لیست کتاب‌های مهندسی پلیمر
اینجا لیست کتاب‌هایی که در تایپیک
کتاب‌های مهندسی پلیمر وجود داره به صورت خلاصه آورده شده.
امیدوارم با اضافه شدن هر کتابی به کتابخونه مهندسی پلیمر این تایپیک هم آپدیت شه تا دوستان راحتتر دنبال کتاب مورد نظرشون بگردند.
#2 The Basics of Testing Plastics
#3 Mechanical Properties of Polymers and Composites
#4 Chemorheology of Polymers: From Fundamental Principles to Reactive Processing
Solid State Polymerization #5
Polymer Surfaces and Interfaces: Characterization, Modification and Application #6
Failure Criteria in Fibre-Reinforced-Polymer Composite #7
Polymeric Biomaterials #8
Carbon-Rich Compounds: From Molecules to Materials #9
Polymer Modifiers and Additives #10
Synthetic Methods in Step-Growth Polymers #11
Soft Matter, Vol.: Polymer Melts and Mixtures #12
Design Formulas For Plastics Engineers #13
Physics of Photorefraction in Polymers #14
Introduction to Polymer Science and Chemistry: A Problem Solving Approach #15
Water-Soluble Polymers: Solution Properties and Applications #16
Conjugated_PolymersTheory_Synthesis_Properties_and _Characterization #17
Polymer Chemistry: A Practical Approach #18
Boron-containing Polymers #19
Synthetic_Polymeric_Membranes #20
Modern theory of polymer solutions (Harper's chemistry series #21
Simulation Methods for Polymers #22
Polymers for Dental and Orthopedic Applications #23
Advanced_Polymer_Processing_Operations #24
Biopolymers_at_Interfaces #25
Inorganic_and_Organometallic_Polymers #26
Polymer_Processing_Instabilities_Control_and_Under standing #27
Polymer_Science_And_Technology #28
Polymer Viscoelasticity: Basics, Molecular Theories and Experiments #29
Light Scattering from Polymer Solutions and Nanoparticle Dispersions (Springer Laboratory) by Wolfgang Schärt #30
Polymer Clay: 20 Weekend Projects Using New and Exciting Techniques By Irene Semanchuk #31
Introduction to Polymer Viscoelasticity #32
NMR Spectra of Polymers and Polymer Additives #33
Polymers for Photonics Applications I: Series: Advances in Polymer Science #34
Product Description #35
Handbook of Polymer Foams #36
Thermal and Electrical Conductivity of Polymer Materials: Advances in Polymer Science #37
Long-Term Properties of Polyolefins Series: Advances in Polymer Science, #38
Rigid Polymer Networks: Advances in Polymer Science #39
Polymer Characterization Laboratory Techniques and Analysis #40
Physical Properties of Polymers (Advances in Polymer Science #41
Rheology and Processing of Polymeric Materials #42
Polymer Structure Characterisation: From Nano To Macro Organization #43
Encyclopedia of Polymer Science and Technology #44
Polymer Physics #45
Polymer-Solvent Molecular Compounds #46
Polymer Processing: Modeling and Simulation #47
Polymer Analysis Polymer Physics (Advances in Polymer Science) Vol 128 #48
Modern Theory of Polymer Solutions #49
Machining of Polymer Composites #50
"Properties of Polymers, Fourth Edition: Their Correlation with Chemical Structure; their Numerical Estimation and Prediction from Additive Group Contributions #51
Polymer Reaction Engineering #52
#57
[h=2]
[/h]
[h=2]
[/h]
#74
#75
[h=2]
[/h]
#76
#78
Handbook_of_Polymer_Synthesis
#79
Advanced Polymer Processing Operations #80
مهندس کدوماش به پلیمر های pvc ربط داره دقیقن؟؟؟؟
تو این کتابا دقیق نمی‌دونم الان که بخام بگم. چون هیشکدوم مستقیم تو عنوانشون pvc نداره. باید تو فصل‌هاش رو نگاه کنیم. فکر می‌کنم دنبال سنتز نباشی و پی‌وی‌سی سخت میخوای.
