انرژی امواج با CorPower
انرژی دریایی یا اقیانوسی، یکی از انواع انرژی های تجدیدپذیر است که در کنار منابع دیگری نظیر انرژی خورشیدی و باد، مورد توجه قرار گرفته است. انرژی امواج و انرژی جزر و مد را می توان مهمترین زیر مجموعه های انرژی های دریایی به شمار آورد. به دلیل تفاوت های موجود در ویژگی ها و روش های فنی جذب آنها، توسعه این دو منبع راه متفاوت و مستقلی را طی کرده است.
corpower-ocean.jpg corpower-ocean-2.jpg In
point absorber systems, this consists of a hydraulic pump that generates electricity as it's pulled up and released by the buoy. In the CorPower system, however, there's a geared drivetrain, developed at Sweden's KTH Royal Institute of Technology. That drivetrain uses multiple small pinion wheels to convert linear motion into rotation, spinning up a flywheel. corpower-ocean-0.jpgAdditionally, the drivetrain is said to enhance the buoy's movements, allowing it to rise and fall more while staying in sync with the rhythm of the waves. According to CorPower CEO Patrik Möller, this means that the system harnesses wave motion "all the way between the wave crest and wave trough and back in an optimal way, no matter how long or high the waves are."Energy is temporarily stored onboard, before being output at a smooth and consistent rate via electrical cables running to the shore. According to KTH, the buoys/converters are lightweight, compact, and relatively inexpensive to manufacture. One 8-meter (26-ft)-diameter buoy should be able to produce 250-300 kilowatts in a "typical Atlantic environment."The technology was recently awarded €100,000 at MIT's Building Global Innovators Demo Day. A pilot project using the buoys is planned for this November.Sources:
