Ease of Access keyboard shortcuts
[TABLE]
[TR]
[TD]Right Shift for eight seconds[/TD]
[TD]Turn Filter Keys on and off[/TD]
[/TR]
[TR]
[TD]Left Alt+Left Shift+PrtScn (or PrtScn)[/TD]
[TD]Turn High Contrast on or off[/TD]
[/TR]
[TR]
[TD]Left Alt+Left Shift+Num Lock[/TD]
[TD]Turn Mouse Keys on or off[/TD]
[/TR]
[TR]
[TD]Shift five times[/TD]
[TD]Turn Sticky Keys on or off[/TD]
[/TR]
[TR]
[TD]Num Lock for five seconds[/TD]
[TD]Turn Toggle Keys on or off[/TD]
[/TR]
[TR]
[TD]Windows logo key +U[/TD]
[TD]Open the Ease of Access Center[/TD]
[/TR]
[/TABLE]
General keyboard shortcuts
[TABLE]
[TR]
[TD]F1[/TD]
[TD]Display Help[/TD]
[/TR]
[TR]
[TD]Ctrl+C (or Ctrl+Insert)[/TD]
[TD]Copy the selected item[/TD]
[/TR]
[TR]
[TD]Ctrl+X[/TD]
[TD]Cut the selected item[/TD]
[/TR]
[TR]
[TD]Ctrl+V (or Shift+Insert)[/TD]
[TD]Paste the selected item[/TD]
[/TR]
[TR]
[TD]Ctrl+Z[/TD]
[TD]Undo an action[/TD]
[/TR]
[TR]
[TD]Ctrl+Y[/TD]
[TD]Redo an action[/TD]
[/TR]
[TR]
[TD]Delete (or Ctrl+D)[/TD]
[TD]Delete the selected item and move it to the Recycle Bin[/TD]
[/TR]
[TR]
[TD]Shift+Delete[/TD]
[TD]Delete the selected item without moving it to the Recycle Bin first[/TD]
[/TR]
[TR]
[TD]F2[/TD]
[TD]Rename the selected item[/TD]
[/TR]
[TR]
[TD]Ctrl+Right Arrow[/TD]
[TD]Move the cursor to the beginning of the next word[/TD]
[/TR]
[TR]
[TD]Ctrl+Left Arrow[/TD]
[TD]Move the cursor to the beginning of the previous word[/TD]
[/TR]
[TR]
[TD]Ctrl+Down Arrow[/TD]
[TD]Move the cursor to the beginning of the next paragraph[/TD]
[/TR]
[TR]
[TD]Ctrl+Up Arrow[/TD]
[TD]Move the cursor to the beginning of the previous paragraph[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift with an arrow key[/TD]
[TD]Select a block of text[/TD]
[/TR]
[TR]
[TD]Shift with any arrow key[/TD]
[TD]Select more than one item in a window or on the desktop, or select text within a document[/TD]
[/TR]
[TR]
[TD]Ctrl with any arrow key+Spacebar[/TD]
[TD]Select multiple individual items in a window or on the desktop[/TD]
[/TR]
[TR]
[TD]Ctrl+A[/TD]
[TD]Select all items in a document or window[/TD]
[/TR]
[TR]
[TD]F3[/TD]
[TD]Search for a file or folder[/TD]
[/TR]
[TR]
[TD]Alt+Enter[/TD]
[TD]Display properties for the selected item[/TD]
[/TR]
[TR]
[TD]Alt+F4[/TD]
[TD]Close the active item, or exit the active program[/TD]
[/TR]
[TR]
[TD]Alt+Spacebar[/TD]
[TD]Open the shortcut menu for the active window[/TD]
[/TR]
[TR]
[TD]Ctrl+F4[/TD]
[TD]Close the active document (in programs that allow you to have multiple documents open simultaneously)[/TD]
[/TR]
[TR]
[TD]Alt+Tab[/TD]
[TD]Switch between open items[/TD]
[/TR]
[TR]
[TD]Ctrl+Alt+Tab[/TD]
[TD]Use the arrow keys to switch between open items[/TD]
[/TR]
[TR]
[TD]Ctrl+Mouse scroll wheel[/TD]
[TD]Change the size of icons on the desktop[/TD]
[/TR]
[TR]
[TD]Windows logo key Win +Tab[/TD]
[TD]Cycle through programs on the taskbar by using Aero Flip 3-D[/TD]
[/TR]
[TR]
[TD]Ctrl+Windows logo key Win +Tab[/TD]
[TD]Use the arrow keys to cycle through programs on the taskbar by using Aero Flip 3-D[/TD]
[/TR]
[TR]
[TD]Alt+Esc[/TD]
[TD]Cycle through items in the order in which they were opened[/TD]
[/TR]
[TR]
[TD]F6[/TD]
[TD]Cycle through screen elements in a window or on the desktop[/TD]
[/TR]
[TR]
[TD]F4[/TD]
[TD]Display the address bar list in Windows Explorer[/TD]
[/TR]
[TR]
