Mahnaz.D 61917 ارسال شده در 3 دی، 2011 این برنامه کامل شده ی برنامه ی گوگل اسکچاپه...که قیمتش هم تقریبا 500 دلاره برنامش عالیه...عین همون گوگل اسکچاپه فقط یه سری ابزار فوق العاده داره... Google SketchUp Pro is a simple but powerful tool for exploring and presenting your ideas in 3D. SketchUp Pro is everything traditional CAD software isn't -- quick to learn and intuitive to use. Create 3D Models Using SketchUp Pro, you can create 3D models, either by starting from scratch or by using existing data. Import drawings, CAD plans, photos, aerial imagery and other information, then use the modeling tools in SketchUp Pro to develop your ideas into 3D. Add data to your model Within SketchUp Pro, you have the ability to add attributes to your model with Dynamic Components. At any point, create a report summarizing the attribute data in your model. Use these reports to extract quantities and take-offs throughout the evolution of your model. Export and Share Some projects require the use of traditional CAD applications or renderering applications to develop construction drawings, photo-realistic images or to share information. SketchUp Pro can export your 3D model in a number of 2D and 3D formats for use with other applications. Present and Document For many of your projects, SketchUp Pro, which includes LayOut, is all you will need. LayOut is the 2D companion to SketchUp Pro for creating deliverables like permit and construction drawings, presentation documents and full-screen digital presentations. Only Google SketchUp Pro includes Style Builder, a tool for creating one-of-a-kind, sketchy-edge Styles for your SketchUp models. Turn hard-lined computer drawings into approachable sketches. Help your audience see the big picture by removing just the right amount of detail from your drawings. Hand-drawn sketches add nuance and personality to a concept, which can help to convey meaning or set the tone for an idea. Make your models and drawings a part of your visual brand. When you create a custom Style and apply it to your SketchUp model, no one else in the world is able to make models that look like yours. Your models and drawings will be totally unique. Turn any stroke into a custom Style. Scan in, photograph or draw the strokes you want to use. Sketchy-edge Styles can be based on anything: wavy pencil lines, quick pen strokes, marks from a fat stick of graphite. If you can see it, you can turn it into a Style. 2
Mahnaz.D 61917 ارسال شده در 3 دی، 2011 یکی از کاربرد های فوق العاده ی این برنامه...شیت بندیه :texc5lhcbtrocnmvtp8:texc5lhcbtrocnmvtp8 دیگه لازم نیست هی از این برنامه اون برنامه خروجی بگیرید...حالا کیفیت تغییر کنه یا نکنه....ای داد بیداد پلانمو تغییر دادم 3d ش به هم خورد با این برنامه همه چی راحت رو به راه می شه..... یه ویدئو هست که کامل شیت بندی رو توضیح می ده.....:yes: برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام 2
!Hooman 10133 ارسال شده در 13 دی، 2011 نرم افزار معروف و قدرتمند طراحی مدل های سه بعدی کمپانی گوگل مخصوص دانشجویان رشته های معماری ، عمران ، ساختمان ، گرافیک و ... امروزه نرم افزارهای طراحی و برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام جایگزین روش های سنتی و قدیمی شده اند. شاید تا چند سال پیش تنها راه طراحی نقشه یک ساختمان استفاده از ابزارها و وسایل نقشه کشی بود اما امروزه شاهد هستیم که نرم افزار های مختلف نقشه کشی جایگزین این ابزارها شده اند. امروز در سایت میهن دانلود نرم افزاری را برایتان آماده کرده ایم که مخصوص طراحی مدل های سه بعدی می باشد. نرم افزار برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام یکی از محبوب ترین و قدرتمند ترین نرم افزارهای طراحی و ساخت اشکال سه بعدی می باشد که شما با استفاده از آن به راحتی می توانید مدل های سه بعدی خلق کنید. این نرم افزار همانطور که از نام آن مشخص است محصول کمپانی معروف گوگل می باشد و بسیاری از طراحان از آن برای ساخت مدل های سه