surge arrester
سلام به بچه هاي قدرتي گل:icon_gol:
مختصر و مفيد مي پرسم.........درباره surge arrester كسي اطلاعات مفيد داره؟
خواهشا" pdf نزارين.
تنكيو.سپاس:icon_gol:
اقدامات حفاظتی درصنعت برق
داش محسن جوابت اینجاس فک کنم
امين جون دستت درد نكنه :icon_gol:ولي اوني كه من ميخواستم نبود.
تو صفحات آخرو دیدی؟؟؟؟
الان در مورد برقگیر میخوای دیگه؟؟؟؟:w127:
آره.خدا بگم چيكارت كنه چشام كور شد.همون اول ميگفتي صفحه آخرو بخون...
اين هم يه نوع برق گيره.اما يه جورايي با بقيه فرق داره.تو اكثر وسايل الكتريكي جديد كه ميزنن اونو هم ميزارن.يه مداره.سرعت بالايي داره و تا يك چهارم پالس جريان مزاحم رو تشخيص ميده و مدار رو از برق اضافي (خصوصا" صاعقه) محافظت ميكنه........
:ws3:
خب باشه
میگردم میابم باست
Surge Arresters
Cooper Power Systems offers the largest, most economical selection for low voltage, distribution, riser pole, intermediate, and station surge arresters for overhead and underground applications in the industry.
Evolution Surge Arrester
Engineered to survive the elements and protect system assets, the UltraSIL polymer-housed Evolution distribution class surge arrester from Cooper Power Systems is designed and engineered to provide utilities with proven reliability and field-tested construction.
Upgrade the efficiency of the power grid and reduce environmental impact…one transformer, riser, and mid-line arrester at a time.
Non-Gapped Design
The VariSTAR® (gap-less MOV) design is available for overhead distribution system protection in both porcelain or silicone rubber housings. For underground distribution application needs, Cooper Power Systems offers standard gap-less MOV elbow and parking stand arresters.
CPS has a large line of low voltage arresters for a wide range of application needs from transformer secondary to home or business service entrances to inside the home. Other low voltage products protect lighting, motors, irrigation wells, traffic lights, railroad crossing gates, and any other number of low voltage applications.
CPS also offers a full line of Intermediate and Station Class arresters in either silicone rubber or porcelain housings.
Elbow Arrester
Cooper Power Systems proven POSI-BREAK design has expanded from protection of loadbreak separable connector systems to the arrester market. Cooper Power Systems has designed an elbow arrester, the POSI-BREAK elbow arrester, which increases reliability while protecting your operators. POSI-BREAK elbow arresters address the partial vacuum flashover that occurs when an elbow or cap is separated from an energized bushing. Our POSI-BREAK elbow arrester offers improved dielectric strength and minimizes susceptibility to partial vacuum flashovers while increased tolerance to contamination and high altitude increases its reliability.
Surge arrestor
Surge protector
A Surge Arrestor is installed between communication equipment and coaxial cable connector or between two communication equipments to protect communication equipment from damage caused by transient state voltage formed by lightning induction. It adopts quarter-wave technology, is designed according to VSW theory and frequency spectrum of lightning wave. It has features of quick reaction, big current passing capacity, wide frequency band, low VSWR, low insertion loss, easy installation and free maintenance. It can be used to meet protection requirements of various communication equipments and lightning sensitivity.
Use
An electrical appliance used to protect electronic equipment against lightning overvoltage transients. It is usually connected to wires (power phase line, signal line, zero line) and ground between being protective devices in parallel, when the lightning over-voltage the value of the required actions voltage, arrestor immediate to limit over-voltage amplitude lead to protection equipment and systems, enabling the system to work properly.
Surge arrestor series
Low-voltage surge arrestor Apply in Low-voltage distribution system, exchange of electrical appliances protector, low-voltage distribution transformer windings
Distribution arrestor Apply in 3KV, 6KV, 10KV AC power distribution system to protect distribution transformers, cables and power station equipment
The station type of common valve arrestor Used to protect the 3 ~ 220KV transformer station equipment and communication system
Magnetic blow valve station arrestor Use to 35 ~ 500KV protect communication systems, transformers and other equipment
Protection of rotating machine using magnetic blow valve arrester Used to protect the AC generator and motor insulation
Line Magnetic blow valve arrester Used to protect 330KV and above communication system circuit equipment insulation
DC or blowing valve-type arrester Use to protect the DC system’s insulation of electrical equipment
Neutral protection arrester Apply in motor or the transformer’s neutral protection
Fiber-tube arrester Apply in the power station’s wires and the weaknesses protection in the insulated
Plug-in Signal Arrester Used to twisted-pair transmission line in order to protect communications and computer systems
High-frequency feeder arrester Used to protect the microwave, mobile base stations satellite receiver, etc.
