مقالات لاتين گروه زراعت
Eng.NaDi
سلام دوستان
در اين بخش با كمك شما سعي خواهيم كرد مقالات لاتين رو كه با موضوعات زراعي هستند قرار بديم، تا ديگران هم اگر مايل بودند استفاده كنند.
ممنون:icon_gol:
Soybean response to application of poultry manure and phosphorus fertilizer in the Sub-humid Savanna of Nigeria
Field experiments were conducted during the rainy seasons of 2003 and 2005 in Samaru in the NorthernGuinea Savanna zone of Nigeria to test the response of two soybean varieties to application of poultrymanure and phosphorus fertilizer levels. Soybean varieties TGx 1448-2E and TGx 1019-2EB were grownwithout and with 1t/ha of poultry manure and four levels of P (0, 13.2, 26.4 and 39.6 kgP/ha) in allpossible factorial combinations using randomized complete block design with four replicates. TGx1448-2EB was shorter, had more pods and heavier seeds than TGx 1019-2EB. Grain yield and total drymatter per hectare were higher in TGx 1448-2EB. Application of manure consistently influenced mostparameters in both years. Manure application increased leaf area index, plant height, nodule dry weight,total dry matter per plant and per hectare, number of pods per plant and grain yield per hectare.Phosphorus application increased leaf area index, plant height, nodule dry weight, total dry matter perhectare and grain yield per hectare. Highest grain yield was obtained with 26.4 kgP/ha which was notsignificantly different from yield obtained with 39.6 kgP/ha. Regression model showed a quadraticresponse and the agronomic optimum was 23.3 kgP/ha for a grain yield of 1.7 t/ha when averaged overboth years. Application of 1 t/ha of poultry manure significantly (P
fertilizers in any of the years or when weighed over the years.
Salt Stress Effects on Respiration and Growth of Germinated Seeds of Different Wheat (Triticum aestivumL.) Cultivars
Aliakbar Maghsoudi Moud and Kobra Maghsoudi
Abstract:
Establishment of seedlings at early growth stages of crop plants as one of the most important determinants of high yield is severely affected by soil salinity. Therefore, high germination rate and vigorous early growth under salty soils is preferred. In this study salt tolerance of wheat cultivars were examined at germination and seedling growth stages. Seeds were germinated and grown in long dark cups using distilled water as control and two levels of salt stress imposed by 9 and 15 ds/m NaCl solution for 48 hours. Coleoptile and root growth was measured as the response of cultivars to salinity. Seedling respiration was expressed as the difference between initial seed weight and seedling dry weight after 48 hours. Significant differences were found among cultivars in terms of coleoptile and root growth under salt stress condition. Differences among cultivars in terms of respiration rate were also significant indicating that genetic variation exists among wheat cultivars. It was also found that seedling respiration was decreased as salinity level was increased. Significant correlation coefficients were found between coleoptile growth and respiration under all condition. Salt stress inhibited coleoptile growth more than root growth. It was concluded that wheat seedling maintenance respiration is higher that what is
estimated
for C3 plants
Key words: Salt stress % Respiration % Germination % Wheat
EFFECT OF WATER STRESS ON YIELD AND EVAPOTRANSPIRATION OF SUNWLOWER
Pejić, B.*, Maksimović, L., Škorić, D., Milić, S.,Stričević, R., Ćupina, B.
SUMMARY
An experiment was conducted at Rimski Šančevi Experiment Field of Institute of Field and Vegetable Crops in Novi Sad during 2000 - 2005. The soil in the experimental plot was calcareous chernozem on loess terrace. Using the yield response factor (ky)the study investigated how sunflower yield and evapotranspiration, were affected by deficit of available soil water during the growing season. The experiment consisted of an irrigated treatment (T1), in which irrigation was used when soil moisture levels dropped to 60-65% of FC (field capacity), and a nonirrigated control treatment (T0). The sunflower hybrid
used in the study was NS-H-111.On average, no significant differences in yield level were observed betweenT1 (3.79 t ha-1) and T0 (3.75 t ha-1) treatments. Seasonal evapotranspiration (ETm) obtained in T1 treatment was in the 402-479 mm range
The yield response factor (ky) was obtained as 0.20 for total growing season and 0.27 and 0.48 for vegetative, flowering and yield formation period, respectively 0.31. Period from flowering to maturity was the most sensitive towards water deficiency.