1- دو تا کتاب لاتین خوب هست که گویا متاسفانه نسخه دیجیتال نداره و کتاب‌ه. تو کتابخونه‌مون دیده بودم.
2-یه کتاب فارسی هم هست علوم و تکنولوژی پلی وینیل کلراید، دکتر ابراهیمی، انتشارات دانشگاه امیرکبیر (نخوندمش اما که بعید میدونم چیز خاصی توش باشه، مگر اینگه بخوای از صفر بدونی راجع به pvc ).
3- این کتاب هم گویا نزدیک به اون چیزی که میخای رو داره:
foam
4- تو این کتابای زیری هم شاید باشه. باید سرفصل هارو چک کنیم.
5- این
رو اول بخون..
از بخش 10 رو فرایند pvc توضیح داده
6- ** دو تا مقاله خوب لاتین هست متاسفانه سیستمم یه مشکلی داره احتمالا باز نمیشه فایل ها تو کامپیوترت
حالا باز
ببین این دو تا باز میشن تو کامپیوترت؟ اگه باز نشد بگو سعی میکنم تا فردا با یه سیستم دیگه برات بذارم.
مهندس خیلی ممنون خیلی زحمت شد ، من میخاستم فقط اسم چندتا کتاب رو تو پروژم نام ببرم که فک کنم کافی باشه اینا
http://www.noandishaan.com/forums/thread131133.html#post1428520
اگه خاستین یه کمکی هم اینجا بکنین بهم :w16:
foam
5- این
رو اول بخون..
حالا باز
فایلهارو هم باز کرد ولی اینا که انگلیسین :(:banel_smiley_4:
گفتم كه لاتين هستند. مقاله هاي خيلي خوبي اند. فكر كنم براي مطالعه ت خوب باشن.
من بي تقصيرم:banel_smiley_4: علم ب زبان ه لاتين ه... فارسي مقاله به درد بخوري تو اين زمينه پيدا نكردم.همش چرت و پرت بود. اينو بريز تو اون بعد تست بگير. يا اينكه روش سنتزي بود ك بعيد ميدونم ب كارت بياد.
اگه عجله اي نيس كارت بذار از بچه ها سراغ مي گيرم ببينم كسي تو اين زمينه كار كرده يا نه. الان كسي ب ذهنم نمياد:ws52:
ممنون مهندس
درست میگین واقعن علم به لاتینه ، الان خود من ، وقتی تو درست کردن یه خودپرداز میبینم این همه عاجزم خیلی شرم دارم واقعن آخه این عابر بانکه این همه مشکلات داره یا از ناتوانی علم ماست که نمیتونیم یه چیز به این سادگی رو یه نظر بدیم؟؟؟ساختشو حالا نمیگم اینکه نمیتونیم یه نظر قاطع هم بدیم خیلی ضایس نه؟؟؟
در مورد عجله هم بگم که زیاد عجله ای نیس دارم مطالبمو یه جا جمع میکنم که بعد ویرایشو اصلاح کنم که تحویل بدم 5 ماهه رو این پروژه کار میکنم هر روزم یه مطلب جدید پیدا میکنم و آخر سر هم به این انجمن رو آوردم ، بدونه تارف میگم این انجمن از بین همه انجمن ها خیلی قدرتمنده
ممنون مهندس
ایراد از خیلی جاهاست.
1- مهم اینه این تکنولوژی این دستگاه مال کشورهای پیشرفته‌ست(حتی اگه خ ساده باشه). اونا هم با چهار یا پنج سال کار بهش نرسیدن. اگه این دستگاه رو میبینی شاید اسمش این باشه که مثلا 1 ساله روش کار کردن و ساختن... اما حقیقت امر اینه که از سوزن‌هاشون تا فضاپیماهاشون همه حاصل دانشی‌ه که در عرض سالها بدست آوردن.