[TD]Shift+F10[/TD]
[TD]Display the shortcut menu for the selected item[/TD]
[/TR]
[TR]
[TD]Ctrl+Esc[/TD]
[TD]Open the Start menu[/TD]
[/TR]
[TR]
[TD]Alt+underlined letter[/TD]
[TD]Display the corresponding menu[/TD]
[/TR]
[TR]
[TD]Perform the menu command (or other underlined command)[/TD]
[/TR]
[TR]
[TD]F10[/TD]
[TD]Activate the menu bar in the active program[/TD]
[/TR]
[TR]
[TD]Right Arrow[/TD]
[TD]Open the next menu to the right, or open a submenu[/TD]
[/TR]
[TR]
[TD]Left Arrow[/TD]
[TD]Open the next menu to the left, or close a submenu[/TD]
[/TR]
[TR]
[TD]F5 (or Ctrl+R)[/TD]
[TD]Refresh the active window[/TD]
[/TR]
[TR]
[TD]Alt+Up Arrow[/TD]
[TD]View the folder one level up in Windows Explorer[/TD]
[/TR]
[TR]
[TD]Esc[/TD]
[TD]Cancel the current task[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift+Esc[/TD]
[TD]Open Task Manager[/TD]
[/TR]
[TR]
[TD]Shift when you insert a CD[/TD]
[TD]Prevent the CD from automatically playing[/TD]
[/TR]
[TR]
[TD]Left Alt+Shift[/TD]
[TD]Switch the input language when multiple input languages are enabled[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift[/TD]
[TD]Switch the keyboard layout when multiple keyboard layouts are enabled[/TD]
[/TR]
[TR]
[TD]Right or Left Ctrl+Shift[/TD]
[TD]Change the reading direction of text in right-to-left reading languages[/TD]
[/TR]
[/TABLE]
Dialog box keyboard shortcuts
[TABLE]
[TR]
[TD]Ctrl+Tab[/TD]
[TD]Move forward through tabs[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift+Tab[/TD]
[TD]Move back through tabs[/TD]
[/TR]
[TR]
[TD]Tab[/TD]
[TD]Move forward through options[/TD]
[/TR]
[TR]
[TD]Shift+Tab[/TD]
[TD]Move back through options[/TD]
[/TR]
[TR]
[TD]Perform the command (or select the option) that goes with that letter[/TD]
[/TR]
[TR]
[TD]Enter[/TD]
[TD]Replaces clicking the mouse for many selected commands[/TD]
[/TR]
[TR]
[TD]Spacebar[/TD]
[TD]Select or clear the check box if the active option is a check box[/TD]
[/TR]
[TR]
[TD]Arrow keys[/TD]
[TD]Select a button if the active option is a group of option buttons[/TD]
[/TR]
[TR]
[TD]F1[/TD]
[/TR]
[TR]
[TD]F4[/TD]
[TD]Display the items in the active list[/TD]
[/TR]
[TR]
[TD]Backspace[/TD]
[TD]Open a folder one level up if a folder is selected in the Save As or Open dialog box[/TD]
[/TR]
[/TABLE]
Windows logo key keyboard shortcuts
[TABLE]
[TR]
[TD]Windows logo key [/TD]
[TD]Open or close the Start menu.[/TD]
[/TR]
[TR]
[TD]Windows logo key +Pause[/TD]
[TD]Display the System Properties dialog box.[/TD]
[/TR]
[TR]
[TD]Windows logo key +D[/TD]
[TD]Display the desktop.[/TD]
[/TR]
[TR]
[TD]Windows logo key +M[/TD]
[TD]Minimize all windows.[/TD]
[/TR]
[TR]
[TD]Windows logo key +Shift+M[/TD]
[TD]Restore minimized windows to the desktop.[/TD]
[/TR]
[TR]
[TD]Windows logo key +E[/TD]
[TD]Open Computer.[/TD]
[/TR]
[TR]
[TD]Windows logo key +F[/TD]
[TD]Search for a file or folder.[/TD]
[/TR]
[TR]
[TD]Ctrl+Windows logo key +F[/TD]
[TD]Search for computers (if you're on a network).[/TD]
[/TR]
[TR]
[TD]Windows logo key +L[/TD]
[TD]Lock your computer or switch users.[/TD]
[/TR]
[TR]
[TD]Windows logo key +R[/TD]
[TD]Open the Run dialog box.[/TD]
[/TR]
[TR]
[TD]Windows logo key +T[/TD]
[TD]Cycle through programs on the taskbar.[/TD]
[/TR]
[TR]
[TD]Windows logo key +number[/TD]
