مشاعره با واژه های انگلیسی معماری
Residential unit
A residential community is a
, usually a small
or
, that is composed mostly of
, as opposed to
businesses and/or industrial facilities, all three of which are considered to be the three main types of occupants of the typical community.
k
واحد مسکونی
  • پاسخ 497
Timber : الوار چوب
1. Wood prepared for use in building and carpentry.
2. Trees grown for such wood: "contracts to cut timber
reinforcement: آرماتور
1. the act of reinforcing.
2. the state of being reinforced.
3. something that reinforces or strengthens.
4. Often, reinforcements. an additional supply of personnel, ships, aircraft, etc., for a military force.
5. a system of steel bars, strands, wires, or mesh for absorbing the tensile and shearing stresses in concrete work.
پست اول رو دوباره دقیق بخونید لطفا" :flowerysmile:
tablet
لوح نوشته
A flat slab of stone, clay, or wood, used esp. for an inscription
parapet نرده,حصار
a low protective wall along the edge of a bridge,roof or balcony
ماله:Trowel
A flat-bladed hand tool for leveling, spreading, or shaping substances such as cement or mortar
A small implement with a pointed, scoop-shaped blade used for digging, as in setting plants
s
landscapE
دید و منظر
the landscape is every thing you can look across an area of land ,including hills,rivers,building,trees,and plants.
equilibrium :موازنه،تعادل
A condition in which all acting influences are canceled by others, resulting in a stable, balanced, or unchanging system.
Mental or emotional balance; poise
minimalisM
مینی مالیسم
minimalism is a style in which a small number of very simple things are used to crate a particular effect
mud: گل
1. Wet, sticky, soft earth, as on the banks of a river.
2. Slang Wet plaster, mortar, or cement.
3. Slanderous or defamatory charges or comments
DucT
داکت
A duct is a pipe,tube,or channel which carries a liquid or gas
trap door = دریچه (در شیروانی یا کف)
a door or flap flush with and covering an opening, esp in a ceiling
the opening so covered
roof gardeN
باغ بام
a roof garden is a garden on the flat roof of a building
nook : پستو
A small corner, alcove, or recess, especially one in a large room.
keystone = سنگ سر طاق
Architecture The central wedge-shaped stone of an arch that locks its parts together. Also called headstone
The central supporting element of a whole
expressionism
اکسپریونیسم
expressionism is a style of art,which uses symbols and exaggeration to represent emotions,rather than representing physical reality
Mansard roof
سقف شیروانی چهار ترک
a curb roof in which each face has two slopes, the lower one steeper than the upper.
fireplace=شومینه
A fireplace is an architectural structure to contain a fire for heating and, especially
historically, for cooking. A fire is contained in a firebox or firepit
edge
گوشه- کنار
The outside limit of an object, area, or surface