بعدی مجازی استفاده می کنند. همچنین شما می توانید با استفاده از ابزارهایی که در این نرم افزار قرار گرفته اقدام به طراحی و ساخت مدلهای سه بعدی از خانه ، آلونک ، عرشه کشتی ، سازه های چوبی و حتی سفینه فضایی کنید. بعلاوه در این نرم افزار تمام ابزارهایی را که یک دانشجو برای طراحی مدل سه بعدی پروژه خود به آنها احتیاج دارد قرار گرفته تا بتواند به آسانی آنرا طراحی نماید. از دیگر قابلیت های این نرم افزار می توان امکان ایجاد طراحی های دو بعدی ، ساخت مدل های هوشمند با قابلیت ایجاد نماها و زاویه های مختلف و ... اشاره نمود. یکی دیگر از امکانات بسیار خوب این نرم افزار امکان جستجو در پایگاه داده های بزرگ مدلهای سه بعدی گوگل است که شما با استفاده از این امکان می توانید به جستجوی دقیق اطلاعات طرح خود در گوگل بپردازید همچنین پس از طراحی مدل مورد نظر خود می توانید آنرا با استفاده از نرم افزار با سایر کاربران جهان به اشترک بگذارید. توضیحات کامل تر و ویژگیهای نرم افزار در ادامه مطلب موجود است ... برخی از ویژگیهای این نرم افزار: - امکان طراحی و ساخت مدل های سه بعدی و مجازی. - داشتن تمام ابزارهای طراحی مدل های مختلف سه بعدی. - امکان جستجو در میان پایگاه داده بزرگ مدلهای سه بعدی گوگل. - امکان اضافه کردن بافت های جدید به مدلها یا ساخت بافت جدید. - قابلیت به اشتراک گذاری مدلهای خلق شده با کاربران سراسر جهان. - امکان خلق ، تغییر ، چرخش و تغییر مقیاس اشکال هندسی. - امکان اضافه کردن سایه برای هر مدلی بر روی زمین. - سازگار با ويندوز هاي مختلف. - و ... برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام اتصال خود را از اینترنت قطع نموده و اقدام به نصب نرم افزار نمایید. در مرحله ی آخر از نصب نرم افزار با برداشتن تیک مربوط به اجرای برنامه مانع اجرای آن شوید. در صورتی که برنامه به صورت خودکار اجرا شد با زدن دگمه Close از آن خارج شوید. برخی از نرم افزارها با خروج از محیط آنها بسته نمی شوند بلکه آیکون آنها در نوار Taskbar و در کنار ساعت ویندوز قرار می گیرد با کلیک راست بر روی آیکون برنامه و انتخاب گزینه ی Exit یا Quit آنرا ببندید. پس از مطمئن شدن از بسته بودن نرم افزار وارد پوشه ی Keygen از فایل دانلود شده و با کلیک بر روی فایل درون پوشه اقدام به اجرای آن نمایید. بعد از اجرای فایل برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام اقدام به اجرای نرم افزار نمایید. سپس مجددآ به سراغ Keygen رفته و در صفحه ی باز شده در صورتی که کادری از لیست نرم افزارها وجود دارد، نرم افزار مورد نظر را انتخاب کنید. در کادر نام برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام را وارد کنید و در کادر ایمیل mihan@download.com را وارد کنید و سپس بر روی گزینه Generate کلیک کنید. Name و Serial و Email بدست آمده را در محل های خواسته شده درون نرم افزار وارد کنید تا نرم افزار مورد نظر به طور کامل از محدودیت خارج شود. (برخی از Keygen ها ممکن است تنها یک کادر نام و یا ایمیل داشته باشند که در اینصورت کافیست که همان یک کادر را پر کنید). (برخی از Keygen ها ممکن است کادر مربوط به وارد کردن نام در آنها خاموش باشد و نامی به صورت پیش فرض در آنها قرار گرفته باشد در اینصورت کافیست که فقط بر روی Generat کلیک کنید و از نام پیش فرض و سریال بدست آمده استفاده نمایید). (برخی از Keygen ها ممکن است تنها با نامی که نرم افزار به شما می دهد کار کنند در اینصورت در کادر وارد کردن نام و سریال نرم افزار، نامی را که در برنامه وجود دارد در کادر نام Keygen وارد کنید). برای دانلود به لینک زیر مراجعه نمایید. برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام
Mahnaz.D 61917 ارسال شده در 23 دی، 2011 دانلود v-ray 1.48.93 برای sketch up * نسخه ی تست شده...به همراه کرک برنامه. برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام آموزش نصب در تاپیک: روش نصب v-ray برای اسکچاپ ( همه ی ورژن ها) 2
SAMANEH 66 46 ارسال شده در 22 بهمن، 2011 ممنون اما من دانلود کردم و پلاگین تو اسکچاپ من فعال نیست. اسکچاپ 8 است آیا کار خاصی باید کرد؟ 1
Mahnaz.D 61917 ارسال شده در 22 بهمن، 2011 ممنون اما من دانلود کردم و پلاگین تو اسکچاپ من فعال نیست. اسکچاپ 8 است آیا کار خاصی باید کرد؟ نصب هم کردید دیگه؟؟؟ من هم اسکچاپ8 دارم....نه مشکلی نباید باشه... وقتی نصب می کنید یه تب پلاگین اون بالا اصافه می شه ...
