Doctor_Shovan مهمان
هر واژه واصطلاحی فارسی یا لاتین که به ذهنتون میرسه یا در حین سرچ یا مطالعه پیدا میکنید اینجا بنویسید . درصورت لزوم هم معنی یا تعریف ان رو ذکر کنید .:icon_gol:
Weak Acid
.Definition: A weak acid is an acid that is partially dissociated in an Aqueous Solution
Examples: CH3COOH
  • پاسخ 40
Doctor_Shovan مهمان
Qualitative Analysis
Definition: The determination of the nature of the chemical species in a sample
Examples: She used qualitative analysis to find that the solution contained Cu2+ and Cl- ions
Doctor_Shovan مهمان
Kelvin Temperature Scale
Definition: The Kelvin temperature scale is an absolute temprature scale based on the definition that
the volume of a gas at constant (low) pressure is directly proportional to temprature and that 100 degrees separates the freezing and boiling points of water
Usage: Kelvin temperatures are written with a capital letter 'K' and without the degree symbol, such as 1 K, 1120 K. Note that 0 K is absolute zero, and there are no negative Kelvin temperatures
Doctor_Shovan مهمان
Half-Cell Definition: A half-cell is half of an electrolytic or voltaic cell, where either oxidation or reduction occurs. The half-cell reaction at the anode is oxidation, while the half-cell reaction at the cathode is reduction
Doctor_Shovan مهمان
Deionization
Definition: The removal of ions. The term is generally used with respect to removal of ions from water. Deionization is commonly achieved by passing the water through successive ion exchange columns. In one column, ions are exchanged for H+ ions. In another column, anions are exchanged for OH- ions. Following a reaction of H+ with OH- ions, no ions remain in solution
Doctor_Shovan مهمان
Ionization Energy
:Ionization Energy Definition
Ionization energy is the energy required to remove an electron from a gaseous atom or ion. The first or initial ionization energy or Ei of an atom or molecule is the energy required to remove one mole of electrons from one mole of isolated gaseous atoms or ions. You may think of ionization energy as a measure of the difficulty of removing electron or the strength by which an electron is bound. The higher the ionization energy, the more difficult it is to remove an electron . Therefore, ionization energy is in indicator of reactivity
Also Known As: ionization potential, IE, IP
Doctor_Shovan مهمان
Titration
Definition: Titration is the process in which one solution is added to another solution such that it reacts under conditions in which the added volume may be accurately measured. Titrations are most commonly associated with acid-base reaction, but they may involve other types of reactions as well
backwash
برای برطرف کردن رسوباتی که از یک سیال خاص در مبدل ها و لاین های صنعتی و به ویژه فیل ترها (استرینر ) حاصل شده عملیاتی به عنوان backwash کردن انجام می شود که مراحل ان به این ترتیب است که مسیر خروجی بسته وسیال از طریق مسیر خروجی back زده میشود که در این شرایط با برگشت سیال فیل تر را تمیز کرده واز درین که روی مسیر ورودی است خارج میشود .
این کار از باز کردن ***** جلو گیری میکند .
reboiler
نوعی مبدل که بین دو برج تقطیر به کار میرود و کارایی های مختلفی دارد یکی از عمده ترین کاربرد های ان جدا سازی یک ماده از یک سیال وقتی از برج تقطیر اول به دوم حرکت می کند میباشد در واقع برج تقطیر دوم دارای نقطه ذوب پایین تری میباشد و از سیال همین برج برای سرد کردن این مبدل استفاده میشود و همینطور اغلب این مبدل ها دارای یک مسیر ریسیکل میباشند که این مسیر نقش کنتر فشار برای برج تقطیر اول را دارد به این ترتیب که با گرفت بخارات بالی برج و سرد کردن ان دوباره ان را به برج برگردانده البته به بالای برج و علاوه بر سرد کردن برج بخار های دیگر را سرد کرده و ااز بیشتر شدن ان جلو گیری می کنند
drier
دستگاهی چهت خشک کردن هوا ی مرطوب .
به صورت چند مخزن ساخته شده اند که حاوب مواد شیمیایی جاذب از خانواده الومین ها هستند .این دستگاه عمدتا طی مراحل شش گانه ای کار می کند که برای مثال مرحله احیا یکی از این مراخل می باشذ که خود ماده الومین رطوبت زدایی میشود ..
در مرحله گرمایش حرارت یا به وسیله بخار سوپر هیت تهیه میشود البته در حجم بالا یا به وسیله هیتر برقی ..
در مورد این دستگاه سوالی ذلشتید تا اونجایی که بدونم جواب میدم چون تجربه کار با اونو داشتم البته ایت دستگاه در بیشتر موارد اتو عمل میکنه ونیازی جتی به گنترل هم نذارد ...
موفق باشید
Doctor_Shovan مهمان
Accuracy
Accuracy refers to the correctness of a single measurement. Accuracy is determined by comparing the measurement against the true or accepted value
Precision
Precision refers to how well experimental values agree with each other. If you hit a bullseye precisely, then you are able to hit the same spot on the target each time, even though that spot may be distant from the center
This target has been hit with
a high degree of accuracy, yet a low degree of precision
This target has been struck with
a high degree of precision, yet a low degree of accuracy
Doctor_Shovan مهمان
Half-Life
Definition: The time required to convert one half of a
reactant to product. The term is commonly applied to radioactive decay, where the reactant is the parent isotope and the product is a daughter isotope
Perg
معمولا برای پاک سازی لاین های صنعتی و همینطور عایق سازی ذاکت ها ی سرد از پرج نیتروژن استفاده می شود همونطور که می دانید نیتروژن گازی بی اثر می باشد در نتیجه واکنش پذیری ان نزدیک به صفر و همی نطور فاقد خاصیت اشتعال زایی می باشد بنابرین در واحد های صنعتی برای موارد زیر استفاده می شود البته پرج نیتروژن استفاده های دیگری هم دارد که از ان جمله می توان کاربرد ان در پمپ های فوق سرد یا کریوجنیک را نام برد که برای سییل بندی استفاده میشود ...
