR] [TR] [TD]Ctrl+F[/TD] [TD]Start a basic find[/TD] [/TR] [TR] [TD]Ctrl+G[/TD] [TD]Go to a page[/TD] [/TR] [TR] [TD]F5[/TD] [TD]Refresh find results[/TD] [/TR] [TR] [TD]F5[/TD] [TD]Refresh the note list[/TD] [/TR] [TR] [TD]F6[/TD] [TD]Toggle between a note list and a note[/TD] [/TR] [TR] [TD]Ctrl+Shift+C[/TD] [TD]Display a shortcut menu for column headings in a note list[/TD] [/TR] [TR] [TD]F11[/TD] [TD]View a note in full-screen mode[/TD] [/TR] [TR] [TD]F1[/TD] [TD]Open Journal Help[/TD] [/TR] [/TABLE] 4 لینک به دیدگاه
panisa 12132 مالک اشتراک گذاری ارسال شده در 8 فروردین، ۱۳۹۱ Windows Help viewer keyboard shortcuts [TABLE] [TR] [TD]Alt+C [/TD] [TD]Display the Table of Contents [/TD] [/TR] [TR] [TD]Alt+N [/TD] [TD]Display the Connection Settings menu [/TD] [/TR] [TR] [TD]F10 [/TD] [TD]Display the Options menu [/TD] [/TR] [TR] [TD]Alt+Left Arrow [/TD] [TD]Move back to the previously viewed topic [/TD] [/TR] [TR] [TD]Alt+Right Arrow [/TD] [TD]Move forward to the next (previously viewed) topic [/TD] [/TR] [TR] [TD]Alt+A [/TD] [TD]Display the customer support page [/TD] [/TR] [TR] [TD]Alt+Home [/TD] [TD]Display the Help and Support home page [/TD] [/TR] [TR] [TD]Home [/TD] [TD]Move to the beginning of a topic [/TD] [/TR] [TR] [TD]End [/TD] [TD]Move to the end of a topic [/TD] [/TR] [TR] [TD]Ctrl+F [/TD] [TD]Search the current topic [/TD] [/TR] [TR] [TD]Ctrl+P [/TD] [TD]Print a topic [/TD] [/TR] [TR] [TD]F3 [/TD] [TD]Move the cursor to the search box [/TD] [/TR] [/TABLE] 4 لینک به دیدگاه