Key words: sunflower (Helianthus annuus L.), yield response factor (ky), yield, evapotranspiration
  • 3 هفته بعد...
Effect of water stress on yield and agronomic characters of peanut (Arachis hypogaea L.) b
Nimitr Vorasoot , Patcharin Songsri, Chutipong Akkasaeng ,Sanun Jogloy and Aran Patanothai
Abstract:
Peanut production in Thailand is concentrated in upland area under rain-fed conditions. Unpredictable
time and the extent of water deficit occurs every year and causes a reduction in yield and quality. Under
these conditions the use of cultivars tolerant to drought and producing high yield should be advantageous.
The objective of this study was to investigate the effect of water stress on yield and agronomic characters of
peanut cultivars. A glasshouse experiment was conducted for evaluation of 4 peanut cultivars, Tainan 9,
Khon Kaen 60-3, ICGV 98308 and ICGV 98324, under three regimes of water (field capacity, 1/2 available
water and 1/4 available water) in earthen pots. A 4×3 factorial experiment in randomized complete block
design with 4 replications was conducted. Total dry weight, pod yield, seed yield, 100 seed weight and shelling
percentage were determined at the final harvest. At field capacity, all peanut cultivars performed well. Yield
and agronomic characters of all cultivars were decreased under water stress; and significant response of
genotypes was observed. Khon Kaen 60-3 and ICGV 98308 were more sensitive to water stress, comparing
with Tainan 9 and ICGV 98324.
Key words : water stress, peanut genotypes, dry matter, dry pod yield, agronomic characters
Effect of Drought Stress on Alfalfa Cultivars (Medicago sativa L.) in Germination Stage
H. Hamidi and A. Safarnejad
Abstract:
Drought is one of the most important natural phenomenon which affects on plant growth. Alfalfa
(Medicago sativa L.) is an essential fodder product which has extensive and depth roots system, this
advantage enables the plant to tolerate long term drought without any damage to its regrowth process. In order
to measure germination percentage and rate, root and shoot growth of 6 alfalfa cultivars (each cultivar has few
years old) under various osmotic potential, an experimental design was carried out complete randomized in vitro
condition in four replications. To expose drought stress over plant polyethylene glycol (PEG6000) with 0
(control), -3, -6, -9 bar was used. Those cultivars under experiment include Yazdi, Hamedani, Qareh Yonjeh,
Maupa, Simmer Chenskaya and CUF101. The results indicated that by reducing osmotic potential of culture
environment higher drought stress, a significant decrease in germination percentage and rate, radicle and
plumule length and seed vigority index were observed, while the ratio of radicle to plumule was increased.
Correlation coefficients of studied plant traits also showed that germination percentage and rate have
significant and positive correlations with plumule length, but significant and negative correlation with the ratio
of radicle to plumule. Among cultivars, Yazdi and Maupa had higher germination percentage and rate under
sever stresses, therefore their tolerance against drought stress during germination stage is more than other
cultivars.
Key words: Alfalfa % Drought stress % Germination % Medicago sativa % Tolerance
  • 2 ماه بعد...
The Effect of Mycorrhizae on the Growth of Zea mays in Nutrient
Deficient Soil
Renata M. Lehman
Abstract:
The purpose of this experiment was to determine of Zea mays (corn) exhibited greater plant growth and
fewer symptoms of nutrient deficiency when grown in a nutrient deficient soil that had been inoculated
with mycorrhizae.
Effect of Lead Toxicity on Growth, Chlorophyll and Lead (Pb
Contents of Two Varieties of Maize (Zea mays L.)
Abdul Ghani
Abstract:
Two varieties of maize (Zea mays L.) (Neelam and Desi) were exposed to different concentrations
of lead [0, 10, 20 and 30 ppm Pb(NO3)2•4H2O] for 14 days in earthen pots. Exposure of maize varieties to
excess Pb resulted in a significant root growth inhibition though shoot growth remained less affected. The
results of chlorophyll analysis indicated that the highly toxic Pb level affected photochemical efficiency in
Neelam, while no significant effect was observed in the Desi. This result was related to the accumulation
of Pb. The results of the present study indicated that, Desi withstands excess Pb with its higher Pb
accumulation capacity in roots and better upregulated protective mechanisms compared to Neelam.
Therefore, Desi is more tolerant to Pb toxicity compared to Neelam which was found to be susceptible variety.
Key words: Maize (Zea mays L.), lead toxicity, Pb accumulation, Pb concentrations