فراموش نشود که نیتروژن گازی به شدت خفه کننده و کشنده است اما سمی نیست بلکه به دلایلی دیگر باعث مرگ می شود در کمتر از سه ثانیه ..
تا یادم نرفته بگم که در داکت ها برای عایق بندی خطوط لوله علاوه بر عایق پشم شیشه از ماده ای سفید و رنگ و پودر مانند به نامه پرلیت استفاده میشود که برای جلوگیری از رطوبت زدگی پرلیت از پرج نیتروژن استفاده می شود ...
pfdو p&id
به طور کامل نمی دونم این دو اصطلاح مخفف چه واؤه هایی است اما در مهندسی مخصوصا مهندسی شیمی به نفشه های صنهتی اطلاق میشود که جزییات واحد صنعتی را با بیشتر اطلاعات طراحی و فرایندی در خو د جای داده اند اما با این تفاوت که p&id کاملتر و دارای جزیات بیشتر از جمله قطر لاینها و اتصالات ابزار دقیقی و همینطور فشار و دمای طراحی شده برای هر قسمت ..معمولا pfd برای مبتدی ها و برای اینکه دید کلی نسبت به استقرار دستگاهها داشته باشیم مورد استفاده است وو
در کل فکر میکنم هر شرکت برای اینکه کار نقشه خوانی اسانتر وقالل فهمتر باشد کلاس های اموزشی در این رابطه برای کارمندانش برگذار کند
pfdو p&id
به طور کامل نمی دونم این دو اصطلاح مخفف چه واؤه هایی است اما در مهندسی مخصوصا مهندسی شیمی به نفشه های صنهتی اطلاق میشود که جزییات واحد صنعتی را با بیشتر اطلاعات طراحی و برایندی در خو د جای داده اند اما با این تفاوت که p&id کاملتر و دارای جزیات بیشتر از جمله قطر لاینها و اتصالات ابزار دقیقی و همینطور فشار و دمای طراحی شده برای هر قسمت ..معمولا pfd برای مبتدی ها و برای اینکه دید کلی نسبت به استقرار دستگاهها داشته باشیم مورد استفاده است وو
در کل فکر میکنم هر شرکت برای اینکه کار مقشه خوانی اسانتر وقالل فهمتر باشد کلاس های اموزشی در این رابطه برای کارمندانش برگذار کند
p&id
به یکسری از نقشه ها اطلاق میشه که دارای جزئیات بیشتری از نقشه های معمولی واحدها یا قسمتها میباشند وبه صورت دقیقتری جزئیات بخشهای مختلف رو تشریح میکنن
میشه گفت یک نقشه توصیفی هستند
تا جایی که من برخورد داشتم دیگه پلان های قدیمی رواجی ندارند وp&id جایگزین نقشه های معمول شده
اینم توضیحی که ویکی پدیا درموردp&id داده
P&ID is an initialism that could mean:
* Piping and instrumentation diagram - a schematical diagram showing piping, equipment and instrumentation connections within process units in oil refineries, petrochemical and chemical plants, natural gas processing plants, power plants, water treatment and other similar plants
* Process and instrumentation diagram - a family of functional one-line diagrams showing hull, mechanical and electrical (HM&E) systems like piping, and cable block diagrams
ویک نمونه از این نقشه ها
A Process Flow Diagram - PFD - (or System Flow Diagram - SFD) shows the relationships between the major components in the system. PFD also tabulate process design values for the components in different operating modes, typical minimum, normal and maximum. A PFD does not show minor components, piping systems, piping ratings and designations.
A PFD should include:
  • Process Piping
  • Major equipment symbols, names and identification numbers
  • Control, valves and valves that affect operation of the system
  • Interconnection with other systems
  • Major bypass and recirculation lines
  • System ratings and operational values as minimum, normal and maximum flow, temperature and pressure
  • Composition of fluids
This figure depict a small and simplified PFD:
System Flow Diagrams should not include:
  • pipe class
  • pipe line numbers
  • minor bypass lines
  • isolation and shutoff valves
  • maintenance vents and drains
  • relief and safety valve
  • code class information
  • seismic class information
Doctor_Shovan مهمان
Patina
Definition: Patina is the name given to the thin layer of corrosion products that forms on a metal surface that has been exposed to air and water. A patina typically has a characteristic color. Most often, patina refers to the greenish coating that forms on copper and its alloys
همونطور که از اسمش پیداست جهت اطمینان از ایمنی و کنترل فشار در مسیر های فرایند به کار گرفته میشه هر شیر اطمینانی روی فشاری خاص تنظیم میشه که در ان فشار عمل کرده و باعص تخلیه میشه اگر ماده تخلیه شوند خطرناک باشه به وسیله مسیری مجزا به سمت اجکتور یا محل تخلیه امن هدایت میشه ..تقریبا شبیه همون شیر اطمینان موجود در اب گرم کنهای خانگی است اما در صنایع خیلی پیشرفته تر و در مدل های متنوع تر به کار می رود .
