نرم افزار : SAP2000 V 14.2.4
Version: 14.2.4
Supported Operating Systems: Windows XP & Vista
MODELING (A, P, B)
• Object Based Graphical Interface
• Model Templates with Auto Meshing
• Frame, Cable and Tendon Members
• Area (Shell) and Solid Objects with Internal Meshing
• Integrated Graphical Section Designer for Complex Frame Shapes
• Bridge Wizard for Bridge Modeling (A, P, BR)
• Editing with Move, Merge, Mirror and Replicate
• Accurate Dimensioning with Guidelines and Snapping
• Auto Edge Constraints for Mismatched Shell Meshes
• Quick Draw Options for Object Creation
• Tendons in Frame, Shell and Solid Objects
• Parametric Bridge Cross Sections (A, P, BR)
• Support for Multiple Coordinate Systems
• Powerful Grouping and Selection Options
• Definition of Highway Layout Lines (A, P, BR)
• Automatic Generation of Code Lateral Wind and Seismic Loads
• Wind Loads on Open Structures
• Transfer of Loads from Area Objects to Framing Systems
• Application of Lane Loads to Bridge (A, P, BR)
• Cracked Properties – Property Modification Factors
• Gravity, Pressure and Thermal Loading
• Line and Surface Multi-Linear Springs (A)
• Staged Construction Analysis (A, SC)
• Wave Generator (A, OS)
• Parametric Tendon Layout for Box Girders (A, P, BR)
SAP2000 ANALYSIS
• Static Analysis with Frame and Shell Objects (A, P, B)
• Response Spectrum Analysis with Eigen or Ritz Vectors (A, P, B)
• P-Delta Analysis (A, P, B)
• Joint Constraints including Rigid Bodies & Diaphragms (A, P, B)
• Applied Force and Displacement Loading (A, P, B)
• Gravity, Pressure and Thermal Loading (A, P, B)
• Layered Shell Element (A, P, B)
• Post Tensioning in Frame, Area and Solid Objects (A, P, B)
• Relaxation & Anchorage Slip Losses in Tendons (A, SC)
• Plane, Asolid and Solid Objects (A, P)
• Time History Analysis, including Multiple Base Excitation (A, P)
• Frequency Domain Analysis – Power Spectral Density (A, P)
• Moving Loads (A, P, BR)
• Time Dependent Concrete Creep & Shrinkage Effects (A, SC)
• Frame Hinges for Axial, Flexural, Shear & Torsional Behavior (A)
• Nonlinear Static Pushover Analysis (A)
• Viscous Dampers (A)
• Fiber Hinges (A)
• Base Isolators (A)
• Gap Object for Structural Pounding (A)
• Time History with Wilson FNA or Direct Integration Methods (A)
• Dynamic Effects of Moving Loads (A, P, BR)
• Segmental Construction Analysis (A, SC)
• API Simplified Fatigue Analysis (A, OS)
BUCKLING
• Buckling Analysis Around Any Nonlinear State (A)
• Element-Based P-Delta Effects for Local Buckling Instabilities (A)
LARGE DISPLACEMENTS
• Large Displacement/Small Strain Analysis (A)
• Nonlinear Large Rotations Cable Analysis (A)
FREQUENCY DOMAIN
• Steady State Analysis (A, P)
• Power Spectral Density (PSD) Analysis (A, P)
• Frequency Dependent Properties for Links/Supports (A, P)
NONLINEAR MATERIAL BEHAVIOR
• Pushover Analysis Using Fiber Models (A)
• Viscous Damper with Nonlinear Exponent on Velocity Term (A)
• Base Isolator with Biaxial Plasticity Behavior (A)
• Hinges offer P-M-M Interaction Eng-Syria.NET with Moment-Curvature (A)
• Section Designer – Mander Model for Confined Concrete (A)
• Pivot-Hysteresis and Takeda Models for Plastic Link Behavior (A)
• Double-Acting Friction Pendulum Isolators (A)
Significant enhancements included in SAP2000 v14.2.4
• Concrete frame design has been enhanced to improve the smoothing of P-M-M interaction
surfaces in those rare cases where they become non-convex due to kinks in the P-M curves.
• A new design overwrite has been added for steel frame design using the "Eurocode 3-2005"
code. You may now use the "Is Rolled Section" parameter to indicate whether the member
is rolled or welded. The assignment as rolled or welded affects the b/t ratio and therefore
may affect the section classification. It may also affect the shear-area calculation.
• The limit on the number of nodes (joints) allowed for exporting a model to a SASSI file has
been increased from 9999 to 99999. The exported files are still compatible with the older format
if fewer than 10000 nodes are exported
  • 3 ماه بعد...
Sap2000 v 15
SAP2000 - 01 Introductory Tutorial 30 min
SAP2000 - 02 Select Commands 6 min
SAP2000 - 03 Draw Commands 9 min
SAP2000 - 04 Mass and Modal Analysis 5 min
SAP2000 - 05 P-Delta Analysis 10 min
SAP2000 - 06 Nonprismatic Sections 6 min
SAP2000 - 07 Interactive Database Editing 7 min
SAP2000 - 08 Area Edge Constraints 3 min
SAP2000 - 09 Tension-only Bracing 4 min
SAP2000 - 10 Response Spectrum Analysis 5 min
SAP2000 - 11 Modal Time History Analysis 14 min
SAP2000 - 12 Section Designer 12 min
SAP2000 - 13 Cardinal Points 9 min
SAP2000 - 14 Formatting Display Tables 8 min
SAP2000 - 15 Creating Reports 11 min
SAP2000 - 16 Cable Objects 18 min
SAP2000 - 17 Tendons 10 min
SAP2000 - 18 Gap Elements 17 min
SAP2000 - 19 Nonlinear Staged Construction Analysis 6 min
SAP2000 - 20 Nonlinear Shear Walls 30 min
SAP2000 - 21 Static Pushover Analysis 10 min
SAP2000 - 22 Power Spectral Density 13 min
SAP2000 - 23 Wave Loading 5 min
SAP2000 - 24 Model Alive 4 min
SAP2000 - 25 Open Application Programming Interface 13 min
منبع:[RTL][/RTL] csiberkeley.com
AM 00 : 1
Hour
Minutes
AM PM
1 2 3 4 5 6 7 8 9 10 11 12