[TD]Start the program pinned to the taskbar in the position indicated by the number. If the program is already running, switch to that program.[/TD]
[/TR]
[TR]
[TD]Shift+Windows logo key number[/TD]
[TD]Start a new instance of the program pinned to the taskbar in the position indicated by the number.[/TD]
[/TR]
[TR]
[TD]Ctrl+Windows logo key +number[/TD]
[TD]Switch to the last active window of the program pinned to the taskbar in the position indicated by the number.[/TD]
[/TR]
[TR]
[TD]Alt+Windows logo key +number[/TD]
[TD]Open the Jump List for the program pinned to the taskbar in the position indicated by the number.[/TD]
[/TR]
[TR]
[TD]Windows logo key +Tab[/TD]
[TD]Cycle through programs on the taskbar by using Aero Flip 3-D.[/TD]
[/TR]
[TR]
[TD]Ctrl+Windows logo key +Tab[/TD]
[TD]Use the arrow keys to cycle through programs on the taskbar by using Aero Flip 3-D.[/TD]
[/TR]
[TR]
[TD]Ctrl+Windows logo key +B[/TD]
[TD]Switch to the program that displayed a message in the notification area.[/TD]
[/TR]
[TR]
[TD]Windows logo key +Spacebar[/TD]
[TD]Preview the desktop.[/TD]
[/TR]
[TR]
[TD]Windows logo key +Up Arrow[/TD]
[TD]Maximize the window.[/TD]
[/TR]
[TR]
[TD]Windows logo key +Left Arrow[/TD]
[TD]Maximize the window to the left side of the screen.[/TD]
[/TR]
[TR]
[TD]Windows logo key +Right Arrow[/TD]
[TD]Maximize the window to the right side of the screen.[/TD]
[/TR]
[TR]
[TD]Windows logo key +Down Arrow[/TD]
[TD]Minimize the window.[/TD]
[/TR]
[TR]
[TD]Windows logo key +Home[/TD]
[TD]Minimize all but the active window.[/TD]
[/TR]
[TR]
[TD]Windows logo key +Shift+Up Arrow[/TD]
[TD]Stretch the window to the top and bottom of the screen.[/TD]
[/TR]
[TR]
[TD]Windows logo key +Shift+Left Arrow or Right Arrow[/TD]
[TD]Move a window from one monitor to another.[/TD]
[/TR]
[TR]
[TD]Windows logo key +P[/TD]
[TD]Choose a presentation display mode.[/TD]
[/TR]
[TR]
[TD]Windows logo key +G[/TD]
[TD]Cycle through gadgets.[/TD]
[/TR]
[TR]
[TD]Open Ease of Access Center.[/TD]
[/TR]
[TR]
[TD]Windows logo key +X[/TD]
[TD]Open Windows Mobility Center.[/TD]
[/TR]
[/TABLE]
Windows Explorer keyboard shortcuts
[TABLE]
[TR]
[TD]Ctrl+N[/TD]
[TD]Open a new window[/TD]
[/TR]
[TR]
[TD]Ctrl+W[/TD]
[TD]Close the current window[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift+N[/TD]
[TD]Create a new folder[/TD]
[/TR]
[TR]
[TD]End[/TD]
[TD]Display the bottom of the active window[/TD]
[/TR]
[TR]
[TD]Home[/TD]
[TD]Display the top of the active window[/TD]
[/TR]
[TR]
[TD]F11[/TD]
[TD]Maximize or minimize the active window[/TD]
[/TR]
[TR]
[TD]Ctrl+Period (.)[/TD]
[TD]Rotate a picture clockwise[/TD]
[/TR]
[TR]
[TD]Ctrl+Comma (,)[/TD]
[TD]Rotate a picture counter-clockwise[/TD]
[/TR]
[TR]
[TD]Num Lock+Asterisk (*) on numeric keypad[/TD]
[TD]Display all subfolders under the selected folder[/TD]
[/TR]
[TR]
[TD]Num Lock+Plus Sign (+) on numeric keypad[/TD]
[TD]Display the contents of the selected folder[/TD]
[/TR]
[TR]
[TD]Num Lock+Minus Sign (-) on numeric keypad[/TD]
[TD]Collapse the selected folder[/TD]
[/TR]
[TR]
[TD]Left Arrow[/TD]
[TD]Collapse the current selection (if it's expanded), or select the parent folder[/TD]
[/TR]
[TR]
[TD]Alt+Enter[/TD]
[TD]Open the Properties dialog box for the selected item[/TD]
[/TR]
[TR]
[TD]Alt+P[/TD]
[TD]Display the preview pane[/TD]
[/TR]
[TR]
[TD]Alt+Left Arrow[/TD]
[TD]View the previous folder[/TD]
[/TR]
[TR]
[TD]Backspace[/TD]
[/TR]
[TR]
[TD]Display the current selection (if it's collapsed), or select the first subfolder[/TD]
[/TR]
[TR]
[TD]Alt+Right Arrow[/TD]
[TD]View the next folder[/TD]
[/TR]
[TR]
[TD]View the parent folder[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift+E[/TD]
[TD]Display all folders above the selected folder[/TD]
[/TR]
[TR]
[TD]Change the size and appearance of file and folder icons[/TD]
[/TR]
[TR]
[TD]Alt+D[/TD]
[TD]Select the address bar[/TD]
[/TR]
[TR]
[TD]Ctrl+E[/TD]
[TD]Select the search box[/TD]
[/TR]
[TR]
[TD]Ctrl+F[/TD]
[/TR]
[/TABLE]
Taskbar keyboard shortcuts
[TABLE]
[TR]
[TD]Shift+Click on a taskbar button[/TD]
[TD]Open a program or quickly open another instance of a program[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift+Click on a taskbar button[/TD]
[TD]Open a program as an administrator[/TD]
[/TR]
[TR]
[TD]Shift+Right-click on a taskbar button[/TD]
[TD]Show the window menu for the program[/TD]
[/TR]
[TR]
[TD]Shift+Right-click on a grouped taskbar button[/TD]
[TD]Show the window menu for the group[/TD]
[/TR]
[TR]
[TD]Ctrl+Click on a grouped taskbar button[/TD]
[TD]Cycle through the windows of the group[/TD]
[/TR]
[/TABLE]
Magnifier keyboard shortcuts
[TABLE]
[TR]
[TD]Windows logo key + Plus Sign (+) or Minus Sign (-)[/TD]
[TD]Zoom in or out[/TD]
[/TR]
[TR]
[TD]Ctrl+Alt+Spacebar[/TD]
[TD]Preview the desktop in full-screen mode[/TD]
[/TR]
[TR]
[TD]Ctrl+Alt+F[/TD]
[TD]Switch to full-screen mode[/TD]
[/TR]
[TR]
[TD]Ctrl+Alt+L[/TD]
[TD]Switch to lens mode[/TD]
[/TR]
[TR]
[TD]Ctrl+Alt+D[/TD]
[TD]Switch to docked mode[/TD]
[/TR]
[TR]
[TD]Ctrl+Alt+I[/TD]
[TD]Invert colors[/TD]
[/TR]
[TR]
[TD]Ctrl+Alt+arrow keys[/TD]
[TD]Pan in the direction of the arrow keys[/TD]
[/TR]
[TR]
[TD]Ctrl+Alt+R[/TD]
[TD]Resize the lens[/TD]
[/TR]
[TR]
[TD]Windows logo key + Esc[/TD]
[TD]Exit Magnifier[/TD]
[/TR]
[/TABLE]
Remote Desktop Connection keyboard shortcuts
[TABLE]
[TR]
[TD]Alt+Page Up[/TD]
[TD]Move between programs from left to right.[/TD]
[/TR]
[TR]
[TD]Alt+Page Down[/TD]
[TD]Move between programs from right to left.[/TD]
[/TR]
[TR]
[TD]Alt+Insert[/TD]
[TD]Cycle through programs in the order that they were started in.[/TD]
[/TR]
[TR]
[TD]Alt+Home[/TD]
[TD]Display the Start menu.[/TD]
[/TR]
[TR]
[TD]Ctrl+Alt+Break[/TD]
[TD]Switch between a window and full screen.[/TD]
[/TR]
[TR]
[TD]Ctrl+Alt+End[/TD]
[TD]Display the Windows Security dialog box.[/TD]
[/TR]
[TR]
[TD]Alt+Delete[/TD]
[TD]Display the system menu.[/TD]
[/TR]
[TR]
[TD]Ctrl+Alt+Minus Sign (-) on the numeric keypad[/TD]
[TD]Place a copy of the active window, within the client, on the Terminal server clipboard (provides the same functionality as pressing Alt+PrtScn on a local computer).[/TD]
[/TR]
[TR]
[TD]Ctrl+Alt+Plus Sign (+) on the numeric keypad[/TD]
[TD]Place a copy of the entire client window area on the Terminal server clipboard (provides the same functionality as pressing PrtScn on a local computer).[/TD]
[/TR]
[TR]
[TD]Ctrl+Alt+Right Arrow[/TD]
[TD]“Tab” out of the Remote Desktop controls to a control in the host program (for example, a button or a text box). Useful when the Remote Desktop controls are embedded in another (host) program.[/TD]
[/TR]
[TR]
[TD]Ctrl+Alt+Left Arrow[/TD]
[/TR]
[/TABLE]
Paint keyboard shortcuts
[TABLE]
[TR]
[TD]Ctrl+N
[/TD]
[TD]Create a new picture[/TD]
[/TR]
[TR]
[TD]Ctrl+O[/TD]
[TD]Open an existing picture[/TD]
[/TR]
[TR]
[TD]Ctrl+S[/TD]
[TD]Save changes to a picture[/TD]
[/TR]
[TR]
[TD]F12[/TD]
[TD]Save the picture as a new file[/TD]
[/TR]
[TR]
[TD]Ctrl+P[/TD]
[TD]Print a picture[/TD]
[/TR]
[TR]
[TD]Alt+F4[/TD]
[TD]Close a picture and its Paint window[/TD]
[/TR]
[TR]
[TD]Ctrl+Z[/TD]
[TD]Undo a change[/TD]
[/TR]
[TR]
[TD]Ctrl+Y[/TD]
[TD]Redo a change[/TD]
[/TR]
[TR]
[TD]Ctrl+A[/TD]
[TD]Select the entire picture[/TD]
[/TR]
[TR]
[TD]Ctrl+X[/TD]
[TD]Cut a selection[/TD]
[/TR]
[TR]
[TD]Ctrl+C[/TD]
[TD]Copy a selection to the Clipboard[/TD]
[/TR]
[TR]
[TD]Ctrl+V[/TD]
[TD]Paste a selection from the Clipboard[/TD]
[/TR]
[TR]
[TD]Move the selection or active shape right by one pixel[/TD]
[/TR]
[TR]
[TD]Left Arrow[/TD]
[TD]Move the selection or active shape left by one pixel[/TD]
[/TR]
[TR]
[TD]Down Arrow[/TD]
[TD]Move the selection or active shape down by one pixel[/TD]
[/TR]
[TR]
[TD]Up Arrow[/TD]
[TD]Move the selection or active shape up by one pixel[/TD]
[/TR]
[TR]
[TD]Esc[/TD]
[TD]Cancel a selection[/TD]
[/TR]
[TR]
[TD]Delete[/TD]
[TD]Delete a selection[/TD]
[/TR]
[TR]
[TD]Ctrl+B[/TD]
[TD]Bold selected text[/TD]
[/TR]
[TR]
[TD]Ctrl++[/TD]
[TD]Increase the width of a brush, line, or shape outline by one pixel[/TD]
[/TR]
[TR]
[TD]Ctrl+-[/TD]
[TD]Decrease the width of a brush, line, or shape outline by one pixel[/TD]
[/TR]
[TR]
[TD]Ctrl+I[/TD]
[TD]Italicize selected text[/TD]
[/TR]
[TR]
[TD]Ctrl+U[/TD]
[TD]Underline selected text[/TD]
[/TR]
[TR]
[TD]Ctrl+E[/TD]
[TD]Open the Properties dialog box[/TD]
[/TR]
[TR]
[TD]Ctrl+W[/TD]
[TD]Open the Resize and Skew dialog box[/TD]
[/TR]
[TR]
[TD]Ctrl+Page Up[/TD]
[TD]Zoom in[/TD]
[/TR]
[TR]
[TD]Ctrl+Page Down[/TD]
[TD]Zoom out[/TD]
[/TR]
[TR]
[TD]F11[/TD]
[TD]View a picture in full-screen mode[/TD]
[/TR]
[TR]
[TD]Ctrl+R[/TD]
[TD]Show or hide the ruler[/TD]
[/TR]
[TR]
[TD]Ctrl+G[/TD]
[TD]Show or hide gridlines[/TD]
[/TR]
[TR]
[TD]F10 or Alt[/TD]
[TD]Display keytips[/TD]
[/TR]
[TR]
[TD]Shift+F10[/TD]
[TD]Show the current shortcut menu[/TD]
[/TR]
[TR]
[TD]F1[/TD]
[TD]Open Paint Help
[/TD]
[/TR]
[/TABLE]
WordPad keyboard shortcuts
[TABLE]
[TR]
[TD]Ctrl+N[/TD]
[TD]Create a new document[/TD]
[/TR]
[TR]
[TD]Ctrl+O[/TD]
[TD]Open an existing document[/TD]
[/TR]
[TR]
[TD]Ctrl+S[/TD]
[TD]Save changes to a document[/TD]
[/TR]
[TR]
[TD]F12[/TD]
[TD]Save the document as a new file[/TD]
[/TR]
[TR]
[TD]Ctrl+P[/TD]
[TD]Print a document[/TD]
[/TR]
[TR]
[TD]Alt+F4[/TD]
[TD]Close WordPad[/TD]
[/TR]
[TR]
[TD]Ctrl+Z[/TD]
[/TR]
[TR]
[TD]Ctrl+Y[/TD]
[/TR]
[TR]
[TD]Ctrl+A[/TD]
[TD]Select the entire document[/TD]
[/TR]
[TR]
[TD]Ctrl+X[/TD]
[/TR]
[TR]
[TD]Ctrl+C[/TD]
[/TR]
[TR]
[TD]Ctrl+V[/TD]
[/TR]
[TR]
[TD]Ctrl+B[/TD]
[TD]Make selected text bold[/TD]
[/TR]
[TR]
[TD]Ctrl+I[/TD]
[/TR]
[TR]
[TD]Ctrl+U[/TD]
[/TR]
[TR]
[TD]Ctrl+=[/TD]
[TD]Make selected text subscript[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift+=[/TD]
[TD]Make selected text superscript[/TD]
[/TR]
[TR]
[TD]Ctrl+L[/TD]
[TD]Align text left[/TD]
[/TR]
[TR]
[TD]Ctrl+E[/TD]
[TD]Align text center[/TD]
[/TR]
[TR]
[TD]Ctrl+R[/TD]
[TD]Align text right[/TD]
[/TR]
[TR]
[TD]Ctrl+J[/TD]
[TD]Justify text[/TD]
[/TR]
[TR]
[TD]Ctrl+1[/TD]
[TD]Set single line spacing[/TD]
[/TR]
[TR]
