درخواست و دانلود مقالات علمی رایگان از سایر پایگاه ها ( ISI ، Wiley و . . .)
سلام و خسته نباشید
این مقاله را لطفا زحمتشو بکشید:
Earthquake Engineering & Structural Dynamics
pages 847–858, August 1990
Diagonal brace with ductile knee anchor for aseismic steel frame
این دو تا رو اگه زحمتشو بکشید ممنون میشم
[TABLE=class: jnlDrpTable]
[TR]
[TH=class: column1]Title:[/TH]
[TD=class: column2]The power of missions: Aligning strategy and culture[/TD]
[/TR]
[TR]
[TH=class: column1]Author(s):[/TH]
[TD=class: column2]
,[/TD]
[/TR]
[/TABLE]
[TR]
[TD=class: column2]Why good management ideas fail:: the neglected power of organizational culture[/TD]
[/TR]
[TR]
[TD=class: column2]
,[/TD]
[/TR]
[/TABLE]
این مقاله ها رو میتونید دانلود کنید ؟
به دومی دسترسی نداشتم
برای پایان نامه خودم نیاز به 4 و5 تا پایان نامه از ProQues دارم . میشه لطفا زحمتش رو بکشید و دانلود کنید.
Computation of flow and heat transfer in helical pipes
by Bandyopadhyay, Alakananda Ph.D., University of Minnesota, 1993, 193 pages; AAT 9328323
Laminar flow and heat transfer in helical pipes with finite pitch
by Liu, Shijie Ph.D., University of Alberta (Canada), 1992, 341 pages; AAT NN73075
Convective heat transfer and enhancement in a helical pippe
by Li, Jian Long D.Eng., Chongqing University (People's Republic of China), 1998 ; AAT H049038
Dynamics of helical flow structures: A description of vortex formation in turbulent fluids
by Nawri, Nikolaj W. Ph.D., University of Maryland, College Park, 2003, 232 pages; AAT 3094520
VELOCITY PROFILES OF A NON-NEWTONIAN FLUID IN HELICAL FLOW
by REA, DAVID RICHARD Ph.D., Princeton University, 1967, 147 pages; AAT 6713504
HELICAL FLOW OF A NON-NEWTONIAN FLUID
by DIERCKES, ALBERT CHARLES, JR. Ph.D., Princeton University, 1965, 233 pages; AAT 6513136
MOMENTUM AND ENERGY TRANSPORT IN LAMINAR HELICAL FLOW
by MANLAPAZ, ROMEO L. Ph.D., University of Pennsylvania, 1971, 382 pages; AAT 7206201
TURBULENT HELICAL FLOW IN AN ANNULUS
by GELHAR, LYNN WALTER Ph.D., The University of Wisconsin - Madison, 1964, 117 pages; AAT 6413877
Theoretical and experimental study of buckling behavior of coiled tubing and axial force transfer modeling in coiled tubing drilling
by Qiu, Weiyong Ph.D., The University of Tulsa, 1997, 172 pages; AAT 9813909
میدونم خیلی زیاد هستند ، اما لطفا زحمتش رو بکشید که ما این پایان نامه رو بدیم و تموم بشه . برای بعضی قسمت های پایان نامه خودم واقعا گیر کردم و این پایان نامه ها واقعا کمکم میکنه.
واقعا ازتون ممنون میشم کمک کنید.
از این استفاده کن چند تاشو میتونی بگیری :
203.131.212.166
3128
برای باقی هم پروکسی های مختلف رو جستجو و امتحان کن.
با عرض سلام خدمت دوستان
به این کتاب نیاز مبرم دارم واقعا ممنون میشوم تهیه نمایید
البته نمیدانم در این تالار میتوان درخواست کتاب داد یا نه!
Carbon Nanotubes
Reinforced Metal Matrix Composites
By
Published
19th October 2010 by CRC Press – 325 pages
Carbon Nanotubes
By
Published
برادر من ! جون عزیزت اولا قبل درخواست ، اطلاعیه های تالار رو بخون !
