نرم افزار شبیه سازی نیروگاههای هسته ای
این ورژن دمو بوده وقابلیت هایی برای اشنایی ونمایش ویژگی های
های هسته ای به عنوان سیمولاتور دارد که میتواند برای علاقه مندان به مباحث نیروگاهی ودوستانی که به دنبال اشنایی با نیروگاه های هسته ای هستند مفید باشد
نرم افزاررا میتوانید ازلینک پایین با حجم 3 مگابایت دانلود نمایید.
Nuclear Power Plant Simulator is a fun way to learn how atomic energy works and what happens in the control room. You are in control of a small commercial nuclear power plant. Your object is to produce as much electricity as you can without causing a MELTDOWN. You will run the plant to it's limits but be careful not to push it too hard or damage and warning lights will appear. Many things can go wrong if you are not careful
If you don't push the plant too hard it will not break down, but your energy output and rating will be lower. Try to find the balance between efficient energy production and safe handling of the equipment.
Nuclear
Simulator is addictive and not too hard to play, but watch out - it is a challenge to do well. The game comes with built in instructions and an animated nuclear plant diagram. There are numerous gauges and screens and warning lights to keep you busy. You can adjust the control rods to produce heat in the reactor, adjust primary coolant to carry heat to the heat exchanger, adjust secondary coolant to take steam to the turbine and on to the cooling tower. There is also a supply of emergency coolant if you need it. It is a lot of fun to see how hard you can push the machinery without causing small and LARGE problems!
Fortunately this game is entirely safe. You will learn a lot about nuclear energy and have fun in the process. The game looks really cool, too.
Nuclear Power Plant version 1.3 is available for immediate download.
Features:
  • Educational and fun game play: learn about process-control while you learn about power plants!
  • In-game CRT informational display shows all of your power plant's vital statistics.
  • Warning lights and temperature guages compliment the CRT display to help you monitor the health and output of your plant.
  • Full version features two difficulty levels - on the harder setting, sub-standard plant workmanship can cause problems.
  • Animated diagram helps you visualize the systems and operations of the facillity.
  • Complete in-game instructions and mouse-over help
  • Great for classroom use, teaches about energy, power plants, process crontrol and more.
  • Addictive game play.
  • Inexpensive to purchase and easy to download and play right away!
