peyman sadeghian 30244 ارسال شده در 7 تیر، 2011 6" x 9" 4-Way Speaker 550 Watts Max Power Carbon Graphite IMPP Cone with Interlaced Aramid Fiber Provides Strength and Rigidity for Full-Bodied, Rich Sound Soft Dome Midrange with Wave Guide for Increased Sensitivity Price: $159.00 برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام Pioneer's Sound Concept The "Open & Smooth" sound concept of our industry-leading speakers delivers both sonic excellence and performance. The open-staging and smooth transition of driver response makes for an immersive experience that is truly the ultimate in-car sound. What is "Open & Smooth"? Open: Open staging and sound characteristics enhance the widening effect that extends way beyond the space between speakers. Smooth: With smooth transitions between mid-bass and tweeter, sound from these speakers is not marred by crossover frequency dips. Pioneering An Ideal Absolute fidelity to musical sources takes form from speakers that reproduce the ambience in which sounds originate. Stage size, musicians’ movement, aural reflection and other distinctive details all bring these sounds to life. Carbon Graphite IMPP Interlaced Aramid Fiber Cone This IMPP cone is designed with long aramid fibers to provide strength and durability that powerful bass sound requires. The revolutionary durable, yet lightweight IMPP cones significantly reduce mid-to-low range distortion and reproduce sound staging to a natural effect. The high-density compressed internal architecture is resilient, handles high power well, and transfers sound quickly. The result is a fullbodied, rich sound character with midrange depth that conventional IMPP cones cannot match. Soft-Dome Diaphragm Midrange For a smooth off-axis response, the speakers include a soft dome midrange driver utilizing a wave guide enclosure. The design enables mid and high frequencies to be projected in a uniform and wide dispersion pattern, resulting in a smooth on- and off-axis response. Low Crossover Frequency Pioneer extends tweeter performance to much lower frequencies, creating a wider response with fuller midrange fidelity and clear, accurate vocals. Other features: New Grille Design Sound absorbing material Light Weight Elastic Polymer Surround for high sensitivity
peyman sadeghian 30244 مالک ارسال شده در 7 تیر، 2011 5¼" Component Speaker Package with 180 Watts Max. Power 35 Watts Nominal Power "Open and Smooth" Sound Design Deep Basket for Full Bass برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام Composite IMPP Cone with Interlaced Aramid Fiber With long aramid fibers interlacing together inside, this IMPP cone design provides the strength and rigidity that powerful bass sound requires. High-density compressed internal architecture is resilient, stacks up against high power well and transfers sound quickly. The result is full-bodied, rich sound character with midrange depth that conventional IMPP cones cannot match. Fits 6"x8" Applications! The included 6"x8" adapter allows this component set to also be used in many Ford and Mazda vehicles that feature a 6"x8" speaker application size.
peyman sadeghian 30244 مالک ارسال شده در 7 تیر، 2011 6-1/2" Component Speaker Package (6-3/4" Compatible) 350 Watts Max Power Carbon Graphite IMPP Cone with Interlaced Aramid Fiber Provides Strength and Rigidity for Full-Bodied, Rich Sound Soft Dome Tweeter with Wave Guide for Increased Sensitivity Price: $144.00 برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام Pioneer's Sound Concept The "Open & Smooth" sound concept of our industry-leading speakers delivers both sonic excellence and performance. The open-staging and smooth transition of driver response makes for an immersive experience that is truly the ultimate in-car sound. What is "Open & Smooth"? Open: Open staging and sound characteristics enhance the widening effect that extends way beyond the space between speakers. Smooth: With smooth transitions between mid-bass and tweeter, sound from these speakers is not marred by crossover frequency dips. Pioneering An Ideal Absolute fidelity to musical sources takes form from speakers that reproduce the ambience in which sounds originate. Stage size, musicians’ movement, aural reflection and other distinctive details all bring these sounds to life. Carbon Graphite IMPP Interlaced Aramid Fiber Cone This IMPP cone is designed with long aramid fibers to provide strength and durability that powerful bass sound requires. The revolutionary durable, yet lightweight IMPP cones significantly reduce mid-to-low range distortion and reproduce sound staging to a natural effect. The high-density compressed internal architecture is resilient, handles high power well, and transfers sound quickly. The result is a fullbodied, rich sound character with midrange depth that conventional IMPP cones cannot match. Soft-Dome Diaphragm Midrange For a smooth off-axis response, the speakers include a soft dome midrange driver utilizing a wave guide enclosure. The design enables mid and high frequencies to be projected in a uniform and wide dispersion pattern, resulting in a smooth on- and off-axis response. Low Crossover Frequency Pioneer extends tweeter performance to much lower frequencies, creating a wider response with fuller midrange fidelity and clear, accurate vocals. Other features: New Grille Design Sound absorbing material Light Weight Elastic Polymer Surround for high sensitivity 14% larger woofer cone - the new TS-A1604C and TS-A1684R have larger cones than conventional speakers, yet they fit into the exact same cut-out dimensions. The result is deeper low-range sound reproduction.