[TD]Ctrl+2[/TD]
[TD]Set double line spacing[/TD]
[/TR]
[TR]
[TD]Ctrl+5[/TD]
[TD]Set line spacing to 1.5[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift+>[/TD]
[TD]Increase the font size[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift+
[TD]Decrease the font size[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift+A[/TD]
[TD]Change characters to all capitals[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift+L[/TD]
[TD]Change the bullet style[/TD]
[/TR]
[TR]
[TD]Ctrl+D[/TD]
[TD]Insert a Microsoft Paint drawing[/TD]
[/TR]
[TR]
[TD]Ctrl+F[/TD]
[TD]Find text in a document[/TD]
[/TR]
[TR]
[TD]F3[/TD]
[TD]Find the next instance of the text in the Find dialog box[/TD]
[/TR]
[TR]
[TD]Ctrl+H[/TD]
[TD]Replace text in a document[/TD]
[/TR]
[TR]
[TD]Move the cursor one word to the left[/TD]
[/TR]
[TR]
[TD]Move the cursor one word to the right[/TD]
[/TR]
[TR]
[TD]Move the cursor to the line above[/TD]
[/TR]
[TR]
[TD]Move the cursor to the line below[/TD]
[/TR]
[TR]
[TD]Ctrl+Home[/TD]
[TD]Move to the beginning of the document[/TD]
[/TR]
[TR]
[TD]Ctrl+End[/TD]
[TD]Move to the end of the document[/TD]
[/TR]
[TR]
[TD]Move up one page[/TD]
[/TR]
[TR]
[TD]Move down one page[/TD]
[/TR]
[TR]
[TD]Ctrl+Delete[/TD]
[TD]Delete the next word[/TD]
[/TR]
[TR]
[TD]F10[/TD]
[/TR]
[TR]
[TD]Shift+F10[/TD]
[/TR]
[TR]
[TD]F1[/TD]
[TD]Open WordPad Help[/TD]
[/TR]
[/TABLE]
Calculator keyboard shortcuts
[TABLE]
[TR]
[TD]Alt+1[/TD]
[TD]Switch to Standard mode[/TD]
[/TR]
[TR]
[TD]Alt+2[/TD]
[TD]Switch to Scientific mode[/TD]
[/TR]
[TR]
[TD]Alt+3[/TD]
[TD]Switch to Programmer mode[/TD]
[/TR]
[TR]
[TD]Alt+4[/TD]
[TD]Switch to Statistics mode[/TD]
[/TR]
[TR]
[TD]Ctrl+E[/TD]
[TD]Open date calculations[/TD]
[/TR]
[TR]
[TD]Ctrl+H[/TD]
[TD]Turn calculation history on or off[/TD]
[/TR]
[TR]
[TD]Ctrl+U[/TD]
[TD]Open unit conversion[/TD]
[/TR]
[TR]
[TD]Alt+C[/TD]
[TD]Calculate or solve date calculations and worksheets[/TD]
[/TR]
[TR]
[TD]F1[/TD]
[TD]Open Calculator Help[/TD]
[/TR]
[TR]
[TD]Ctrl+Q[/TD]
[TD]Press the M- button[/TD]
[/TR]
[TR]
[TD]Ctrl+P[/TD]
[TD]Press the M+ button[/TD]
[/TR]
[TR]
[TD]Ctrl+M[/TD]
[TD]Press the MS button[/TD]
[/TR]
[TR]
[TD]Ctrl+R[/TD]
[TD]Press the MR button[/TD]
[/TR]
[TR]
[TD]Ctrl+L[/TD]
[TD]Press the MC button[/TD]
[/TR]
[TR]
[TD]%[/TD]
[TD]Press the % button[/TD]
[/TR]
[TR]
[TD]F9[/TD]
[TD]Press the +/– button[/TD]
[/TR]
[TR]
[TD]/[/TD]
[TD]Press the / button[/TD]
[/TR]
[TR]
[TD]*[/TD]
[TD]Press the * button[/TD]
[/TR]
[TR]
[TD]+[/TD]
[TD]Press the + button[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Press the – button[/TD]
[/TR]
[TR]
[TD]R[/TD]
[TD]Press the 1/× button[/TD]
[/TR]
[TR]
[TD]@[/TD]
[TD]Press the square root button[/TD]
[/TR]
[TR]
[TD]0-9[/TD]
[TD]Press the number buttons (0-9)[/TD]
[/TR]
[TR]
[TD]=[/TD]
[TD]Press the = button [/TD]
[/TR]
[TR]
[TD].[/TD]
[TD]Press the . (decimal point) button[/TD]
[/TR]
[TR]
[TD]Backspace[/TD]
[TD]Press the backspace button[/TD]
[/TR]
[TR]
[TD]Esc[/TD]
[TD]Press the C button[/TD]
[/TR]
[TR]
[TD]Del[/TD]
[TD]Press the CE button[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift+D[/TD]
[TD]Clear the calculation history[/TD]
[/TR]
[TR]
[TD]F2[/TD]
[TD]Edit the calculation history[/TD]
[/TR]
[TR]
[TD]Up Arrow key[/TD]
[TD]Navigate up in the calculation history[/TD]
[/TR]
[TR]
