EN-EZEL 13039 اشتراک گذاری ارسال شده در 16 شهریور، ۱۳۸۸ Solidworks Video Tutorial Volume 1 To Volume 3 | 1.6 GB This video tutorial covers SolidWorks 2007, and is also applicable to some earlier versions. With its comprehensive, step-by-step approach, this hands-on tutorial will help you master the techniques you need to quickly become productive in SolidWorks. Created by SolidWorks experts, the video tutorials contain real-world insight and will enable you to draw, design, edit, view and plot in SolidWorks. You will find all of the essential material necessary to successfully create any 2-dimensional (2D) as well as 3-dimensional solid models applicable to any design, architecture, or service industry. VIDEO COURSE CONTENT 01 Basic 02 Interface 43 Overview 03 Tangent Arc 44 Optimizing The Part 04 More on Extrusion eDrawings 05 Sample Hole 45 Overview 06 Complex Extruded Cut 46 Interface 07 Hole Wizard 47 Measure Tool 08 Shell 48 Manipulate Components 09 Section View 49 Section Tool 10 Constant Radius Fillet 50 Mass/Texture 11 Variable Radius Fillet 51 Markup Tool 12 Face Fillet 52 STL Files 13 Full Round Fillet Sheet Metal 14 FilletXpert 53 Bend Allowance 15 Chamfer 54 Applying K-Factor 16 Revolved Feature 55 Bend Allowance/Deduction 17 Revolved Cut 56 Bend Table 18 Mirror Feature 57 Gauge Table 19 Apply Color 58 Creating Base Flange 20 Apply Texture 59 Edge Flange 21 Apply Material 60 Trim Side Bends & Offset 22 Linear Pattern 61 Auto Relief 23 Circular Pattern 62 Custom Relief 24 Draft (Neutral Plane) 63 Miter Flange 25 Draft (Parting Line) 64 Hem Tool 26 Draft (Parting Line with Step) 65 Sketched Bend 27 DraftXpert 66 Closed Corner 28 Rib 67 Jog 29 2D Fillet 68 Break Corner/Corner Trim 30 Mirror Sketching 69 Break Flat Pattern 31 Dynamic Mirror Sketching 70 Tab 32 Trim Entithes 71 Lofted Bend 33 Offset 72 Extruded Cut 34 Selected Contours 73 Simple Hole 35 Sketch Picture 74 Unfold & Fold 36 Assemble 75 Flattened State 37 First 2D Drawing 76 The Design Library 38 Projection View 77 Creating a Library Feature 39 Section View 78 Creating a Forming Tool 40 Dimensions 79 Using a Forming Tool 41 Sample 3Dsketch 80 Forming Tool Comand 42 3D Sketch Plane 81 Insert Bends 82 Vent 83 Fill Pattern Volume 2 - SURFACE DESIGN Running Time: 4 hours 41min VIDEO COURSE CONTENT 01 Curvature Options 32 Funnel Body 02 Zebra Stripes 33 Extrude Surface (Handle) 03 Geometric Continuity 34 Support Sketch (Handle) 04 Extruded Surface 35 Lofted Surface (Handle) 05 Surface Trim 36 Adjusting Handle 06 Boundary Surface Project (Pocket Game) 07 Fillet 37 Circuit Board 08 Project Curve 38 Housing (Solid Body) 09 Thicken 39 Surface (Top Housing) 10 Half Pipe Connection 40 Surface (LCD Opening) 11 Sketch Cross-Connection 41 Surface (Bottom Housing) 12 Pipes Cross-Connection 42 Fillet (Housing) 13 Filled Surface 43 Battery Cover 14 Lofted Surface 44 Create Assembly 15 Swept Surface 45 Creating Shell 16 Swept Twist 46 Edit Battery Cover 17 Swept (Follow Path) 47 Insert Assembly 18 Planar Surface 48 Creating Buttons 19 Face Curves 49 LCD Opening 20 Intersection Curve 50 Top Housing (Details) 21 Offset Surface 51 Dial Pad (Details)1 22 Ruled Surface 52 Dial Pad (Details)2 23 Insert Pictures 53 Dial Pad (Add Fillets) 24 Creating Bottom Surface 54 Buttons Openings 25 Revolved Surface 55 Battery 26 Middle Surface Bodies 56 Add Ribs Top Housing 27 Solid Body 57 Add Ribs Bottom Housing 28 Bathroom Sink 58 Add Bosses (Buttom) 29 Filled Surface 59 Holes (PC Board) 30 Base & Drain Pipe 60 Add Bosses (Top) 31 Funnel (Creating sketch) 61 LCD Openings (Details) Volume 3 - WELDMENTS & MOLD DESIGN Running Time: 1 hour 25min VIDEO COURSE CONTENT 01 Structural Member 02 End Caps 03 Gusset 04 Filled Bead 05 Trim-Extend 06 Insert Part 07 Custom Profile 08 Sub-Weldment 09 Move-Copy 10 Extruded Cut 11 Configurations 12 Project (3d Sketch) 13 Project 2 14 Cut List (Drawings) Mold Design 15 Move Face 16 Scale 17 Parting Line 18 Straddle Faces 19 Undercut Detection 20 Parting Line II 21 Shut off Surfaces 22 Parting Surface 23 Tooling Split 24 Core 25 Mold Assembly 26 MoldflowXpress برای دانلود روی ادامه کلیک کنید برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام لینک به دیدگاه
