تاپیک مرجع مقالات لاتین
A Contribution to the VCO modeling and simulation
Voltage-Controlled Oscillators (VCOs) are at the
heart of many electronic systems such as phase-locked
loops (PLL), radar, and communication systems. The
overall performance of these systems is often limited by the
VCO’s parameters and performance. Optimizing system
performance requires a complete understanding of the
VCO’s characteristics. Most applications require that the
VCO operate at one frequency, and then be quickly
switched to another frequency where it will stay for some
time. The key VCO parameters here are frequency
overshoot, settling time, and post-tuning drift. Depending
on how often a VCO is switched, these parameters will
change. In this paper we describe a model of VCO intended
to be used in system modeling in the PSPICE environment.
Model is especially designed for study of the VCO’s step
response
Download
A Low-Power, Small Area Quadrature LC-VCO using miniature 3D Solenoid shaped Ind.
A low-power, small area quadrature 5GHz
LC-VCO includes 20GHz oscillator and 1/4 divider has been
fabricated using a miniature 3D solenoid shaped inductor in
90nm CMOS. Owing to a small area and a small magnetic
energy of the 3D inductor, a chip area of 2597μm2 which is
1/10 of the reported smallest LC-VCOs and 2.8mW power
consumption including the divider have been achieved
without degrading a figure of merit (FOM). The phase noise
was -103dBc/Hz (@1MHz offset) and the phase error was
with the chip area as small as that of ring oscillators. This
small area LC-VCO is suitable for low-power, low-cost
wireless transceivers and high speed communication systems
Download
Modeling, Design and Characterization of a New Low-Jitter Analog Dual Tuning LC
This paper describes the modeling, design, and characterization
of a low-jitter 2.4-GHz LC-VCO PLL architecture
realized in a standard 0.12- m CMOS technology. It features
an analog dual control loop for fine and coarse VCO tuning that
allows very low VCO gain (60 MHz/V) for noise rejection while
maintaining a wide tuning range. The coarse input of the VCO
is driven by an analog circuit that adjusts the VCO gain in a
continuous manner. Measurements demonstrate an integrated
jitter of 0.74 ps that is 43% lower compared to results from a
standard PLL topology (STD PLL) with a single control loop.
The PLLs have the same bandwidth and output frequency range
and were built on the same wafer for comparison. The circuit
area of the proposed LC-VCO PLL is 0.7 mm2 and the power
consumption is 32 mW. The area and power consumption of the
proposed LC-VCO PLL are less than 1% larger compared to the
STD PLL
Download
Algorithm of Digital Image Watermarking Technique Combined with HVS
HVS theory plays important role in the application of digital image watermarking technique. When inserting watermarking, the visual masking feature of HVS could be fully used to design digital watermarking algorithm with good perceived performance. When extracting watermarking from the damaged image, human's visual feature could be combined to recover the damaged image so as to obtain better effect. This article combines with human visual feature to study digital watermarking technique, utilizes watermarking redundant technique to insert watermarking, extracts watermarking in line with the damage situation of watermarking, and combines with visual redundancy feature to achieve a image scrambling algorithm that is easy to recover and a recovery scheme for damaged scrambling image
Download
Modal Expansion Analysis of Discrete Source Scattering by a Spherically Stratifi
In this paper, an eigenfunction expansion into the standard vecfor spherical wave funcfions is
used to compute the scattering of electromagnetic radiation by a spherically stratified object.
Unlike in most other work on electromagnetic scattering, our incident field is that of an infinitesimal
current elemenf (a point source) and not a plane wave. Its expansion coefficients
are obtained by “matching the far-field”. The coefficients for the scattered fields are then
determined from the boundary conditions at each interface, at the origin and at infinity.
This analysis is employed to determine the radiation properties of a dielectric lens at microwave
frequencies. Each shell is assumed to be homogeneous and isotropic with a given
complex permittivity, permeability and conductivity. The work is extended to include the
scattering of other sources such as horns and microstrip patches which are then used in conjunction
with the lens to form a multiple beam antenna. The calculated quantities are the
antenna gain along with its near- and far-field radiation patterns. These results are compared
to measurements on a 30 cm multiple beam system
Download
FAR-FIELD ANTENNA PATTERNS DETERMINED FROM INFRARED HOLOGRAMS
In this paper, we describe a technique based on optical holography which allows
determination of the amplitude and phase of an unknown antenna on a near-field plane from
amplitude-only measurements. We measure the interference pattern between the fields
radiated by the antenna under test (AUT) and a known reference field. The reference field
is produced by a standard gain horn radiating at an angle to the AUT and positioned so that
the peak of the radiation occurs approximately at the same place as the peak from the AUT.
The fields are detected by a resistive screen which absorbs some of the incident energy and
heats as a function of the electric field intensity distribution. We use an infrared camera to
record the temperature distribution caused by the interference of microwave energy radiated
by the reference and the AUT. Data are processed using an enhanced algorithm based on
conventional holography for recovery of the complex near field . The new algorithm
allows elimination of the spurious images commonly present in optical hologram readouts
using illumination of the hologram with the reference wave
