EN-EZEL 13039 ارسال شده در 18 اردیبهشت، 2010 علائم اختصاری تکنولوژی خودرو 2V - Two (Venturi) Valve (two barrel carburetor) 2WS - Two Wheel Steer 3GR - Third Gear 4GR - Fourth Gear 4EAT - Four speed Electronic Automatic Transmission 4R70W - Four speed, Rear wheel drive, (up to) 700 lb/ft torque rated, Wide ratio 4R100 - Four speed, Rear wheel drive, (up to) 1000 lb/ft torque rated 4V - Four (Venturi) Valve (four barrel carburetor) 4WAL - Four Wheel Antilock 4WAS - Four Wheel Air Suspension 4WD - Four Wheel Drive 4WS - Four Wheel Steer 5R55W - Five speed, Rear wheel drive, (up to) 550 lb/ft torque rated, Wide ratio A - Amperes A-6 - Axial 6 cylinder A/C compressor AALA - American Automobile Labelling Act AAT - Ambient Air Temperature ABARS - Automobile Backward Automatic Ranging System ABC - Active Body Control ABS - Antilock Brake System AC - Alternating Current A/C - Air Conditioning ACC - Adaptive Cruise Control ACC - Air Conditioning Clutch ACC - Automatic Climate Control accel - Acceleration ACCS - Air Conditioning Cyclic Switch accum - Accumulator accy - Accessory ACD - Air Conditioning Demand ACE - Active Cornering Enhancement ACL - Air cleaner ACM - Airbag Control Module ACM - Audio Control Module ACR4 - Air Conditioning Refrigerant, Recovery, Recycling, Recharging ACON - Air Conditioning On ACP - Air Conditioning Pressure act - Actual ACT - Air Charge Temperature actv - Activate ACV - (thermactor) Air Control Valve A/D - Analog to Digital AD - Accomodated Device adapt - Adaptive adapts - Adapters ADAS - Advanced Driver Assistance System ADBV - Anti Drainback Valve ADC - Automatic Distance Control ADG - Accomodated Device Gateway adj - Adjust ADL - Automatic Door Lock ADS - Auxilliary Discriminating Sensor ADU - Analog-Digital Unit AECM - Airbag Electronic Control Module A/F - Air Fuel Ratio (see also AFR) AFC - Air Flow Control AFC - Air Fuel Control AFCD - Advanced Frontal Crash Dummy AFCM - Alternate Fuel Control Module AFECM - Alternate Fuel Engine Control Module AFO - Alternate Fuel Operation AFR - Air Fuel Ratio (see also A/F) aft - After AGSP - Auxilliary Gauge Switch Pack AGVS - Automated Guided Vehicle System AHLD - Automatic Headlamp Levelling Device AHR - Active Head Restraint ahrs - Amp Hours AHS - Active Handling System AIM - Automotive Interior Material AIR - Air Injection Reaction (Secondary air injection) AIRB - Secondary Air Injection Bypass AIRD - Secondary Air Injection Diverter AIS - Automatic Idle Speed ALC - Automatic Lamp Control ALC - Automatic Level Control ALCL - Assembly Line Communications Link (replaced with DLC) ALDL - Assembly Line Data Link (replaced with DLC) ALM - Adaptive Learn Matrix ALR - Automatic Locking Retractor Alt - Alternative ALT - Alternator (replaced with GEN) AM - Amplitude Modulation AMB - Ambient AMM - Air Mass Meter amp - Amplifier amps - Amperes or Amperage AMS - Automatic Music Search AMT - Automated Manual Transmission AOD - Automatic Overdrive AODE - Automatic Overdrive Electronic (transmission) AODE-W - Automatic Overdrive Electronic - Wide ratio (transmission) AOS - Automatic Occupant Sensing AP - Accelerator Pedal APP - Accelerator Pedal Position APADS - Air Conditioning Protection and Diagnostic System APECS - Advanced Proportional Engine Control System API - American Petroleum Institute APT - Adjustable part Throttle ARC - Active Roll Control ARC - Automatic Ride Control ARS - Adaptive Receptive System ARS - Automatic Restraint System ARTHUR - Automatic Radio system for Traffic situations on Highways and Urban Roads ASA - Air Signal Attenuator ASA - Automatic Slack Adjuster ASARC - Air Suspension Automatic Ride Control ASC - Anti Stall Control ASD - Automatic Shutdown ASF - Audi Space Frame ASG - Automatic-Shift Gearbox ASM - Acceleration Simulation Mode ASM - Air Solenoid Module ASM - Alarm Siren Module asm - Assembly ASR - Acceleration Slip Regulation ASSYST - Active Service System ASTC - Automatic Stability and Traction Control ASTM - American Society for Testing and Materials A/T - Automatic Transmission/Transaxle ATC - Automatic Temperature Control ATDC - After Top Dead Center ATF - Active Transfer Case ATF - Automatic Transfer Case ATF - Automatic Transmission Fluid ATM - Actuator Test Mode ATTS - Advanced Torque Transfer System ATX - Automatic Transaxle AWD - All Wheel Drive AWG - American Wire Gage AYC - Active Yaw Control AXOD - Automatic Overdrive Transaxle AXOD-E - Automatic Overdrive Transaxle - Electronically Controlled B+ - Battery positive (voltage) BARO - Barometric (pressure) BAS - Brake Apply Sensor batt - Battery BBV - Brake Booster Vacuum BCM - Body Control Module BECU - Body Electronic Control Unit BFC - Body Function Controller BHP - Brake Horsepower BLM - Block Learn Multiplier (replaced with LT FUEL TRIM) B-LVL - Bilevel BLW - Brake Lining Wear BMAP - Barometric and Manifold Absolute Pressure bn - Bank BOB - Break-Out Box BOO - Brake On/Off BP - Back Pressure BPA - Bypass Air BPCM - Battery Pack Control Module BPMV - Brake Pressure Modulator Valve BPP - Brake Pedal Position BPW - base pulse width BSFC - Brake Specific Fuel Consumption BTCM - Brake Torque Control Module BTDC - Before Top Dead Center BTSI - Brake Transmission Shift Interlock Btu - British thermal units BV - Battery Voltage C3I - Computer Controlled Coil Ignition CAB - Controller, Antilock Brake CAC - Charge Air Cooler CAFC - Company Average Fuel Consumption (Canada) CAFE - Corporate Average Fuel Economy (USA) cal - Calibration calc - Calculated Calif - California CAN - Controlled Area Network CANP - Canister Purge (solenoid) CAMM - Computer Aided Manufacturing Measurement CAMS - Computerized Automotive Maintenance System CARB - California Air Resources Board CARS - Canadian Automotive Repair and Service Council CASE - Cranking Angle Sensing Error cass - Cassette CATS - Computer Aided Test Suite CC - Climate Control CC - Cruise Control CCC - Computer Command Control CCD - Chrysler Collision Detection CCCD - Catalytic Converter Cool-Down CCD - Computer Controlled Dwell CCDIC - Climate Control Driver Information Center CCFL - Cold-Cathode Flourescent Lamp CCM - Central Control Module CCO - Converter Clutch Override CCOT - Cycling Clutch Orifice Tube CCP - Climate Control Panel CCP - Controlled Canister Purge CCRM - Constant Control Relay Module CCS - Coast Clutch Solenoid CCW - Counter ClockWise CD - Compact Disc CDA - Cylinder De-Activation CDR - Chrysler Diagnostic Readout CDRV - Crankcase Depression Regulator Valve CDX - Compact Disc Changer CE - Commutator End CEL - Check Engine Lamp (replaced with MIL) CEAB - Cold Engine Air Bleed CEMF - Counter Electromotive Force CEMS - Catalyst Efficiency Management System CEMS - Carbureted Engine Management System CFI - Central Fuel Injection (replaced with TBI) CFI - Continuous Fuel Injection CFI - Cross Fire Injection CHMSL - Center High Mounted Stop Lamp CID - Cubic Inch Displacement CID - Cylinder Identification CJC - Collision Judgement Coefficient CKP - Crankshaft Position CKT - Circuit CL - Closed Loop CLC - Converter Lockup Clutch (replaced with TCC) CLCC - Closed Loop Carburetor Control CLTBI - Closed Loop Throttle Body Injection CLYC - Closed Loop Yaw Control CLNT - Coolant CMFI - Central Multi-port Fuel Injection cmd - Command cmdd - Commanded CMP - Camshaft Position CMVSS - Canadian Motor Vehicle Safety Standards CNG - Compressed Natural Gas CO - Carbon Monoxide CO2 - Carbon Dioxide COBDIMR - Customer On Board Diagnostics Inspection/Maintenance Readiness COMBATT - Commercially Based Tactical Truck combo - Combination comm - Communication cond - Condition const - Constant COP - Coil On Plug COP - Computer Operating Properly CP - Canister Purge CPA - Connector Position Assurance CPI - Central Port Fuel Injection CPL - Control Parts List CPM - Cellular Phone Module CPP - Clutch Pedal Position CPS - Cam Profile Switching CPS - Center Panel Switches CPS - Central Power Supply CPS - Childseat Postioning Sensor CPU - Central Processing Unit CRR - Cool Running Rotor CRT - Cathode Ray Tube CRTS - Continuously Regenerating Trap System CS - Charging System CSE GND - PCM Case Ground CSI - Compression Sense Ignition CSM - Central Security Module cSt - Centistokes CSTO - Compression Sense Time-Out CTD - Content Theft Deterent CTM - Central Timer Module CTOX - Continuous Trap Oxidizer CTP - Closed Throttle Position (switch) CTS - Coolant Temperature Sensor CV - Constant Velocity CVRSS - Continuously Variable Road Sensing Suspenion CVRTD - Continuously Variable Real Time Damping CVS - Canister Vent Solenoid CVT - Continuously Variable Transmission, Transaxle CWS - Continental Wheel System CZS -
ارسالهای توصیه شده