ثانیا وقتی درخواست کتاب میدی لااقل 2 مین توو نت سرچ کن ببین این کتاب برای کدوم خراب شده ایه!
الان شما لینک tandfonline (اونم فروشگاه کتابش !!! ) رو میدی در صورتی که خودت نوشتی CRC Press !!!
با اینجور درخواست دادن بنده فکر میکنم داری منو مسخره میکنی و فقط به این فکر میکنی که کار خودت راه بیفته و گور بابای دانلودر!
به هر حال :
اول مرورگرت رو بصورت زیر تنظیم کن :
در نهایت هم وارد لینک زیر شو و کتابت رو دانلود کن.
به هر حال :
دوست عزیز اگه میشه بگید این پروکسی ها رو چجوری پیدا کردید تا دیگه کمتر مزاحم شیم؟لطفا
http://www.noandishaan.com/forums/thread90332.html
با سلام مجموعه مقالات دومین کنفرانس مدیریت تولید و عملیات می خواستم .لینک ها رو خودتون گذاشتید رو صفحه
:w58:
سلام میشه این 3تا مقاله رو برای من بذارید. ممنون
1.
[h=1]A Simple CPM Time-Cost Tradeoff Algorithm[/h]
  • برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید.
2.
[h=1]The discrete time/cost trade-off problem: extensions and heuristic procedures[/h]
3. Goyal, S.K., 1975. A note on simple CPM time–cost tradeoff algorithm. Management Science 21 (6), 718–722.
1.
2.
در صورت امکان این دو مقاله رو لطف کنید:
[TR]
[/TH]
[TD=class: column2]How green are HRM practices, organizational culture, learning and teamwork? A Brazilian study[/TD]
[/TR]
[TR]
[/TH]
[TD=class: column2]
, [/TD]
[/TR]
[/TABLE]
[TR]
[TD=class: column2]Shades of green: the greenfield concept in HRM[/TD]
[/TR]
[TR]
[TD=class: column2]
, [/TD]
[/TR]
[/TABLE]
[TR]
[/TH]
[/TR]
[TR]
[/TH]
[TD=class: column2]
, [/TD]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[TD=class: column2]
, [/TD]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[TD=class: column2]
,[/TD]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[TD=class: column2]
,[/TD]
[/TR]
[/TABLE]
میدونم اینجا باید درخواست دانلود مقاله بدیم ولی به این کتاب احتیاج مبرم دارم:
[TABLE=class: cms_table]
[TR=class: cms_table_metadata_row]
[TD=class: cms_table_metadata_label][/TD]
[TD=class: cms_table_metadata_value]Magnetic Exchange Coupling in Hard-soft Ferromagnetic Composite Thin Films of CoPt-Co: Role of Processing and Structure
[/TD]
[/TR]
[TD=class: cms_table_metadata_label]Author[/TD]
[/TD]
[/TR]
[TD=class: cms_table_metadata_label]Publisher[/TD]
[TD=class: cms_table_metadata_value]Lehigh University, 2001[/TD]
[/TR]
[TD=class: cms_table_metadata_label]Length[/TD]
[TD=class: cms_table_metadata_value]480 pages[/TD]
[/TR]
[/TABLE]
من به این مقاله نیاز دارم ممنون میشم اگه کسی دسترسی داره برام بگیره
[h=1]An Efficient Framework for Power-Aware Design of Heterogeneous MPSoC[/h]
لینک:
[TD=class: cms_table_metadata_value]Magnetic Exchange Coupling in Hard-soft Ferromagnetic Composite Thin Films of CoPt-Co: Role of Processing and Structure[/TD]
[/TR]
[/TD]
[/TR]
[/TR]
[/TR]
[/TABLE]
لینک:
اینجا درخواست بده :
http://www.noandishaan.com/forums/thread76646.html
[h=1]Some follower forces and load stiffness[/h]H. D. Hibbit
[h=2]International Journal for Numerical Methods in Engineering[/h]
pages 937–941, 1979
ممنون از لطفتون