SAMANEH 66 46 ارسال شده در 24 بهمن، 2011 آره تب باز می شه ولی کار نمی کنن.شاید من نمی دونم با پلاگین چجور باید کار کرد 1
Mahnaz.D 61917 ارسال شده در 24 بهمن، 2011 آره تب باز می شه ولی کار نمی کنن.شاید من نمی دونم با پلاگین چجور باید کار کرد می شه یه عکس بذاری از صفحه ی اسکچاپت؟ تب پلاگین میاد که نوشته وی ری....اون هست؟ در مورد نور هم هست تبش.... چون من خودم همین رو دارم و کار می کنه شاید درست نصبش نکردی....
SAMANEH 66 46 ارسال شده در 24 بهمن، 2011 تب پلاگین قبل helpمیاد و بعد از window اما مثل فیلمای آموزشی که بچه ها گذاشته بودن هیچ جدول و چیزی باز نمی کنه.آیا چیزی نصب می کنن که جدول ها و تنظیمات رو نشون بده ؟عکسو نتونستم بزارم شرمنده. ما باید متریال بریزیم توش که کار کنه ؟
Mahnaz.D 61917 ارسال شده در 24 بهمن، 2011 تب پلاگین قبل helpمیاد و بعد از window اما مثل فیلمای آموزشی که بچه ها گذاشته بودن هیچ جدول و چیزی باز نمی کنه.آیا چیزی نصب می کنن که جدول ها و تنظیمات رو نشون بده ؟عکسو نتونستم بزارم شرمنده.ما باید متریال بریزیم توش که کار کنه ؟ یه همچین چیزی داری؟ اگه نداری برو view بعد toolbar بعد v-ray for sketch up.... امیدوارم درست شه 1
SAMANEH 66 46 ارسال شده در 26 بهمن، 2011 یه شکل دیگه میاد این عکس تو مال من .مثلا سومی R میاره مال شما F هست .اسکچاپ و که بار می کنم you do not have a valid license for v- ray for sketchup میاره 3
Mahnaz.D 61917 ارسال شده در 26 بهمن، 2011 یه شکل دیگه میاد این عکس تو مال من .مثلا سومی R میاره مال شما F هست .اسکچاپ و که بار می کنم you do not have a valid license for v- ray for sketchup میاره خب اشتباه نصب کردی... پاک کن و دوباره نصب کم.... توی پست اول برو آموزش نصب...اونجا گفتم لایسنسش رو چه جوری واری کنید.... 2
zahra_zam 16 ارسال شده در 17 تیر، 2012 سلام بچه ها. تمام لینکای بالا دیگه از لود خارج شدن. کسیمیتونه بهم واسه دانلود کمک کنه؟ ضمنا من تازه کارم اینجا کوچه پس کوچه هارو نمیشناسم:5c6ipag2mnshmsf5ju3 2
Mohammad Aref 120459 ارسال شده در 17 تیر، 2012 سلام بچه ها. تمام لینکای بالا دیگه از لود خارج شدن. کسیمیتونه بهم واسه دانلود کمک کنه؟ ضمنا من تازه کارم اینجا کوچه پس کوچه هارو نمیشناسم:5c6ipag2mnshmsf5ju3 سلام. خوش اومدی. ایشالا به زودی به کوچه پس کوچه هام آشنا میشی کوچه ها و محله هاش صمیمیه پستای شماره های 13 و 15 که کار میکرد: http://www.noandishaan.com/forums/thread69439-2.html#post551935 2
zahra_zam 16 ارسال شده در 17 تیر، 2012 خب حالا میشه بی زحمت لینک آموزششم واسم بذارید:5c6ipag2mnshmsf5ju3:icon_gol: ممنون میشم مهندس 3
Mohammad Aref 120459 ارسال شده در 17 تیر، 2012 خب حالا میشه بی زحمت لینک آموزششم واسم بذارید:5c6ipag2mnshmsf5ju3:icon_gol: ممنون میشم مهندس بفرمایید: http://www.noandishaan.com/forums/thread29344.html 3
نسیبه 11 ارسال شده در 29 شهریور، 2012 سلام این سایت *****ه با ***** شکن هم که وارد میشم دانلود نمیشه لطفا راهنمایی کنید
art-89 11 ارسال شده در 27 مهر، 2012 سلام این نسخه v-ray برای مک قابل استفاده نیست.... گویا فقط تو چند ناحیه اجازه دانلود میده.... میشه یه نسخه که با اسکچ ۸ و سیستم مک سازگار باشه بذارید؟