[TD]Down Arrow key[/TD]
[TD]Navigate down in the calculation history[/TD]
[/TR]
[TR]
[TD]Esc[/TD]
[TD]Cancel editing the calculation history[/TD]
[/TR]
[TR]
[TD]Enter[/TD]
[TD]Recalculate the calculation history after editing[/TD]
[/TR]
[TR]
[TD]F3[/TD]
[TD]Select Degrees in Scientific mode[/TD]
[/TR]
[TR]
[TD]F4[/TD]
[TD]Select Radians in Scientific mode[/TD]
[/TR]
[TR]
[TD]F5[/TD]
[TD]Select Grads in Scientific mode[/TD]
[/TR]
[TR]
[TD]I[/TD]
[TD]Press the Inv button in Scientific mode[/TD]
[/TR]
[TR]
[TD]D[/TD]
[TD]Press the Mod button in Scientific mode[/TD]
[/TR]
[TR]
[TD]Ctrl+S[/TD]
[TD]Press the sinh button in Scientific mode[/TD]
[/TR]
[TR]
[TD]Ctrl+O[/TD]
[TD]Press the cosh button in Scientific mode[/TD]
[/TR]
[TR]
[TD]Ctrl+T[/TD]
[TD]Press the tanh button in Scientific mode[/TD]
[/TR]
[TR]
[TD]([/TD]
[TD]Press the ( button in Scientific mode[/TD]
[/TR]
[TR]
[TD])[/TD]
[TD]Press the ) button in Scientific mode[/TD]
[/TR]
[TR]
[TD]N[/TD]
[TD]Press the ln button in Scientific mode[/TD]
[/TR]
[TR]
[TD];[/TD]
[TD]Press the Int button in Scientific mode[/TD]
[/TR]
[TR]
[TD]S[/TD]
[TD]Press the sin button in Scientific mode[/TD]
[/TR]
[TR]
[TD]O[/TD]
[TD]Press the cos button in Scientific mode[/TD]
[/TR]
[TR]
[TD]T[/TD]
[TD]Press the tan button in Scientific mode[/TD]
[/TR]
[TR]
[TD]M[/TD]
[TD]Press the dms button in Scientific mode[/TD]
[/TR]
[TR]
[TD]P[/TD]
[TD]Press the pi button in Scientific mode[/TD]
[/TR]
[TR]
[TD]V[/TD]
[TD]Press the F-E button in Scientific mode[/TD]
[/TR]
[TR]
[TD]X[/TD]
[TD]Press the Exp button in Scientific mode[/TD]
[/TR]
[TR]
[TD]Q[/TD]
[TD]Press the x^2 button in Scientific mode[/TD]
[/TR]
[TR]
[TD]Y[/TD]
[TD]Press the x^y button in Scientific mode[/TD]
[/TR]
[TR]
[TD]#[/TD]
[TD]Press the x^3 button in Scientific mode[/TD]
[/TR]
[TR]
[TD]L[/TD]
[TD]Press the log button in Scientific mode[/TD]
[/TR]
[TR]
[TD]![/TD]
[TD]Press the n! button in Scientific mode[/TD]
[/TR]
[TR]
[TD]Ctrl+Y[/TD]
[TD]Press the y√x button in Scientific mode[/TD]
[/TR]
[TR]
[TD]Ctrl+B[/TD]
[TD]Press the 3√x button in Scientific mode[/TD]
[/TR]
[TR]
[TD]Ctrl+G[/TD]
[TD]Press the 10x button in Scientific mode[/TD]
[/TR]
[TR]
[TD]F5[/TD]
[TD]Select Hex in Programmer mode[/TD]
[/TR]
[TR]
[TD]F6[/TD]
[TD]Select Dec in Programmer mode[/TD]
[/TR]
[TR]
[TD]F7[/TD]
[TD]Select Oct in Programmer mode[/TD]
[/TR]
[TR]
[TD]F8[/TD]
[TD]Select Bin in Programmer mode[/TD]
[/TR]
[TR]
[TD]F12[/TD]
[TD]Select Qword in Programmer mode[/TD]
[/TR]
[TR]
[TD]F2[/TD]
[TD]Select Dword in Programmer mode[/TD]
[/TR]
[TR]
[TD]F3[/TD]
[TD]Select Word in Programmer mode[/TD]
[/TR]
[TR]
[TD]F4[/TD]
[TD]Select Byte in Programmer mode[/TD]
[/TR]
[TR]
[TD]K[/TD]
[TD]Press the RoR button in Programmer mode[/TD]
[/TR]
[TR]
[TD]J[/TD]
[TD]Press the RoL button in Programmer mode[/TD]
[/TR]
[TR]
[TD]
[TD]Press the Lsh button in Programmer mode[/TD]
[/TR]
[TR]
[TD]>[/TD]
[TD]Press the Rsh button in Programmer mode[/TD]
[/TR]
[TR]
[TD]%[/TD]
[TD]Press the Mod button in Programmer mode[/TD]
[/TR]
[TR]
[TD]([/TD]
[TD]Press the ( button in Programmer mode[/TD]
[/TR]
[TR]
[TD])[/TD]
[TD]Press the ) button in Programmer mode[/TD]
[/TR]
[TR]
[TD]|[/TD]
[TD]Press the Or button in Programmer mode[/TD]
[/TR]
[TR]
[TD]^[/TD]
[TD]Press the Xor button in Programmer mode[/TD]
[/TR]
[TR]
[TD]~[/TD]
[TD]Press the Not button in Programmer mode[/TD]
[/TR]
[TR]
[TD]&[/TD]
[TD]Press the And button in Programmer mode[/TD]
[/TR]
[TR]
[TD]A-F[/TD]
[TD]Press the A-F buttons in Programmer mode[/TD]
[/TR]
[TR]
[TD]Spacebar[/TD]
[TD]Toggles the bit value in Programmer mode[/TD]
[/TR]
[TR]
[TD]A[/TD]
[TD]Press the Average button in Statistics mode[/TD]
[/TR]
[TR]
[TD]Ctrl+A[/TD]
[TD]Press the Average Sq button in Statistics mode[/TD]
[/TR]
[TR]
[TD]S[/TD]
[TD]Press the Sum button in Statistics mode[/TD]
[/TR]
[TR]
[TD]Ctrl+S[/TD]
[TD]Press the Sum Sq button in Statistics mode[/TD]
[/TR]
[TR]
[TD]T[/TD]
[TD]Press the S.D. button in Statistics mode[/TD]
[/TR]
[TR]
[TD]Ctrl+T[/TD]
[TD]Press the Inv S.D. button in Statistics mode[/TD]
[/TR]
[TR]
[TD]D[/TD]
[TD]Press the CAD button in Statistics mode[/TD]
[/TR]
[/TABLE]
Windows Journal keyboard shortcuts
[TABLE]
[TR]
[TD]Ctrl+N[/TD]
[TD]Start a new note[/TD]
[/TR]
[TR]
[TD]Ctrl+O[/TD]
[TD]Open a recently used note[/TD]
[/TR]
[TR]
[TD]Ctrl+S[/TD]
[TD]Save changes to a note[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift+V[/TD]
[TD]Move a note to a specific folder[/TD]
[/TR]
[TR]
[TD]Ctrl+P[/TD]
[TD]Print a note[/TD]
[/TR]
[TR]
[TD]Alt+F4[/TD]
[TD]Close a note and its Journal window[/TD]
[/TR]
[TR]
[TD]Ctrl+Z[/TD]
[/TR]
[TR]
[TD]Ctrl+Y[/TD]
[/TR]
[TR]
[TD]Ctrl+A[/TD]
[TD]Select all items on a page[/TD]
[/TR]
[TR]
[TD]Ctrl+X[/TD]
[/TR]
[TR]
[TD]Ctrl+C[/TD]
[/TR]
[TR]
[TD]Ctrl+V[/TD]
[/TR]
[TR]
[TD]Esc[/TD]
[/TR]
[TR]
[TD]Delete[/TD]
[/TR]
[TR]
[TD]Ctrl+F[/TD]
[TD]Start a basic find[/TD]
[/TR]
[TR]
[TD]Ctrl+G[/TD]
[TD]Go to a page[/TD]
[/TR]
[TR]
[TD]F5[/TD]
[TD]Refresh find results[/TD]
[/TR]
[TR]
[TD]F5[/TD]
[TD]Refresh the note list[/TD]
[/TR]
[TR]
[TD]F6[/TD]
[TD]Toggle between a note list and a note[/TD]
[/TR]
[TR]
[TD]Ctrl+Shift+C[/TD]
[TD]Display a shortcut menu for column headings in a note list[/TD]
[/TR]
[TR]
[TD]F11[/TD]
[TD]View a note in full-screen mode[/TD]
[/TR]
[TR]
[TD]F1[/TD]
[TD]Open Journal Help[/TD]
[/TR]
[/TABLE]
Windows Help viewer keyboard shortcuts
[TABLE]
[TR]
[TD]Alt+C
[/TD]
[TD]Display the Table of Contents
[/TD]
[/TR]
[TR]
[TD]Alt+N
[/TD]
[TD]Display the Connection Settings menu
[/TD]
[/TR]
[TR]
[TD]F10
[/TD]
[TD]Display the Options menu
[/TD]
[/TR]
[TR]
[TD]Alt+Left Arrow
[/TD]
[TD]Move back to the previously viewed topic
[/TD]
[/TR]
[TR]
[TD]Alt+Right Arrow
[/TD]
[TD]Move forward to the next (previously viewed) topic
[/TD]
[/TR]
[TR]
[TD]Alt+A
[/TD]
[TD]Display the customer support page
[/TD]
[/TR]
[TR]
[TD]Alt+Home
[/TD]
[TD]Display the Help and Support home page
[/TD]
[/TR]
[TR]
[TD]Home
[/TD]
[TD]Move to the beginning of a topic
[/TD]
[/TR]
[TR]
[TD]End
[/TD]
[TD]Move to the end of a topic
[/TD]
[/TR]
[TR]
[TD]Ctrl+F
[/TD]
[TD]Search the current topic
[/TD]
[/TR]
[TR]
[TD]Ctrl+P
[/TD]
[TD]Print a topic
[/TD]
[/TR]
[TR]
[TD]F3
[/TD]
[TD]Move the cursor to the search box
[/TD]
[/TR]
[/TABLE]
به گفتگو بپیوندید
مهمان
ارسال پاسخ به این موضوع ...
×   شما در حال چسباندن محتوایی با قالب بندی هستید.   حذف قالب بندی
  تنها استفاده از 75 اموجی مجاز می باشد.
×   لینک شما به صورت اتوماتیک جای گذاری شد.   نمایش به صورت لینک
×   محتوای قبلی شما بازگردانی شد.   پاک کردن محتوای ویرایشگر
×   شما مستقیما نمی توانید تصویر خود را قرار دهید. یا آن را اینجا بارگذاری کنید یا از یک URL قرار دهید.