peyman sadeghian 30244 مالک ارسال شده در 7 تیر، 2011 5-1/4" Component Speaker Package 300 Watts Max Power Carbon Graphite IMPP Cone with Interlaced Aramid Fiber Provides Strength and Rigidity for Full-Bodied, Rich Sound Soft Dome Tweeter with Wave Guide for Increased Sensitivity Price: $134.00 برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام Pioneer's Sound Concept The "Open & Smooth" sound concept of our industry-leading speakers delivers both sonic excellence and performance. The open-staging and smooth transition of driver response makes for an immersive experience that is truly the ultimate in-car sound. What is "Open & Smooth"? Open: Open staging and sound characteristics enhance the widening effect that extends way beyond the space between speakers. Smooth: With smooth transitions between mid-bass and tweeter, sound from these speakers is not marred by crossover frequency dips. Pioneering An Ideal Absolute fidelity to musical sources takes form from speakers that reproduce the ambience in which sounds originate. Stage size, musicians’ movement, aural reflection and other distinctive details all bring these sounds to life. Carbon Graphite IMPP Interlaced Aramid Fiber Cone This IMPP cone is designed with long aramid fibers to provide strength and durability that powerful bass sound requires. The revolutionary durable, yet lightweight IMPP cones significantly reduce mid-to-low range distortion and reproduce sound staging to a natural effect. The high-density compressed internal architecture is resilient, handles high power well, and transfers sound quickly. The result is a fullbodied, rich sound character with midrange depth that conventional IMPP cones cannot match. Soft-Dome Diaphragm Midrange For a smooth off-axis response, the speakers include a soft dome midrange driver utilizing a wave guide enclosure. The design enables mid and high frequencies to be projected in a uniform and wide dispersion pattern, resulting in a smooth on- and off-axis response. Low Crossover Frequency Pioneer extends tweeter performance to much lower frequencies, creating a wider response with fuller midrange fidelity and clear, accurate vocals. Other features: New Grille Design Sound absorbing material Light Weight Elastic Polymer Surround for high sensitivity
peyman sadeghian 30244 مالک ارسال شده در 7 تیر، 2011 6-1/2" 4-Way Speaker (6-3/4" compatible) 350 Watts Max Power Carbon Graphite IMPP Cone with Interlaced Aramid Fiber Provides Strength and Rigidity for Full-Bodied, Rich Sound Soft Dome Midrange with Wave Guide for Increased Sensitivity Price: $119.00 Pioneer's Sound Concept The "Open & Smooth" sound concept of our industry-leading speakers delivers both sonic excellence and performance. The open-staging and smooth transition of driver response makes for an immersive experience that is truly the ultimate in-car sound. What is "Open & Smooth"? Open: Open staging and sound characteristics enhance the widening effect that extends way beyond the space between speakers. Smooth: With smooth transitions between mid-bass and tweeter, sound from these speakers is not marred by crossover frequency dips. Pioneering An Ideal Absolute fidelity to musical sources takes form from speakers that reproduce the ambience in which sounds originate. Stage size, musicians’ movement, aural reflection and other distinctive details all bring these sounds to life. Carbon Graphite IMPP Interlaced Aramid Fiber Cone This IMPP cone is designed with long aramid fibers to provide strength and durability that powerful bass sound requires. The revolutionary durable, yet lightweight IMPP cones significantly reduce mid-to-low range distortion and reproduce sound staging to a natural effect. The high-density compressed internal architecture is resilient, handles high power well, and transfers sound quickly. The result is a fullbodied, rich sound character with midrange depth that conventional IMPP cones cannot match. Soft-Dome Diaphragm Midrange For a smooth off-axis response, the speakers include a soft dome midrange driver utilizing a wave guide enclosure. The design enables mid and high frequencies to be projected in a uniform and wide dispersion pattern, resulting in a smooth on- and off-axis response. Low Crossover Frequency Pioneer extends tweeter performance to much lower frequencies, creating a wider response with fuller midrange fidelity and clear, accurate vocals. Other features: New Grille Design Sound absorbing material Light Weight Elastic Polymer Surround for high sensitivity 14% larger woofer cone - the new TS-A1604C and TS-A1684R have larger cones than conventional speakers, yet they fit into the exact same cut-out dimensions. The result is deeper low-range sound reproduction. برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام
