پلی فنیلن اکساید
Poly(phenylene oxide), or PPO, is one of those high-performance polymers we like to call
engineering thermoplastics
. Its biggest strength is its resistance to high temperatures. It has a very high
, 210 oC. But there"s a price for being heat-resistant. Most polymers are processed at high temperature in a liquid-like state. But if your polymer won"t become liquid-like at reasonable temperatures, you can"t process it! For this reason, PPO is often made into
with high-impact
(HIPS for short). Blending PPO with HIPS makes the PPO easier to process, plus it gives PPO some resilience. PPO needs this toughening because by itself PPO can be brittle in some situations. General Electric makes PPO/HIPS blends and sells them under the name NorylTM.
Structurally, PPO is made of phenylene rings linked together by ether linkages in the 1,4 or
para-
positions, with a methyl group attached to carbon atoms in the 2 and 6 positions.
This polymer should really be called poly(2,6-dimethylphenylene oxide), but we call it poly(phenylene oxide) because we"re lazy.
PPO is made by what we call
oxidative coupling polymerization
of the monomer 2,6-dimethylphenol. Water is a by-product, and so this is a
