spow 44197 اشتراک گذاری ارسال شده در 9 مهر، ۱۳۹۰ برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام [TABLE=align: center] [TR] [TD][/TD] [TD][/TD] [/TR] [TR] [TD=class: x]Term[/TD] [TD=class: x]Abbreviation or Symbol[/TD] [/TR] [TR] [TD=class: wide]Across Flats[/TD] [TD]AF[/TD] [/TR] [TR] [TD=class: wide]Assembly [/TD] [TD]ASSY[/TD] [/TR] [TR] [TD=class: wide]Centres[/TD] [TD]CRS[/TD] [/TR] [TR] [TD=class: wide]Centre Line ..On View[/TD] [TD] [/TD] [/TR] [TR] [TD=class: wide]Centre line ..On Note[/TD] [TD]CL[/TD] [/TR] [TR] [TD=class: wide]Centre Of Gravity[/TD] [TD]CG[/TD] [/TR] [TR] [TD=class: wide]Chamfer of Chamferred..In a Note[/TD] [TD]CHAM[/TD] [/TR] [TR] [TD=class: wide]Cheese Head[/TD] [TD]CH HD[/TD] [/TR] [TR] [TD=class: wide]Countersunk/ Countersink[/TD] [TD]CSK[/TD] [/TR] [TR] [TD=class: wide]Countersunk Head[/TD] [TD]CSK HD[/TD] [/TR] [TR] [TD=class: wide]Counterbore[/TD] [TD]CBORE[/TD] [/TR] [TR] [TD=class: wide]Cylinder or Cylinderical[/TD] [TD]CYL[/TD] [/TR] [TR] [TD=class: wide]Diameter..in a note[/TD] [TD]DIA[/TD] [/TR] [TR] [TD=class: wide]Diameter..preceding a dimension[/TD] [TD] [/TD] [/TR] [TR] [TD=class: wide]Drawing[/TD] [TD]DRG[/TD] [/TR] [TR] [TD=class: wide]Equally Spaced[/TD] [TD]EQUI SP[/TD] [/TR] [TR] [TD=class: wide]External[/TD] [TD]EXT[/TD] [/TR] [TR] [TD=class: wide]Figure[/TD] [TD]FIG[/TD] [/TR] [TR] [TD=class: wide]Full Indicated Movement[/TD] [TD]FIM[/TD] [/TR] [TR] [TD=class: wide]Hexagon[/TD] [TD]HEX[/TD] [/TR] [TR] [TD=class: wide]Hexagon Head[/TD] [TD]HEX HD[/TD] [/TR] [TR] [TD=class: wide]Insulated or Insulation[/TD] [TD]INSUL[/TD] [/TR] [TR] [TD=class: wide]Internal[/TD] [TD]INT[/TD] [/TR] [TR] [TD=class: wide]Least Material Condition..In a Note[/TD] [TD]LMC[/TD] [/TR] [TR] [TD=class: wide]Least Material Condition..(Geom.Dim)[/TD] [TD][/TD] [/TR] [TR] [TD=class: wide]Left hand[/TD] [TD]LH[/TD] [/TR] [TR] [TD=class: wide]Long[/TD] [TD]LG[/TD] [/TR] [TR] [TD=class: wide]Machine[/TD] [TD]MC[/TD] [/TR] [TR] [TD=class: wide]Material[/TD] [TD]MAT[/TD] [/TR] [TR] [TD=class: wide]Maximum[/TD] [TD]MAX[/TD] [/TR] [TR] [TD=class: wide]Maximum Material Condition..In a note[/TD] [TD]MMC[/TD] [/TR] [TR] [TD=class: wide]Maximum Material Condition..(Geom. tol)[/TD] [TD] [/TD] [/TR] [TR] [TD=class: wide]Minimum[/TD] [TD]MIN[/TD] [/TR] [TR] [TD=class: wide]Not to Scale (In a note and underlined[/TD] [TD]NTS[/TD] [/TR] [TR] [TD=class: wide]Number[/TD] [TD]NO.[/TD] [/TR] [TR] [TD=class: wide]Pattern Number[/TD] [TD]PATT NO.[/TD] [/TR] [TR] [TD=class: wide]Pitch Circle Diameter[/TD] [TD]PCD[/TD] [/TR] [TR] [TD=class: wide]Radius..In a note[/TD] [TD]RAD[/TD] [/TR] [TR] [TD=class: wide]Radius..Preceding a dimension[/TD] [TD]R[/TD] [/TR] [TR] [TD=class: wide]Reference[/TD] [TD]REF[/TD] [/TR] [TR] [TD=class: wide]Required[/TD] [TD]REQD[/TD] [/TR] [TR] [TD=class: wide]Right hand[/TD] [TD]RH[/TD] [/TR] [TR] [TD=class: wide]Round Head[/TD] [TD]RD HD[/TD] [/TR] [TR] [TD=class: wide]Screw of Screwed[/TD] [TD]SCR[/TD] [/TR] [TR] [TD=class: wide]Sheet (Drawing Number) [/TD] [TD]SH[/TD] [/TR] [TR] [TD=class: wide]Sketch (prefix to Drawing Number) [/TD] [TD]SK[/TD] [/TR] [TR] [TD=class: wide]Specification[/TD] [TD]SPEC[/TD] [/TR] [TR] [TD=class: wide]Spherical Radius..Preceding dim [/TD] [TD]SR[/TD] [/TR] [TR] [TD=class: wide]Spotface[/TD] [TD]SFACE[/TD] [/TR] [TR] [TD=class: wide]Square ..In a note[/TD] [TD]SQ[/TD] [/TR] [TR] [TD=class: wide]Square ..Preceding dim[/TD] [TD][/TD] [/TR] [TR] [TD=class: wide]Standard[/TD] [TD]STD[/TD] [/TR] [TR] [TD=class: wide]Taper.. On Dia or Width[/TD] [TD][/TD] [/TR] [TR] [TD=class: wide]Thread[/TD] [TD]THD[/TD] [/TR] [TR] [TD=class: wide]Thick[/TD] [TD]THK[/TD] [/TR] [TR] [TD=class: wide]Tolerance[/TD] [TD]TOL[/TD] [/TR] [TR] [TD=class: wide]Typically OR Typical[/TD] [TD]TYP[/TD] [/TR] [TR] [TD=class: wide]Undercut[/TD] [TD]UCUT[/TD] [/TR] [TR] [TD=class: wide]Volume[/TD] [TD]VOL[/TD] [/TR] [/TABLE] برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام The second figure shows the acceptable simplified representations of holes drilled for bolts or rivets-- Side view برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام The third figure shows the acceptable simplified representations of holes with bolts or rivets-- Side view برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام The fourth view simply shows how to conveniently indicate the bolt or rivet designation.. برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام 3 لینک به دیدگاه