Receptacle -type surge arrester Use to Protect the terminal Electronic equipment
Signal Arrester Apply in MODEM, DDN line, fax, phone, process control signal circuit etc.
Network arrester Apply in servers, workstations, interfaces etc.
Coaxial cable lightning arrester Used to the coaxial cable in order to protect the wireless transmission and receiving system
arrow1.jpg برقگيرهاي سيليكونيSURGE ARRESTERS اين برقگير براي استفاده در مناطق آلوده و شبکه هايي که ميزان رعد و برق بالايي دارند مناسب است. اين نوع برقگيرها محدوده ولتاژ 5kV تا 36kV را پوشش داده و قابليت تحمل انرژي تعيين شده طبق استانداردهاي IEC 60815 - IEC 60099-4 براي برقگيرهاي شبکه توزيع را به خوبي دارا مي باشند. توليد آن ها بر اساس استانداردهاي مذکور بوده و داراي گواهي تاييد از شرکت CESI ايتاليا مي باشند.
ساختمان برقگير
ساختمان اصلي اين برقگيرها از قرص هاي اکسيد روي مخلوط با چند اکسيد فلزي ديگر تشکيل شده است. اين قرص ها با درجه خلوص بالا، دانه بندي کاملا کنترل شده و به طور تمام اتوماتيک توليد مي شوند که سبب کيفيت عالي، قابليت اجرا و عملکرد مطمئن اين قطعات مي گردد. بر روي اين قرص ها پوششي از رزين داراي الياف شيشه و مقاوم به حرارت کشيده شده است که سبب پوشش کامل با فشار يکنواخت، استقامت مکانيکي و خواص الکتريکي مناسب آنها مي شود و در نهايت پليمر سيليکون براي پوشش خارجي برقگير بکار رفته است. محاسن برقگيرهاي داراي پوشش سيليکوني
arrow1.jpg برقگير تهيه شده از سيليکون نياز به تعميرات و نگهداري ندارد. چون سطح صاف سيليکون از چسبيدن هر گونه ماده اي جلوگيري مي کند. در محيط هاي بسيار آلوده اگر آلودگي روي آن رسوب کند در اثر بارش باران يا وزش باد خودبخود پاک مي شود.
arrow1.jpg مقاومت بالا در مقابل عوامل محيطي مانند رطوبت|،حرارت،آلاينده ها،گاز ازن و اشعه UV
arrow1.jpg وزن سبک و نشکن بودن آن وسهولت در نصب و نگهداري
arrow1.jpg قابليت اطمينان بالا در شرايط سخت و پايداري الکتريکي و مکانيکي در عمل و قابليت عبور انرژي هاي بالا.
arrow1.jpg ابعاد کوچک که اجازه نصب در هر موقعيتي (افقي، عمودي، يا مايل) را مي دهد.
arrow1.jpg هيدرو فوب (آب گريز) بودن، که اين خاصيت سبب مي شود قطرات آب بر روي سيليکون لايه اي پيوسته تشکيل نداده و از ايجاد جريان خزشي جلوگيري به عمل آيد.
arrow1.jpg اگر در اثر جرقه آسيبي به روکش سيليکون وارد آيد، لايه تخريب شده خود به خود ترميم مي شود.
کليه مشخصات مربوط به اين برقگير بر روي در پوش بالاي برقگير حک شده است. قطعات موجود در برقگير ها در صورت نياز:
arrow1.jpg پايه براکت عايق براي نصب برقگير
arrow1.jpg ديسکانکتور اتوماتيک که با براکت عايق بطور افقي نصب مي شود.
اين ديسکانکتور در اثر اصابت صاعقه جدا شده و از اتصال کوتاه شدن مدار جلوگيري مي کند. در اين حالت نياز به بازرسي هاي دوره اي است تا ديسکانکتورجدا شده برقگير،مجددا وصل و در صورت خراب شدن برقگير، براکت و ديسکانکتور جديد نصب گردد.
