معرفی ساب وور کنوود kfc-w3012
blank.gifKFC-W3012
Performance Series 12" Subwoofer
Super-sturdy, super powerful, the KFC-W3012 is a 12-inch sub that handles an impressive 1200W of power. A truly high-performance sub, the KFC-W3012 has a long stroke design and a silver textured pattern cone woofer that adds strength and rigidity to the cone for maximum bass performance.
General Features•MAX POWER 1200W•12" Woofer with 4-ohm voice coil•Urethane Surround•Dragon Spider Design•2-Layer Voice Coil Design•Dual Magnet Drive•8AWG Wire Capable Push Terminals•Frequency Response: 39-300 Hz•Sensitivity: 86 dB•Mounting depth: 6-3/16"
SPECIFICATIONS:•Peak Input Power: 1200W•Rated Input Power: 400W•Impedance: 4 Ohms•Sensitivity: 86dB•Free-Air Resonance: 32Hz •Frequency Response: 39Hz – 300Hz
Recommended Sealed Enclosure•Volume: 1.25 cu.ft•Width: 14-3/4”•Height: 14-9/16”•Depth: 14” •Mounting Hole: 11-1/8”•Displacement: 0.157 cu.ft
Recommended Vented Enclosure•Volume: 1.5cu.ft•Width: 19-15/16”•Height: 14-3/16”•Depth: 12-5/8” •Mounting Hole: 11-1/8” •Slot Width: 1-3/8”•Slot Height: 12-11/16”•Slot Length: 18-7/8” •Displacement: 0.157 cu.ftblank.gif*Product descriptions, specifications and features are subject to change without notice. Some features may require the purchase of additional accessories. For proper fit, compatibility, and accessory information check with your
