سلام دوستان عزیز:icon_gol:
مجموعه ای از کدهای پرکاربرد در ماشنهای کنترل عددی یا ماشینهای CNC رو براتون قرار میدم
امیدوارم به درد دوستان عزیز بخوره
موفق باشیم
G-codes
G00 Positioning in Rapid
G01 Linear Interpolation
(G02 Circular Interpolation (CW
(G03 Circular Interpolation (CCW
G04 Dwell
G07 Imaginary axis designation
G09 Exact stop check
G10 Program parameter input
G11 Program parameter input cancel
G12 Circle Cutting CW
G13 Circle Cutting CCW
G17 XY Plane
G18 XZ Plane
G19 YZ Plane
G20 Inch Units
G21 Metric Units
G22 Stored stroke limit ON
G23 Stored stroke limit OFF
G27 Reference point return check
G28 Automatic return to reference point
G29 Automatic return from reference point
G30 Return to 2nd, 3rd, 4th reference point
G31 Skip function
G33 Thread cutting
(G34 Bolt hole circle (Canned Cycle
(G35 Line at angle (Canned Cycle
(G36 Arc (Canned Cycle
G40 Cutter compensation Cancel
G41 Cutter compensation Left
G42 Cutter compensation Right
(G43 Tool Length Compensation (Plus
(G44 Tool Length Compensation (Minus
G45 Tool offset increase
G46 Tool offset decrease
G47 Tool offset double increase
G48 Tool offset double decrease
G49 Tool Length Compensation Cancel
G50 Scaling OFF
G51 Scaling ON
G52 Local coordinate system setting
G53 Machine coordinate system selection
G54 Workpiece Coordinate System
G55 Workpiece Coordinate System 2
G56 Workpiece Coordinate System 3
G57 Workpiece Coordinate System 4
G58 Workpiece Coordinate System 5
G59 Workpiece Coordinate System 6
G60 Single direction positioning
G61 Exact stop check mode
G62 Automatic corner override
G63 Tapping mode
G64 Cutting mode
G65 Custom macro simple call
G66 Custom macro modal call
G67 Custom macro modal call cancel
G68 Coordinate system rotation ON
G69 Coordinate system rotation OFF
G70 Inch Units
G71 Metric Units
G72 User canned cycle
G73 High-Speed Peck Drilling Cycle
G74 Counter tapping cycle
G75 User canned cycle
G76 Fine boring cycle
G77 User canned cycle
G78 User canned cycle
G79 User canned cycle
G80 Cancel Canned Cycles
G81 Drilling Cycle
G82 Counter Boring Cycle
G83 Deep Hole Drilling Cycle
G84 Tapping cycle
G85 Boring Cycle
G86 Boring Cycle
G87 Back Boring Cycle
G88 Boring Cycle
G89 Boring Cycle
G90 Absolute Positioning
G91 Incremental Positioning
G92 Reposition Origin Point
G93 Inverse time feed
G94 Per minute feed
G95 Per revolution feed
G96 Constant surface speed control
G97 Constant surface speed control cancel
G98 Set Initial Plane default
G99 Return to Retract (Rapid) Plane
: M-codes
M00 Program Stop
M01 Optional Program Stop
M02 Program End
M03 Spindle On Clockwise
M04 Spindle On Counterclockwise
M05 Spindle Stop
M06 Tool Change
M08 Coolant On
M09 Coolant Off
M10 Clamps On
M11 Clamps Off
M30 End of Program, Reset to Start
M98 Call subroutine command
M99 Return from subroutine command
Turning
: G-codes
G04 Dwell
G07 Feedrate sine curve control
G10 Data setting
G11 Data setting cancel
G17 XY Plane
G18 XZ Plane
G19 YZ Plane
G20 Inch Units
G21 Metric Units
G22 Stored stroke check function ON
G23 Stored stroke check function OFF
G25 Spindle speed fluctuation detection OFF
G26 Spindle speed fluctuation detection ON
G28 Automatic Zero Return
G29 Return from Zero Return Position
G30 2nd reference point return
G31 Skip function
G32 Thread cutting
G34 Variable lead thread cutting
G36 Automatic tool compensation
G40 Tool Nose Radius Compensation Cancel
G41 Tool Nose Radius Compensation Left
G42 Tool Nose Radius Compensation Right
G46 Automatic Tool Nose Radius Compensation
G50 Coordinate system setting and maximum rpm
G53 Machine coordinate system setting
G63 Tapping mode
G64 Cutting mode
G65 User macro simple call
G66 User macro modal call
G67 User macro modal call cancel
G68 Mirror image for double turrets ON
G69 Mirror image for double turrets OFF
G70 Finishing Cycle
G71 Turning Cycle
G72 Facing Cycle
G73 Pattern repeating
G74 Peck Drilling Cycle
G75 Grooving Cycle
G76 Threading Cycle
G80 Canned cycle for drilling cancel
G83 Face Drilling Cycle
G84 Face Tapping Cycle
G86 Face Boring Cycle
G87 Side Drilling Cycle
G88 Side Tapping Cycle
G89 Side Boring Cycle
G90 Absolute Programming
G91 Incremental Programming
G92 Thread Cutting Cycle
G94 Endface Turning Cycle
G98 Linear Feedrate Per Time
G99 Feedrate Per Revolution
G107 Cylindrical Interpolation
G112 Polar coordinate interpolation mode
G113 Polar coordinate interpolation mode cancel
G250 Polygonal turning mode cancel
G251 Polygonal turning mode
M-codes
M00 Program Stop
M02 Program End
M05 Spindle Stop
M07 Coolant 1 On
M08 Coolant 2 On
M09 Coolant Off
M98 Subprogram call
M99 Return from subprogram
يک مرکز چرخش سي‌ان‌سي کنترل رقمي رايانه‌اي يا سي‌ان‌سي به تنظيمات ماشين‌ابزار صنعتي از طريق هدايت رايانه‌اي گفته مي‌شود.
بوسيله ی سي‌ان‌سي مي‌توان به سرعت قطعاتي با اندازه‌هاي دقيق از فلز يا چوب درست کرد. شکل اين قطعات از پيش توسط يک برنامه که در سيستم کم (CAM) توليد شده مشخص مي‌گردد. معمولاً براي اين منظور هنوز از استاندارد EIA-274-D استفاده مي‌شود که کد جي (G) هم ناميده مي‌شود.
روش سي‌ان‌سي ادامه‌دهنده روش دستگاه‌هاي ان‌سي (کنترل رقمي) بود. از ان‌سي در جنگ جهاني دوم براي توليد جنگ‌افزار و پيچ‌ها استفاده زيادي مي‌شد.
نسل اول این دستگاه ها NC ها بوده اند یعنی کامپیوتر را نداشته است و دستگاه طبق منطقی خاص دستورات را درک می کرده مثلا با استفاده از کارت های پانچ شده. به عنوان مثال در دستگاه تراش برای دستور پیشروی بدین صورت عمل می شود که قسمت ساپورت دستگاه را بوسیله دسته چرخان به جلو میبریم در ماشین های NC این کار توسط یک سری دستورات پانچ شده بر روی نوار پانچ صورت می گرفت در دستگاه های CNC امروزین اینکار توسط یک کد صورت می گیرد .
پس یک دستگاه CNC عملا همان همان دستگاه دستی ساده می باشد که قابلیت فرمان پذیری از طریق کد ها و منطق ریاضیاتی را دارد در این دستگاه حضور کاربر (اپراتور) برای کار با دستگاه محدود به ایستادن این فرد پشت بخش کنترل کننده دستگاه می باشد و نوشتن برنامه های حرکتی آنهم فقط برای یکبار ، دیگر دستگاه این عمل را بصورت خودکار هر چند بار که بخواهیم تکرار می نمایدالبته بدون حضور کاربر.
