مجموعه استاندارد های BS - Iso تهویه مطبوع
شامل استاندارد های ملی انگلیس در زمینه طراحی راهگاه های هوایی - سیستم های تبرید و تهویه مطبوع - جریان هوای پاک - سیستم های کنترل حرارت ساختمان و انرژی و
BS 0848-1 1997 ISO 5801 1997 Fans for general purposes - Part 1 Performance testing using standardized airways
BS 853
BS 4434 1989 - Safety Aspects in - Refrigeration Appliances & Systems - SUPERSEDED BUT REFERRED TO IN BLDG REGS
BS 4773-1.1 1991 Methods for Testing and rating air terminal devices for air distribn systems - Part 1 Aerodyn testing
BS 4954-1 1973 Methods for Testing and rating induction units for air distribution systems - Part 1 Thermal and aerodynam~1
BS 5250 2002 Code of practice for control of condensation in buildings
BS 5295 Part 0 1989 Enviro Cleanliness in Encl Spaces - Gen Intro Clean Rooms & Clean Air Devices
BS 5295 Part 2 1989.Enviro Cleanliness in Encl Spaces - Spec Clean Rooms & Clean Air Devices
BS 5295 Part 3 1989 Enviro Cleanliness in Encl Spaces - Guide OP & Disciplines Clean Rooms & Clean Air Devices
BS 5422 2001 Method for specifying thermal insulating materials for pipes, tanks, vessels, ductwork and equipment opera~1
BS 5720 1979 Code of practice for Mechanical ventilation and air conditioning in buildings - (formerly CP 352)
BS 6144 1990 Specification for Expansion vessels using an internal diaphragm, for unvented hot water supply systems
BS 7346-1 1990 Components for smoke and heat control systems - Part 1 Specification for natural smoke and heat exhaust v~1
BS 7346-7 2006 Component of smoke & heat control system
BS 8313-1997 Accomodation of building services in ducts
BS EN 00378 Part 1 2000 Refrig Sys & Heat Pumps Safety & Enviro Req - Basics
BS EN 00378 Part 3 2000 Refrig Sys & Heat Pumps Safety & Enviro Req - Instal'n Site & Personal Protect
BS EN 00378 Part 4 2000 Refrig Sys & Heat Pumps Safety & Enviro Req - O & M
BS EN 410 1998 Glass in building Determination of luminous and solar characteristics of glazing
BS EN 779 2002 - Particulate Air Filters for general ventilation - Determination of the filtration performance
BS EN 1264-1 1998 Floor heating - Systems and Components - Part 1. Definitions and symbols
BS EN 1264-2 1998 Floor heating - Systems and Components - Part 2. Determination of the thermal output
BS EN 1264-3 1998 Floor heating - Systems and Components - Part 3. Dimensioning
BS EN 1264-4 2001 Floor heating - Systems and Components - Part 4 Installation
BS EN 1822-4 2000 HEPA Filters
BS EN 1822-5 2000 HEPA Filters
BS EN 12101-6 - 2005 Smoke and heat control systems
BS EN 12975 2000 Thermal Solar Systems and Components - Solar Collectors - Part 1 General Rwquirements
BS EN 13141-7 2004 VENTILATION FOR BUILDINGS
BS EN 13141-8 2006 Ventilation for building
BS EN ISO 05167 Part 1 1997 Measure of Fluid Flow by DP Devices - Orifices, Nozzles & Venturi Tubes
BS EN ISO 07730 1995 Moderate thermal environments - Determination of the PMV and PPD indices and specification of the c~1
BS EN ISO 10077-1 2000 (Amend 2001) Thermal Performance of Windows, Doors and Shutters - Calculation of Thermal Transmitt~1
BS EN ISO 10211-1 1996 Thermal Bridges in Building Construction - Calculation of Heat Flows and Surface Temperatures - Pa~1
BS EN ISO 10211-2 2001 Thermal Bridges in Building Construction - Calculation of Heat Flows and Surface Temperatures - Pa~1
BS EN ISO 12241 1998 Thermal Insulation for Building Equipment & Industrial Instal'ns - Calculation Rules
BS EN ISO 13788 2002 Hygrothermal Performance of Building Components and be - Internal Surface Temp.. - Calculation methods
BS EN ISO 13789 1999 Thermal Performance of Buildings - Transmission Heat Loss Coefficient - Calculation method
BS EN ISO 13790 2004 Thermal Performance of Buildings - Calculation of energy use for space heating
BS EN ISO 14644 Part 1 1999 Clean Rooms & Assoc'd Environ
s - Classifications of Air Cleanliness
BS EN ISO 14644 Part 2 2000 Clean Rooms & Assoc'd Environ's - Spec Testing .. to ISO 14644 Part 1
حجم فایل : 28 مگابایت
فرمت فایل : pdf
تعداد فایل : 41
قیمت : رایگان
دانلود
pass: mechanicspa.mihanblog
com
منبع : mechanicspa.mihanblog.com