شرمنده هم نباش... داری اطلاعات جمع می‌کنی برسی به ساختش دیگه. اون کسی که الان اوستای ساخت خودپردازه اولش که اومده تو کارش مطمئنا فقط الفباشو میدونسته . کم کم اوستا شده.
تازه مشکلاتت مونده:ws3: واس یه کاری بعد از کلی مطالعه روش ساخت یه قطعه‌ای رو پیدا کردم... اما ماده‌ای میخاستم که گریدش تو ایران نبود. حتی گفتم اون ماده رو خودم بسازم اما دستگاه‌هایی که برای ساختش لازم بود هم نمی‌تونستن اندازه‌ای که مدنظرم بود رو در حالت روتینش دربیارن. یعنی صاحباش ریسک هم نمی‌کردن دستگاه رو دو روز در اختیارم قرار بدن. کاری که خ دوست داشتم و یک سال با ذوق دنبالش بودم رفت تو بایگانی خاطراتم.
2- سیستم اموزشی مشکل داره. الان تو دانشکده ما به یه ارشد پلیمر بگی پلی ‌یورتان، یه سری اطلاعات کلی میده بهت و اگه موضوع پروژه‌ش نباشه میگه تخصص من نیست . راست هم میگه چون سیستم طوری‌ه که در زمان دانشگاه مجبوره فقط رو یه زمینه خاص کار کنه. تو اون زمینه بهترین میشه اما خیلی از زمینه ها رو از دست میدیم. فرصت زیادی برای کارای دیگه نمی‌مونه. همین PVC اگه وقت داشتم می‌تونستم کمکت کنم اما درگیری‌ها مجالی نمی‌ذاره.
امیدوارم بتونم کمکی کنم. در حد بضاعتم تمام تلاشم رو می‌کنم.:a030:
ممنون مهندس از امیدواری هایی که بهم دادیم خیلی خرسند شدم :) راستش من یه پروژه ای رو خودم به آخرش رسوندم درسته تو دانشگاه آزاد درس میخونم و همه میگن دانشگاه آزاده اینا علمی ندارن که ، ولی من دوست دارم همیشه خودم باشم و بمونم :ws37: هر پروژه ای که بهم واگذار میشه با تمام دقت به آخر میرسونم ؛ اگه یادتون باشه تا چندوقت پیش رویه طراحی کارخانه تردمیل کار میکردم ، از خودم تعریف نمیکنم و نمیگم پروژم نقصی نداشت ولی از بین همه پروژه هایی که ارائه داده بودن پروژه ام خیلی کامل بود در حدی بود که استاد گفت واسه استارت طراحی این مطالب و طراحی کافیه این خودش خیییییلی قوت قلب میده به آدم و خیلی خوشحالم که بلخره کسی پیدا شد که فرق کار خود آدمو با بیرون بدونه ، منظورم از گفتن این همه حرف اینه که وقتی یه کاری به دست خود آدم تموم میشه خیلی آدم راضی از کارش و تلاشش میشه الانم پروژه من در مورد ساخت رک هایه این خودپردازه بود ولی من درمورد ساخت کلی این دستگاه کار کردم و به خیلی چیزا رسیدم و اینیم که میبینم بغیر خودم کسی هم هست تو این مملکت که علاقه داره به یادگرفتن و یاد دادن خیلی خوشحالم میکنه:a030:
اگه یه بار تو گوگل سرچ بزنین خودپرداز یا عابر بانک اولین لینکی که پیدا میکنه نواندیشان :) این ینی اینکه این اطلاعات تو ایران (وبلاگها و وبسایتهای ایرانی) برای اولین بار در این سایت بحث میشه
بازم ممنون از قوت قلبتون :a030:
