فرمول زمان ها
christian
Simple present
Subject + verb
Do ‘does + subject + verb
Subject + don’t / doesn’t + verb
It- she-he + verb.es.s
We never use (es.s) with does in question
Present progressive
Subject + am. is / are + verb.ing
We change am is are place with the place of the subject
Subject + am is are + not + verb
Present perfect
Subject + have / has + past participle
Have has + subject + past participle
Subject + have not_ has not + past participle
Present perfect progressive
Subject + have / has + been + verb.ing
Have + subject + been + verb.ing
Subject + have not / has not + been + verb.ing
Simple past
Subject + past verb + object
Did + subject + verb
Subject + did not + verb
Past progressive
Subject + was / were + verb.ing + when + simple past
When + simple past , subject + was were + verb.ing
As + subject + was / were +verb.ing + simple past
While + subject + was / were , verb.ing + simple past
Simple past + while + subject +was were + verb.ing
Was were + subject + verb.ing
Subject + was not_ were not + verb.ing
Past perfect
Subject + had + past participle + before + simple past
Before + simple past , subject + had + past participle
After + subject + had + past participle , simple past
Simple past + after + subject +had + past participle
Had + subject + past participle
Had not + subject +past participle
Past perfect progressive
Subject + had + been + verb.ing + before + simple past
Simple future
Subject + will + verb
Will + subject+ verb
Subject + won’t + verb
Subject + to be + going to + verb
To be + subject + going to + verb
Some times we use simple present , present progressive in state of simple future
Future progressive
Subject + will + be + verb. ing
Future perfect
Subject + will + have + past participle
Future perfect progressive
Subject + will + have + been + verb .ing
Gerund
Verb . ing used as noun
Use gerund as subject
Speaking English for a long time has made tired
Use gerund as object of verb
Enjoy _ dislike_ miss _ mind_ avoid_ deny_ finish………
Use gerund as object of preposition
Of_ with _ with out _ in _ on_to_by………..
Using the second verb after the first verb
  • Let _ make _ bid….. + verb
  • Enjoy _ dislike …. + verb.ing
  • Remember _ stop ……. + (verb.ing) or (to. Verb)
  • every verb other than 1_2_3_ parts + to. verb
The passive
  • Subject + verb + object = object + am / is / are + past participle
  • Subject + past verb + object = object + was were + past participle
  • Subject + am is are + verb.ing + object = object + am is are + being + past participle
  • Subject + was / were + verb.ing + object = object + was / were + being + p.p
  • Subject + have / has + past participle + object = object + have / has + been + p.p
  • Subject + had + p.p+ object = object + had + been + past participle
  • subject + ( can / could_ shall / should _ will / would _ may / might _ must / had to/ has to / have to_ to be going to ) + verb +object = object + (“””””””””””””””””””””””) + be +past participle
  • Subject + will + have + p.p +object = object + will + have + been + p.p
First / second / third / new condition
  • If + simple present , will + verb ( future _ real _ possible )
  • If + simple past , would + verb ( present _ unreal )
  • If + past perfect , would have + past participle ( past _ unreal )
  • If + subject + should + verb , imperative
Example : If you should see her , just tell that I waiting for he .
Note : 1. we can use unless in state of if not .
2. We should use were in state of was in 2nd condition