بدنه این دستگاه تقریبا شبیه دستگاه های دستی می باشند یک CNC فرز عملا همان بدنه سخت افزاری فرز دستی را دارد همینطور برای CNC تراش و CNC سنگ و...
تنها تفاوت اضافه شدن بخش کنترل گر میباشد (البته این تفاوت بصورت عام می باشد ولی به صورت خاص مطمئنا بخش الکترونیکی هم تغییر کرده است )
اما بخش کنترلگر ،این بخش ،بخش اصلی یک دستگاه CNC می باشد در صنعت این بخش با نام کنترلر CONTROLER خوانده می شود یک دستگاه CNC از هر نوع (تراش،فرز ،سنگ،ابزار تیز کن،تزریق ،پرس ،و...)بیشتربا نوع کنترلرش شناخته شده است مطمئنا آموزشی که به افراد داده میشود در اصل براساس کنترلر این دستگا ه ها می باشد
کنترلر های مختلفی برای دستگاه های CNC موجود میباشد مانند فانوک – هایدن هاین، زیمنس – C39 - 2P22 –C15 – فاگورو میتسوبیشی و...
زیمنس و هایدن هاین از مارک هایی می باشند که در ایران فراوان استفاده می شوند اما تفاوت های اینها به چگونه است
منطق در یافت اطلاعات بصورت کد هائی می باشد که با G شروع می شوند به عنوان مثال کد G01 حرکت خطی است G02 و G03 حرکت دورانی می باشند و G90 نوع مختصات را از نظر مطلق بودن یا نسبی بودن مشخص می نماید .
کدهای عنوان شده کدهای عمومی می باشند و در کدهای خاص با توجه به نوع کنترلر شاید شماره کد فرق تماید به عنوان مثال G20 در زیمنس منظور انتخاب سیستم اندازه گیری متریک می باشد ولی این در هایدن هاین کد G70 این کار را انجام میدهد پس همانطور که گفته شد آموزش کدها باید با توجه به نوع کنترلر صورت گیرد .
مبانی این دستگاهها :
اصول اولیه از بدنه دستگاه و فرمت آنها
اصول اولیه ای از کدها : به عنوان مثال کدها چگونه عمل می نمایند. ساده ترین مثال باز هم کد G01 می باشد. مثلا در خط فرمان دستگاه تراش تایپ می شود G01 X20 Z-30 F10 S100 M7
دستگاه ابزار را به این نقطه ،با سرعت 10 با هر واخد از پیش تعیین شده با سرعت اسپیندل هزار و...می برد
آشنائی اولیه با منطق ها مثلا باید انتخاب شود که سیستم اندازه گیری مطلق باشد یا نسبی و یا حتی قطبی متریک باشد یا نه کدهای جانبی برای مشخص کردن سرعت و غیره
چگونه زیر گروه کاری انتخاب می شود مثلا برنامه ای نوشته شود که دستگاه باید به نقاط مختلف برود و بعد از انجام عملیات در آن محل یک عمل با یک گروه عمل خاص را تکرار کند مثلا برای این کار یک زیر برنامه نوشته میشود که باید هربار دستگاه در آن موقعیت آنها را انجام دهد
معرفی M کدها که کارهای جانبی مانند روشن کردن پمپ ماده خنک کننده و ..
حل چند مثال از قطعات مختلف در تراش و فرزو حتی الامکان در یک دستگاه دیگر نظیر سنگ یا پرس،مثال ها باید به گونه ای باشد که کاربر به سادگی درکی از نحوه انجام کار بدست بیاورد.
در ادامه چند نمونه از عکس های مربوط به بعضی از انواع دستگاه های CNC را مشاهده می کنید :
  • 6 سال بعد...
با سلام خدمت دوستان
عذر میخام من به تازگی کار با فرز سی ان سی با کنترلر هایدن هاین رو شروع کردم
میخواستم بدونم آیا این کنترلر قابلیت اینو داره که مث کنترلر زیمنس چندین صفر از میزکار گرفت و چند قطعه رو روی میز بست؟
ممنون میشم
